Mesh Chat Model - Error Message = No free slots for new incoming segmented messages
We are getting this message on our RELAY - via PuTTY.
"No free slots for new incoming segmented messages"
uart:~$ [01:00:53.683,380] <wrn> bt_mesh_transport: trans_seg: No free slots for new incoming segmented messages
then >>>
ASSERTION FAIL @ WEST_TOPDIR/zephyr/lib/os/ring_buffer.c:73
We are getting this error - using CHAT MODEL in MESH.  The RELAY gives us this same error message - we have increased the CONFIG_BT_MESH_ADV_BUF_COUNT value from 13 to 50.
We read here >>>  "No free slots" error while sending message  that adding a timing delay may help.
We have not added a timing delay yet but lets say we use 0.1s between receiving and transmitting on to the proxy or the next Relay. Is this because of timing issues between the next available Tx slot being ready and the device being ready - or mistiming i should say.
How do we add a small delay?
We put this into our VS Code build - yes?
Please help if you can give us some information - many thanks.
We have nRF52840 BLE > nRF21540 DK as RELAY > nRF21540 DK as proxy.
Thanks - Richard
    I've had chat with my colleagues that are working now inbetween Christmas and New Years, but I will have to ask the Mesh team in January when they get back from vacation to see if I find something more conclusive with you.
    From what we've discussed so far it looks like these messages are "normal" messaging and are to be expected, but I can't state this with certainty. Are you able to locate where in the firmware said logs are coming from?
    Andreas
  • Hi Andreas, sorry for the delay. The error is coming when reading from a python script on a raspberry Pi with the Proxy connected.
    We have another problem.
    I flash xm122 devices using a XB122 (DK board) connected to a nrf52840DK board via a SWD cable.
    I have been using nrfProgrammer v4.01 with SEGGER JLink version JLink_MacOSX_V784b_universal.
    On opening the programmer->select device I see
    When JLink appears then the xm122 won't erase and write.
    It used to show this
    When it showed this NRF52840 I could flash the xm122 (which is connected to the XB122)
    If i update the programmer to v4.1.0 or v4.2.0 then I see the NRF52840 in the selected devices everytime but I also see this error
    11:12:36.377
    Using JLink version: JLink_V7.88j
    11:12:36.457
    Getting serialport options from persistent store 001050269628.pc-nrfconnect-programmer
    11:12:36.470
    Getting serialport options from persistent store 00480.pc-nrfconnect-programmer
    11:12:42.084
    Error: Failed with exit code 1. Failed to device info one or more devices: * 1050269628: [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink. Message: Operation device-info failed, [jlink] JLINKARM_DLL_ERROR.
    11:12:42.106
    Using nrfutil device to communicate with target via JLink
    11:12:42.740
    Reading readback protection status for Application core
    11:12:42.742
    Failed to reading readback protection status for application core core. Error: [object Object], message: Batch task protection-get failed, [jlink] JLINKARM_DLL_ERROR
    11:12:42.775
    Error: Failed with exit code 1. One or more batch tasks failed: - [jlink] JLINKARM_DLL_ERROR, code: Nrfjlink. Message: Batch task protection-get failed, [jlink] JLINKARM_DLL_ERROR.
    11:12:42.819
    I've installed different SEGGER JLink versions and still get this error.
  • In a terminal if I run
    nrfjprog --recover --log
    This is the log
    [2024-Jan-17 14:42:57] [debug] --------------------------------------------------------------------------------
    [2024-Jan-17 14:42:57] [debug] nrfjprog --recover --log
    [2024-Jan-17 14:42:57] [debug] nrfjprog version 10.18.1 external
    [2024-Jan-17 14:42:57] [ info] Load library at /Applications/Development/nrfCommandLine/lib/libnrfjprogdll.dylib.
    [2024-Jan-17 14:42:57] [ info] Library loaded, loading member functions.
    [2024-Jan-17 14:42:57] [ info] Member functions succesfully loaded.
    [2024-Jan-17 14:42:57] [debug] [ Client] - open
    [2024-Jan-17 14:42:57] [debug] [ Client] - start
    [2024-Jan-17 14:42:57] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 167ccaf4-9d85-4b90-a7cd-4161aaa7be7d.
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2024-Jan-17 14:42:57] [debug] [  JLink] - Logger sink registered in JLink logger
    [2024-Jan-17 14:42:57] [debug] [  nRFXX] - open
    [2024-Jan-17 14:42:57] [debug] [  nRFXX] - just_check_family
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - open_dll
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2024-Jan-17 14:42:57] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
    [2024-Jan-17 14:42:57] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2024-Jan-17 14:42:57] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - Set batch mode
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - dll_version
    [2024-Jan-17 14:42:57] [ info] [SeggerBackend] - Segger dll version 7.92.n loaded.
    [2024-Jan-17 14:42:57] [trace] [ Worker] - Command open executed for 5 milliseconds with result 0
    [2024-Jan-17 14:42:57] [trace] [ Client] - Command open executed for 12 milliseconds with result 0
    [2024-Jan-17 14:42:57] [debug] [ Client] - config
    [2024-Jan-17 14:42:57] [trace] [ Client] - Command config executed for 6 milliseconds with result 0
    [2024-Jan-17 14:42:57] [debug] [ Client] - enum_emu_snr
    [2024-Jan-17 14:42:57] [trace] [ Client] - Command enum_emu_con_info executed for 6 milliseconds with result 0
    [2024-Jan-17 14:42:57] [debug] [ Client] - connect_to_emu_with_snr
    [2024-Jan-17 14:42:57] [debug] [  nRFXX] - config
    [2024-Jan-17 14:42:57] [trace] [ Worker] - Command config executed for 1 milliseconds with result 0
    [2024-Jan-17 14:42:57] [debug] [  nRFXX] - enum_emu_con_info
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - enum_emu_con_info
    [2024-Jan-17 14:42:57] [trace] [ Worker] - Command enum_emu_con_info executed for 0 milliseconds with result 0
    [2024-Jan-17 14:42:57] [debug] [  nRFXX] - connect_to_emu_with_snr
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - ---just_get_num_emus
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - Segger logging enabled.
    [2024-Jan-17 14:42:57] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06
    [2024-Jan-17 14:42:57] [trace] [  JLink] - Hardware: V1.00
    [2024-Jan-17 14:42:57] [trace] [  JLink] - S/N: 1050234641
    [2024-Jan-17 14:42:57] [trace] [  JLink] - OEM: SEGGER
    [2024-Jan-17 14:42:57] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2024-Jan-17 14:42:57] [trace] [  JLink] - Bootloader: 2021 May 18
    [2024-Jan-17 14:42:57] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2024-Jan-17 14:42:57] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2024-Jan-17 14:42:57] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2024-Jan-17 14:42:57] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2024-Jan-17 14:42:57] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V792n/JLinkGUIServerExe
    [2024-Jan-17 14:42:57] [trace] [  JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V792n/JLinkGUIServerExe
    [2024-Jan-17 14:42:57] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.92n "
    [2024-Jan-17 14:42:57] [trace] [ Client] - Command connect_to_emu_with_snr executed for 313 milliseconds with result 0
    [2024-Jan-17 14:42:57] [debug] [ Client] - read_connected_emu_snr
    [2024-Jan-17 14:42:57] [trace] [ Client] - Command read_connected_emu_snr executed for 6 milliseconds with result 0
    [2024-Jan-17 14:42:57] [debug] [ Client] - read_device_family
    [2024-Jan-17 14:42:57] [trace] [ Client] - Command read_device_family executed for 5 milliseconds with result -6
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 290.222ms returns "O.K."
