MCUBoot HelloWorld code does not build successfully when the build configuration selected is nrf7002dk_nrf5340_cpuapp but it works when the build configuration selected is nrf5340dk_nrf5340_cpuapp
Hi everyone,
I have an nrf7002DK board and I was trying to build the MCUBoot HelloWorld code and i got the error message shown in below when my build configuration set was nrf7002dk_nrf5340_cpuapp.
Building PlatformBootloader3
C:\WINDOWS\system32\cmd.exe /d /s /c "west build --build-dir c:/Arjun/WPM/Code/PlatformBootloader3/build_1 c:/Arjun/WPM/Code/PlatformBootloader3 --pristine --board nrf7002dk_nrf5340_cpuapp --no-sysbuild -- -DNCS_TOOLCHAIN_VERSION:STRING="NONE" -DCONF_FILE:STRING="c:/Arjun/WPM/Code/PlatformBootloader3/prj.conf" -DBOARD_ROOT:STRING="c:/arjun/wpm/code/platformbootloader3""
-- Application: C:/Arjun/WPM/Code/PlatformBootloader3
-- CMake version: 3.20.5
-- Found Python3: C:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found suitable exact version "3.8.2") found components: Interpreter
-- Cache files will be written to: C:/ncs/v2.4.0/zephyr/.cache
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.0/zephyr)
-- Found west (found suitable version "1.0.0", minimum required is "0.7.1")
-- Board: nrf7002dk_nrf5340_cpuapp
-- Found host-tools: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found toolchain: zephyr 0.16.0 (C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk)
-- Found Dtc: C:/ncs/toolchains/31f4403e35/opt/bin/dtc.exe (found suitable version "1.4.7", minimum required is "1.4.6")
-- Found BOARD.dts: C:/ncs/v2.4.0/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp.dts
-- Generated zephyr.dts: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/zephyr/dts.cmake
Parsing C:/ncs/v2.4.0/zephyr/Kconfig
Loaded configuration 'C:/ncs/v2.4.0/nrf/boards/arm/nrf7002dk_nrf5340/nrf7002dk_nrf5340_cpuapp_defconfig'
Merged configuration 'c:/Arjun/WPM/Code/PlatformBootloader3/prj.conf'
Configuration saved to 'C:/Arjun/WPM/Code/PlatformBootloader3/build_1/zephyr/.config'
Kconfig header saved to 'C:/Arjun/WPM/Code/PlatformBootloader3/build_1/zephyr/include/generated/autoconf.h'
-- Found GnuLd: c:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe (found version "2.38")
-- Found assembler: C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc.exe
-- Found Python3: C:/ncs/toolchains/31f4403e35/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
=== child image mcuboot - begin ===
loading initial cache file C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/child_image_preload.cmake
CMake Warning (dev) at C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/child_image_preload.cmake:7 (set):
Syntax error in cmake code at
when parsing string
C:\ncs\toolchains\31f4403e35\opt\bin\python.exe
Invalid escape sequence \3
Policy CMP0010 is not set: Bad variable reference syntax is an error. Run
"cmake --help-policy CMP0010" for policy details. Use the cmake_policy
command to set the policy and suppress this warning.
This warning is for project developers. Use -Wno-dev to suppress it.
-- Application: C:/ncs/v2.4.0/bootloader/mcuboot/boot/zephyr
-- Found devicetree overlay: C:/ncs/v2.4.0/nrf/modules/mcuboot/usb.overlay
-- Generated zephyr.dts: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/zephyr.dts
-- Generated devicetree_generated.h: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/include/generated/devicetree_generated.h
-- Including generated dts.cmake file: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/dts.cmake
Parsing C:/ncs/v2.4.0/bootloader/mcuboot/boot/zephyr/Kconfig
Merged configuration 'C:/ncs/v2.4.0/bootloader/mcuboot/boot/zephyr/prj.conf'
Merged configuration 'C:/ncs/v2.4.0/nrf/subsys/partition_manager/partition_manager_enabled.conf'
Merged configuration 'C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/misc/generated/extra_kconfig_options.conf'
Configuration saved to 'C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/.config'
Kconfig header saved to 'C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/include/generated/autoconf.h'
CMake Warning at C:/ncs/v2.4.0/zephyr/CMakeLists.txt:838 (message):
No SOURCES given to Zephyr library: lib__libc__common
Excluding target from build.
