Lets just stick to GPIO?
  1. I am trying to initialize multiple input buttons and multiple output LEDS.
  2. I am trying to glow the LEDS with corresponding buttons. ex:- button 0 glows led0 and so on.
    // Here i can only initialize single input and output But not multiple one. #ifdef BSP_LED_0 #define GPIO_OUTPUT_PIN_NUMBER BSP_LED_0 /**< Pin number for output. */ #endif
    #ifndef GPIO_OUTPUT_PIN_NUMBER #error "Please indicate output pin" #endif
    #ifdef BSP_BUTTON_0 #define GPIO_INPUT_PIN_NUMBER BSP_BUTTON_0 /**< Pin number for output. */ #endif
    #ifndef GPIO_INPUT_PIN_NUMBER #error "Please indicate output pin" #endif
    #define BSP_LED_0 #define BSP_LED_1 LED_2 #define BSP_BUTTON_0 #define BSP_BUTTON_1 BUTTON_2
    int main(void) {
     while(1)
         if(BSP_BUTTON_0 == 1) // Here I am facing error every time
             nrf_gpio_port_pin_toggle(BSP_LED_0);
             nrf_delay_ms(500);
    } Explain my mistakes
  • This should fix your example:
        //BSP_LED0 and BSP_BUTTON_0 is defined in boards.h file
        nrf_gpio_cfg_output(BSP_LED_0);
        nrf_gpio_cfg_input(BSP_BUTTON_0, NRF_GPIO_PIN_PULLUP);
        while (true)
            if(nrf_gpio_pin_read(BSP_BUTTON_0) == 0)
                nrf_gpio_pin_toggle(BSP_LED_0);
                nrf_delay_ms(500);
    A better solution is to use PPI, this code will set that up:
    void button_led_ppi_init()
        uint32_t gpiote_event_addr;
        uint32_t gpiote_task_addr;
        nrf_ppi_channel_t ppi_channel;
        ret_code_t err_code;
        //init GPIOTE driver
        if(!nrf_drv_gpiote_is_init())
        //LED
        nrf_drv_gpiote_out_config_t config = GPIOTE_CONFIG_OUT_TASK_TOGGLE(true);
        err_code = nrf_drv_gpiote_out_init(BSP_LED_0, &config);
        nrf_drv_gpiote_out_task_enable(BSP_LED_0);
        //BUTTON
        nrf_drv_gpiote_in_config_t event_config = GPIOTE_CONFIG_IN_SENSE_TOGGLE(true);
        event_config.pull = NRF_GPIO_PIN_PULLUP;
        err_code = nrf_drv_gpiote_in_init(BSP_BUTTON_0, &event_config, NULL);
        nrf_drv_gpiote_in_event_enable(BSP_BUTTON_0, true);
        //PPI
        err_code = nrf_drv_ppi_channel_alloc(&ppi_channel);
        gpiote_task_addr = nrf_drv_gpiote_out_task_addr_get(BSP_LED_0);
        gpiote_event_addr = nrf_drv_gpiote_in_event_addr_get(BSP_BUTTON_0);
        err_code = nrf_drv_ppi_channel_assign(ppi_channel, gpiote_event_addr, gpiote_task_addr);
        err_code = nrf_drv_ppi_channel_enable(ppi_channel);
  • Do not change the entire question! This will make it hard for other people to read the post, or the whole answer will have to be edited (like in this case). If you are editing your question (adding information etc) this should be done with "EDIT: {new info}". If you are just formatting the question, there is no need to state it. If you are changing the whole question to something else, please post another one.