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_HasError()
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_Lock()
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.003ms returns 0x01
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.001ms returns 0x00
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.002ms returns 0x00
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.004ms returns 0
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.709ms returns 0x00
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2024-Jan-17 14:42:57] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.076ms
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_GetSpeed()
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.001ms returns 2000
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_GetSN()
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.003ms returns 1050234641
    [2024-Jan-17 14:42:57] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 303 milliseconds with result 0
    [2024-Jan-17 14:42:57] [debug] [  nRFXX] - read_connected_emu_snr
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.002ms returns 0x01
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - read_connected_emu_snr
    [2024-Jan-17 14:42:57] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2024-Jan-17 14:42:57] [debug] [  nRFXX] - read_device_family
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - read_debug_port_idr
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - read_debug_port_register
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - coresight_configure
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.167ms returns 0
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.542ms returns 0
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.251ms returns 0
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
    [2024-Jan-17 14:42:57] [trace] [  JLink] - Value=0x2BA01477
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.207ms returns 0
    [2024-Jan-17 14:42:57] [trace] [  JLink] - Value=0x03000077
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.214ms returns 0
    [2024-Jan-17 14:42:57] [error] [  nRFXX] - Device does not have an ARM debug port.
    [2024-Jan-17 14:42:57] [trace] [ Worker] - Command read_device_family executed for 1 milliseconds with result -6
    [2024-Jan-17 14:42:57] [debug] [  nRFXX] - close
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - close
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - disconnect_from_emu
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - is_connected_to_device
    [2024-Jan-17 14:42:57] [trace] [  JLink] - JLINK_IsConnected()
    [2024-Jan-17 14:42:57] [trace] [  JLink] - - 0.001ms returns FALSE
    [2024-Jan-17 14:42:57] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Jan-1[2024-Jan-17 14:43:17] [debug] --------------------------------------------------------------------------------
    [2024-Jan-17 14:43:17] [debug] nrfjprog --recover --log
    [2024-Jan-17 14:43:17] [debug] nrfjprog version 10.18.1 external
    [2024-Jan-17 14:43:17] [ info] Load library at /Applications/Development/nrfCommandLine/lib/libnrfjprogdll.dylib.
    [2024-Jan-17 14:43:17] [ info] Library loaded, loading member functions.
    [2024-Jan-17 14:43:17] [ info] Member functions succesfully loaded.
    [2024-Jan-17 14:43:17] [debug] [ Client] - open
    [2024-Jan-17 14:43:17] [debug] [ Client] - start
    [2024-Jan-17 14:43:17] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 81384353-1821-4b1d-a5c1-683070bbf8f8.
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2024-Jan-17 14:43:17] [debug] [  JLink] - Logger sink registered in JLink logger
    [2024-Jan-17 14:43:17] [debug] [  nRFXX] - open
    [2024-Jan-17 14:43:17] [debug] [  nRFXX] - just_check_family
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - open_dll
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2024-Jan-17 14:43:17] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
    [2024-Jan-17 14:43:17] [trace] [ Client] - Command open executed for 31 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [ Client] - config
    [2024-Jan-17 14:43:17] [trace] [ Client] - Command config executed for 6 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [ Client] - enum_emu_snr
    [2024-Jan-17 14:43:17] [trace] [ Client] - Command enum_emu_con_info executed for 6 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [ Client] - connect_to_emu_with_snr
    [2024-Jan-17 14:43:17] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2024-Jan-17 14:43:17] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - Set batch mode
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - dll_version
    [2024-Jan-17 14:43:17] [ info] [SeggerBackend] - Segger dll version 7.92.n loaded.
    [2024-Jan-17 14:43:17] [trace] [ Worker] - Command open executed for 17 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [  nRFXX] - config
    [2024-Jan-17 14:43:17] [trace] [ Worker] - Command config executed for 3 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [  nRFXX] - enum_emu_con_info
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - enum_emu_con_info
    [2024-Jan-17 14:43:17] [trace] [ Worker] - Command enum_emu_con_info executed for 0 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [  nRFXX] - connect_to_emu_with_snr
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---just_get_num_emus
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - Segger logging enabled.
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Hardware: V1.00
    [2024-Jan-17 14:43:17] [trace] [  JLink] - S/N: 1050234641
    [2024-Jan-17 14:43:17] [trace] [  JLink] - OEM: SEGGER
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Bootloader: 2021 May 18
    [2024-Jan-17 14:43:17] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2024-Jan-17 14:43:17] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V792n/JLinkGUIServerExe
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V792n/JLinkGUIServerExe
    [2024-Jan-17 14:43:17] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.92n "
    [2024-Jan-17 14:43:17] [trace] [ Client] - Command connect_to_emu_with_snr executed for 327 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [ Client] - read_connected_emu_snr
    [2024-Jan-17 14:43:17] [trace] [ Client] - Command read_connected_emu_snr executed for 5 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [ Client] - read_device_family
    [2024-Jan-17 14:43:17] [trace] [ Client] - Command read_device_family executed for 6 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [ Client] - select_family
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 304.159ms returns "O.K."
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_HasError()
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_Lock()
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.170ms returns 0x01
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.000ms returns 0x00
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.008ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 1.045ms returns 0x00
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2024-Jan-17 14:43:17] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.004ms
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.291ms
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_GetSpeed()
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.001ms returns 2000
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_GetSN()
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.003ms returns 1050234641
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.002ms
    [2024-Jan-17 14:43:17] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 322 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [  nRFXX] - read_connected_emu_snr
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.007ms returns 0x01
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - read_connected_emu_snr
    [2024-Jan-17 14:43:17] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [  nRFXX] - read_device_family
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.003ms returns 0x01
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - read_debug_port_idr
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - read_debug_port_register
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - coresight_configure
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.209ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.392ms returns 0
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.194ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Value=0x2B000077
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.222ms returns 0
    [2024-Jan-17 14:43:17] [trace] [ Client] - Command select_family executed for 12 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [ Client] - recover
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Value=0x2BA01477
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.214ms returns 0
    [2024-Jan-17 14:43:17] [ info] [  nRFXX] - Discovered device from family NRF52.
    [2024-Jan-17 14:43:17] [trace] [ Worker] - Command read_device_family executed for 1 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - set_core_data
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - Set core data:
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] -   Device ID: nRF52
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] -   Expected core: 234881279
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] -   Existing Expected core: 4294967295
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] -   Coprocessor: APPLICATION
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] -   AHB AP index: 0
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] -   Core base address: 4294967295
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---set_coresight_ahb_ap_index
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_ExecCommand("device = nRF52", ...).
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Device "NRF52" selected.
