MCUBoot HelloWorld code does not build successfully when the build configuration selected is nrf7002dk_nrf5340_cpuapp but it works when the build configuration selected is nrf5340dk_nrf5340_cpuapp
Hi everyone,
I have an nrf7002DK board and I was trying to build the MCUBoot HelloWorld code and i got the error message shown in below when my build configuration set was nrf7002dk_nrf5340_cpuapp.
Building PlatformBootloader3
C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/Arjun/WPM/Code/PlatformBootloader3/build_1 c:/Arjun/WPM/Code/PlatformBootloader3 --pristine --board nrf7002dk_nrf5340_cpuapp --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="c:/Arjun/WPM/Code/PlatformBootloader3/prj.conf" -DBOARD_ROOT:STRING="c:/arjun/wpm/code/platformbootloader3""
-- Application: C:/Arjun/WPM/Code/PlatformBootloader3
-- CMake version: 3.20.5
-- Found Python3: C:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.4.0/zephyr/.cache
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.0/zephyr)
-- Found west (found suitable version "1.0.0", minimum required is "0.7.1")
-- Board: nrf7002dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/31f4403e35/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.4.0/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/zephyr/dts.cmake
Parsing C:/ncs/v2.4.0/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.4.0/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_defconfig'
Merged configuration 'c:/Arjun/WPM/Code/PlatformBootloader3/prj.conf'
Configuration saved to 'C:/Arjun/WPM/Code/PlatformBootloader3/build_1/zephyr/.config'
Kconfig header saved to 'C:/Arjun/WPM/Code/PlatformBootloader3/build_1/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Found Python3: C:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/child_image_preload.cmake
CMake Warning (dev) at C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/child_image_preload.cmake:7 (set):
Syntax error in cmake code at
when parsing string
C:\ncs\toolchains\31f4403e35\opt\bin\python.exe
Invalid escape sequence \3
Policy CMP0010 is not set: Bad variable reference syntax is an error. Run
"cmake --help-policy CMP0010" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
This warning is for project developers. Use -Wno-dev to suppress it.
-- Application: C:/ncs/v2.4.0/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: C:/ncs/v2.4.0/nrf/modules/mcuboot/usb.overlay
-- Generated zephyr.dts: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/dts.cmake
Parsing C:/ncs/v2.4.0/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration 'C:/ncs/v2.4.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/ncs/v2.4.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/include/generated/autoconf.h'
CMake Warning at C:/ncs/v2.4.0/zephyr/CMakeLists.txt:838 (message):
No SOURCES given to Zephyr library: lib__libc__common
Excluding target from build.
No SOURCES given to Zephyr library: drivers__spi
MCUBoot bootloader key file: C:/ncs/v2.4.0/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot
=== child image mcuboot - end ===
CMake Warning at C:/ncs/v2.4.0/nrf/modules/mcuboot/CMakeLists.txt:310 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
-- Configuring done
-- Generating done
[1/183] Generating include/generated/version.h
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.0/zephyr), build: v3.3.99-ncs1
[2/183] Creating directories for 'mcuboot_subimage'
[3/183] No download step for 'mcuboot_subimage'
[4/183] No update step for 'mcuboot_subimage'
[5/183] No patch step for 'mcuboot_subimage'
[6/183] No configure step for 'mcuboot_subimage'
[6/183] Performing build step for 'mcuboot_subimage'
[1/290] Generating include/generated/version.h
[2/290] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/290] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/290] Generating include/generated/driver-validation.h
[5/290] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[6/290] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/290] Generating include/generated/offsets.h
[8/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[9/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[10/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[11/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[12/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[13/290] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[14/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/soc.c.obj
[15/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[16/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[17/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[18/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
[19/290] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[20/290] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.0/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[21/290] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.0/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
[22/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[23/290] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[24/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[25/290] Generating linker_zephyr_pre1.cmd
[26/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[27/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[28/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[29/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[30/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[31/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[32/290] Generating linker_zephyr_pre0.cmd
[33/290] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[34/290] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[35/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[36/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[37/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[38/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[39/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_cookie.c.obj
[40/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_debug_helpers_generated.c.obj
[41/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_msg.c.obj
[42/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_client.c.obj
[43/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj
[44/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls.c.obj
[45/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls13_client.c.obj
[46/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls12_client.c.obj
[47/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_ticket.c.obj
[48/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls12_server.c.obj
[49/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/timing.c.obj
[50/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj
[51/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls13_generic.c.obj
[52/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/threading.c.obj
[53/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls13_server.c.obj
[54/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509.c.obj
[55/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/version.c.obj
[56/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/version_features.c.obj
[57/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509_crl.c.obj
[58/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509_create.c.obj
[59/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509write_crt.c.obj
[60/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509write_csr.c.obj
[61/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509_csr.c.obj
[62/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509_crt.c.obj
[63/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[64/290] Linking C static library zephyr\arch\common\libisr_tables.a
[65/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[66/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.c.obj
