Samples hci_lpuart + lte_ble_gateway not working on thingy91 SDKs v2.4.2, v2.3.0, v2.2.0
Hi, I am programming on a thingy91 (and a nrf9160DK).
I have an app that uses hci_lpuart sample and used to be running with 1.9.1 sdk, the app is very similar to the lte_ble_gateway sample
I am migrating to a newer version (2.4.2) and I managed to make it work on my DK.
However, when I try to flash it on the thingy91, it will not be able to enable bluetooth (using bt_enable) because of what's going on with the 52 chip.
I can make both my app and the lte_ble_gw sample work on my DK (using hci_lpuart sample) but when trying to do the exact same thing on my Thingy91, nothing works and the bluetooth cannot be enable, no matter what I try.
I would like to know if I need to have any specific configuration (maybe a specific .overlay file or smth) as it's most likely that the problem comes from compatibility issues with the configuration build provided when getting the sample since I cannot even make a nordic sample work on my thingy.
Thanks for your answers.
0x35c
  • Hi, thanks for your update ! Did you test it on the sample and does it work ?
    I don't really understand where and how am I supposed to change this uart1 configuration ?
    Here is my overlay for the 52 (hci_lpuart sample)
    8358.thingy91_nrf52840.overlay
    Here is my configuration for the 91 (running my app which has been developed starting from the lte_ble_gateway and has the same stucture as the sample)
    6215.thingy91_nrf9160_ns.overlay
    If you can guide me through what needs to be change it would be very much appreciated !
    0x35c
  • Yes, I tested this and it works now for me aswell.
    in both the overlay files you need to change
    &uart1 {
    	current-speed = <1000000>;
    	status = "okay";
    to
    &uart1 {
    	status = "disabled";
    and in
    you need to add these lines
    &uart1 {
    	status = "okay";
    The changes are mentioned clearly in these PR view
    Did you build the lte_ble_gateway sample with this configuration board: thingy91_nrf9160_ns ? If I try to build the sample with status = "disabled"; in my overlay file I will get this compilation error:
    -- Found Python3: /home/esc/ncs/toolchains/7795df4459/usr/local/bin/python3.8 (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: /home/esc/.cache/zephyr
    -- Configuring done
    -- Generating done
    -- Build files have been written to: /home/esc/versions/lte_ble_gateway/build/tfm
    [153/157] Linking C executable bin/tfm_s.axf
               FLASH:       47928 B      48640 B     98.54%
                 RAM:       14736 B        32 KB     44.97%
    [24/381] Performing install step for 'tfm'
    -- Install configuration: "MinSizeRel"
    [271/381] Building C object zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/home/esc/ncs/v2.5.0/nrf/drivers/serial/uart_nrf_sw_lpuart.c.obj
    FAILED: zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/home/esc/ncs/v2.5.0/nrf/drivers/serial/uart_nrf_sw_lpuart.c.obj
    ccache /home/esc/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/bin/arm-zephyr-eabi-gcc -DAPP_VERSION=v2.5.0 -DEXT_API_MAGIC=0x281ee6de,0xb845acea,23298 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,23298 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_USER_CONFIG_FILE=\"nrf-config-user.h\" -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DPICOLIBC_INTEGER_PRINTF_SCANF -DUSE_PARTITION_MANAGER=1 -D_FORTIFY_SOURCE=1 -D_POSIX_C_SOURCE=200809 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR_SUPERVISOR__ -D__ZEPHYR__=1 -I/home/esc/ncs/v2.5.0/zephyr/include -Izephyr/include/generated -I/home/esc/ncs/v2.5.0/zephyr/soc/arm/nordic_nrf/nrf91 -I/home/esc/ncs/v2.5.0/zephyr/soc/arm/nordic_nrf/common/. -I/home/esc/ncs/v2.5.0/zephyr/subsys/bluetooth -I/home/esc/ncs/v2.5.0/zephyr/subsys/net/lib/sockets/. -I/home/esc/ncs/v2.5.0/zephyr/subsys/settings/include -I/home/esc/ncs/v2.5.0/nrf/include -I/home/esc/ncs/v2.5.0/nrf/lib/at_cmd_parser/include -Itfm/install/interface/include -I/home/esc/ncs/v2.5.0/nrf/subsys/net/lib/nrf_cloud/./include -I/home/esc/ncs/v2.5.0/nrf/subsys/net/lib/fota_download/./include -I/home/esc/ncs/v2.5.0/nrf/include/tfm -I/home/esc/ncs/v2.5.0/nrf/tests/include -Itfm/generated/interface/include -I/home/esc/ncs/v2.5.0/modules/lib/cjson -I/home/esc/ncs/v2.5.0/nrf/modules/cjson/include -I/home/esc/ncs/v2.5.0/modules/hal/cmsis/CMSIS/Core/Include -I/home/esc/ncs/v2.5.0/zephyr/modules/cmsis/. -I/home/esc/ncs/v2.5.0/modules/hal/nordic/nrfx -I/home/esc/ncs/v2.5.0/modules/hal/nordic/nrfx/drivers/include -I/home/esc/ncs/v2.5.0/modules/hal/nordic/nrfx/mdk -I/home/esc/ncs/v2.5.0/zephyr/modules/hal_nordic/nrfx/. -I/home/esc/ncs/v2.5.0/modules/debug/segger/SEGGER -I/home/esc/ncs/v2.5.0/modules/debug/segger/Config -I/home/esc/ncs/v2.5.0/modules/crypto/tinycrypt/lib/include -I/home/esc/ncs/v2.5.0/nrfxlib/nrf_modem/include -I/home/esc/versions/lte_ble_gateway/src -Imodules/nrf/subsys/nrf_security/src/include/generated -I/home/esc/ncs/v2.5.0/nrf/subsys/nrf_security/include -I/home/esc/ncs/v2.5.0/nrf/ext/oberon/psa/core/include -I/home/esc/ncs/v2.5.0/nrf/ext/oberon/psa/core/library -I/home/esc/ncs/v2.5.0/modules/crypto/mbedtls/include -I/home/esc/ncs/v2.5.0/modules/crypto/mbedtls/library -I/home/esc/ncs/v2.5.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -I/home/esc/ncs/v2.5.0/nrfxlib/crypto/nrf_oberon/include -I/home/esc/ncs/v2.5.0/nrfxlib/softdevice_controller/include -Wshadow -fno-strict-aliasing -Os -imacros /home/esc/versions/lte_ble_gateway/build/zephyr/include/generated/autoconf.h -fno-printf-return-value -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfp16-format=ieee --sysroot=/home/esc/ncs/toolchains/7795df4459/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros /home/esc/ncs/v2.5.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -ftls-model=local-exec -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=/home/esc/versions/lte_ble_gateway=CMAKE_SOURCE_DIR -fmacro-prefix-map=/home/esc/ncs/v2.5.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=/home/esc/ncs/v2.5.0=WEST_TOPDIR -ffunction-sections -fdata-sections --specs=picolibc.specs -std=c99 -MD -MT zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/home/esc/ncs/v2.5.0/nrf/drivers/serial/uart_nrf_sw_lpuart.c.obj -MF zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/home/esc/ncs/v2.5.0/nrf/drivers/serial/uart_nrf_sw_lpuart.c.obj.d -o zephyr/drivers/serial/CMakeFiles/drivers__serial.dir/home/esc/ncs/v2.5.0/nrf/drivers/serial/uart_nrf_sw_lpuart.c.obj -c /home/esc/ncs/v2.5.0/nrf/drivers/serial/uart_nrf_sw_lpuart.c
    In file included from /home/esc/ncs/v2.5.0/zephyr/include/zephyr/toolchain/gcc.h:92,
                     from /home/esc/ncs/v2.5.0/zephyr/include/zephyr/toolchain.h:50,
                     from /home/esc/ncs/v2.5.0/zephyr/include/zephyr/sys/time_units.h:10,
                     from /home/esc/ncs/v2.5.0/zephyr/include/zephyr/sys/util.h:615,
                     from /home/esc/ncs/v2.5.0/zephyr/include/zephyr/devicetree.h:25,
                     from /home/esc/ncs/v2.5.0/zephyr/include/zephyr/device.h:12,
                     from /home/esc/ncs/v2.5.0/zephyr/include/zephyr/drivers/uart.h:26,
                     from /home/esc/ncs/v2.5.0/nrf/drivers/serial/uart_nrf_sw_lpuart.c:7:
    /home/esc/ncs/v2.5.0/nrf/drivers/serial/uart_nrf_sw_lpuart.c: In function 'lpuart_init':
    /home/esc/ncs/v2.5.0/zephyr/include/zephyr/device.h:85:41: error: '__device_dts_ord_124' undeclared (first use in this function); did you mean '__device_dts_ord_12'?
       85 | #define DEVICE_NAME_GET(dev_id) _CONCAT(__device_, dev_id)
    /home/esc/ncs/v2.5.0/zephyr/include/zephyr/toolchain/common.h:132:26: note: in definition of macro '_DO_CONCAT'
      132 | #define _DO_CONCAT(x, y) x ## y
    /home/esc/ncs/v2.5.0/zephyr/include/zephyr/device.h:85:33: note: in expansion of macro '_CONCAT'
    /home/esc/ncs/v2.5.0/zephyr/include/zephyr/device.h:211:37: note: in expansion of macro 'DEVICE_NAME_GET'
      211 | #define DEVICE_DT_NAME_GET(node_id) DEVICE_NAME_GET(Z_DEVICE_DT_DEV_ID(node_id))
    /home/esc/ncs/v2.5.0/zephyr/include/zephyr/device.h:228:34: note: in expansion of macro 'DEVICE_DT_NAME_GET'
      228 | #define DEVICE_DT_GET(node_id) (&DEVICE_DT_NAME_GET(node_id))
    /home/esc/ncs/v2.5.0/nrf/drivers/serial/uart_nrf_sw_lpuart.c:970:22: note: in expansion of macro 'DEVICE_DT_GET'
      970 |         data->uart = DEVICE_DT_GET(DT_INST_BUS(0));
    /home/esc/ncs/v2.5.0/zephyr/include/zephyr/device.h:85:41: note: each undeclared identifier is reported only once for each function it appears in
    [284/381] Building C object modules/nrf/subsys/net/lib/nrf_cloud/CMakeFiles/..__nrf__subsys__net__lib__nrf_cloud.dir/src/nrf_cloud_codec_internal.c.obj
    FATAL ERROR: command exited with status 1: /home/esc/ncs/toolchains/7795df4459/usr/local/bin/cmake --build /home/esc/versions/lte_ble_gateway/build
     *  The terminal process terminated with exit code: 1.
