NTC build error migrating from nRF Connect v2.4.2 to 2.5
We works on a project that use a custom board based on nRF5340 with an NTC. Everything works fine with nRF Connect v2.4.2.
Migrating to v2.5 of the SDK generates error on this project due to NTC.
/home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/../lib/gcc/arm-zephyr-eabi/12.2.0/../../../../arm-zephyr-eabi/bin/ld.bfd: app/libapp.a(power_module.c.obj):/home/bgorostidi/Workspace/Projects/Iot/9220Sparklin_NRF53/src/modules/power_module.c:71: undefined reference to `__device_dts_ord_4'
collect2: error: ld returned 1 exit status
FATAL ERROR: command exited with status 1: /home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/toolchains/7795df4459/usr/local/bin/cmake --build /home/bgorostidi/Workspace/Projects/Iot/9220Sparklin_NRF53/build
Based on information in build folder, "__device_dts_ord_4" is the NTC node.
 * Generated by gen_defines.py
 * DTS input file:
 *   /home/bgorostidi/Workspace/Projects/Iot/9220Sparklin_NRF53/build/zephyr/zephyr.dts.pre
 * Directories with bindings:
 *   /home/bgorostidi/Workspace/Toolchains/nrfConnect_SDK/v2.5.0/nrf/dts/bindings, /home/bgorostidi/Workspace/Projects/Iot/9220Sparklin_NRF53/dts/bindings, $ZEPHYR_BASE/dts/bindings
 * Node dependency ordering (ordinal and path):
 *   0   /
 *   1   /aliases
 *   2   /chosen
 *   3   /entropy_bt_hci
 *   4   /ntc-thermistor
Extract of our dts:
	table: ntc-thermistor-rt-table {
		compatible = "zephyr,ntc-thermistor-rt-table";
		tr-table = <0 15000>, <10 9760>, <20 6500>, <30 4430>, <40 3090>, <50 2190>, <60 1580>, <70 1160>, <80 870>, <85 750>;
	temp_sensor: ntc-thermistor {
		compatible = "zephyr,ntc-thermistor";
		io-channels = <&adc 6>;
		zephyr,rt-table = <&table>;
		r25-ohm = <5100>;
		pullup-uv = <0>;
		pullup-ohm = <0>;
		pulldown-ohm = <1300>;
		connection-type = "NTC_CONNECTED_POSITIVE";
Does the new SDK version include some changes on NTC part?
Best regards