No SOURCES given to Zephyr library: drivers__spi
MCUBoot bootloader key file: C:/ncs/v2.4.0/bootloader/mcuboot/root-rsa-2048.pem
-- Configuring done
-- Generating done
-- Build files have been written to: C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot
=== child image mcuboot - end ===
CMake Warning at C:/ncs/v2.4.0/nrf/modules/mcuboot/CMakeLists.txt:310 (message):
--- WARNING: Using default MCUBoot key, it should not ---
--- be used for production. ---
-- Configuring done
-- Generating done
[1/183] Generating include/generated/version.h
-- Zephyr version: 3.3.99 (C:/ncs/v2.4.0/zephyr), build: v3.3.99-ncs1
[2/183] Creating directories for 'mcuboot_subimage'
[3/183] No download step for 'mcuboot_subimage'
[4/183] No update step for 'mcuboot_subimage'
[5/183] No patch step for 'mcuboot_subimage'
[6/183] No configure step for 'mcuboot_subimage'
[6/183] Performing build step for 'mcuboot_subimage'
[1/290] Generating include/generated/version.h
[2/290] Generating misc/generated/syscalls.json, misc/generated/struct_tags.json
[3/290] Generating include/generated/syscall_dispatch.c, include/generated/syscall_list.h
[4/290] Generating include/generated/driver-validation.h
[5/290] Generating include/generated/kobj-types-enum.h, include/generated/otype-to-str.h, include/generated/otype-to-size.h
[6/290] Building C object zephyr/CMakeFiles/offsets.dir/arch/arm/core/offsets/offsets.c.obj
[7/290] Generating include/generated/offsets.h
[8/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map_layout.c.obj
[9/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_minimal.c.obj
[10/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/storage/flash_map/flash_map.c.obj
[11/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_base_addresses.c.obj
[12/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/validate_enabled_instances.c.obj
[13/290] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj
[14/290] Building C object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/nrf53/soc.c.obj
[15/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/assert.c.obj
[16/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/reboot.c.obj
[17/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf.c.obj
[18/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_nano.c.obj
[19/290] Building ASM object zephyr/CMakeFiles/zephyr.dir/soc/arm/nordic_nrf/common/soc_nrf_common.S.obj
[20/290] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.0/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_abort_zephyr.c.obj
[21/290] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.0/nrfxlib/crypto/nrf_cc312_platform/src/nrf_cc3xx_platform_no_mutex_zephyr.c.obj
[22/290] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/tracing/tracing_none.c.obj
[23/290] Building C object zephyr/CMakeFiles/zephyr.dir/C_/ncs/v2.4.0/nrf/subsys/partition_manager/flash_map_partition_manager.c.obj
[24/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/thread.c.obj
[25/290] Generating linker_zephyr_pre1.cmd
[26/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap_helper.S.obj
[27/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/irq_manage.c.obj
[28/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi_on_reset.S.obj
[29/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/swap.c.obj
[30/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/nmi.c.obj
[31/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/prep_c.c.obj
[32/290] Generating linker_zephyr_pre0.cmd
[33/290] Building C object zephyr/arch/common/CMakeFiles/arch__common.dir/sw_isr_common.c.obj
[34/290] Building C object zephyr/arch/common/CMakeFiles/isr_tables.dir/isr_tables.c.obj
[35/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/cpu_idle.S.obj
[36/290] Building C object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/fatal.c.obj
[37/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/main_weak.c.obj
[38/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/banner.c.obj
[39/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_cookie.c.obj
[40/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_debug_helpers_generated.c.obj
[41/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_msg.c.obj
[42/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_client.c.obj
[43/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_ciphersuites.c.obj
[44/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls.c.obj
[45/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls13_client.c.obj
[46/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls12_client.c.obj
[47/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_ticket.c.obj
[48/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls12_server.c.obj
[49/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/timing.c.obj
[50/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls13_keys.c.obj
[51/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls13_generic.c.obj
[52/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/threading.c.obj
