How to create a custom board definition for nRF9160.
Dear support members,
I would like to know how to create a custom board definition for nRF9160.
The development environment I am trying is below.
NCS v2.5.0
MFW v1.3.5
sample project: Hello world
I tried making a "non-secure" board for nRF9160 using the URL below as a reference.
webinars.nordicsemi.com/adding-custom-board-support-in-nrf-4
But I got an error like the one attached.
Executing task: nRF Connect: Generate config customboard_nrf9160_ns for c:\work\MyApp\hello_world
Building hello_world
C:\WINDOWS\system32\cm d.exe /d /s /c "west build --build-dir c:/work/MyApp/hello_world/build c:/work/MyApp/hello_world --pristine --board customboard_nrf9160_ns --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DBOARD_ROOT:STRING="c:/work/my_board""
-- Application: C:/work/MyApp/hello_world
-- CMake version: 3.20.5
-- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.5.0/zephyr/.cache
-- Zephyr version: 3.4.99 (C:/ncs/v2.5.0/zephyr)
-- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
-- Board: customboard_nrf9160_ns
-- Found host-tools: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/c57af46cb7/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/work/my_board/boards/arm/customboard_nrf9160_ns/customboard_nrf9160_ns.dts
-- Generated zephyr.dts: C:/work/MyApp/hello_world/build/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/work/MyApp/hello_world/build/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/work/MyApp/hello_world/build/zephyr/dts.cmake
Parsing C:/ncs/v2.5.0/zephyr/Kconfig
Loaded configuration 'C:/work/my_board/boards/arm/customboard_nrf9160_ns/customboard_nrf9160_ns_defconfig'
Merged configuration 'C:/work/MyApp/hello_world/prj.conf'
Configuration saved to 'C:/work/MyApp/hello_world/build/zephyr/.config'
Kconfig header saved to 'C:/work/MyApp/hello_world/build/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Configuring done
-- Generating done
-- Build files have been written to: C:/work/MyApp/hello_world/build
[1/126] Generating ../../zephyr/include/generated/ncs_version.h
[2/126] Generating include/generated/version.h
-- Zephyr version: 3.4.99 (C:/ncs/v2.5.0/zephyr), build: v3.4.99-ncs1
[3/126] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[4/126] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[5/126] Generating include/generated/driver-validation.h
[6/126] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[7/126] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[8/126] Generating include/generated/offsets.h
[9/126] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[10/126] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[11/126] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[12/126] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[13/126] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[14/126] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[15/126] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[16/126] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[17/126] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/__aeabi_read_tp.S.obj
[18/126] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[19/126] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/malloc.c.obj
[20/126] Building C object zephyr/lib/libc/common/CMakeFiles/lib__libc__common.dir/source/stdlib/abort.c.obj
[21/126] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[22/126] Building C object zephyr/soc/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[23/126] Building C object zephyr/lib/libc/picolibc/CMakeFiles/lib__libc__picolibc.dir/libc-hooks.c.obj
[24/126] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[25/126] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[26/126] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[27/126] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.5.0/modules/hal/nordic/nrfx/mdk/system_nrf91.c.obj
[28/126] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[29/126] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[30/126] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[31/126] Linking C static library zephyr\soc\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[32/126] Linking C static library zephyr\lib\libc\common\liblib__libc__common.a
[33/126] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[34/126] Linking C static library zephyr\lib\libc\picolibc\liblib__libc__picolibc.a
[35/126] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[36/126] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[37/126] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[38/126] Building C object zephyr/kernel/CMakeFiles/kernel.dir/busy_wait.c.obj
[39/126] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[40/126] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[41/126] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[42/126] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[43/126] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[44/126] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.5.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[45/126] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[46/126] Building C object CMakeFiles/app.dir/src/main.c.obj
