Posix API and WPA Supplicant compatibility - nRF7002dk
Hi all,
A few months ago, I created an application for nRF7002dk on nRF Connect SDK v2.3.0 that connected to a provided Wi-Fi network and then created four TCP and UDP sockets using the Posix API.
Now I am trying to migrate the project to nRF Connect SDK v2.4.2 and I have found that the Posix API I used to create the sockets and the WPA supplicant support I used to connect to the WiFi network are no longer compatible, so I cannot create the sockets successfully. How can I modify my application to get both features?
I tried to build the project using this prj.conf file, skipping the Posix API setting, but I was unable to create the sockets.
CONFIG_WIFI=y
CONFIG_WIFI_NRF700X=y
# WPA supplicant
CONFIG_WPA_SUPP=y
# Below configs need to be modified based on security
# CONFIG_STA_KEY_MGMT_NONE=y
CONFIG_STA_KEY_MGMT_WPA2=y
# CONFIG_STA_KEY_MGMT_WPA2_256=y
# CONFIG_STA_KEY_MGMT_WPA3=y
CONFIG_STA_SAMPLE_SSID=""
CONFIG_STA_SAMPLE_PASSWORD=""
CONFIG_NET_CONFIG_PEER_IPV4_ADDR=""
# System settings
CONFIG_NEWLIB_LIBC=y
CONFIG_NEWLIB_LIBC_NANO=n
CONFIG_THREAD_NAME=y
# Networking
CONFIG_NETWORKING=y
CONFIG_NET_SOCKETS=y
CONFIG_NET_SOCKETS_POSIX_NAMES=y
CONFIG_NET_LOG=y
CONFIG_NET_IPV4=y
CONFIG_NET_UDP=y
CONFIG_NET_TCP=y
CONFIG_NET_DHCPV4=y
CONFIG_NET_PKT_RX_COUNT=16
CONFIG_NET_PKT_TX_COUNT=16
# Below section is the primary contributor to SRAM and is currently
# tuned for performance, but this will be revisited in the future.
CONFIG_NET_BUF_RX_COUNT=16
CONFIG_NET_BUF_TX_COUNT=16
CONFIG_NET_BUF_DATA_SIZE=128
CONFIG_HEAP_MEM_POOL_SIZE=200000
CONFIG_NET_TC_TX_COUNT=0
CONFIG_NET_IF_UNICAST_IPV4_ADDR_COUNT=1
CONFIG_NET_MAX_CONTEXTS=10
CONFIG_NET_CONTEXT_SYNC_RECV=y
CONFIG_INIT_STACKS=y
CONFIG_NET_L2_ETHERNET=y
CONFIG_NET_CONFIG_SETTINGS=y
CONFIG_NET_SOCKETS_POLL_MAX=4
# Memories
CONFIG_MAIN_STACK_SIZE=4096
CONFIG_NET_TX_STACK_SIZE=4096
CONFIG_NET_RX_STACK_SIZE=4096
# Debugging
CONFIG_STACK_SENTINEL=y
CONFIG_DEBUG_COREDUMP=y
CONFIG_DEBUG_COREDUMP_BACKEND_LOGGING=y
CONFIG_DEBUG_COREDUMP_MEMORY_DUMP_MIN=y
CONFIG_SHELL_CMDS_RESIZE=n
# Kernel options
CONFIG_ENTROPY_GENERATOR=y
CONFIG_TEST_RANDOM_GENERATOR=y
# Logging
CONFIG_LOG=y
CONFIG_LOG_BUFFER_SIZE=2048
CONFIG_POSIX_CLOCK=y
CONFIG_PM=y
CONFIG_NET_CONFIG_MY_IPV4_ADDR="192.168.1.99"
CONFIG_NET_CONFIG_MY_IPV4_NETMASK="255.255.255.0"
CONFIG_NET_CONFIG_MY_IPV4_GW="192.168.1.1"
# printing of scan results puts pressure on queues in new locking
# design in net_mgmt. So, use a higher timeout for a crowded
# environment.
CONFIG_NET_MGMT_EVENT_QUEUE_TIMEOUT=5000
CONFIG_DEBUG=y
Best,
Candela