[67/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[68/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[69/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[70/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[71/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
[72/290] Generating zephyr/autogen-pubkey.c
[73/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[74/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[75/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[76/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[77/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[78/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[79/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[80/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[81/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[82/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[83/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[84/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[85/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[86/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[87/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[88/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[89/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[90/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[91/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[92/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[93/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[94/290] Linking C static library zephyr\arch\common\libarch__common.a
[95/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[96/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[97/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[98/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[99/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[100/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[101/290] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[102/290] Building C object CMakeFiles/app.dir/main.c.obj
[103/290] Building C object CMakeFiles/app.dir/os.c.obj
[104/290] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[105/290] Building C object CMakeFiles/app.dir/keys.c.obj
[106/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[107/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[108/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
[109/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
[110/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[111/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[112/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
[113/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
[114/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[115/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[116/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[117/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[118/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
[119/290] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[120/290] Building C object CMakeFiles/app.dir/arm_cleanup.c.obj
[121/290] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
[122/290] Linking C static library zephyr\libzephyr.a
[123/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[124/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[125/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[126/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[127/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[128/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[129/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[130/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[131/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[132/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[133/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[134/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[135/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[136/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[137/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[138/290] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[139/290] Generating ../../../include/generated/libc/minimal/strerror_table.h
[140/290] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[141/290] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[142/290] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[143/290] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[144/290] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
[145/290] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[146/290] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[147/290] Linking C static library app\libapp.a
[148/290] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[149/290] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[150/290] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[151/290] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[152/290] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[153/290] Linking C static library zephyr\kernel\libkernel.a
[154/290] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
[155/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[156/290] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[157/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/sha256.c.obj
[158/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/sha1.c.obj
[159/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj
[160/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/sha512.c.obj
[161/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_cache.c.obj
[162/290] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[163/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[164/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/zephyr_init.c.obj
[165/290] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[166/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[167/290] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[168/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[169/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[170/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[171/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[172/290] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[173/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[174/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[175/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[176/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[177/290] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj
[178/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[179/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[180/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[181/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[182/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[183/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[184/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[185/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[186/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[187/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[188/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[189/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[190/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[191/290] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[192/290] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[193/290] Linking C static library zephyr\drivers\console\libdrivers__console.a
[194/290] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[195/290] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[196/290] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[197/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[198/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[199/290] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[200/290] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[201/290] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[202/290] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[203/290] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