[47/126] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.5.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[48/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[49/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[50/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[51/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[52/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[53/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[54/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[55/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[56/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[57/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[58/126] Linking C static library app\libapp.a
[59/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[60/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[61/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[62/126] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[63/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[64/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[65/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[66/126] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
FAILED: zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DKERNEL -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPICOLIBC_INTEGER_PRINTF_SCANF -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.5.0/zephyr/kernel/include -IC:/ncs/v2.5.0/zephyr/arch/arm/include -IC:/ncs/v2.5.0/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.5.0/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/ncs/v2.5.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.5.0/nrf/include -IC:/ncs/v2.5.0/nrf/tests/include -IC:/ncs/v2.5.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.5.0/zephyr/modules/cmsis/. -IC:/ncs/v2.5.0/modules/hal/nordic/nrfx -IC:/ncs/v2.5.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.5.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.5.0/zephyr/modules/hal_nordic/nrfx/. -isystem C:/ncs/v2.5.0/nrfxlib/crypto/nrf_cc310_platform/include -fno-strict-aliasing -Os -imacros C:/work/MyApp/hello_world/build/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.5.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/work/MyApp/hello_world=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.5.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.5.0=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj -MF zephyr\CMakeFiles\zephyr.dir\soc\arm\nordic_nrf\validate_base_addresses.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj -c C:/ncs/v2.5.0/zephyr/soc/arm/nordic_nrf/validate_base_addresses.c
In file included from C:\ncs\v2.5.0\zephyr\include\zephyr\toolchain.h:50,
                 from C:\ncs\v2.5.0\zephyr\include\zephyr\kernel_includes.h:19,
                 from C:\ncs\v2.5.0\zephyr\include\zephyr\kernel.h:17,
                 from C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:7:
C:\ncs\v2.5.0\zephyr\include\zephyr\toolchain\gcc.h:81:36: error: static assertion failed: ""
   81 | #define BUILD_ASSERT(EXPR, MSG...) _Static_assert(EXPR, "" MSG)
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:87:9: note: in expansion of macro 'BUILD_ASSERT'
   87 |         BUILD_ASSERT(                                                   \
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:123:1: note: in expansion of macro 'CHECK_DT_REG'
  123 | CHECK_DT_REG(adc, NODE_ADDRESS(adc, nordic_nrf_adc, NRF_ADC, NRF_SAADC));
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:126:1: note: in expansion of macro 'CHECK_DT_REG'
  126 | CHECK_DT_REG(clock, NRF_CLOCK);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:131:1: note: in expansion of macro 'CHECK_DT_REG'
  131 | CHECK_DT_REG(dppic, NRF_DPPIC);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:133:1: note: in expansion of macro 'CHECK_DT_REG'
  133 | CHECK_DT_REG(egu0, NRF_EGU0);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:134:1: note: in expansion of macro 'CHECK_DT_REG'
  134 | CHECK_DT_REG(egu1, NRF_EGU1);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:135:1: note: in expansion of macro 'CHECK_DT_REG'
  135 | CHECK_DT_REG(egu2, NRF_EGU2);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:136:1: note: in expansion of macro 'CHECK_DT_REG'
  136 | CHECK_DT_REG(egu3, NRF_EGU3);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:137:1: note: in expansion of macro 'CHECK_DT_REG'
  137 | CHECK_DT_REG(egu4, NRF_EGU4);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:138:1: note: in expansion of macro 'CHECK_DT_REG'
  138 | CHECK_DT_REG(egu5, NRF_EGU5);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:140:1: note: in expansion of macro 'CHECK_DT_REG'
  140 | CHECK_DT_REG(flash_controller, NRF_NVMC);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:141:1: note: in expansion of macro 'CHECK_DT_REG'
  141 | CHECK_DT_REG(gpio0, NRF_P0);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:143:1: note: in expansion of macro 'CHECK_DT_REG'
  143 | CHECK_DT_REG(gpiote, NRF_GPIOTE);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:112:9: note: in expansion of macro 'CHECK_DT_REG'
  112 |         CHECK_DT_REG(lbl,                                               \
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:144:1: note: in expansion of macro 'CHECK_I2C_REG'