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 1.095ms returns 0x00
    [2024-Jan-17 14:43:17] [trace] [ Worker] - Command select_family executed for 1 milliseconds with result 0
    [2024-Jan-17 14:43:17] [debug] [  nRF52] - recover
    [2024-Jan-17 14:43:17] [debug] [  nRF52] - Just_recover
    [2024-Jan-17 14:43:17] [debug] [  nRF52] - Just_is_ctrl_ap_available
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - read_access_port_register
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.228ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Value=0xF0000000
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.211ms returns 0
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.188ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Value=0x02880000
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.207ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.204ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.225ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - Value=0x02080000
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.270ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.256ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.231ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.260ms returns 0
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - write_access_port_register
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2024-Jan-17 14:43:17] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.186ms returns 0
    [2024-Jan-17 14:43:17] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
    [2024-Jan-17 14:43:17] [trace] [  JLink] - - 0.180ms returns 0
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - read_access_port_register
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Value=0x00000001
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.696ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_HasError()
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Value=0x00000000
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.736ms returns 0
    [2024-Jan-17 14:43:18] [debug] [  nRF52] - Just_debug_reset
    [2024-Jan-17 14:43:18] [debug] [  nRF52] - Just_is_ctrl_ap_available
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.326ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Value=0x02880000
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.311ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Value=0x00880000
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.299ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.269ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.259ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.249ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.263ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.248ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.242ms returns 0
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - write_access_port_register
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.417ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.282ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.784ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.332ms returns 0
    [2024-Jan-17 14:43:18] [debug] [  nRF52] - Just_readback_status
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.402ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.305ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.356ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.323ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.301ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.324ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.300ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.283ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.347ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.284ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.252ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.247ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.276ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.255ms returns 0
    [2024-Jan-17 14:43:18] [ info] [  nRF52] - Protection status read as NONE
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.219ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.246ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Value=0x00080000
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.298ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.270ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.266ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.261ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.258ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.274ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.313ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.264ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.416ms returns 0
    [2024-Jan-17 14:43:18] [debug] [  nRF52] - Just_read_device_version
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.260ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.257ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.271ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.224ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.331ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.239ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.256ms returns 0
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - read_u32
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_connect_to_device
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - is_connected_to_device
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---set_coresight_ahb_ap_index
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.002ms returns 0x00
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_ExecCommand("device = nRF52", ...).
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Device "NRF52" selected.
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 1.751ms returns 0x00
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_Connect()
    [2024-Jan-17 14:43:18] [trace] [  JLink] - InitTarget() start
    [2024-Jan-17 14:43:18] [trace] [  JLink] -  J-Link Script File: Executing InitTarget()
    [2024-Jan-17 14:43:18] [trace] [  JLink] - InitTarget() end - Took 2.48ms
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Found SW-DP with ID 0x2BA01477
    [2024-Jan-17 14:43:18] [trace] [  JLink] - DPIDR: 0x2BA01477
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CoreSight SoC-400 or earlier
    [2024-Jan-17 14:43:18] [trace] [  JLink] - AP map detection skipped. Manually configured AP map found.
    [2024-Jan-17 14:43:18] [trace] [  JLink] - AP[0]: AHB-AP (IDR: Not set)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - AP[0]: Core found
    [2024-Jan-17 14:43:18] [trace] [  JLink] - AP[0]: AHB-AP ROM base: 0xE00FF000
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Found Cortex-M4 r0p1, Little endian.
    [2024-Jan-17 14:43:18] [trace] [  JLink] - -- Max. mem block: 0x0003C600
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE000EDF0)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000EDF0)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE0002000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - FPUnit: 6 code (BP) slots and 2 literal slots
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE000EDFC)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000EDFC)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE0001000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE0001000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE000ED88)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000ED88)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CoreSight components:
    [2024-Jan-17 14:43:18] [trace] [  JLink] - ROMTbl[0] @ E00FF000
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(64 bytes @ 0xE00FF000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xE000EFE0)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - [0][0]: E000E000 CID B105E00D PID 000BB00C SCS-M7
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xE0001FE0)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - [0][1]: E0001000 CID B105E00D PID 003BB002 DWT
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xE0002FE0)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - [0][2]: E0002000 CID B105E00D PID 002BB003 FPB
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xE0000FE0)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - [0][3]: E0000000 CID B105E00D PID 003BB001 ITM
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xDFF40FE0)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - [0][4]: DFF40000 CID 00000000 PID 00000000 ???
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xE0041FE0)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - [0][5]: E0041000 CID A105800D PID 000B3925 ???
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 20.061ms returns 0x00
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_CORE_GetFound()
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.003ms returns 0xE0000FF
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_read_u32
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_invalidate_cache
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_ExecCommand("InvalidateCache", ...).
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.371ms returns 0x00
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_ReadMemU32(0x10000130, 0x1 Items)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0x10000130)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Data:  08 00 00 00
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.385ms returns 1 (0x1)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.003ms returns 0x00
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_ReadMemU32(0x10000134, 0x1 Items)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0x10000134)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Data:  03 00 00 00
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.363ms returns 1 (0x1)
    [2024-Jan-17 14:43:18] [debug] [  nRF52] - Just_decode_device_version
    [2024-Jan-17 14:43:18] [debug] [  nRF52] - Device identified as NRF52840_xxAA_REV2
    [2024-Jan-17 14:43:18] [debug] [  nRF52] - write_approtect
    [2024-Jan-17 14:43:18] [debug] [  nRF52] - NRF52840 REV2 does not implement updated APPROTECT mechanism.
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - halt
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_halt
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_Halt()
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 3.484ms returns 0x00
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - sys_reset
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.363ms returns 0x00
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_sys_reset
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_SetResetType(JLINKARM_CM3_RESET_TYPE_NORMAL)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.005ms returns JLINKARM_CM3_RESET_TYPE_NORMAL
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_Reset()
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2024-Jan-17 14:43:18] [trace] [  JLink] - Reset: Reset device via AIRCR.SYSRESETREQ.
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000ED0C)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE0002000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 72.725ms
    [2024-Jan-17 14:43:18] [debug] [  nRF52] - Just_power_ram_all
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - Select AP 1, DP Bank 255, AP Bank 15
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.275ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.285ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.268ms returns 0
    [2024-Jan-17 14:43:18] [trace] [ Client] - Command recover executed for 1186 milliseconds with result 0
    [2024-Jan-17 14:43:18] [debug] [ Client] - read_device_info
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.366ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.312ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.483ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.292ms returns 0
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - write_u32
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_write_u32
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_write_debug_port_register
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Jan-17 14:43:18] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.234ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.240ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_WriteU32_64(0x40000904, 0x0000FFFF)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000904)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 1.503ms returns 0 (0x00000000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.245ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_WriteU32_64(0x40000914, 0x0000FFFF)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000914)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.376ms returns 0 (0x00000000)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.243ms returns 0
    [2024-Jan-17 14:43:18] [trace] [  JLink] - JLINK_WriteU32_64(0x40000924, 0x0000FFFF)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000924)
    [2024-Jan-17 14:43:18] [trace] [  JLink] - - 0.410ms returns 0 (0x00000000)
    [2024-Jan-17 14:43:18] [trace] [ Client] - Command read_device_info executed for 12 milliseconds with result 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.249ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_HasError()
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.230ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_WriteU32_64(0x40000934, 0x0000FFFF)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000934)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.375ms returns 0 (0x00000000)
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - write_u32
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_connect_to_device
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - is_connected_to_device
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_write_u32
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_write_debug_port_register
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.238ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.241ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_WriteU32_64(0x40000944, 0x0000FFFF)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000944)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.363ms returns 0 (0x00000000)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.233ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.234ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_WriteU32_64(0x40000954, 0x0000FFFF)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000954)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.378ms returns 0 (0x00000000)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.242ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_WriteU32_64(0x40000964, 0x0000FFFF)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000964)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.393ms returns 0 (0x00000000)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.291ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_WriteU32_64(0x40000974, 0x0000FFFF)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000974)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.396ms returns 0 (0x00000000)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.288ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.268ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_WriteU32_64(0x40000984, 0x0000FFFF)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000984)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.385ms returns 0 (0x00000000)
    [2024-Jan-17 14:43:19] [debug] [  nRF52] - Just_clear_resetreas
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.287ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.266ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_WriteU32_64(0x40000400, 0xFFFFFFFF)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000400)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.003ms
    [2024-Jan-17 14:43:19] [trace] [ Worker] - Command recover executed for 1181 milliseconds with result 0
    [2024-Jan-17 14:43:19] [debug] [  nRF52] - read_device_info
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.014ms returns 0x01
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_Lock()
    [2024-Jan-17 14:43:19] [debug] [  nRF52] - Just_read_device_version
    [2024-Jan-17 14:43:19] [debug] [  nRF52] - Just_readback_status
    [2024-Jan-17 14:43:19] [debug] [  nRF52] - Just_is_ctrl_ap_available
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - read_access_port_register
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.507ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - Value=0xF0000040
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.256ms returns 0
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.215ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - Value=0x02880000
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.237ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.244ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.209ms returns 0
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.195ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - Value=0x00000000
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.222ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - Value=0x00000001
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.289ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.218ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.220ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.243ms returns 0
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.250ms returns 0
    [2024-Jan-17 14:43:19] [ info] [  nRF52] - Protection status read as NONE
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - read_u32
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_IsConnected()
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.003ms returns TRUE
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_read_u32
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_invalidate_cache
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_ExecCommand("InvalidateCache", ...).