[204/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/aesni.c.obj
[205/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/aria.c.obj
[206/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/aes.c.obj
[207/290] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
[208/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/base64.c.obj
[209/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/asn1parse.c.obj
[210/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/asn1write.c.obj
[211/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/bignum_core.c.obj
[212/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/chacha20.c.obj
[213/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/bignum_mod.c.obj
[214/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/bignum_mod_raw.c.obj
[215/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ccm.c.obj
[216/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/camellia.c.obj
[217/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/cipher_wrap.c.obj
[218/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/cipher.c.obj
[219/290] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[220/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/chachapoly.c.obj
[221/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/cmac.c.obj
[222/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/code_share.c.obj
[223/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/debug.c.obj
[224/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/constant_time.c.obj
[225/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ctr_drbg.c.obj
[226/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/des.c.obj
[227/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/dhm.c.obj
[228/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ecdsa.c.obj
[229/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ecjpake.c.obj
[230/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ecp.c.obj
[231/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ecp_curves.c.obj
[232/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ecdh.c.obj
[233/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/hash_info.c.obj
[234/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/entropy.c.obj
[235/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/entropy_poll.c.obj
[236/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/error.c.obj
[237/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/gcm.c.obj
[238/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/md.c.obj
[239/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/lmots.c.obj
[240/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/hkdf.c.obj
[241/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/lms.c.obj
[242/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/hmac_drbg.c.obj
[243/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/md5.c.obj
[244/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/net_sockets.c.obj
[245/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
[246/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/mps_trace.c.obj
[247/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/mps_reader.c.obj
[248/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pk.c.obj
[249/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/padlock.c.obj
[250/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/nist_kw.c.obj
[251/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/oid.c.obj
[252/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pem.c.obj
[253/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pkcs7.c.obj
[254/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pk_wrap.c.obj
[255/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pkcs12.c.obj
[256/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pkcs5.c.obj
[257/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pkparse.c.obj
[258/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/poly1305.c.obj
[259/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/platform.c.obj
[260/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pkwrite.c.obj
[261/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/bignum.c.obj
[262/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/platform_util.c.obj
[263/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_driver_wrappers.c.obj
[264/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_aead.c.obj
[265/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_cipher.c.obj
[266/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto.c.obj
[267/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_client.c.obj
[268/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_hash.c.obj
[269/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_ecp.c.obj
[270/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_pake.c.obj
[271/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_mac.c.obj
[272/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_rsa.c.obj
[273/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_its_file.c.obj
[274/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_se.c.obj
[275/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_storage.c.obj
[276/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_slot_management.c.obj
[277/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ripemd160.c.obj
[278/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/rsa.c.obj
[279/290] Linking C static library modules\mbedtls\libmodules__mbedtls.a
[280/290] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr\zephyr_pre0.elf -fuse-ld=bfd -Wl,-T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/mbedtls/libmodules__mbedtls.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"c:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp" -LC:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie C:/ncs/v2.4.0/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.17.a && cmd.exe /C "cd /D C:\Arjun\WPM\Code\PlatformBootloader3\build_1\mcuboot\zephyr && C:\ncs\toolchains\31f4403e35\opt\bin\cmake.exe -E echo ""
c:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj):(.rodata.spi_nor_config_0+0x0): undefined reference to `__device_dts_ord_141'
collect2.exe: error: ld returned 1 exit status
[162/183] Linking C executable zephyr\zephyr_pre0.elf
[166/183] Linking C executable zephyr\zephyr_pre1.elf
[171/183] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf
cmd.exe /C "cd /D C:\Arjun\WPM\Code\PlatformBootloader3\build_1\mcuboot && C:\ncs\toolchains\31f4403e35\opt\bin\cmake.exe --build . --"
[173/183] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 23688 B 491008 B 4.82%
RAM: 6256 B 512 KB 1.19%
IDT_LIST: 0 GB 2 KB 0.00%
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\31f4403e35\opt\bin\cmake.EXE' --build 'c:\Arjun\WPM\Code\PlatformBootloader3\build_1'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
Meanwhile the same code builds properly if the build configuration selected is nrf5340DK_nrf5340_cpuapp.
    Are you sure you are building my example hello_world_7002DK_secboot?
    I compared the build log and found there are some differences
    CMake Warning at C:/ncs/v2.4.0/nrf/cmake/partition_manager.cmake:528 (message):
    Could not find memory mapped address for XIP. Generated update hex files
    will not have the correct base address. Hence they can not be programmed
    directly to the external flash
    It seems you are building your project with XIP which is not used in my example.
    -Amanda H.
  • I am using the hello world example from the VSCode
    Create new application > search for MCUBoot > select application skeleton(helloworld)
    Could you try to build and run my example?
    Of course, you can copy the prj.conf, child_image folder, and boards folder from my hello_world_7002DK_secboot example to the sample you are using. They should also work.
    -Amanda H.
  • Hi Amanda,
    I tried running your example as well with 2.4.0 SDK as well as 2.5.0 SDK
    I thought that it might be something to do with the SDK and then i reinstalled the SDK as well. still the issue persists.
