nrfConnect 2.5.0: mbedTLS fails to compile (calloc())
Hi there: we've just updated from nrfConnect 2.3.0 to nrfConnect 2.5.0 and mbedTLS (which seems to have been modified in nrfConnect 2.5.0) now fails to link (in platform.c) because it needs and is unable to find calloc():
/home/arm_embedded_gcc-10-2020-q4-major/bin/ld.bfd: modules/mbedtls/libmbedTLSBase.a(platform.c.obj):/home/nrfconnectsdk-v2.5.0/modules/crypto/mbedtls/library/platform.c:56: undefined reference to `calloc'
As you can see, we are just compiling with GCC for ARM, the newlib of which likely does provide calloc(), but since the linker seems to be being given -nostdlib I guess that is not being included, Zephyr must be providing it.
FYI, we use the default Zephyr MINIMAL_LIBC with normal malloc (so CONFIG_MINIMAL_LIBC_MALLOC=n), however that shouldn't affect calloc(); we don't use calloc() at all and it seems to be under a separate Zephyr configuration switch, CONFIG_MINIMAL_LIBC_CALLOC, which is at the default of y, confirmed by looking in the generated .config file, so it is there inside Zephyr (and just calls malloc() then zeroes it, as you might expect).
Have checked the migration guide but couldn't find anything about this.
Anyway, we don't really care, just need to know how to make it happy please.
FYI, here is our build configuration:
CONFIG_DEBUG=y
CONFIG_MINIMAL_LIBC=y
CONFIG_HEAP_MEM_POOL_SIZE=131072
CONFIG_USERSPACE=y
CONFIG_INIT_STACKS=y
CONFIG_THREAD_STACK_INFO=y
CONFIG_THREAD_NAME=y
CONFIG_IRQ_OFFLOAD=y
CONFIG_MAIN_STACK_SIZE=8192
CONFIG_EXECUTE_XOR_WRITE=n
CONFIG_ASSERT=y
CONFIG_LOG=y
CONFIG_LOG_DEFAULT_LEVEL=3
CONFIG_DEBUG_OPTIMIZATIONS=y
CONFIG_USE_SEGGER_RTT=y
CONFIG_RTT_CONSOLE=y
CONFIG_UART_CONSOLE=n
CONFIG_LOG_BACKEND_UART=n
CONFIG_SEGGER_RTT_BUFFER_SIZE_UP=2048
CONFIG_EXTRA_EXCEPTION_INFO=y
CONFIG_I2C=y
CONFIG_SPI=y
...and here is the complete linker line as emitted by west:
[612/633] Linking CXX executable zephyr/zephyr_pre0.elf
FAILED: zephyr/zephyr_pre0.elf zephyr/zephyr_pre0.map /home/workspace/build/zephyr/zephyr_pre0.map
: && ccache /home/arm_embedded_gcc-10-2020-q4-major/bin/arm-none-eabi-g++ -gdwarf-4 zephyr/CMakeFiles/zephyr_pre0.dir/misc/empty_file.c.obj -o zephyr/zephyr_pre0.elf zephyr/CMakeFiles/offsets.dir/./arch/arm/core/offsets/offsets.c.obj -fuse-ld=bfd -T zephyr/linker_zephyr_pre0.cmd -Wl,-Map=/home/workspace/build/zephyr/zephyr_pre0.map -Wl,--whole-archive app/libapp.a zephyr/libzephyr.a zephyr/arch/common/libarch__common.a zephyr/arch/arch/arm/core/aarch32/libarch__arm__core__aarch32.a zephyr/arch/arch/arm/core/aarch32/cortex_m/libarch__arm__core__aarch32__cortex_m.a zephyr/arch/arch/arm/core/aarch32/cortex_m/cmse/libarch__arm__core__aarch32__cortex_m__cmse.a zephyr/arch/arch/arm/core/aarch32/mpu/libarch__arm__core__aarch32__mpu.a zephyr/lib/libc/minimal/liblib__libc__minimal.a zephyr/lib/libc/common/liblib__libc__common.a zephyr/soc/soc/arm/common/cortex_m/libsoc__arm__common__cortex_m.a zephyr/boards/arm/nrf5340dk_nrf5340/libboards__arm__nrf5340dk_nrf5340.a zephyr/subsys/random/libsubsys__random.a zephyr/subsys/bluetooth/common/libsubsys__bluetooth__common.a zephyr/subsys/bluetooth/host/libsubsys__bluetooth__host.a zephyr/subsys/net/libsubsys__net.a zephyr/drivers/bluetooth/libdrivers__bluetooth.a zephyr/drivers/clock_control/libdrivers__clock_control.a zephyr/drivers/console/libdrivers__console.a zephyr/drivers/gpio/libdrivers__gpio.a zephyr/drivers/i2c/libdrivers__i2c.a zephyr/drivers/mbox/libdrivers__mbox.a zephyr/drivers/pinctrl/libdrivers__pinctrl.a zephyr/drivers/serial/libdrivers__serial.a zephyr/drivers/spi/libdrivers__spi.a zephyr/drivers/timer/libdrivers__timer.a modules/nrf/drivers/hw_cc310/lib..__nrf__drivers__hw_cc310.a modules/mbedtls/libmbedTLSBase.a modules/mbedtls/libmbedTLSCrypto.a modules/mbedtls/libmbedTLSX509.a modules/mbedtls/libmodules__mbedtls.a modules/hal_nordic/nrfx/libmodules__hal_nordic__nrfx.a modules/libmetal/libmetal/lib/libmetal.a modules/open-amp/open-amp/lib/libopen_amp.a modules/segger/libmodules__segger.a -Wl,--no-whole-archive zephyr/kernel/libkernel.a -L"/home/arm_embedded_gcc-10-2020-q4-major/bin/../lib/gcc/arm-none-eabi/10.2.1/thumb/v8-m.main/nofp" -L/home/workspace/build/zephyr -lgcc zephyr/arch/common/libisr_tables.a modules/mbedtls/libmbedTLSBase.a modules/mbedtls/libmbedTLSCrypto.a modules/mbedtls/libmbedTLSX509.a -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee -Wl,--gc-sections -Wl,--build-id=none -Wl,--sort-common=descending -Wl,--sort-section=alignment -Wl,--no-relax -Wl,-u,_OffsetAbsSyms -Wl,-u,_ConfigAbsSyms -nostdlib -static -Wl,-X -Wl,-N -Wl,--orphan-handling=warn /home/nrfconnectsdk-v2.5.0/nrfxlib/crypto/nrf_cc312_platform/lib/cortex-m33/soft-float/no-interrupts/libnrf_cc312_platform_0.9.18.a && cd /home/workspace/build/zephyr && /usr/local/bin/cmake -E true