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.003ms returns 0x00
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_ReadMemU32(0x10000130, 0x1 Items)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0x10000130)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - Data:  08 00 00 00
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.375ms returns 1 (0x1)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_ReadMemU32(0x10000134, 0x1 Items)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0x10000134)
    [2024-Jan-17 14:43:19] [trace] [  JLink] - Data:  03 00 00 00
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.349ms returns 1 (0x1)
    [2024-Jan-17 14:43:19] [debug] [  nRF52] - Just_decode_device_version
    [2024-Jan-17 14:43:19] [debug] [  nRF52] - Device identified as NRF52840_xxAA_REV2
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.043ms
    [2024-Jan-17 14:43:19] [trace] [ Worker] - Command read_device_info executed for 5 milliseconds with result 0
    [2024-Jan-17 14:43:19] [debug] [  nRF52] - close
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.010ms returns 0x01
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - close
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - disconnect_from_emu
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.002ms returns TRUE
    [2024-Jan-17 14:43:19] [trace] [  JLink] - - 0.293ms returns 0
    [2024-Jan-17 14:43:19] [debug] [SeggerBackend] - Disable trace before closing connection.
    [2024-Jan-17 14:43:19] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg([2024-Jan-17 14:44:00] [debug] --------------------------------------------------------------------------------
    [2024-Jan-17 14:44:00] [debug] nrfjprog --recover --log
    [2024-Jan-17 14:44:00] [debug] nrfjprog version 10.18.1 external
    [2024-Jan-17 14:44:00] [ info] Load library at /Applications/Development/nrfCommandLine/lib/libnrfjprogdll.dylib.
    [2024-Jan-17 14:44:00] [ info] Library loaded, loading member functions.
    [2024-Jan-17 14:44:00] [ info] Member functions succesfully loaded.
    [2024-Jan-17 14:44:00] [debug] [ Client] - open
    [2024-Jan-17 14:44:00] [debug] [ Client] - start
    [2024-Jan-17 14:44:00] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence fc65be9f-e448-4450-b775-0526a4a9b666.
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2024-Jan-17 14:44:00] [debug] [  JLink] - Logger sink registered in JLink logger
    [2024-Jan-17 14:44:00] [debug] [  nRFXX] - open
    [2024-Jan-17 14:44:00] [debug] [  nRFXX] - just_check_family
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - open_dll
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2024-Jan-17 14:44:00] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
    [2024-Jan-17 14:44:00] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2024-Jan-17 14:44:00] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - Set batch mode
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - dll_version
    [2024-Jan-17 14:44:00] [ info] [SeggerBackend] - Segger dll version 7.92.n loaded.
    [2024-Jan-17 14:44:00] [trace] [ Worker] - Command open executed for 5 milliseconds with result 0
    [2024-Jan-17 14:44:00] [trace] [ Client] - Command open executed for 12 milliseconds with result 0
    [2024-Jan-17 14:44:00] [debug] [ Client] - config
    [2024-Jan-17 14:44:00] [trace] [ Client] - Command config executed for 6 milliseconds with result 0
    [2024-Jan-17 14:44:00] [debug] [ Client] - enum_emu_snr
    [2024-Jan-17 14:44:00] [trace] [ Client] - Command enum_emu_con_info executed for 6 milliseconds with result 0
    [2024-Jan-17 14:44:00] [debug] [ Client] - connect_to_emu_with_snr
    [2024-Jan-17 14:44:00] [debug] [  nRFXX] - config
    [2024-Jan-17 14:44:00] [trace] [ Worker] - Command config executed for 1 milliseconds with result 0
    [2024-Jan-17 14:44:00] [debug] [  nRFXX] - enum_emu_con_info
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - enum_emu_con_info
    [2024-Jan-17 14:44:00] [trace] [ Worker] - Command enum_emu_con_info executed for 0 milliseconds with result 0
    [2024-Jan-17 14:44:00] [debug] [  nRFXX] - connect_to_emu_with_snr
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - ---just_get_num_emus
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2024-Jan-17 14:44:00] [debug] [SeggerBackend] - Segger logging enabled.
    [2024-Jan-17 14:44:00] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06
    [2024-Jan-17 14:44:01] [trace] [  JLink] - Hardware: V1.00
    [2024-Jan-17 14:44:01] [trace] [  JLink] - S/N: 1050234641
    [2024-Jan-17 14:44:01] [trace] [  JLink] - OEM: SEGGER
    [2024-Jan-17 14:44:01] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2024-Jan-17 14:44:01] [trace] [  JLink] - Bootloader: 2021 May 18
    [2024-Jan-17 14:44:01] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2024-Jan-17 14:44:01] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2024-Jan-17 14:44:01] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V792n/JLinkGUIServerExe
    [2024-Jan-17 14:44:01] [trace] [  JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V792n/JLinkGUIServerExe
    [2024-Jan-17 14:44:01] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.92n "
    [2024-Jan-17 14:44:01] [trace] [ Client] - Command connect_to_emu_with_snr executed for 356 milliseconds with result 0
    [2024-Jan-17 14:44:01] [debug] [ Client] - read_connected_emu_snr
    [2024-Jan-17 14:44:01] [trace] [ Client] - Command read_connected_emu_snr executed for 6 milliseconds with result 0
    [2024-Jan-17 14:44:01] [debug] [ Client] - read_device_family
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 334.446ms returns "O.K."
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_HasError()
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_Lock()
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.005ms returns 0x01
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.001ms returns 0x00
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.000ms returns 0x00
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.004ms returns 0
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.640ms returns 0x00
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2024-Jan-17 14:44:01] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.086ms
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_GetSpeed()
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.001ms returns 2000
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_GetSN()
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.002ms returns 1050234641
    [2024-Jan-17 14:44:01] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 347 milliseconds with result 0
    [2024-Jan-17 14:44:01] [debug] [  nRFXX] - read_connected_emu_snr
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.003ms returns 0x01
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - read_connected_emu_snr
    [2024-Jan-17 14:44:01] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2024-Jan-17 14:44:01] [trace] [ Client] - Command read_device_family executed for 12 milliseconds with result 0
    [2024-Jan-17 14:44:01] [debug] [ Client] - select_family
    [2024-Jan-17 14:44:01] [trace] [ Client] - Command select_family executed for 5 milliseconds with result 0
    [2024-Jan-17 14:44:01] [debug] [ Client] - recover
    [2024-Jan-17 14:44:01] [debug] [  nRFXX] - read_device_family
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - read_debug_port_idr
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - read_debug_port_register
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - coresight_configure
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 2.047ms returns 0
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.388ms returns 0
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.193ms returns 0
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - Value=0x2BA01477
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.194ms returns 0
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.207ms returns 0
    [2024-Jan-17 14:44:01] [ info] [  nRFXX] - Discovered device from family NRF52.