    I think it tells that the uart1 pin cannot be accessed (which is what we changed in the .overlay file) and I don't know how can you compile with status = "disabled"; in your thingy91_nrf9160_ns.overlay overlay file.
    I am also wondering why are you talking about the Connectivity Bridge sample ? The only 2 samples I use are hci_lpuart for the 52 chip and lte_ble_gateway for the 91 chip.
    And the builds of these 3 are independent so I don't get how changing something in applications/connectivity_bridge/app.overlay (which I never used) could affect the compilation of any other sample.
    Yes,
    Please see below
    I did not create any overlay file I changed the exact same way as in the PR I linked in the files
    boards/arm/thingy91_nrf52840/thingy91_nrf52840.dts
    boards/arm/thingy91_nrf9160/thingy91_nrf9160_common.dts
    As mentioned here
  • Oh okay I did not understand I had to change it directly in the source sdk .dts files. So I did that, it compiles well on both hci_lpuart sample and lte_ble_gateway.
    However, the problem persists:
    *** Booting nRF Connect SDK v2.5.0 ***
    [00:00:00.256,896] <inf> lte_ble_gw: LTE Sensor Gateway sample started
    [00:00:00.257,049] <inf> lte_ble_gw: Initializing Bluetooth..
    [00:00:00.505,706] <inf> lte_ble_gw: Establishing LTE link (this may take some time) ...
    [00:00:04.321,807] <wrn> lpuart: req pin low when expected high
    [00:00:04.321,960] <err> lpuart: Empty receiver state:4
    ASSERTION FAIL [err == 0] @ WEST_TOPDIR/zephyr/subsys/bluetooth/host/hci_core.c:338
      command opcode 0x0c03 timeout with err -11
    [00:00:10.267,547] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000000  r2/a3:  0x00000002
    [00:00:10.267,547] <err> os: r3/a4:  0x2000d298 r12/ip:  0x00000010 r14/lr:  0x0002049d
    [00:00:10.267,578] <err> os:  xpsr:  0x41000000
    [00:00:10.267,578] <err> os: Faulting instruction address (r15/pc): 0x000204a8
    [00:00:10.267,639] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    [00:00:10.267,669] <err> os: Current thread: 0x2000f7b8 (unknown)
    [00:00:10.489,440] <err> fatal_error: Resetting system
    [00:00:00.252,288] <wrn> lpuart: req pin low when expected high
    [00:00:00.252,380] <err> lpuart: Empty receiver state:4
    [00:00:00.256,317] <inf> lte_ble_gw: LTE Sensor Gateway sample started
    [00:00:00.256,469] <inf> lte_ble_gw: Initializing Bluetooth..
    [00:00:00.502,990] <inf> lte_ble_gw: Establishing LTE link (this may take some time) ...
    [00:00:06.873,809] <wrn> lpuart: req pin low when expected high
    [00:00:06.873,931] <err> lpuart: Empty receiver state:4
    [00:00:10.266,998] <err> os: r0/a1:  0x00000003  r1/a2:  0x00000000  r2/a3:  0x00000002
    [00:00:10.266,998] <err> os: r3/a4:  0x2000d298 r12/ip:  0x00000010 r14/lr:  0x0002049d
    [00:00:10.267,028] <err> os:  xpsr:  0x41000000
    [00:00:10.267,028] <err> os: Faulting instruction address (r15/pc): 0x000204a8
    [00:00:10.267,089] <err> os: >>> ZEPHYR FATAL ERROR 3: Kernel oops on CPU 0
    [00:00:10.267,120] <err> os: Current thread: 0x2000f7b8 (unknown)
    [00:00:10.488,800] <err> fatal_error: Resetting system
    [00:00:00.252,319] <wrn> lpuart: req pin low when expected high
    [00:00:00.252,410] <err> lpuart: Empty receiver state:4
    [00:00:00.256,347] <inf> lte_ble_gw: LTE Sensor Gateway sample started
    [00:00:00.256,500] <inf> lte_ble_gw: Initializing Bluetooth..
    [00:00:06.866,638] <wrn> lpuart: req pin low when expected high
    [00:00:06.866,760] <err> lpuart: Empty receiver state:4
    This is the log of what I have when I run my thingy91, which is the same as before the fix.
    I don't know if I did something wrong but for me it doesn't work...
    Again, thanks for your time !
