Bricked MCU?
Hi, we've a custom board with an nRF52820 chip on, and are just at the start of bringing the board up.
Previously we've been developing our code on the nRF52822DK, and doing ok.
We had a blinky program, and I'd managed to flash that onto the custom board, and was starting to probe if it was actually running, but now I can't connect to the target board.
We're using a Jlink base to program and debug, and the SWD interface (with the reset line connected), and the target's getting a good 3.0V supply to the target.
We've been using VS code and have tried resetting and erasing the board, but get an error like:
-- west flash: using runner nrfjprog
-- runners.nrfjprog: Flashing file: /Users/nRFprojects/220905//build_P/zephyr/zephyr.hex
[error] [ Client] - Encountered error -102: Command read_device_info executed for 133 milliseconds with result -102
[error] [ Worker] - An unknown error.
[error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 31 milliseconds with result -102
Failed to read device memories.
ERROR: JLinkARM DLL reported an error. Try again. If error condition
ERROR: persists, run the same command again with argument --log, contact Nordic
ERROR: Semiconductor and provide the generated log.log file to them.
NOTE: For additional output, try running again with logging enabled (--log).
NOTE: Any generated log error messages will be displayed.
FATAL ERROR: command exited with status 33: nrfjprog --program /Users/nRFprojects/220905/build_P/zephyr/zephyr.hex --sectoranduicrerase --verify -f NRF52 --snr 51028748
As suggested, I've tried running that with the --log option but it says:
FATAL ERROR: runner nrfjprog received unknown arguments: ['--log']
I'm updating to the 2.5 toolchain now, but don't expect that'll help, so any help or advice on how to unbrick the board would be very much appreciated!
Alex
  • Ok, so I've worked out it was the nrfjprog command that needed the --log option, like:
    nrfjprog --program /Users/nRFprojects/220905/build_P/zephyr/zephyr.hex --sectoranduicrerase --verify -f NRF52 --snr 51028748 --log
    The log.log file contains (I couldn't work out how to attach it, sorry!)
    [2023-Dec-03 11:51:00] [debug] --------------------------------------------------------------------------------
    [2023-Dec-03 11:51:00] [debug] nrfjprog --program /Users/nRFprojects/220905/build_P/zephyr/zephyr.hex --sectoranduicrerase --verify -f NRF52 --snr 51028748 --log
    [2023-Dec-03 11:51:00] [debug] nrfjprog version 10.23.0 external
    [2023-Dec-03 11:51:00] [ info] Load library at /Applications/Nordic Semiconductor/lib/libnrfjprogdll.dylib.
    [2023-Dec-03 11:51:00] [ info] Library loaded, loading member functions.
    [2023-Dec-03 11:51:00] [ info] Member functions succesfully loaded.
    [2023-Dec-03 11:51:01] [debug] [ Client] - open
    [2023-Dec-03 11:51:01] [debug] [ Client] - start
    [2023-Dec-03 11:51:01] [ info] [ Client] - stdout: Jlinkarm nRF Worker ready. Handling sequence c0fde5ae-7564-4576-a818-46ba000ace77.
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - Logger sink registered in Segger backend logger
    [2023-Dec-03 11:51:01] [debug] [ JLink] - Logger sink registered in JLink logger
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - open
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - just_check_family
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - open_dll
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - No J-Link DLL path was provided. Attempting to auto detect.
    [2023-Dec-03 11:51:01] [trace] [ Client] - Command open executed for 15 milliseconds with result 0
    [2023-Dec-03 11:51:01] [debug] [ Client] - config
    [2023-Dec-03 11:51:01] [ info] [SeggerBackend] - Load library at /Applications/SEGGER/JLink/libjlinkarm.dylib.
    [2023-Dec-03 11:51:01] [ info] [SeggerBackend] - Library loaded, loading member functions.
    [2023-Dec-03 11:51:01] [ info] [SeggerBackend] - Member functions succesfully loaded.
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - Set batch mode
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - dll_version
    [2023-Dec-03 11:51:01] [ info] [SeggerBackend] - Segger dll version 7.94. loaded.
