Sorry for the strange ramblings, I'm new. I have such a simple question, I want to run LED Driver SCT2024CSSG to NRF52810, it needs a CLK signal, how should I write it? Can all conclusions be connected?
I will look into this and come back to you with an answer when I have something more constructive for you, hopefully within tomorrow!
Andreas
Hi again,
Could you specify which SDK you're using? I see you're developing for the nRF52810 so I'm curious if this you're using nRF5 SDK or nRF Connect SDK (NCS)
Andreas
Thanks for the reply.
Yes, I am using nRF52810 microcontroller.
Yes, I am using the nRF SDK.
Andrius
You need to specify if it is "nRF5 SDK" or "nRF Connect SDK". "nRF SDK" does not specify which you're using
Andreas
Thanks for the replies, but this case can be closed. Everything worked out.
