Error 14 (0xe): GATT ERR UNLIKELY
After sending a notification that is less than the negotiated MTU. It is less than 20 bytes
It occurs sporadically.
I 10:26:08.450 Notification received from 15ff1845-05d3-4c5b-8281-93d4e07420cf, value: (0x) 30-2E-30-30-2C-2D-30-2E-30-30-2C-30-2E-30-32, "0.00,-0.00,0.02"
A 10:26:08.450 "(0x) 30-2E-30-30-2C-2D-30-2E-30-30-2C-30-2E-30-32, "0.00,-0.00,0.02"" received
I 10:26:08.453 Notification received from 15ff1845-05d3-4c5b-8281-93d4e07420cf, value: (0x) 30-2E-30-31-2C-2D-30-2E-30-30-2C-30-2E-30-34, "0.01,-0.00,0.04"
A 10:26:08.453 "(0x) 30-2E-30-31-2C-2D-30-2E-30-30-2C-30-2E-30-34, "0.01,-0.00,0.04"" received
I 10:26:08.457 Notification received from 15ff1845-05d3-4c5b-8281-93d4e07420cf, value: (0x) 30-2E-30-30-2C-2D-30-2E-30-30-2C-30-2E-30-33, "0.00,-0.00,0.03"
A 10:26:08.457 "(0x) 30-2E-30-30-2C-2D-30-2E-30-30-2C-30-2E-30-33, "0.00,-0.00,0.03"" received
E 10:26:08.458 Error 14 (0xe): GATT ERR UNLIKELY
I use nRF Connect app for testing on Android.
  • Wireshark and nrf52840 dongle don't see those packets.
  • Frame 3478: 35 bytes on wire (280 bits), 35 bytes captured (280 bits) on interface COM36-4.2, id 0
        Section number: 1
        Interface id: 0 (COM36-4.2)
            Interface name: COM36-4.2
            Interface description: nRF Sniffer for Bluetooth LE COM36
        Encapsulation type: nRF Sniffer for Bluetooth LE (186)
        Arrival Time: Nov 23, 2023 12:07:47.818196000 Central European Standard Time
        UTC Arrival Time: Nov 23, 2023 11:07:47.818196000 UTC
        Epoch Arrival Time: 1700737667.818196000
        [Time shift for this packet: 0.000000000 seconds]
        [Time delta from previous captured frame: 0.000230000 seconds]
        [Time delta from previous displayed frame: 0.011480000 seconds]
        [Time since reference or first frame: 24.821341000 seconds]
        Frame Number: 3478
        Frame Length: 35 bytes (280 bits)
        Capture Length: 35 bytes (280 bits)
        [Frame is marked: False]
        [Frame is ignored: False]
        [Protocols in frame: nordic_ble:btle:btl2cap:btatt]
        Board: 36
        Header Version: 3, Packet counter: 47146
            Length of payload: 28
            Protocol version: 3
            Packet ID: 6
        Length of packet: 10
        Flags: 0x01
            .... ...1 = CRC: Ok
            .... ..0. = Direction: Slave -> Master
            .... .0.. = Encrypted: No
            .... 0... = MIC (not relevant): 0
            .000 .... = PHY: LE 1M (0)
            0... .... = Reserved: 0
        Channel Index: 23
        RSSI: -48 dBm
        Event counter: 1681
        Timestamp: 1491198514µs
        [Packet time (start to end): 152µs]
        [Delta time (end to start): 150µs]
        [Delta time (start to start): 230µs]
    Bluetooth Low Energy Link Layer
        Access Address: 0x9c124f94
        [Master Address: 52:12:d5:6c:bf:9a (52:12:d5:6c:bf:9a)]
        [Slave Address: f8:a4:c9:d7:48:fd (f8:a4:c9:d7:48:fd)]
        Data Header
            .... ..10 = LLID: Start of an L2CAP message or a complete L2CAP message with no fragmentation (0x2)
            .... .1.. = Next Expected Sequence Number: 1 [ACK]
            .... 0... = Sequence Number: 0 [OK]
            ...0 .... = More Data: False
            ..0. .... = CTE Info: Not Present
            00.. .... = RFU: 0
            Length: 9
        [L2CAP Index: 60]
        [Connection Parameters in: 551]
        CRC: 0x38ef92
    Bluetooth L2CAP Protocol
        Length: 5
        CID: Attribute Protocol (0x0004)
    Bluetooth Attribute Protocol
        Opcode: Error Response (0x01)
            0... .... = Authentication Signature: False
            .0.. .... = Command: False
            ..00 0001 = Method: Error Response (0x01)
        Request Opcode in Error: Write Request (0x12)
            ..01 0010 = Method: Write Request (0x12)
        Handle in Error: 0x0012 (Unknown: Unknown)
            [Service UUID: 25ae144105d34c5b828193d4e07420cf]
            [UUID: 25ae144205d34c5b828193d4e07420cf]
        Error Code: Unlikely Error (0x0e)
  • Im sorry but I can not share that file with you
  • That is fine, but if you are unable to provide relevant information or instructions for me to reproduce the issue locally, I'm afraid there is not much more I can do to troubleshoot this further. I have already attempted to search for similar issues in our databases but have not found anything that resembles your case.
