How to set pin always on
 I've tried the following code derived from the blinky example, and a couple other things i've seen online, but i can't seem to turn pin 1.11 on.
struct gpio_dt_spec pin_dev = GPIO_DT_SPEC_GET(DT_NODELABEL(led0), gpios);
const struct device *port = DEVICE_DT_GET(DT_NODELABEL(gpio1));
const gpio_pin_t pin = 11;
	int err;
	if (!device_is_ready(pin_dev.port)) {
		return;
	err = gpio_pin_configure_dt(&pin_dev, GPIO_OUTPUT_ACTIVE);
	printk("Pin 1.11 has the value: %x and error code: %d\n", gpio_pin_get_raw(port, pin), err);
	return;
Outputs:
Pin 1.11 has the value: 0 and error code: 0
How do i set the pin?
Note: I've tried removing CONFIG_BT from the project as this suggests that might be the problem, but it still doesn't set the pin.