[53/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_tls13_server.c.obj
[54/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509.c.obj
[55/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/version.c.obj
[56/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/version_features.c.obj
[57/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509_crl.c.obj
[58/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509_create.c.obj
[59/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509write_crt.c.obj
[60/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509write_csr.c.obj
[61/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509_csr.c.obj
[62/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/x509_crt.c.obj
[63/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/src/nrfx_clock.c.obj
[64/290] Linking C static library zephyr\arch\common\libisr_tables.a
[65/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/nrfx_glue.c.obj
[66/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/mdk/system_nrf5340_application.c.obj
[67/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/src/nrfx_dppi.c.obj
[68/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/helpers/nrfx_flag32_allocator.c.obj
[69/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/src/nrfx_nvmc.c.obj
[70/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/src/nrfx_gpiote.c.obj
[71/290] Building C object modules/hal_nordic/nrfx/CMakeFiles/modules__hal_nordic__nrfx.dir/C_/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/src/nrfx_wdt.c.obj
[72/290] Generating zephyr/autogen-pubkey.c
[73/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/cbprintf_packaged.c.obj
[74/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/dec.c.obj
[75/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/thread_entry.c.obj
[76/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/printk.c.obj
[77/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/hex.c.obj
[78/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/rb.c.obj
[79/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/sem.c.obj
[80/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/fdtable.c.obj
[81/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/timeutil.c.obj
[82/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap.c.obj
[83/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/multi_heap.c.obj
[84/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/heap-validate.c.obj
[85/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/bitarray.c.obj
[86/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/notify.c.obj
[87/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc8_sw.c.obj
[88/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32c_sw.c.obj
[89/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/onoff.c.obj
[90/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc16_sw.c.obj
[91/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc32_sw.c.obj
[92/290] Building C object zephyr/CMakeFiles/zephyr.dir/lib/os/crc7_sw.c.obj
[93/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/errno.c.obj
[94/290] Linking C static library zephyr\arch\common\libarch__common.a
[95/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/device.c.obj
[96/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/init.c.obj
[97/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/fatal.c.obj
[98/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/kheap.c.obj
[99/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/xip.c.obj
[100/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timeout.c.obj
[101/290] Linking C static library modules\hal_nordic\nrfx\libmodules__hal_nordic__nrfx.a
[102/290] Building C object CMakeFiles/app.dir/main.c.obj
[103/290] Building C object CMakeFiles/app.dir/os.c.obj
[104/290] Building C object CMakeFiles/app.dir/flash_map_extended.c.obj
[105/290] Building C object CMakeFiles/app.dir/keys.c.obj
[106/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/tlv.c.obj
[107/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/image_validate.c.obj
[108/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/encrypted.c.obj
[109/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/image_ec256.c.obj
[110/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/image_rsa.c.obj
[111/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/bootutil_misc.c.obj
[112/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/image_ed25519.c.obj
[113/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/fault_injection_hardening.c.obj
[114/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/loader.c.obj
[115/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/swap_scratch.c.obj
[116/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/swap_misc.c.obj
[117/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/swap_move.c.obj
[118/290] Building C object CMakeFiles/app.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/caps.c.obj
[119/290] Building C object CMakeFiles/app.dir/nrf_cleanup.c.obj
[120/290] Building C object CMakeFiles/app.dir/arm_cleanup.c.obj
