Incomplete installation on MacOS, file permission issue ?
Hi All,
After hours of reading this forum, I could not find a solution to an annoying issue I have with nRF Connect SDK installation on macOS Sonoma.
Please kindly note that I don't want to go through manual installation ;-)
Whenever I try to install the SDK (both via the nRF Connect for desktop App or from with Visual Studio Code):
- in my development account, the SDK directory is not populated at first and further, any attempt to "Update SDK" does not populate it neither
- in my "root" account, the SDK directory is properly populated and the visual studio environment is ready for development.
    - but when back in my account, the visual studio nRF panel, "WELCOME" zone, only allows to create a blank application: the "copy from sample" is missing.
I have redone the automatic process many times, rebooted in between, deleted the installed directories, ...
No way to succeed
Any help would be much appreciated !
  • Ok, could you try the following command to update to the latest version of west?
    pip3 install west
  • Hi Charlie,
    I really value your continuous interest in this issue. Thanks !
    I have tried "pip3 install west" under my, admin enabled, account, then deletion of the nordic nordic directory together with the nRF Connect for Desktop.
    However, the reinstallation from the nRF Connect for Desktop still yields in an empty v2.5.0 directory.
    And from within the VS Studio Code nRF extension, the toolchain installation seems to succeed but the SDK installation stil fails.
    I am hintless !
  • Ok, I also run out of idea now.
    Do you have any chance to test on another Mac?
    Maybe this will help to do some comparison.
    Charlie
  • Hi all,
    I had put my development on hold, hoping a new release would solve this issue.
    But since I cannot wait any longer I tried again.
    It seems Nrf Connect for desktop is more verbose and I got the following error messages.
    I have tried to reinstall everything from scratch with Admin rights attached to my account, no way to have it work, again :-(
    Is it of any helps to solve my issues .
    Again, any support for this nice community would be much appreciated
    There are multiple errors:
    Failed to clone the repositories: Error: Cloning into '/opt/nordic/ncs/v2.5.1/.west/manifest-tmp'... Note: switching to '87355af5914e498f449b7a68bb5641031a7b8885'.
    You are in 'detached HEAD' state. You can look around, make experimental changes and commit them, and you can discard any commits you make in this state without impacting any branches by switching back to a branch.
    If you want to create a new branch to retain commits you create, you may do so (now or later) by using -c with the switch command. Example:
    git switch -c <new-branch-name>
    Or undo this operation with:
    git switch -
    Turn off this advice by setting config variable advice.detachedHead to false
    Updating files: 50% (4054/8086) Updating files: 51% (4124/8086) Updating files: 52% (4205/8086) Updating files: 53% (4286/8086) Updating files: 54% (4367/8086) Updating files: 55% (4448/8086) Updating files: 56% (4529/8086) Updating files: 57% (4610/8086) Updating files: 58% (4690/8086) Updating files: 59% (4771/8086) Updating files: 60% (4852/8086) Updating files: 61% (4933/8086) Updating files: 62% (5014/8086) Updating files: 63% (5095/8086) Updating files: 64% (5176/8086) Updating files: 65% (5256/8086) Updating files: 66% (5337/8086) Updating files: 67% (5418/8086) Updating files: 68% (5499/8086) Updating files: 69% (5580/8086) Updating files: 70% (5661/8086) Updating files: 71% (5742/8086) Updating files: 72% (5822/8086) Updating files: 73% (5903/8086) Updating files: 74% (5984/8086) Updating files: 75% (6065/8086) Updating files: 76% (6146/8086) Updating files: 77% (6227/8086) Updating files: 78% (6308/8086) Updating files: 79% (6388/8086) Updating files: 80% (6469/8086) Updating files: 81% (6550/8086) Updating files: 82% (6631/8086) Updating files: 83% (6712/8086) Updating files: 84% (6793/8086) Updating files: 85% (6874/8086) Updating files: 86% (6954/8086) Updating files: 87% (7035/8086) Updating files: 88% (7116/8086) Updating files: 89% (7197/8086) Updating files: 90% (7278/8086) Updating files: 91% (7359/8086) Updating files: 92% (7440/8086) Updating files: 93% (7520/8086) Updating files: 94% (7601/8086) Updating files: 95% (7682/8086) Updating files: 96% (7763/8086) Updating files: 97% (7844/8086) Updating files: 98% (7925/8086) Updating files: 99% (8006/8086) Updating files: 100% (8086/8086) Updating files: 100% (8086/8086), done. Traceback (most recent call last): File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/manifest.py", line 1296, in init validate(source_data) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/manifest.py", line 474, in validate raise ManifestVersionError(min_version_str) west.manifest.ManifestVersionError: ('0.13', None)
    The above exception was the direct cause of the following exception:
    Traceback (most recent call last): File "/opt/nordic/ncs/toolchains/20d68df7e5/bin/west", line 8, in <module> sys.exit(main()) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/app/main.py", line 781, in main app.run(argv or sys.argv[1:]) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/app/main.py", line 106, in run self.run_command(argv) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/app/main.py", line 336, in run_command cmd.run(args, unknown, self.topdir, manifest=self.manifest) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/commands.py", line 140, in run self.do_run(args, unknown) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/app/project.py", line 198, in do_run topdir = self.bootstrap(args) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/app/project.py", line 286, in bootstrap projects = Manifest.from_file(temp_manifest, File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/manifest.py", line 1153, in from_file return Manifest(**kwargs) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/manifest.py", line 1298, in init raise ManifestVersionError(mv.version, file=source_file) from mv west.manifest.ManifestVersionError: ('0.13', PosixPath('/opt/nordic/ncs/v2.5.1/.west/manifest-tmp/west.yml')) Error: Launched process exited with non-zero status: 1
    git switch -
  • Hi Charlie,
    I have posted an update. Would it be useful to better understand the issue and solve it ?
    TIA for any help
    Rgds
