nrfutil completion install powershell
When executing:
The output suggests adding this to $PROFILE
# From nrfutil completion install
# WARNING: nrfutil tab-completion may become slow because of Windows Defender
if ( Test-Path -Path ${USERPROFILE}\.nrfutil\share\nrfutil-completion\scripts\powershell\setup.ps1 ) {
    . ${USERPROFILE}\.nrfutil\share\nrfutil-completion\scripts\powershell\setup.ps1
I did some debuging to find out why the tab-completion does not work.
If I am not wrong the variable ${USERPROFILE} should be $env:USERPROFILE.
At least on my system (Windows 11, PowerShell 7.4) that was the solution.
Am I doing something wrong?
    Where are nrfutil and .nrfutil located on your system, and where do you execute command "nrfutil completion install powershell" from?
    Could you provide more details about your solution?
    Dejan
  • I am just opening a PowerShell Terminal.
    This opens in my $HOME directory, C:\Useres\myuser
    This also the location of .nrfutil
    I installed nrfutil with:
    winget install NordicSemiconductor.nrfutil
    Get-Command -Name nrfutil
    CommandType     Name                                               Version    Source
    Application     nrfutil.exe                                        0.0.0.0    C:\Users\timur\AppData\Local\Microsoft\WinGet\Packages\NordicSemiconductor.nrfutil_Microsoft.Winget.Source_8wekyb3d8bbwe\nrfutil.exe
    This is my $PROFILE where I had to add the $USERPROFILE manualy.
    # Set USERPROFILE
    $USERPROFILE = $env:USERPROFILE
    Invoke-Expression -Command $(gh completion -s powershell | Out-String)
    # Aliases
    Set-Alias -Name ll -Value Get-ChildItem -Force
    # Powershell Modules
    Import-Module posh-git
    Set-PSReadlineKeyHandler -Key Tab -Function MenuComplete
    else {
        Write-Host "⚠️ The nrfutil completion script does not exist."
        exit
    Where is the location of your $PROFILE?
    Could you show the places where you needed to add $USERPROFILE manually?
    Dejan
  • echo $profile
    C:\Users\timur\OneDrive\Dokumente\PowerShell\Microsoft.PowerShell_profile.ps1
    I edited my last reply.
    Dejan