  144 | CHECK_I2C_REG(i2c0, 0);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:145:1: note: in expansion of macro 'CHECK_I2C_REG'
  145 | CHECK_I2C_REG(i2c1, 1);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:146:1: note: in expansion of macro 'CHECK_DT_REG'
  146 | CHECK_DT_REG(i2c2, NRF_TWIM2);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:147:1: note: in expansion of macro 'CHECK_DT_REG'
  147 | CHECK_DT_REG(i2c3, NRF_TWIM3);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:148:1: note: in expansion of macro 'CHECK_DT_REG'
  148 | CHECK_DT_REG(i2s0, NRF_I2S0);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:149:1: note: in expansion of macro 'CHECK_DT_REG'
  149 | CHECK_DT_REG(ipc, NRF_IPC);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:150:1: note: in expansion of macro 'CHECK_DT_REG'
  150 | CHECK_DT_REG(kmu, NRF_KMU);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:156:1: note: in expansion of macro 'CHECK_DT_REG'
  156 | CHECK_DT_REG(pdm0, NRF_PDM0);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:157:1: note: in expansion of macro 'CHECK_DT_REG'
  157 | CHECK_DT_REG(power, NRF_POWER);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:159:1: note: in expansion of macro 'CHECK_DT_REG'
  159 | CHECK_DT_REG(pwm0, NRF_PWM0);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:160:1: note: in expansion of macro 'CHECK_DT_REG'
  160 | CHECK_DT_REG(pwm1, NRF_PWM1);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:161:1: note: in expansion of macro 'CHECK_DT_REG'
  161 | CHECK_DT_REG(pwm2, NRF_PWM2);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:162:1: note: in expansion of macro 'CHECK_DT_REG'
  162 | CHECK_DT_REG(pwm3, NRF_PWM3);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:167:1: note: in expansion of macro 'CHECK_DT_REG'
  167 | CHECK_DT_REG(regulators, NRF_REGULATORS);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:170:1: note: in expansion of macro 'CHECK_DT_REG'
  170 | CHECK_DT_REG(rtc0, NRF_RTC0);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:171:1: note: in expansion of macro 'CHECK_DT_REG'
  171 | CHECK_DT_REG(rtc1, NRF_RTC1);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:106:9: note: in expansion of macro 'CHECK_DT_REG'
  106 |         CHECK_DT_REG(lbl,                                               \
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:173:1: note: in expansion of macro 'CHECK_SPI_REG'
  173 | CHECK_SPI_REG(spi0, 0);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:174:1: note: in expansion of macro 'CHECK_SPI_REG'
  174 | CHECK_SPI_REG(spi1, 1);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:175:1: note: in expansion of macro 'CHECK_SPI_REG'
  175 | CHECK_SPI_REG(spi2, 2);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:176:1: note: in expansion of macro 'CHECK_DT_REG'
  176 | CHECK_DT_REG(spi3, NRF_SPIM3);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:186:1: note: in expansion of macro 'CHECK_DT_REG'
  186 | CHECK_DT_REG(timer0, NRF_TIMER0);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:187:1: note: in expansion of macro 'CHECK_DT_REG'
  187 | CHECK_DT_REG(timer1, NRF_TIMER1);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:188:1: note: in expansion of macro 'CHECK_DT_REG'
  188 | CHECK_DT_REG(timer2, NRF_TIMER2);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:118:9: note: in expansion of macro 'CHECK_DT_REG'
  118 |         CHECK_DT_REG(lbl,                                               \
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:191:1: note: in expansion of macro 'CHECK_UART_REG'
  191 | CHECK_UART_REG(uart0, 0);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:192:1: note: in expansion of macro 'CHECK_DT_REG'
  192 | CHECK_DT_REG(uart1, NRF_UARTE1);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:193:1: note: in expansion of macro 'CHECK_DT_REG'
  193 | CHECK_DT_REG(uart2, NRF_UARTE2);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:194:1: note: in expansion of macro 'CHECK_DT_REG'
  194 | CHECK_DT_REG(uart3, NRF_UARTE3);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:198:1: note: in expansion of macro 'CHECK_DT_REG'
  198 | CHECK_DT_REG(vmc, NRF_VMC);
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:199:1: note: in expansion of macro 'CHECK_DT_REG'
  199 | CHECK_DT_REG(wdt, NRF_WDT0);    /* this should be the same node as wdt0 */
C:\ncs\v2.5.0\zephyr\soc\arm\nordic_nrf\validate_base_addresses.c:200:1: note: in expansion of macro 'CHECK_DT_REG'
  200 | CHECK_DT_REG(wdt0, NRF_WDT0);
[67/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[68/126] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[69/126] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_complete.c.obj
[70/126] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[71/126] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf91/soc.c.obj
[72/126] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[73/126] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[74/126] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.5.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_mutex_zephyr.c.obj
[75/126] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.5.0/nrfxlib/crypto/nrf_cc310_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\work\MyApp\hello_world\build'
 *  The terminal process terminated with exit code: 1.