    [2023-Dec-03 11:51:01] [trace] [ Worker] - Command open executed for 7 milliseconds with result 0
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - config
    [2023-Dec-03 11:51:01] [trace] [ Client] - Command config executed for 3 milliseconds with result 0
    [2023-Dec-03 11:51:01] [debug] [ Client] - enum_emu_snr
    [2023-Dec-03 11:51:01] [trace] [ Client] - Command enum_emu_con_info executed for 2 milliseconds with result 0
    [2023-Dec-03 11:51:01] [debug] [ Client] - connect_to_emu_with_snr
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - enum_emu_snr
    [2023-Dec-03 11:51:01] [trace] [ Worker] - Command config executed for 3 milliseconds with result 0
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - enum_emu_con_info
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - is_connected_to_emu
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - enum_emu_con_info
    [2023-Dec-03 11:51:01] [trace] [ Worker] - Command enum_emu_con_info executed for 2 milliseconds with result 0
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - connect_to_emu_with_snr
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - connect_to_emu_with_snr
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - ---just_enum_emu_snr
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - ---just_get_num_emus
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - ---just_connect_to_emu_with_snr
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - ---just_connect_to_emu_without_snr
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - Segger logging enabled.
    [2023-Dec-03 11:51:01] [trace] [ JLink] - Firmware: J-Link V11 compiled Nov 22 2023 09:48:47
    [2023-Dec-03 11:51:01] [trace] [ JLink] - Hardware: V11.00
    [2023-Dec-03 11:51:01] [trace] [ JLink] - S/N: 51028748
    [2023-Dec-03 11:51:01] [trace] [ JLink] - OEM: SEGGER
    [2023-Dec-03 11:51:01] [trace] [ JLink] - Feature(s): GDB
    [2023-Dec-03 11:51:01] [trace] [ JLink] - Bootloader: 2019 Jul 04
    [2023-Dec-03 11:51:01] [trace] [ JLink] - USB speed mode: High speed (480 MBit/s)
    [2023-Dec-03 11:51:01] [trace] [ JLink] - TELNET listener socket opened on port 19021
    [2023-Dec-03 11:51:01] [trace] [ JLink] - WEBSRV WEBSRV_Init(): Starting webserver thread(s)
    [2023-Dec-03 11:51:01] [trace] [ JLink] - WEBSRV Failed to put socket into listener state (port 19080)
    [2023-Dec-03 11:51:01] [trace] [ JLink] - WEBSRV Webserver running on local port 19081
    [2023-Dec-03 11:51:01] [trace] [ JLink] - Looking for J-Link GUI Server exe at: /Applications/SEGGER/JLink_V794/JLinkGUIServerExe
    [2023-Dec-03 11:51:01] [trace] [ JLink] - Forking J-Link GUI Server: /Applications/SEGGER/JLink_V794/JLinkGUIServerExe
    [2023-Dec-03 11:51:01] [trace] [ JLink] - J-Link GUI Server info: "J-Link GUI server V7.94 "
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 21.776ms returns "O.K."
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_HasError()
    [2023-Dec-03 11:51:01] [trace] [ Client] - Command connect_to_emu_with_snr executed for 49 milliseconds with result 0
    [2023-Dec-03 11:51:01] [debug] [ Client] - read_connected_emu_snr
    [2023-Dec-03 11:51:01] [trace] [ Client] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2023-Dec-03 11:51:01] [debug] [ Client] - read_device_info
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_Lock()
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_ExecCommand("SetRestartOnClose = 0", ...).
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.005ms returns 0x01
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_ExecCommand("DisableFlashDL", ...).
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.001ms returns 0x00
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_ExecCommand("ExcludeFlashCacheRange 0x0-0xFFFFFFFF", ...).
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.002ms returns 0x00
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_SetHookUnsecureDialog
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_SetHookUnsecureDialog(...)
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.006ms returns 0
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_TIF_Select(JLINKARM_TIF_SWD)
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 1.120ms returns 0x00
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_GetSpeedInfo()
    [2023-Dec-03 11:51:01] [trace] [ JLink] - 180000000 Hz / n, n >= 12
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - Connected emulator supports SWD speeds up to 15000kHz
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_SetSpeed(2000)
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.173ms
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_GetSpeed()
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.002ms returns 2000
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - SWD clock set to 2000kHz
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_GetSN()
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.001ms returns 51028748
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.003ms
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - read_device_family
    [2023-Dec-03 11:51:01] [trace] [ Worker] - Command connect_to_emu_with_snr executed for 44 milliseconds with result 0
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - read_connected_emu_snr
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_IsOpen()
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.007ms returns 0x01
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - read_connected_emu_snr
    [2023-Dec-03 11:51:01] [trace] [ Worker] - Command read_connected_emu_snr executed for 0 milliseconds with result 0
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - read_device_info
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.001ms returns 0x01
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - Just_read_device_version
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - Just_readback_status
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - Just_is_ctrl_ap_available
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - read_access_port_register
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - ---just_read_access_port_register
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - coresight_configure
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_GetHWStatus(...)
