Error 14 (0xe): GATT ERR UNLIKELY
After sending a notification that is less than the negotiated MTU. It is less than 20 bytes
It occurs sporadically.
I 10:26:08.450 Notification received from 15ff1845-05d3-4c5b-8281-93d4e07420cf, value: (0x) 30-2E-30-30-2C-2D-30-2E-30-30-2C-30-2E-30-32, "0.00,-0.00,0.02"
A 10:26:08.450 "(0x) 30-2E-30-30-2C-2D-30-2E-30-30-2C-30-2E-30-32, "0.00,-0.00,0.02"" received
I 10:26:08.453 Notification received from 15ff1845-05d3-4c5b-8281-93d4e07420cf, value: (0x) 30-2E-30-31-2C-2D-30-2E-30-30-2C-30-2E-30-34, "0.01,-0.00,0.04"
A 10:26:08.453 "(0x) 30-2E-30-31-2C-2D-30-2E-30-30-2C-30-2E-30-34, "0.01,-0.00,0.04"" received
I 10:26:08.457 Notification received from 15ff1845-05d3-4c5b-8281-93d4e07420cf, value: (0x) 30-2E-30-30-2C-2D-30-2E-30-30-2C-30-2E-30-33, "0.00,-0.00,0.03"
A 10:26:08.457 "(0x) 30-2E-30-30-2C-2D-30-2E-30-30-2C-30-2E-30-33, "0.00,-0.00,0.03"" received
E 10:26:08.458 Error 14 (0xe): GATT ERR UNLIKELY
I use nRF Connect app for testing on Android.
    Is the log above from nRF Connect or your nRF5340 board? Also, after getting the GATT error, do you stop receiving notifications?
    Vidar
  • The log is from nRf Connect app.
    No, notifications keep going
  • Wireshark and nrf52840 dongle don't see those packets.
  • Frame 3478: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM36-4.2, id 0
        Section number: 1
        Interface id: 0 (COM36-4.2)
            Interface name: COM36-4.2
            Interface description: nRF Sniffer for Bluetooth LE COM36
        Encapsulation type: nRF Sniffer for Bluetooth LE (186)
        Arrival Time: Nov 23, 2023 12:07:47.818196000 Central European Standard Time
        UTC Arrival Time: Nov 23, 2023 11:07:47.818196000 UTC
        Epoch Arrival Time: 1700737667.818196000
        [Time shift for this packet: 0.000000000 seconds]
        [Time delta from previous captured frame: 0.000230000 seconds]
        [Time delta from previous displayed frame: 0.011480000 seconds]
        [Time since reference or first frame: 24.821341000 seconds]
        Frame Number: 3478
        Frame Length: 35 bytes (280 bits)
        Capture Length: 35 bytes (280 bits)
        [Frame is marked: False]
        [Frame is ignored: False]
        [Protocols in frame: nordic_ble:btle:btl2cap:btatt]
        Board: 36
        Header Version: 3, Packet counter: 47146
            Length of payload: 28
            Protocol version: 3
            Packet ID: 6
        Length of packet: 10
        Flags: 0x01
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
            .... .0.. = Encrypted: No
            .... 0... = MIC (not relevant): 0
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 23
        RSSI: -48 dBm
        Event counter: 1681
        Timestamp: 1491198514µs
        [Packet time (start to end): 152µs]
        [Delta time (end to start): 150µs]
        [Delta time (start to start): 230µs]
    Bluetooth Low Energy Link Layer
        Access Address: 0x9c124f94
        [Master Address: 52:12:d5:6c:bf:9a (52:12:d5:6c:bf:9a)]
        [Slave Address: f8:a4:c9:d7:48:fd (f8:a4:c9:d7:48:fd)]
        Data Header
            .... ..10 = LLID: Start of an L2CAP message or a complete L2CAP message with no fragmentation (0x2)
            .... .1.. = Next Expected Sequence Number: 1 [ACK]
            .... 0... = Sequence Number: 0 [OK]
            ...0 .... = More Data: False
            ..0. .... = CTE Info: Not Present
            00.. .... = RFU: 0
            Length: 9
        [L2CAP Index: 60]
        [Connection Parameters in: 551]
        CRC: 0x38ef92
    Bluetooth L2CAP Protocol
        Length: 5
        CID: Attribute Protocol (0x0004)
    Bluetooth Attribute Protocol
        Opcode: Error Response (0x01)
            0... .... = Authentication Signature: False
            .0.. .... = Command: False
            ..00 0001 = Method: Error Response (0x01)
        Request Opcode in Error: Write Request (0x12)
            ..01 0010 = Method: Write Request (0x12)
        Handle in Error: 0x0012 (Unknown: Unknown)
            [Service UUID: 25ae144105d34c5b828193d4e07420cf]
            [UUID: 25ae144205d34c5b828193d4e07420cf]
        Error Code: Unlikely Error (0x0e)
  • Im sorry but I can not share that file with you
  • That is fine, but if you are unable to provide relevant information or instructions for me to reproduce the issue locally, I'm afraid there is not much more I can do to troubleshoot this further. I have already attempted to search for similar issues in our databases but have not found anything that resembles your case.