    [2024-Jan-17 14:44:01] [trace] [ Worker] - Command read_device_family executed for 3 milliseconds with result 0
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - set_core_data
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - Set core data:
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] -   Device ID: nRF52
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] -   Expected core: 234881279
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] -   Existing Expected core: 4294967295
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] -   Coprocessor: APPLICATION
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] -   AHB AP index: 0
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] -   Core base address: 4294967295
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - ---set_coresight_ahb_ap_index
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_ExecCommand("device = nRF52", ...).
    [2024-Jan-17 14:44:01] [trace] [  JLink] - Device "NRF52" selected.
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.831ms returns 0x00
    [2024-Jan-17 14:44:01] [trace] [ Worker] - Command select_family executed for 0 milliseconds with result 0
    [2024-Jan-17 14:44:01] [debug] [  nRF52] - recover
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.002ms returns 0x01
    [2024-Jan-17 14:44:01] [debug] [  nRF52] - Just_recover
    [2024-Jan-17 14:44:01] [debug] [  nRF52] - Just_is_ctrl_ap_available
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - read_access_port_register
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.216ms returns 0
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - Value=0xF0000000
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.195ms returns 0
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.164ms returns 0
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - Value=0x02880000
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.197ms returns 0
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.226ms returns 0
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - write_access_port_register
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2024-Jan-17 14:44:01] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.162ms returns 0
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.171ms returns 0
    [2024-Jan-17 14:44:01] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2024-Jan-17 14:44:01] [trace] [  JLink] - Value=0x00000001
    [2024-Jan-17 14:44:01] [trace] [  JLink] - - 0.657ms returns 0
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - read_access_port_register
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Value=0x00000000
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.671ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_HasError()
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - Just_debug_reset
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - Just_is_ctrl_ap_available
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.318ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Value=0x02880000
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.310ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.266ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.250ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.247ms returns 0
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - write_access_port_register
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.291ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.230ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 1.847ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.315ms returns 0
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - Just_readback_status
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.498ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.267ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.249ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.328ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.223ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Value=0x00000001
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.256ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.242ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.248ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.253ms returns 0
    [2024-Jan-17 14:44:02] [ info] [  nRF52] - Protection status read as NONE
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.216ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.254ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.515ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.338ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.258ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.251ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.378ms returns 0
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - Just_read_device_version
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.379ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Value=0x00080000
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.305ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.261ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.269ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.263ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.257ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.217ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.255ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.282ms returns 0
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - read_u32
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_connect_to_device
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - is_connected_to_device
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---set_coresight_ahb_ap_index
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.002ms returns 0x00
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_ExecCommand("device = nRF52", ...).
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Device "NRF52" selected.
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 1.673ms returns 0x00
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_Connect()
    [2024-Jan-17 14:44:02] [trace] [  JLink] - InitTarget() start
    [2024-Jan-17 14:44:02] [trace] [  JLink] -  J-Link Script File: Executing InitTarget()
    [2024-Jan-17 14:44:02] [trace] [  JLink] - InitTarget() end - Took 2.15ms
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Found SW-DP with ID 0x2BA01477
    [2024-Jan-17 14:44:02] [trace] [  JLink] - DPIDR: 0x2BA01477
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CoreSight SoC-400 or earlier
    [2024-Jan-17 14:44:02] [trace] [  JLink] - AP map detection skipped. Manually configured AP map found.
    [2024-Jan-17 14:44:02] [trace] [  JLink] - AP[0]: AHB-AP (IDR: Not set)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - AP[0]: Core found
    [2024-Jan-17 14:44:02] [trace] [  JLink] - AP[0]: AHB-AP ROM base: 0xC00FF000
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Found Cortex-M4 r0p1, Little endian.
    [2024-Jan-17 14:44:02] [trace] [  JLink] - -- Max. mem block: 0x0003C600
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE000EDF0)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000EDF0)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE0002000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - FPUnit: 6 code (BP) slots and 2 literal slots
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE000EDFC)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000EDFC)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE0001000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE0001000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE000ED88)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000ED88)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CoreSight components:
    [2024-Jan-17 14:44:02] [trace] [  JLink] - ROMTbl[0] @ C00FF000
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_ReadMem(64 bytes @ 0xC00FF000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 13.196ms returns 0x00
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_CORE_GetFound()
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.002ms returns 0xE0000FF
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_read_u32
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_invalidate_cache
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_ExecCommand("InvalidateCache", ...).
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.013ms returns 0x00
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_ReadMemU32(0x10000130, 0x1 Items)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0x10000130)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Data:  08 00 00 00
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.430ms returns 1 (0x1)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.003ms returns 0x00
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_ReadMemU32(0x10000134, 0x1 Items)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0x10000134)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Data:  03 00 00 00
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.383ms returns 1 (0x1)
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - Just_decode_device_version
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - Device identified as NRF52840_xxAA_REV2
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - write_approtect
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - NRF52840 REV2 does not implement updated APPROTECT mechanism.
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - halt
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_halt
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_Halt()
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 3.845ms returns 0x00
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - sys_reset
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.387ms returns 0x00
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_sys_reset
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_SetResetType(JLINKARM_CM3_RESET_TYPE_NORMAL)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.007ms returns JLINKARM_CM3_RESET_TYPE_NORMAL
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_Reset()
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Reset: Reset device via AIRCR.SYSRESETREQ.
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000ED0C)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE0002000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 72.053ms
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - Just_power_ram_all
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - Select AP 1, DP Bank 255, AP Bank 15
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.271ms returns 0
    [2024-Jan-17 14:44:02] [trace] [ Client] - Command recover executed for 1177 milliseconds with result 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.296ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Value=0x00800000
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.294ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.311ms returns 0
    [2024-Jan-17 14:44:02] [debug] [ Client] - read_device_info
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.283ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.319ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.300ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.287ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.312ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.308ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.322ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.264ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.237ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.293ms returns 0
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - write_u32
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_write_u32
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_write_debug_port_register
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.281ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.226ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_WriteU32_64(0x40000904, 0x0000FFFF)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000904)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 1.059ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.259ms returns 0
    [2024-Jan-17 14:44:02] [trace] [ Client] - Command read_device_info executed for 12 milliseconds with result 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_WriteU32_64(0x40000914, 0x0000FFFF)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000914)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.400ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.265ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_WriteU32_64(0x40000924, 0x0000FFFF)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000924)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.378ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_WriteU32_64(0x40000934, 0x0000FFFF)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000934)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.422ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_WriteU32_64(0x40000944, 0x0000FFFF)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000944)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.430ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_WriteU32_64(0x40000954, 0x0000FFFF)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000954)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.404ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_WriteU32_64(0x40000964, 0x0000FFFF)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000964)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.374ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.252ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_WriteU32_64(0x40000974, 0x0000FFFF)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000974)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.360ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.260ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_WriteU32_64(0x40000984, 0x0000FFFF)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000984)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.408ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - Just_clear_resetreas
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.278ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.284ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_WriteU32_64(0x40000400, 0xFFFFFFFF)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000400)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.391ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.011ms
    [2024-Jan-17 14:44:02] [trace] [ Worker] - Command recover executed for 1170 milliseconds with result 0
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - read_device_info
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.003ms returns 0x01
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_Lock()
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.298ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - Value=0xF0000040
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.275ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.274ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.272ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.280ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.289ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.276ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_IsConnected()
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.003ms returns TRUE
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.389ms returns 1 (0x1)
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.037ms
    [2024-Jan-17 14:44:02] [trace] [ Worker] - Command read_device_info executed for 4 milliseconds with result 0
    [2024-Jan-17 14:44:02] [debug] [  nRF52] - close
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.013ms returns 0x01
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - close
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - disconnect_from_emu
    [2024-Jan-17 14:44:02] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.007ms returns TRUE
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.452ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - - 0.301ms returns 0
    [2024-Jan-17 14:44:02] [trace] [  JLink] - JLINK_HasEr[2024-Jan-17 14:44:39] [debug] --------------------------------------------------------------------------------
    [2024-Jan-17 14:44:39] [debug] nrfjprog --recover --log
    [2024-Jan-17 14:44:39] [debug] nrfjprog version 10.18.1 external
    [2024-Jan-17 14:44:39] [ info] Load library at /Applications/Development/nrfCommandLine/lib/libnrfjprogdll.dylib.