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 1.460ms returns 0
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_CORESIGHT_Configure()
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 102.155ms returns 0
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - read_debug_port_idr
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - read_debug_port_register
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - ---just_read_debug_port_register
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - ---just_select_debug_port_register
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - Select AP 255, DP Bank 0, AP Bank 255
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x02, 0x00000000)
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.582ms returns -1
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - ---just_abort_debug_action
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - Attempting to clear any configuration errors in debug port before closing connection.
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_CORESIGHT_WriteAPDPReg(DP reg 0x00, 0x0000001F)
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.606ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.666ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.644ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.583ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.617ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.648ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.645ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.612ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.611ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.559ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.631ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.574ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.750ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.781ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.629ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.638ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.647ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.663ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.624ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.580ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.567ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.632ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.596ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.591ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.614ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.604ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.625ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.539ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.557ms returns -1
    [2023-Dec-03 11:51:01] [error] [ Client] - Encountered error -102: Command read_device_info executed for 134 milliseconds with result -102
    [2023-Dec-03 11:51:01] [warning] Failed to read device info. Attempting to complete command anyways.
    [2023-Dec-03 11:51:01] [debug] [ Client] - read_memory_descriptors
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.602ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.544ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.554ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.593ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.608ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.125ms
    [2023-Dec-03 11:51:01] [error] [ Worker] - An unknown error.
    [2023-Dec-03 11:51:01] [trace] [ Worker] - Command read_device_info executed for 131 milliseconds with result -102
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - read_memory_descriptors
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - Just_read_memory_descriptors
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - ---just_is_debug_region_powered
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.709ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.633ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.641ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.673ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.665ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.637ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.659ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.621ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.692ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.703ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.679ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.743ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.770ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.620ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.639ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.581ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.610ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.635ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.615ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.538ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.556ms returns -1
    [2023-Dec-03 11:51:01] [error] [ Client] - Encountered error -102: Command read_memory_descriptors executed for 31 milliseconds with result -102
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.626ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.562ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.701ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.108ms
    [2023-Dec-03 11:51:01] [trace] [ Worker] - Command read_memory_descriptors executed for 28 milliseconds with result -102
    [2023-Dec-03 11:51:01] [debug] [ nRF52] - close
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.009ms returns 0x01
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - close
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - disconnect_from_emu
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - ---just_disconnect_from_emu
    [2023-Dec-03 11:51:01] [debug] [SeggerBackend] - is_connected_to_device
    [2023-Dec-03 11:51:01] [trace] [ JLink] - JLINK_IsConnected()
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.002ms returns FALSE
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.689ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.584ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.600ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.607ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.650ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.587ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.603ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.605ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.597ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.592ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.599ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.566ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.546ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.560ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.630ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.757ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.658ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.690ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.680ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.634ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.664ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.681ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.649ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.735ms returns -1
    [2023-Dec-03 11:51:01] [trace] [ JLink] - - 0.677ms returns -1
    Try first to recover your board:
    nrfjprog --recover -f nrf52
    And if your design does not have external LFCLK and/or DCDC inductors, you will need to adjust your prj.conf, as shown here:
     RE: Enabling LDO or DCDC on nrf connect sdk
    Håkon
  • Hi Håkon, thanks for the suggestion, sadly that recover command doesn't seem to work:
    nrfjprog --recover -f nrf52 --log
    Recovering device. This operation might take 30s.
    [error] [ Client] - Encountered error -21: Command recover executed for 131 milliseconds with result -21
    ERROR: Recover failed. Please make sure that the correct device family is given
    ERROR: and try again.
    Is there anything else I can try?
    Alex
  • Hi again Håkon, a little bit of persistence and I've got it back working!
    I added the -c option to set the clock speed to 4kHz and that worked - maybe this means my board isn't be best layout?!
    nrfjprog -f NRF52 -c 4 --recover
    Thanks for your help, and I'm now going on to try the options about the LFCLK and DCDC convertor, but thought I'd let you know I'd made progress - thanks!
    Alex
  • Hi again Håkon, I reckon this might be the last post on this tonight, but I set the LFCLK option in the prj.conf file
    as you suggested, and I can now run my program (in debug) and connect to the board over Bluetooth, so thanks ever so much for your help!
    I'll do some research on how to set the board to run my code on boot, but thought I'd mark your answer as an answer, as with that config setting and
    you've got me from a bricked board back to developing again, and that's brilliant, thank you!
    Alex