[121/290] Building C object CMakeFiles/app.dir/zephyr/autogen-pubkey.c.obj
[122/290] Linking C static library zephyr\libzephyr.a
[123/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/version.c.obj
[124/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/thread.c.obj
[125/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mem_slab.c.obj
[126/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/mempool.c.obj
[127/290] Building C object zephyr/kernel/CMakeFiles/kernel.dir/timer.c.obj
[128/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/exc_exit.S.obj
[129/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/CMakeFiles/arch__arm__core__aarch32.dir/isr_wrapper.S.obj
[130/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault_s.S.obj
[131/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/irq_init.c.obj
[132/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fpu.c.obj
[133/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/reset.S.obj
[134/290] Building ASM object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/vector_table.S.obj
[135/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/scb.c.obj
[136/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/thread_abort.c.obj
[137/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/CMakeFiles/arch__arm__core__aarch32__cortex_m__cmse.dir/arm_core_cmse.c.obj
[138/290] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_core_mpu.c.obj
[139/290] Generating ../../../include/generated/libc/minimal/strerror_table.h
[140/290] Building C object zephyr/soc/arm/common/cortex_m/CMakeFiles/soc__arm__common__cortex_m.dir/arm_mpu_regions.c.obj
[141/290] Building C object zephyr/drivers/clock_control/CMakeFiles/drivers__clock_control.dir/clock_control_nrf.c.obj
[142/290] Building C object zephyr/drivers/console/CMakeFiles/drivers__console.dir/uart_console.c.obj
[143/290] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/flash_page_layout.c.obj
[144/290] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/jesd216.c.obj
[145/290] Building C object zephyr/drivers/gpio/CMakeFiles/drivers__gpio.dir/gpio_nrfx.c.obj
[146/290] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/pinctrl_nrf.c.obj
[147/290] Linking C static library app\libapp.a
[148/290] Building C object zephyr/drivers/pinctrl/CMakeFiles/drivers__pinctrl.dir/common.c.obj
[149/290] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/uart_nrfx_uarte.c.obj
[150/290] Building C object modules/nrf/drivers/hw_cc310/CMakeFiles/..__nrf__drivers__hw_cc310.dir/hw_cc310.c.obj
[151/290] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/nrf_rtc_timer.c.obj
[152/290] Building C object zephyr/drivers/timer/CMakeFiles/drivers__timer.dir/sys_clock_init.c.obj
[153/290] Linking C static library zephyr\kernel\libkernel.a
[154/290] Building C object modules/nrf/lib/fprotect/CMakeFiles/..__nrf__lib__fprotect.dir/fprotect_spu.c.obj
[155/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\libarch__arm__core__aarch32.a
[156/290] Building C object modules/nrf/lib/fatal_error/CMakeFiles/..__nrf__lib__fatal_error.dir/fatal_error.c.obj
[157/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/sha256.c.obj
[158/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/sha1.c.obj
[159/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/rsa_alt_helpers.c.obj
[160/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/sha512.c.obj
[161/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ssl_cache.c.obj
[162/290] Building C object modules/mcuboot/boot/bootutil/zephyr/CMakeFiles/mcuboot_util.dir/C_/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/src/bootutil_public.c.obj
[163/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\cmse\libarch__arm__core__aarch32__cortex_m__cmse.a
[164/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/zephyr_init.c.obj
[165/290] Building C object zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj
[166/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/atoi.c.obj
[167/290] Building C object zephyr/arch/arch/arm/core/aarch32/mpu/CMakeFiles/arch__arm__core__aarch32__mpu.dir/arm_mpu.c.obj
[168/290] Building C object zephyr/arch/arch/arm/core/aarch32/cortex_m/CMakeFiles/arch__arm__core__aarch32__cortex_m.dir/fault.c.obj
[169/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/abort.c.obj
[170/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/malloc.c.obj
[171/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoul.c.obj
[172/290] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/soc_flash_nrf.c.obj
[173/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtol.c.obj
[174/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoull.c.obj
[175/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/strtoll.c.obj
[176/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/qsort.c.obj
[177/290] Building C object zephyr/drivers/flash/CMakeFiles/drivers__flash.dir/spi_nor.c.obj
[178/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/exit.c.obj