I believe this is because "TF-M" is not added to the non-secure build configuration and does not include the secure build configuration.
I think I also need to configure memory settings.
Could you please tell me the minimum settings required to build "Hello world" with a non-secure build structure on a custom nRF9160 board?
Until now, I had been customizing the nRF9160_dk board definition in zephyr\boards\arm\nrf9160dk_nrf9160 by referring to the URL below.
devzone.nordicsemi.com/.../nrf-connect-sdk-tutorial---part-3-ncs-v1-4-0
Is this the best way?
ohta
  • Hi Amando,
    Even after setting the following two settings, a build error occurs.
    CONFIG_BUILD_WITH_TFM=y
    CONFIG_TRUSTED_EXECUTION_NONSECURE=y
    [5/156] Building C object secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/target_cfg.o
    FAILED: secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/target_cfg.o
    C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DBL1_HEADER_SIZE=0x000 -DBL1_TRAILER_SIZE=0x000 -DBL2_HEADER_SIZE=0x000 -DBL2_TRAILER_SIZE=0x000 -DCONFIG_TFM_FLOAT_ABI=0 -DCONFIG_TFM_PARTITION_META -DCONFIG_TFM_USE_TRUSTZONE -DCRYPTO_HW_ACCELERATOR -DDAUTH_CHIP_DEFAULT -DMBEDTLS_PSA_CRYPTO_BUILTIN_KEYS -DMBEDTLS_PSA_CRYPTO_CONFIG_FILE=\"C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/lib/ext/mbedcrypto/mbedcrypto_config/crypto_config_default.h\" -DMBEDTLS_PSA_CRYPTO_DRIVERS -DMCUBOOT_IMAGE_NUMBER=1 -DNRF9160_XXAA -DNRF91_SERIES -DNRF_ALLOW_NON_SECURE_RESET -DNRF_NS_STORAGE -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPLATFORM_DEFAULT_BL1 -DPLATFORM_NS_NV_COUNTERS=0 -DPROJECT_CONFIG_HEADER_FILE=\"C:/work/MyApp/hello_world/build/modules/nrf/modules/tfm/zephyr/tfm_config.h\" -DPSA_CRYPTO_DRIVER_TFM_BUILTIN_KEY -DPS_CRYPTO_AEAD_ALG_CCM -DPS_ENCRYPTION -DTFM_FIH_PROFILE_OFF -DTFM_INTERNAL_TRUSTED_STORAGE_SERVICE_SID=0x00000070 -DTFM_LVL=1 -DTFM_PARTITION_CRYPTO -DTFM_PARTITION_LOG_LEVEL=TFM_PARTITION_LOG_LEVEL_SILENCE -DTFM_PARTITION_NS_AGENT_TZ -DTFM_PARTITION_PLATFORM -DTFM_SPM_LOG_LEVEL=TFM_SPM_LOG_LEVEL_SILENCE -D__NRF_TFM__ -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/cmsis_psa -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/cmsis_psa/include -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/include -Igenerated -Igenerated/secure_fw/spm/include -Igenerated/secure_fw/spm/cmsis_psa -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/cmsis_psa/arch -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include/boot -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/spm/include/interface -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/. -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/native_drivers -IC:/ncs/v2.5.0/modules/hal/nordic/nrfx -IC:/ncs/v2.5.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.5.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/common -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/.. -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/services/include -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/nrf91/. -IC:/ncs/v2.5.0/nrf/modules/tfm/tfm/boards/include -IC:/ncs/v2.5.0/nrf/modules/tfm/tfm/boards/partition -I../zephyr/include/generated -IC:/ncs/v2.5.0/nrf/modules/tfm/tfm/boards/board -I../zephyr/misc/generated/syscalls_links/include -IC:/ncs/v2.5.0/zephyr/include -IC:/ncs/v2.5.0/nrf/modules/tfm/tfm/boards/services/include -IC:/ncs/v2.5.0/nrf/include -IC:/ncs/v2.5.0/nrf/include/tfm -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/accelerator/interface -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/./ext -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/./ext/cmsis -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/./ext/common -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/./ext/driver -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/./include -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/common -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/config -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/crypto -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/firmware_update -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/initial_attestation -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/internal_trusted_storage -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/platform -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/protected_storage -Igenerated/interface/include -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/lib/fih/inc -Igenerated/secure_fw/partitions/crypto -Igenerated/secure_fw/partitions/platform -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/secure_fw/partitions/lib/runtime/include -IC:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/interface/include -mcpu=cortex-m33+nodsp+nofp -Os -DNDEBUG -fmacro-prefix-map=C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/../tf-m-tests=TFM_TEST_REPO_PATH -specs=nano.specs -Wall -Wno-format -Wno-return-type -Wno-unused-but-set-variable -c -fdata-sections -ffunction-sections -fno-builtin -fshort-enums -funsigned-char -mthumb -nostdlib -std=c99 -gdwarf-4 -g -mfloat-abi=soft -mcmse -Wno-unused-value -include C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/include/cmsis_override.h -MD -MT secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/target_cfg.o -MF secure_fw\spm\CMakeFiles\tfm_spm.dir\__\__\platform\ext\target\nordic_nrf\common\core\target_cfg.o.d -o secure_fw/spm/CMakeFiles/tfm_spm.dir/__/__/platform/ext/target/nordic_nrf/common/core/target_cfg.o -c C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c
    C:/ncs/v2.5.0/modules/tee/tf-m/trusted-firmware-m/platform/ext/target/nordic_nrf/common/core/target_cfg.c: In function 'spu_periph_init_cfg':
    C:\ncs\v2.5.0\modules\tee\tf-m\trusted-firmware-m\platform\ext\target\nordic_nrf\common\core\target_cfg.c:870:35: error: 'TFM_PERIPHERAL_GPIO0_PIN_MASK_SECURE' undeclared (first use in this function); did you mean 'TFM_PERIPHERAL_GPIO0_SECURE'?
      870 |     spu_gpio_config_non_secure(0, TFM_PERIPHERAL_GPIO0_PIN_MASK_SECURE, SPU_LOCK_CONF_LOCKED);
    C:\ncs\v2.5.0\modules\tee\tf-m\trusted-firmware-m\platform\ext\target\nordic_nrf\common\core\target_cfg.c:870:35: note: each undeclared identifier is reported only once for each function it appears in
    FAILED: modules/trusted-firmware-m/tfm-prefix/src/tfm-stamp/tfm-build tfm/secure_fw/s_veneers.o tfm/tf-m-tests/app/libtfm_api_ns.a tfm/generated/interface/include/psa_manifest/sid.h tfm/platform/ns/libplatform_ns.a tfm/bin/tfm_s.elf tfm/bin/tfm_s.bin tfm/bin/tfm_s.hex tfm/bin/tfm_ns.bin tfm/bin/tfm_ns.hex tfm/bin/tfm_s_signed.bin tfm/bin/tfm_ns_signed.bin tfm/bin/tfm_s_ns_signed.bin tfm/install/interface/src/tfm_attest_api.c tfm/install/interface/src/tfm_crypto_api.c tfm/install/interface/src/tfm_fwu_api.c tfm/install/interface/src/tfm_its_api.c tfm/install/interface/src/tfm_platform_api.c tfm/install/interface/src/tfm_ps_api.c tfm/install/interface/src/tfm_psa_ns_api.c tfm/install/interface/src/tfm_ioctl_core_ns_api.c
    I was able to build correctly in the NCS 2.4.2 environment.
    This issue seems to only occur with NCS 2.5.0.
    When I directly corrected the part displayed as an error, the build passed.
     <original>
     <modify>
      spu_gpio_config_non_secure(0, 0, SPU_LOCK_CONF_LOCKED);
    Therefore, the only problem seems to be that TFM_PERIPHERAL_GPIO0_PIN_MASK_SECURE is not defined correctly.
    However, TFM_PERIPHERAL_GPIO0_PIN_MASK_SECURE is define in the file below.
    C:\ncs\v2.5.0\modules\tee\tf-m\trusted-firmware-m\platform\ext\target\nordic_nrf\common\nrf91\tfm_peripherals_config_nrf91.h
    Do you know why NCS 2.5.0 does not build correctly?
    ohta
    Sorry for the delay. I was out of the office last week.
    Thanks for the report, this is a regression and we will fix it.
    You can enable the gpio0 node in the dts file as a workaround.
    &gpio0 {
    	status = "okay";
    Is it possible to open this case to the public to benefit more users?
    Amanda H.
  • Hi Amanda,H
    There is no problem with making this case public.
    ohta
