SPI communication with epaper display driver ssd1680
I am currently trying to migrate the code to activate an epaper display from STM to Nordic. The function used to write to the driver via SPI is the following:
int32_t NORDIC_SPI_Write(HANDLER hSPI,uint8_t *pData,uint32_t DataSize){
  ret_code_t ret = NRF_SUCCESS;
  int32_t wr_ret = (int32_t) EMBL_OK;
  HANDLER hPDev = WRSPI_getPhysicalDevice(hSPI);
  WRSPI_setCSS(hSPI,false);
  ret = nrf_drv_spi_transfer(hPDev, pData, DataSize,NULL, 0);
  WRSPI_setCSS(hSPI,true);
  if(ret != NRF_SUCCESS){ // HAL_SPI_Mem_Read retorna o HAL_OK o HAL_ERROR
    wr_ret = (int32_t)EMBL_ERROR;
  return wr_ret;
And the configuration of our SPI is:
  nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG;
  spi_config.mosi_pin = 33;
  spi_config.sck_pin  = 35;
  spi_config.frequency    = SPI_FREQUENCY_FREQUENCY_M1,
The signal Analyzed in both MCUs is practically Identical, with the only difference that when I send the data after a command in nordic the clk signal does not go idle in between bytes, and with the STM it does. Is there anyway to configure SPI so that it acts the same? Attached are both captures of the signal for STM(CLK stops in between bytes) and nordic(constant CLK through all the transfer ):
