mcuboot missing trait mcuBoot in nrfutil
The board is nrf52840 based using mcuboot via usb, mcuboot can be activated using a switch, and is indicated via a led, all setup via device-tree, so no legacy here. Software is quite up to date using zephyr-2.4.99/ncs-2.5.0. Updating works fine using mcumgr, but as I understand it, this tool is deprecated and nrfutil is the new swiss-army-knive (devzone.nordicsemi.com/.../nrf-util-unified-command-line-utility).
But: Updating using nrfutil does not work, presumably because there is no mcuBoot trait listed for MCUBOOT. My question: How do I achieve that mcuboot shows this trait in nrfutil?
# nrfutil --version
nrfutil 7.6.0 (92ce3a0 2023-08-15)
commit-hash: 92ce3a0c1cc7e203326d85919d826009510dc631
commit-date: 2023-08-15
host: x86_64-apple-darwin
build-timestamp: 2023-08-23T08:22:30.0306Z
classification: nrf-external
# nrfutil device list
6XXXXXXXXXXXXXXB
product MCUBOOT
ports /dev/tty.usbmodem14301, vcom: 0
/dev/tty.usbmodem14303, vcom: 1
traits serialPorts, usb
  • Hi mdell,
    It seems that custom devices are not officially supported by nRF Util yet. The documentation says:
    nRF Util supports Nordic Semiconductor Development Kit (DK)s, prototyping platforms, and dongles.
    You could try adding --override-traits mcuBoot to the command and see if it helps?
    Hieu
  • I could not find any documentation about the --override-traits flag. If I try to use it, I get an error:
    nrfutil device program --firmware app_signed.hex --traits mcuBoot --override-traits mcuBoot
    error: unexpected argument '--override-traits' found
    # nrfutil --version
    # nrfutil upgrade
    nrfutil-device is already the newest version (2.0.3)
    nrfutil-nrf5sdk-tools is already the newest version (1.0.1)
  • Sorry about that. I was using the experimental command and thought that the options are available on the main command as well.
    You could use --override-traits with the experimental command. Here is a full command that I used:
    nrfutil device x-execute -o program --args 'firmware[file]=./dfu_application.zip' --device-filter 'serialNumber=1234567890' --override-traits mcuBoot
    Please note that this command is experimental, so the available parameters might change in the future.
  • Hello
    One year after the issue is still here. Do you have any update ?
    Regards
    Thibaud HABRAND
  • Hello Thibaud,
    Are you looking to use nrfutil with MCUboot or SMP Server?
    We are working on a feature to work with MCUboot/MCUmgr/SMP server. Unfortunately, I cannot comment on the timeline for this.
    Our apologies for the inconvenience.
    Hieu
1 2 3