    Building hello_world_7002DK_secboot
    west build --build-dir c:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build c:/Users/E40060476/Downloads/hello_world_7002DK_secboot --pristine --board nrf7002dk_nrf5340_cpuapp --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION=NONE -DBOARD_ROOT=c:/users/e40060476/downloads/hello_world_7002dk_secboot -DCONF_FILE=c:/Users/E40060476/Downloads/hello_world_7002DK_secboot/prj.conf -DDTC_OVERLAY_FILE=c:/Users/E40060476/Downloads/hello_world_7002DK_secboot/boards/nrf7002dk_nrf5340_cpuapp.overlay
    -- Application: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot
    -- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v2.5.0/zephyr/.cache
    -- Zephyr version: 3.4.99 (C:/ncs/v2.5.0/zephyr)
    -- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
    -- Found host-tools: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
    -- Found Dtc: C:/ncs/toolchains/c57af46cb7/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
    -- Found BOARD.dts: C:/ncs/v2.5.0/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: c:/Users/E40060476/Downloads/hello_world_7002DK_secboot/boards/nrf7002dk_nrf5340_cpuapp.overlay
    -- Generated zephyr.dts: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/zephyr/dts.cmake
    Parsing C:/ncs/v2.5.0/zephyr/Kconfig
    Loaded configuration 'C:/ncs/v2.5.0/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_defconfig'
    Merged configuration 'c:/Users/E40060476/Downloads/hello_world_7002DK_secboot/prj.conf'
    Configuration saved to 'C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/zephyr/.config'
    Kconfig header saved to 'C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/zephyr/include/generated/autoconf.h'
    -- Found GnuLd: c:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
    -- Found assembler: C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
    === child image b0 - begin ===
    loading initial cache file C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/b0/child_image_preload.cmake
    -- Application: C:/ncs/v2.5.0/nrf/samples/bootloader
    -- Generated zephyr.dts: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/b0/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/b0/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/b0/zephyr/dts.cmake
    Merged configuration 'C:/ncs/v2.5.0/nrf/samples/bootloader/prj.conf'
    Merged configuration 'C:/ncs/v2.5.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
    Merged configuration 'C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/child_image/b0.conf'
    Merged configuration 'C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/b0/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/b0/zephyr/.config'
    Kconfig header saved to 'C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/b0/zephyr/include/generated/autoconf.h'
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/b0
    === child image b0 - end ===
    CMake Warning at C:/ncs/v2.5.0/nrf/subsys/bootloader/cmake/debug_keys.cmake:36 (message):
    --- WARNING: Using generated NSIB public/private key-pair. ---
    --- It should not be used for production. ---
    --- See CONFIG_SB_SIGNING_KEY_FILE ---
    C:/ncs/v2.5.0/nrf/subsys/bootloader/cmake/provision_hex.cmake:47 (include)
    C:/ncs/v2.5.0/nrf/subsys/CMakeLists.txt:20 (include)
    -- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    loading initial cache file C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/mcuboot/child_image_preload.cmake
    -- Application: C:/ncs/v2.5.0/bootloader/mcuboot/boot/zephyr
    -- Found devicetree overlay: C:/ncs/v2.5.0/nrf/modules/mcuboot/flash_sim.overlay
    -- Found devicetree overlay: C:/ncs/v2.5.0/nrf/modules/mcuboot/usb.overlay
    -- Found devicetree overlay: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/child_image/mcuboot/boards/nrf7002dk_nrf5340_cpuapp.overlay
    -- Generated zephyr.dts: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/mcuboot/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/mcuboot/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/mcuboot/zephyr/dts.cmake
    Parsing C:/ncs/v2.5.0/bootloader/mcuboot/boot/zephyr/Kconfig
    Merged configuration 'C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/child_image/mcuboot/boards/nrf7002dk_nrf5340_cpuapp.conf'
    Merged configuration 'C:/ncs/v2.5.0/nrf/subsys/bootloader/image/log_minimal.conf'
    Merged configuration 'C:/ncs/v2.5.0/nrf/subsys/bootloader/image/multi_image_mcuboot.conf'
    Merged configuration 'C:/ncs/v2.5.0/nrf/subsys/bootloader/image/fw_info.conf'
    Merged configuration 'C:/ncs/v2.5.0/nrf/subsys/partition_manager/ext_flash_mcuboot_secondary.conf'
    Merged configuration 'C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
    Configuration saved to 'C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/mcuboot/zephyr/.config'
    warning: The choice symbol LOG_MODE_MINIMAL (defined at subsys/logging\Kconfig.mode:28) was selected
    (set =y), but no symbol ended up as the choice selection. See
    docs.zephyrproject.org/.../kconfig.html and/or look up
    LOG_MODE_MINIMAL in the menuconfig/guiconfig interface. The Application Development Primer, Setting
    Configuration Values, and Kconfig - Tips and Best Practices sections of the manual might be helpful
    too.
