Two services on a single device
Here's what we're trying to do. We have a gesture recognition wearable that is intended to be used as a remote control for a smartphone. But some smartphone functions are easier to implement using the HID service and some using a custom service. We have the wearable and the phone connected and both services are shown in nRF Connect but if we pair with the HID service first we cannot connect to the custom service using a custom app on the smartphone. Similarly, if we pair to the custom service first, we cannot use the HID service. How do we get both services to work simultaneously from one device?
    When you say 'pair with the HID service first', do you here mean that you have 2 different advertising payloads that you are using, and that you are connecting to one which contains the HID service UUID, or the other which contains the custom service UUID?
    If so, please note that the contents of the advertising payload does not matter for which services are exposed during a connection - once the connection is established the central will perform a discovery which then finds all services offered by the peripheral device.
    When you connect to your device, are you able to see both the HID service and the customer service?
    If so, I think the issue you are seeing stems from the 'control' of the BLE link in the smartphone side. I.e the OS could have control over the BLE link and use it as a HID device, or the custom app could take control over the BLE link (within the smartphone) to use the custom service. The OS will usually only allow a specific subset of known services, such as HID devices, but not custom ones, so the challenge here will perhaps be to find a way to be able to access the BLE connection both from the OS side (for use as HID) and from your custom smartphone app (to access the custom service).
    Karl
  • Would it be possible to establish the HID connection first using the OS settings dialog and then advertise for the custom service? This is obviously not ideal, but would be a short-term fix.
    No, not using 2 different advertising payloads, Here is the UUID array:
    static ble_uuid_t m_adv_uuids[] = {{BLE_UUID_HUMAN_INTERFACE_DEVICE_SERVICE, BLE_UUID_TYPE_BLE},
                                       {CUSTOM_SERVICE_UUID, BLE_UUID_TYPE_VENDOR_BEGIN}};
    I use this for the m_advertising structure. I can see both services with nRF Connect app.
    Both services will be exposed to both centrals at each discovery, but yes - from a BLE standpoint you could have two equal connections to the same device (so long as your smartphone OS permits this, which I personally dont have much insight into), which will expose both services to both connections, but where each of the connections could primarily make use of one service each.
    Then I did not understand what you meant when you said 'pair with HID first' earlier, could you elaborate on this?
    Karl
  • Sure. When the wearable is advertising you can pair with it using either the smartphone's "settings" dialog or with the custom app. Either way, the wearable stops advertising after pairing, which is expected behavior. But if you pair with the settings dialog, the HID interface works but the custom interface does not, and vice versa.
    Aha, I understand - thank you for clarifying!
    In either case you can give it a try to pair to the device both to your OS as a HID device (through the smartphone 'settings'), and to your custom application concurrently and see if that works.
    The device will automatically stop advertising once it has hit its maximum for concurrent connections. If you increase the max concurrent connections you can continue to advertise after the first connection is made, and then try to connect from you custom app at the same time. Please note that I do not have any experience developing a smartphone application, and so I do not know if the OS of your smartphone will allow two separate connections to the same device. I dont see any reason why it should not, but I have been surprised of similar limitations earlier, and so I am cautions in making assumptions that it will work right off the bat.
    Karl