    [2024-Jan-17 14:44:39] [ info] Library loaded, loading member functions.
    [2024-Jan-17 14:44:39] [ info] Member functions succesfully loaded.
    [2024-Jan-17 14:44:39] [debug] [ Client] - open
    [2024-Jan-17 14:44:39] [debug] [ Client] - start
    [2024-Jan-17 14:44:39] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 381125f8-34d5-4cb8-b336-1e9bc609a144.
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2024-Jan-17 14:44:39] [debug] [  JLink] - Logger sink registered in JLink logger
    [2024-Jan-17 14:44:39] [debug] [  nRFXX] - open
    [2024-Jan-17 14:44:39] [debug] [  nRFXX] - just_check_family
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - open_dll
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2024-Jan-17 14:44:39] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
    [2024-Jan-17 14:44:39] [trace] [ Client] - Command open executed for 24 milliseconds with result 0
    [2024-Jan-17 14:44:39] [debug] [ Client] - config
    [2024-Jan-17 14:44:39] [trace] [ Client] - Command config executed for 12 milliseconds with result 0
    [2024-Jan-17 14:44:39] [debug] [ Client] - enum_emu_snr
    [2024-Jan-17 14:44:39] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2024-Jan-17 14:44:39] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - Set batch mode
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - dll_version
    [2024-Jan-17 14:44:39] [ info] [SeggerBackend] - Segger dll version 7.92.n loaded.
    [2024-Jan-17 14:44:39] [trace] [ Worker] - Command open executed for 15 milliseconds with result 0
    [2024-Jan-17 14:44:39] [debug] [  nRFXX] - config
    [2024-Jan-17 14:44:39] [trace] [ Worker] - Command config executed for 3 milliseconds with result 0
    [2024-Jan-17 14:44:39] [trace] [ Client] - Command enum_emu_con_info executed for 6 milliseconds with result 0
    [2024-Jan-17 14:44:39] [debug] [ Client] - connect_to_emu_with_snr
    [2024-Jan-17 14:44:39] [debug] [  nRFXX] - enum_emu_con_info
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - enum_emu_con_info
    [2024-Jan-17 14:44:39] [trace] [ Worker] - Command enum_emu_con_info executed for 0 milliseconds with result 0
    [2024-Jan-17 14:44:39] [debug] [  nRFXX] - connect_to_emu_with_snr
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - ---just_get_num_emus
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2024-Jan-17 14:44:39] [debug] [SeggerBackend] - Segger logging enabled.
    [2024-Jan-17 14:44:39] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Hardware: V1.00
    [2024-Jan-17 14:44:40] [trace] [  JLink] - S/N: 1050234641
    [2024-Jan-17 14:44:40] [trace] [  JLink] - OEM: SEGGER
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Bootloader: 2021 May 18
    [2024-Jan-17 14:44:40] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2024-Jan-17 14:44:40] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V792n/JLinkGUIServerExe
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V792n/JLinkGUIServerExe
    [2024-Jan-17 14:44:40] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.92n "
    [2024-Jan-17 14:44:40] [trace] [ Client] - Command connect_to_emu_with_snr executed for 348 milliseconds with result 0
    [2024-Jan-17 14:44:40] [debug] [ Client] - read_connected_emu_snr
    [2024-Jan-17 14:44:40] [trace] [ Client] - Command read_connected_emu_snr executed for 6 milliseconds with result 0
    [2024-Jan-17 14:44:40] [debug] [ Client] - read_device_family
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 326.656ms returns "O.K."
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_HasError()
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_Lock()
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.157ms returns 0x01
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.001ms returns 0x00
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2024-Jan-17 14:44:40] [trace] [ Client] - Command read_device_family executed for 6 milliseconds with result 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.004ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.771ms returns 0x00
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2024-Jan-17 14:44:40] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.003ms
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.259ms
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_GetSpeed()
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.001ms returns 2000
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_GetSN()
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.003ms returns 1050234641
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.002ms
    [2024-Jan-17 14:44:40] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 345 milliseconds with result 0
    [2024-Jan-17 14:44:40] [debug] [  nRFXX] - read_connected_emu_snr
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.011ms returns 0x01
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - read_connected_emu_snr
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.006ms
    [2024-Jan-17 14:44:40] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2024-Jan-17 14:44:40] [debug] [ Client] - select_family
    [2024-Jan-17 14:44:40] [trace] [ Client] - Command select_family executed for 12 milliseconds with result 0
    [2024-Jan-17 14:44:40] [debug] [ Client] - recover
    [2024-Jan-17 14:44:40] [debug] [  nRFXX] - read_device_family
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.004ms returns 0x01
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - read_debug_port_idr
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - read_debug_port_register
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - coresight_configure
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.141ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.402ms returns 0
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.195ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x00)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Value=0x2BA01477
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.219ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.209ms returns 0
    [2024-Jan-17 14:44:40] [ info] [  nRFXX] - Discovered device from family NRF52.
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.005ms
    [2024-Jan-17 14:44:40] [trace] [ Worker] - Command read_device_family executed for 1 milliseconds with result 0
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - set_core_data
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - Set core data:
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] -   Device ID: nRF52
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] -   Expected core: 234881279
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] -   Existing Expected core: 4294967295
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] -   Coprocessor: APPLICATION
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] -   AHB AP index: 0
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] -   Core base address: 4294967295
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - ---set_coresight_ahb_ap_index
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_ExecCommand("device = nRF52", ...).
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Device "NRF52" selected.
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 1.293ms returns 0x00
    [2024-Jan-17 14:44:40] [trace] [ Worker] - Command select_family executed for 1 milliseconds with result 0
    [2024-Jan-17 14:44:40] [debug] [  nRF52] - recover
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.005ms returns 0x01
    [2024-Jan-17 14:44:40] [debug] [  nRF52] - Just_recover
    [2024-Jan-17 14:44:40] [debug] [  nRF52] - Just_is_ctrl_ap_available
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - read_access_port_register
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.239ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Value=0xF0000000
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.262ms returns 0
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.223ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Value=0x02880000
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.299ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Value=0x02800000
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.238ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.237ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.252ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.230ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.214ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.260ms returns 0
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - write_access_port_register
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2024-Jan-17 14:44:40] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.202ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000001)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 0.187ms returns 0
    [2024-Jan-17 14:44:40] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2024-Jan-17 14:44:40] [trace] [  JLink] - Value=0x00000001
    [2024-Jan-17 14:44:40] [trace] [  JLink] - - 2.042ms returns 0
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - read_access_port_register
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_select_access_port_register
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x02)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Value=0x00000000
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 1.867ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_HasError()
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - Just_debug_reset
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - Just_is_ctrl_ap_available
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 15
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x010000F0)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.347ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(AP reg 0x03)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.313ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Value=0x02880000
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.299ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.314ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.294ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.309ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Value=0x02000000
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.307ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.287ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.260ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.254ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.247ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.258ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.249ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Value=0x02800000
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.281ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.327ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Value=0x00080000
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.302ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.276ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.344ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.266ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.259ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.267ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Value=0x00880000
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.273ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.275ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.278ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.265ms returns 0
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - write_access_port_register
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_write_access_port_register
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - Select AP 1, DP Bank 0, AP Bank 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x01000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.244ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000001)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.232ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x00, 0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 1.540ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(AP reg 0x01, 0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.374ms returns 0
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - Just_readback_status
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.516ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.312ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.317ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.300ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.316ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.308ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Value=0x02080000
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.296ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.401ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.240ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.280ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.261ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.284ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.283ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.282ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.303ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.269ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Value=0x00000001
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.331ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.277ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.271ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.263ms returns 0
    [2024-Jan-17 14:44:41] [ info] [  nRF52] - Protection status read as NONE
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.241ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.274ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.397ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.305ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.268ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.242ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.285ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 1.498ms returns 0
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - Just_read_device_version
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.392ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.289ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.279ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.286ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.270ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.301ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.288ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.272ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.257ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.310ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.251ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.328ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.264ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.262ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.333ms returns 0
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - read_u32
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_connect_to_device
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - is_connected_to_device
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---set_coresight_ahb_ap_index
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_ExecCommand("CORESIGHT_SetIndexAHBAPToUse = 0", ...).
