merged.hex file built from the same code base is different.
I noticed that if I rebuild the merged.hex file from exactly the same code base then all subsequent merged.hex files are different. This is causing us a problem at production.
I am guessing/suspecting this because the file signature/CRC has changed and the reason for its change is something like the timestamp.
Attached is a snapshot of the differences reported by 'Beyond Compare' utility. All the differences are at the end of the merged.hex file.
Q1/ Can you please explain why this is happening?
Q2/ Could you please point me to a document detailing the format of the merged.hex file.
Q3/ Is there a utility that checks only the code content of the merged.hex without including timestamp, CRC, Signature etc...?
Thank you.
Kind regards
Mohamed