[179/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdlib/bsearch.c.obj
[180/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strerror.c.obj
[181/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strspn.c.obj
[182/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strstr.c.obj
[183/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/string.c.obj
[184/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/string/strncasecmp.c.obj
[185/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/stdout_console.c.obj
[186/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrtf.c.obj
[187/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/sprintf.c.obj
[188/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/math/sqrt.c.obj
[189/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/stdout/fprintf.c.obj
[190/290] Building C object zephyr/lib/libc/minimal/CMakeFiles/lib__libc__minimal.dir/source/time/gmtime.c.obj
[191/290] Linking C static library zephyr\soc\arm\common\cortex_m\libsoc__arm__common__cortex_m.a
[192/290] Linking C static library zephyr\drivers\clock_control\libdrivers__clock_control.a
[193/290] Linking C static library zephyr\drivers\console\libdrivers__console.a
[194/290] Linking C static library zephyr\drivers\gpio\libdrivers__gpio.a
[195/290] Linking C static library zephyr\drivers\pinctrl\libdrivers__pinctrl.a
[196/290] Linking C static library modules\nrf\drivers\hw_cc310\lib..__nrf__drivers__hw_cc310.a
[197/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\mpu\libarch__arm__core__aarch32__mpu.a
[198/290] Linking C static library zephyr\arch\arch\arm\core\aarch32\cortex_m\libarch__arm__core__aarch32__cortex_m.a
[199/290] Linking C static library zephyr\drivers\serial\libdrivers__serial.a
[200/290] Linking C static library zephyr\drivers\timer\libdrivers__timer.a
[201/290] Linking C static library modules\nrf\lib\fprotect\lib..__nrf__lib__fprotect.a
[202/290] Linking C static library modules\nrf\lib\fatal_error\lib..__nrf__lib__fatal_error.a
[203/290] Linking C static library modules\mcuboot\boot\bootutil\zephyr\libmcuboot_util.a
[204/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/aesni.c.obj
[205/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/aria.c.obj
[206/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/aes.c.obj
[207/290] Linking C static library zephyr\drivers\flash\libdrivers__flash.a
[208/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/base64.c.obj
[209/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/asn1parse.c.obj
[210/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/asn1write.c.obj
[211/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/bignum_core.c.obj
[212/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/chacha20.c.obj
[213/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/bignum_mod.c.obj
[214/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/bignum_mod_raw.c.obj
[215/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ccm.c.obj
[216/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/camellia.c.obj
[217/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/cipher_wrap.c.obj
[218/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/cipher.c.obj
[219/290] Linking C static library zephyr\lib\libc\minimal\liblib__libc__minimal.a
[220/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/chachapoly.c.obj
[221/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/cmac.c.obj
[222/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/code_share.c.obj
[223/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/debug.c.obj
[224/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/constant_time.c.obj
[225/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ctr_drbg.c.obj
[226/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/des.c.obj
[227/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/dhm.c.obj
[228/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ecdsa.c.obj
[229/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ecjpake.c.obj
[230/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ecp.c.obj
[231/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ecp_curves.c.obj
[232/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ecdh.c.obj
[233/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/hash_info.c.obj
[234/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/entropy.c.obj
[235/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/entropy_poll.c.obj
[236/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/error.c.obj
[237/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/gcm.c.obj
[238/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/md.c.obj
[239/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/lmots.c.obj
[240/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/hkdf.c.obj
[241/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/lms.c.obj
[242/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/hmac_drbg.c.obj
[243/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/md5.c.obj
[244/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/net_sockets.c.obj