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.001ms returns 0x00
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_ExecCommand("device = nRF52", ...).
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Device "NRF52" selected.
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 2.715ms returns 0x00
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_Connect()
    [2024-Jan-17 14:44:41] [trace] [  JLink] - InitTarget() start
    [2024-Jan-17 14:44:41] [trace] [  JLink] -  J-Link Script File: Executing InitTarget()
    [2024-Jan-17 14:44:41] [trace] [  JLink] - InitTarget() end - Took 2.52ms
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Found SW-DP with ID 0x2B801477
    [2024-Jan-17 14:44:41] [trace] [  JLink] - DPIDR: 0x2BA00477
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CoreSight SoC-400 or earlier
    [2024-Jan-17 14:44:41] [trace] [  JLink] - AP map detection skipped. Manually configured AP map found.
    [2024-Jan-17 14:44:41] [trace] [  JLink] - AP[0]: AHB-AP (IDR: Not set)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - AP[0]: Core found
    [2024-Jan-17 14:44:41] [trace] [  JLink] - AP[0]: AHB-AP ROM base: 0xE00FF000
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPUID register: 0x410FC241. Implementer code: 0x41 (ARM)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Found Cortex-M4 r0p1, Little endian.
    [2024-Jan-17 14:44:41] [trace] [  JLink] - -- Max. mem block: 0x0003C600
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE000EDF0)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000EDF0)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE0002000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - FPUnit: 6 code (BP) slots and 2 literal slots
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE000EDFC)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000EDFC)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE0001000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE0001000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0xE000ED88)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000ED88)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CoreSight components:
    [2024-Jan-17 14:44:41] [trace] [  JLink] - ROMTbl[0] @ E00FF000
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(64 bytes @ 0xE00FF000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xDFF0EFE0)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - [0][0]: DFF0E000 CID 00000000 PID 00000000 ???
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xE0001FE0)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - [0][1]: E0001000 CID B105E00D PID 003BB002 DWT
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xDFF02FE0)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - [0][2]: DFF02000 CID 00000000 PID 00000000 ???
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xE0000FE0)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - [0][3]: E0000000 CID B105E00D PID 003BB001 ITM
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xDFF3FFE0)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - [0][4]: DFF3F000 CID 00000000 PID 00000000 ???
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(32 bytes @ 0xE0041FE0)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - [0][5]: E0041000 CID B1059008 PID 000A3924 ???
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 18.204ms returns 0x00
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_CORE_GetFound()
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.003ms returns 0xE0000FF
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_read_u32
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_invalidate_cache
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_ExecCommand("InvalidateCache", ...).
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.309ms returns 0x00
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_ReadMemU32(0x10000130, 0x1 Items)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0x10000130)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Data:  08 00 00 00
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.360ms returns 1 (0x1)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.002ms returns 0x00
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_ReadMemU32(0x10000134, 0x1 Items)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_ReadMem(4 bytes @ 0x10000134)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Data:  03 00 00 00
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.344ms returns 1 (0x1)
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - Just_decode_device_version
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - Device identified as NRF52840_xxAA_REV2
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - write_approtect
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - NRF52840 REV2 does not implement updated APPROTECT mechanism.
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - halt
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_halt
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_Halt()
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 3.769ms returns 0x00
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - sys_reset
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.338ms returns 0x00
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_sys_reset
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_SetResetType(JLINKARM_CM3_RESET_TYPE_NORMAL)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.004ms returns JLINKARM_CM3_RESET_TYPE_NORMAL
    [2024-Jan-17 14:44:41] [trace] [ Client] - Command recover executed for 1206 milliseconds with result 0
    [2024-Jan-17 14:44:41] [debug] [ Client] - read_device_info
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_Reset()
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Reset: Halt core after reset via DEMCR.VC_CORERESET.
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Reset: Reset device via AIRCR.SYSRESETREQ.
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE000ED0C)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0xE0002000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 70.585ms
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - Just_power_ram_all
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - Select AP 1, DP Bank 255, AP Bank 15
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.255ms returns 0
    [2024-Jan-17 14:44:41] [trace] [ Client] - Command read_device_info executed for 18 milliseconds with result 0
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - write_u32
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_write_u32
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_write_debug_port_register
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.234ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_WriteU32_64(0x40000904, 0x0000FFFF)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000904)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 1.388ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.245ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_WriteU32_64(0x40000914, 0x0000FFFF)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000914)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.426ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.211ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_WriteU32_64(0x40000924, 0x0000FFFF)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000924)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.359ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_WriteU32_64(0x40000934, 0x0000FFFF)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000934)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.358ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_WriteU32_64(0x40000944, 0x0000FFFF)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000944)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.368ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.225ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_WriteU32_64(0x40000954, 0x0000FFFF)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000954)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.362ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.229ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.236ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_WriteU32_64(0x40000964, 0x0000FFFF)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000964)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.364ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.220ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_WriteU32_64(0x40000974, 0x0000FFFF)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000974)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.370ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.213ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_WriteU32_64(0x40000984, 0x0000FFFF)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000984)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.351ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - Just_clear_resetreas
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.226ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.231ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_WriteU32_64(0x40000400, 0xFFFFFFFF)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - CPU_WriteMem(4 bytes @ 0x40000400)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.354ms returns 0 (0x00000000)
    [2024-Jan-17 14:44:41] [trace] [ Worker] - Command recover executed for 1200 milliseconds with result 0
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - read_device_info
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.012ms returns 0x01
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_Lock()
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_CORESIGHT_ReadAPDPReg(DP reg 0x01)
    [2024-Jan-17 14:44:41] [trace] [  JLink] - Value=0xF0000040
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.252ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.256ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.291ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.230ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.253ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.320ms returns 0
    [2024-Jan-17 14:44:41] [trace] [  JLink] - JLINK_IsConnected()
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.002ms returns TRUE
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.003ms returns 0x00
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.033ms
    [2024-Jan-17 14:44:41] [trace] [ Worker] - Command read_device_info executed for 7 milliseconds with result 0
    [2024-Jan-17 14:44:41] [debug] [  nRF52] - close
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.003ms returns 0x01
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - close
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - disconnect_from_emu
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 0.001ms returns TRUE
    [2024-Jan-17 14:44:41] [trace] [  JLink] - - 1.488ms returns 0
    [2024-Jan-17 14:44:41] [debug] [SeggerBackend] - Disable trace before closing connection.
    [2024-Jan-17 14:44:41] [debug] [[2024-Jan-25 09:55:11] [debug] --------------------------------------------------------------------------------
    [2024-Jan-25 09:55:11] [debug] nrfjprog --recover --log
    [2024-Jan-25 09:55:11] [debug] nrfjprog version 10.18.1 external
    [2024-Jan-25 09:55:11] [ info] Load library at /Applications/Development/nrfCommandLine/lib/libnrfjprogdll.dylib.