    Kconfig header saved to 'C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/mcuboot/zephyr/include/generated/autoconf.h'
    MCUBoot bootloader key file: C:/ncs/v2.5.0/bootloader/mcuboot/root-rsa-2048.pem
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/mcuboot
    CMake Warning at C:/ncs/v2.5.0/nrf/modules/mcuboot/CMakeLists.txt:320 (message):
    CMake Warning at C:/ncs/v2.5.0/nrf/cmake/partition_manager.cmake:79 (message):
    --- WARNING: Using a bootloader without pm_static.yml. ---
    --- There are cases where a deployed product can consist of ---
    --- multiple images, and only a subset of these images can be ---
    --- upgraded through a firmware update mechanism. In such cases, ---
    --- the upgradable images must have partitions that are static ---
    --- and are matching the partition map used by the bootloader ---
    --- programmed onto the device. ---
    C:/ncs/v2.5.0/zephyr/cmake/modules/kernel.cmake:247 (include)
    C:/ncs/v2.5.0/zephyr/cmake/modules/zephyr_default.cmake:138 (include)
    C:/ncs/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
    C:/ncs/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:92 (include_boilerplate)
    CMakeLists.txt:5 (find_package)
    CMake Warning at C:/ncs/v2.5.0/nrf/cmake/partition_manager.cmake:465 (message):
    Could not find memory mapped address for XIP. Generated update hex files will not have the correct base address. Hence they can not be programmed directly to the external flash
    CMake Warning at C:/ncs/v2.5.0/nrf/cmake/partition_manager.cmake:566 (message):
    -- Configuring done
    -- Generating done
    [7/191] Generating include/generated/version.h
    -- Zephyr version: 3.4.99 (C:/ncs/v2.5.0/zephyr), build: v3.4.99-ncs1
    [2/135] Generating include/generated/version.h
    [135/135] Linking C executable zephyr\zephyr.elf
    FLASH: 26440 B 32 KB 80.69%
    RAM: 4700 B 448 KB 1.02%
    [3/275] Generating include/generated/version.h
    [263/275] Building C object modules/nrf/modules/mcuboot/hooks/CMakeFiles/..__nrf__modules__mcuboot__hooks.dir/nrf53_hooks.c.obj
    FAILED: modules/nrf/modules/mcuboot/hooks/CMakeFiles/..__nrf__modules__mcuboot__hooks.dir/nrf53_hooks.c.obj
    C:\ncs\toolchains\c57af46cb7\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DEXT_API_MAGIC=0x281ee6de,0xb845acea,13570 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,13570 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"mcuboot-mbedtls-cfg.h\" -DNRF5340_XXAA_APPLICATION -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DPICOLIBC_INTEGER_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.5.0/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.5.0/zephyr/soc/arm/nordic_nrf/nrf53 -IC:/ncs/v2.5.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.5.0/nrf/include -IC:/ncs/v2.5.0/nrf/tests/include -IC:/ncs/v2.5.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.5.0/zephyr/modules/cmsis/. -IC:/ncs/v2.5.0/modules/hal/nordic/nrfx -IC:/ncs/v2.5.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.5.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.5.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.5.0/bootloader/mcuboot/boot/zephyr/include -IC:/ncs/v2.5.0/modules/crypto/mbedtls/include -IC:/ncs/v2.5.0/zephyr/modules/mbedtls/configs -IC:/ncs/v2.5.0/zephyr/modules/mbedtls/include -IC:/ncs/v2.5.0/bootloader/mcuboot/boot/bootutil/zephyr/.. -IC:/ncs/v2.5.0/bootloader/mcuboot/boot/bootutil/zephyr/../include -IC:/ncs/v2.5.0/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -isystem C:/ncs/v2.5.0/nrfxlib/crypto/nrf_cc312_platform/include -fno-strict-aliasing -Os -imacros C:/Users/E40060476/Downloads/hello_world_7002DK_secboot/build/mcuboot/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.5.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/ncs/v2.5.0/bootloader/mcuboot/boot/zephyr=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.5.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.5.0=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT modules/nrf/modules/mcuboot/hooks/CMakeFiles/..__nrf__modules__mcuboot__hooks.dir/nrf53_hooks.c.obj -MF modules\nrf\modules\mcuboot\hooks\CMakeFiles\..__nrf__modules__mcuboot__hooks.dir\nrf53_hooks.c.obj.d -o modules/nrf/modules/mcuboot/hooks/CMakeFiles/..__nrf__modules__mcuboot__hooks.dir/nrf53_hooks.c.obj -c C:/ncs/v2.5.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c
    C:/ncs/v2.5.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c: In function 'boot_read_image_header_hook':
    C:/ncs/v2.5.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c:77:42: error: 'PM_MCUBOOT_PRIMARY_1_ADDRESS' undeclared (first use in this function); did you mean 'PM_MCUBOOT_PRIMARY_ADDRESS'?