[245/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/memory_buffer_alloc.c.obj
[246/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/mps_trace.c.obj
[247/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/mps_reader.c.obj
[248/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pk.c.obj
[249/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/padlock.c.obj
[250/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/nist_kw.c.obj
[251/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/oid.c.obj
[252/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pem.c.obj
[253/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pkcs7.c.obj
[254/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pk_wrap.c.obj
[255/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pkcs12.c.obj
[256/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pkcs5.c.obj
[257/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pkparse.c.obj
[258/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/poly1305.c.obj
[259/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/platform.c.obj
[260/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/pkwrite.c.obj
[261/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/bignum.c.obj
[262/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/platform_util.c.obj
[263/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_driver_wrappers.c.obj
[264/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_aead.c.obj
[265/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_cipher.c.obj
[266/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto.c.obj
[267/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_client.c.obj
[268/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_hash.c.obj
[269/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_ecp.c.obj
[270/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_pake.c.obj
[271/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_mac.c.obj
[272/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_rsa.c.obj
[273/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_its_file.c.obj
[274/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_se.c.obj
[275/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_storage.c.obj
[276/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/psa_crypto_slot_management.c.obj
[277/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/ripemd160.c.obj
[278/290] Building C object modules/mbedtls/CMakeFiles/modules__mbedtls.dir/C_/ncs/v2.4.0/modules/crypto/mbedtls/library/rsa.c.obj
[279/290] Linking C static library modules\mbedtls\libmodules__mbedtls.a
[280/290] Linking C executable zephyr\zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map
cmd.exe /C "cd . && C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr\zephyr_pre0.elf -fuse-ld=bfd -Wl,-T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=C:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/flash/libdrivers__flash.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/lib/fprotect/lib..__nrf__lib__fprotect.a modules/nrf/lib/fatal_error/lib..__nrf__lib__fatal_error.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/mcuboot/boot/bootutil/zephyr/libmcuboot_util.a modules/mbedtls/libmodules__mbedtls.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -L"c:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/thumb/v8-m.main/nofp" -LC:/Arjun/WPM/Code/PlatformBootloader3/build_1/mcuboot/zephyr -lgcc zephyr/arch/common/libisr_tables.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn -Wl,-no-pie C:/ncs/v2.4.0/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.17.a && cmd.exe /C "cd /D C:\Arjun\WPM\Code\PlatformBootloader3\build_1\mcuboot\zephyr && C:\ncs\toolchains\31f4403e35\opt\bin\cmake.exe -E echo ""
c:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd.exe: zephyr/drivers/flash/libdrivers__flash.a(spi_nor.c.obj):(.rodata.spi_nor_config_0+0x0): undefined reference to `__device_dts_ord_141'
collect2.exe: error: ld returned 1 exit status
[162/183] Linking C executable zephyr\zephyr_pre0.elf
[166/183] Linking C executable zephyr\zephyr_pre1.elf
[171/183] Building C object zephyr/CMakeFiles/zephyr_final.dir/isr_tables.c.obj
FAILED: modules/mcuboot/mcuboot_subimage-prefix/src/mcuboot_subimage-stamp/mcuboot_subimage-build mcuboot/zephyr/zephyr.hex mcuboot/zephyr/zephyr.elf
cmd.exe /C "cd /D C:\Arjun\WPM\Code\PlatformBootloader3\build_1\mcuboot && C:\ncs\toolchains\31f4403e35\opt\bin\cmake.exe --build . --"
[173/183] Linking C executable zephyr\zephyr.elf
Memory region Used Size Region Size %age Used
FLASH: 23688 B 491008 B 4.82%
RAM: 6256 B 512 KB 1.19%
IDT_LIST: 0 GB 2 KB 0.00%
FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\31f4403e35\opt\bin\cmake.EXE' --build 'c:\Arjun\WPM\Code\PlatformBootloader3\build_1'
* The terminal process terminated with exit code: 1.
* Terminal will be reused by tasks, press any key to close it.
Meanwhile the same code builds properly if the build configuration selected is nrf5340DK_nrf5340_cpuapp.