    [2024-Jan-25 09:55:11] [ info] Library loaded, loading member functions.
    [2024-Jan-25 09:55:11] [ info] Member functions succesfully loaded.
    [2024-Jan-25 09:55:11] [debug] [ Client] - open
    [2024-Jan-25 09:55:11] [debug] [ Client] - start
    [2024-Jan-25 09:55:11] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence 6eb8cc30-d679-4d95-a54b-667018365d5b.
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2024-Jan-25 09:55:11] [debug] [  JLink] - Logger sink registered in JLink logger
    [2024-Jan-25 09:55:11] [debug] [  nRFXX] - open
    [2024-Jan-25 09:55:11] [debug] [  nRFXX] - just_check_family
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - open_dll
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2024-Jan-25 09:55:11] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.7.94.7.dylib.
    [2024-Jan-25 09:55:11] [trace] [ Client] - Command open executed for 12 milliseconds with result 0
    [2024-Jan-25 09:55:11] [debug] [ Client] - config
    [2024-Jan-25 09:55:11] [trace] [ Client] - Command config executed for 12 milliseconds with result 0
    [2024-Jan-25 09:55:11] [debug] [ Client] - enum_emu_snr
    [2024-Jan-25 09:55:11] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2024-Jan-25 09:55:11] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - Set batch mode
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - dll_version
    [2024-Jan-25 09:55:11] [ info] [SeggerBackend] - Segger dll version 7.94.g loaded.
    [2024-Jan-25 09:55:11] [trace] [ Worker] - Command open executed for 7 milliseconds with result 0
    [2024-Jan-25 09:55:11] [debug] [  nRFXX] - config
    [2024-Jan-25 09:55:11] [trace] [ Worker] - Command config executed for 2 milliseconds with result 0
    [2024-Jan-25 09:55:11] [debug] [  nRFXX] - enum_emu_con_info
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - is_connected_to_emu
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - enum_emu_con_info
    [2024-Jan-25 09:55:11] [trace] [ Worker] - Command enum_emu_con_info executed for 0 milliseconds with result 0
    [2024-Jan-25 09:55:11] [trace] [ Client] - Command enum_emu_con_info executed for 6 milliseconds with result 0
    [2024-Jan-25 09:55:11] [debug] [ Client] - connect_to_emu_with_snr
    [2024-Jan-25 09:55:11] [debug] [  nRFXX] - connect_to_emu_with_snr
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - ---just_get_num_emus
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - Segger logging enabled.
    [2024-Jan-25 09:55:11] [trace] [  JLink] - Firmware: J-Link OB-nRF5340-NordicSemi compiled Oct 30 2023 12:13:06
    [2024-Jan-25 09:55:11] [trace] [  JLink] - Hardware: V1.00
    [2024-Jan-25 09:55:11] [trace] [  JLink] - S/N: 1050269628
    [2024-Jan-25 09:55:11] [trace] [  JLink] - OEM: SEGGER
    [2024-Jan-25 09:55:11] [trace] [  JLink] - Feature(s): RDI, FlashBP, FlashDL, JFlash, GDB
    [2024-Jan-25 09:55:11] [trace] [  JLink] - Bootloader: 2021 May 18
    [2024-Jan-25 09:55:11] [trace] [  JLink] - USB speed mode: Full speed (12 MBit/s)
    [2024-Jan-25 09:55:11] [trace] [  JLink] - TELNET listener socket opened on port 19021
    [2024-Jan-25 09:55:11] [trace] [  JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2024-Jan-25 09:55:11] [trace] [  JLink] - WEBSRV Webserver running on local port 19080
    [2024-Jan-25 09:55:11] [trace] [  JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V794g/JLinkGUIServerExe
    [2024-Jan-25 09:55:11] [trace] [  JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V794g/JLinkGUIServerExe
    [2024-Jan-25 09:55:11] [trace] [  JLink] - J-Link GUI Server info: "J-Link GUI server V7.94g "
    [2024-Jan-25 09:55:11] [trace] [ Client] - Command connect_to_emu_with_snr executed for 263 milliseconds with result 0
    [2024-Jan-25 09:55:11] [debug] [ Client] - read_connected_emu_snr
    [2024-Jan-25 09:55:11] [trace] [ Client] - Command read_connected_emu_snr executed for 6 milliseconds with result 0
    [2024-Jan-25 09:55:11] [debug] [ Client] - read_device_family
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 233.882ms returns "O.K."
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_HasError()
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_Lock()
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.002ms returns 0x01
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.000ms returns 0x00
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.001ms returns 0x00
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_SetHookUnsecureDialog
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_SetHookUnsecureDialog(...)
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.003ms returns 0
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 4.398ms returns 0x00
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_GetSpeedInfo()
    [2024-Jan-25 09:55:11] [trace] [  JLink] - 128000000 Hz / n, n >= 64
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.007ms
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 2000kHz
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_SetSpeed(2000)
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.131ms
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_GetSpeed()
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.001ms returns 2000
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_GetSN()
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.001ms returns 1050269628
    [2024-Jan-25 09:55:11] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 257 milliseconds with result 0
    [2024-Jan-25 09:55:11] [debug] [  nRFXX] - read_connected_emu_snr
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_IsOpen()
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - read_connected_emu_snr
    [2024-Jan-25 09:55:11] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2024-Jan-25 09:55:11] [debug] [  nRFXX] - read_device_family
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - read_debug_port_idr
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - read_debug_port_register
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - coresight_configure
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_GetHWStatus(...)
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 1.449ms returns 0
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_CORESIGHT_Configure()
    [2024-Jan-25 09:55:11] [trace] [ Client] - Command read_device_family executed for 121 milliseconds with result -102
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 100.455ms returns 0
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.605ms returns -1
    [2024-Jan-25 09:55:11] [error] [SeggerBackend] - JLinkARM.dll reported "-1", "An unknown error.".
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.499ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.493ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.513ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.488ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.497ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.496ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.468ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.476ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.473ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.472ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.464ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.481ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.502ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.494ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.483ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.492ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.482ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.489ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.477ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.484ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.491ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.010ms
    [2024-Jan-25 09:55:11] [trace] [ Worker] - Command read_device_family executed for 118 milliseconds with result -102
    [2024-Jan-25 09:55:11] [debug] [  nRFXX] - close
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - close
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - disconnect_from_emu
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - is_connected_to_device
    [2024-Jan-25 09:55:11] [trace] [  JLink] - JLINK_IsConnected()
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.001ms returns FALSE
    [2024-Jan-25 09:55:11] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.515ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.495ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.578ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.531ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.503ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.552ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.478ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.470ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.500ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.479ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.487ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.501ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.506ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.583ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.510ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.512ms returns -1
    [2024-Jan-25 09:55:11] [trace] [  JLink] - - 0.687ms returns -1
  • Hi Tim,
    No worries about the response time. We can resync now.
    Regarding the building issue: Does the same behavior occur if you roll back to the previous programmer you've used successfully? You can install other versions through nRF Connect for Desktop
    If rolling back the version does not resolve the issue, we would like you to raise a new ticket for that issue for easier trackability. Please feel free to refer to this ticket in the new one if you believe anything there is relevant.
    TimD said:
    I ran a test with 2 proxy's.  Proxy2 crashed at 01:16:46. The log of the Proxy1 finally captured a message (but didn't crash). Any idea what this is?
    Regarding the error you see I've yet to find anyone who's seen this before. Could you update me regarding if the issue still persists on your end or if you've been able to resolve it? Whats the status on this part now?
    Andreas
  • Hi Andrea, The proxy crash issue doesn't seem to be happening anymore. I did a fix by calling my python script with nohup python .....