    77 | img_head->ih_load_addr = PM_MCUBOOT_PRIMARY_1_ADDRESS;
    C:/ncs/v2.5.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c:77:42: note: each undeclared identifier is reported only once for each function it appears in
    C:/ncs/v2.5.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c:78:41: error: 'PM_CPUNET_APP_SIZE' undeclared (first use in this function)
    78 | img_head->ih_img_size = PM_CPUNET_APP_SIZE;
    In file included from C:/ncs/v2.5.0/zephyr/include/zephyr/toolchain/gcc.h:92,
    from C:/ncs/v2.5.0/zephyr/include/zephyr/toolchain.h:50,
    from C:/ncs/v2.5.0/zephyr/include/zephyr/kernel_includes.h:19,
    from C:/ncs/v2.5.0/zephyr/include/zephyr/kernel.h:17,
    from C:/ncs/v2.5.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c:8:
    C:/ncs/v2.5.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c: In function 'network_core_update':
    C:/ncs/v2.5.0/zephyr/include/zephyr/device.h:85:41: error: '__device_dts_ord_DT_N_NODELABEL_PM_MCUBOOT_PRIMARY_1_DEV_ORD' undeclared (first use in this function)
    85 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
    C:/ncs/v2.5.0/zephyr/include/zephyr/toolchain/common.h:132:26: note: in definition of macro '_DO_CONCAT'
    132 | #define _DO_CONCAT(x, y) x ## y
    C:/ncs/v2.5.0/zephyr/include/zephyr/device.h:85:33: note: in expansion of macro '_CONCAT'
    C:/ncs/v2.5.0/zephyr/include/zephyr/device.h:211:37: note: in expansion of macro 'DEVICE_NAME_GET'
    211 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
    C:/ncs/v2.5.0/zephyr/include/zephyr/device.h:228:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
    228 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
    C:/ncs/v2.5.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c:134:26: note: in expansion of macro 'DEVICE_DT_GET'
    134 | mock_flash_dev = DEVICE_DT_GET(DT_NODELABEL(PM_MCUBOOT_PRIMARY_1_DEV));
    C:/ncs/v2.5.0/nrf/modules/mcuboot/hooks/nrf53_hooks.c:147:34: error: 'PM_CPUNET_B0N_ADDRESS' undeclared (first use in this function)
    147 | if (reset_addr > PM_CPUNET_B0N_ADDRESS) {
    [266/275] Linking C static library modules\mbedtls\libmbedTLSX509.a
    [174/191] Generating zephyr/b0_container.hex
    cmd.exe /C "cd /D C:\Users\E40060476\Downloads\hello_world_7002DK_secboot\build\mcuboot && C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.exe --build . --"
    [176/191] Linking C executable zephyr\zephyr.elf
    FLASH: 39708 B 826880 B 4.80%
    RAM: 6452 B 448 KB 1.41%
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\Users\E40060476\Downloads\hello_world_7002DK_secboot\build'
    Did you modify the example? Please try with the example without modification. If you still have the same issue with the unmodified example, please the .config files under build/zephyr and build/mcuboot/zephyr?
    Note. Please upload the logs by the toolbar -> Insert -> Code instead of pasting into the content. That can help to read the post easily.
    -Amanda H.
