Incomplete installation on MacOS, file permission issue ?
Hi All,
After hours of reading this forum, I could not find a solution to an annoying issue I have with nRF Connect SDK installation on macOS Sonoma.
Please kindly note that I don't want to go through manual installation ;-)
Whenever I try to install the SDK (both via the nRF Connect for desktop App or from with Visual Studio Code):
- in my development account, the SDK directory is not populated at first and further, any attempt to "Update SDK" does not populate it neither
- in my "root" account, the SDK directory is properly populated and the visual studio environment is ready for development.
    - but when back in my account, the visual studio nRF panel, "WELCOME" zone, only allows to create a blank application: the "copy from sample" is missing.
I have redone the automatic process many times, rebooted in between, deleted the installed directories, ...
No way to succeed
Any help would be much appreciated !
  • Hi Rgds,
    Sorry to hear the problem still exists. Let's collect a bit more information from your setup and installation process.
    From the above page, you can click "create system report" to generate a report about your system and share it here.
    I assume you have turned on the "VERBOSE LOGGING" switch. You can rerun installing nRF Connect SDK v2.5.1, then click "OPEN LOG FILE", a detailed log file will open and you can share it here.
    Charlie
  • Hi Charlie,
    Thanks for looking again at this issue. Much appreciated !
    *************** Here is the System report
    # nRFConnect System Report - 2024-01-08T20-44-13.311Z
    - System: Apple Inc. MacBookPro15,1
    - BIOS: Apple Inc. 2020.61.1.0.0
    - CPU: 1 x Intel CoreTm i7-8750H 2.2 GHz 12 cores (6 physical)
    - Memory: 302.1 MB free of 16 GB total
    - Filesystem: /dev/disk1s5s1 (APFS) 931.5 GB 10.6% used
    - OS: macOS (14.2.1) darwin x64
    - Versions
    - kernel: 23.2.0
    - git: 2.39.3
    - node: 16.17.1
    - python:
    - python3: 3.9.6
    - Connected devices:
    Here attached are two files : the content of the error panel and the log file as requested
    Error
    There are multiple errors:
    Failed to clone the repositories: Error: Cloning into '/opt/nordic/ncs/v2.5.1/.west/manifest-tmp'... Note: switching to '87355af5914e498f449b7a68bb5641031a7b8885'.
    You are in 'detached HEAD' state. You can look around, make experimental changes and commit them, and you can discard any commits you make in this state without impacting any branches by switching back to a branch.
    If you want to create a new branch to retain commits you create, you may do so (now or later) by using -c with the switch command. Example:
    git switch -c <new-branch-name>
    Or undo this operation with:
    git switch -
    Turn off this advice by setting config variable advice.detachedHead to false
    Updating files: 57% (4629/8086) Updating files: 58% (4690/8086) Updating files: 59% (4771/8086) Updating files: 60% (4852/8086) Updating files: 61% (4933/8086) Updating files: 62% (5014/8086) Updating files: 63% (5095/8086) Updating files: 64% (5176/8086) Updating files: 65% (5256/8086) Updating files: 66% (5337/8086) Updating files: 67% (5418/8086) Updating files: 68% (5499/8086) Updating files: 69% (5580/8086) Updating files: 70% (5661/8086) Updating files: 71% (5742/8086) Updating files: 72% (5822/8086) Updating files: 73% (5903/8086) Updating files: 74% (5984/8086) Updating files: 75% (6065/8086) Updating files: 76% (6146/8086) Updating files: 77% (6227/8086) Updating files: 78% (6308/8086) Updating files: 79% (6388/8086) Updating files: 80% (6469/8086) Updating files: 81% (6550/8086) Updating files: 82% (6631/8086) Updating files: 83% (6712/8086) Updating files: 84% (6793/8086) Updating files: 85% (6874/8086) Updating files: 86% (6954/8086) Updating files: 87% (7035/8086) Updating files: 88% (7116/8086) Updating files: 89% (7197/8086) Updating files: 90% (7278/8086) Updating files: 91% (7359/8086) Updating files: 92% (7440/8086) Updating files: 93% (7520/8086) Updating files: 94% (7601/8086) Updating files: 95% (7682/8086) Updating files: 96% (7763/8086) Updating files: 97% (7844/8086) Updating files: 98% (7925/8086) Updating files: 99% (8006/8086) Updating files: 100% (8086/8086) Updating files: 100% (8086/8086), done. Traceback (most recent call last): File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/manifest.py", line 1296, in init validate(source_data) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/manifest.py", line 474, in validate raise ManifestVersionError(min_version_str) west.manifest.ManifestVersionError: ('0.13', None)
    The above exception was the direct cause of the following exception:
    Traceback (most recent call last): File "/opt/nordic/ncs/toolchains/20d68df7e5/bin/west", line 8, in <module> sys.exit(main()) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/app/main.py", line 781, in main app.run(argv or sys.argv[1:]) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/app/main.py", line 106, in run self.run_command(argv) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/app/main.py", line 336, in run_command cmd.run(args, unknown, self.topdir, manifest=self.manifest) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/commands.py", line 140, in run self.do_run(args, unknown) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/app/project.py", line 198, in do_run topdir = self.bootstrap(args) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/app/project.py", line 286, in bootstrap projects = Manifest.from_file(temp_manifest, File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/manifest.py", line 1153, in from_file return Manifest(**kwargs) File "/Users/myAccount/Library/Python/3.9/lib/python/site-packages/west/manifest.py", line 1298, in init raise ManifestVersionError(mv.version, file=source_file) from mv west.manifest.ManifestVersionError: ('0.13', PosixPath('/opt/nordic/ncs/v2.5.1/.west/manifest-tmp/west.yml')) Error: Launched process exited with non-zero status: 1
    git switch -
    Close
    LogFile_2024-01-08_21-51.txt
    Thanks in advance
    Regards
    JRSN
  • Hi JRSN,
    Thanks for the information. I am still looking for the cause for "Failed to clone the repositories: Error: Cloning into '/opt/nordic/ncs/v2.5.1/.west/manifest-tmp'" error.
    Just wondering if you have tested on another network environment like home if you only tested in the office or vice versa?
    Another worth trying might be simply testing on a Windows PC to see if the issue also exists.
    Charlie
  • Hi Charlie,
    I wish I could try on another computer or environment but I cannot. Sorry not to be able to help solving this issue with such a try.
    Dis you manage to understand the cloning issue ?
    Thanks for your help
    Regards
    JRSN
  • No, I did not see any other similar issue reports by far.
    May I know your network environment? Is this a PC in the office or school for dedicated usage?
    Charlie
