How to use M95P32 to replace the current external flash
We're going to use external SPI EEPROM, but which is working on the DK board's MX25R64
How to configure MCUboot&OTA using external SPI EEPROM memory?
I expect to get all the configuration processes and files that must be modified, such as overlay and conf modification methods,Thanks!
OS: windows 10
Hardware used: nrf5340 dk
example:C:\ncs\v2.4.1\nrf\samples\matter\lock
  • Hi Sigurd
    Anyway, QSPI is currently disabled and M95P32 control via SPI has been completed,
    is MCU BOOT section able to describe clearly how to implement this?
  • Hi Sigurd
    The compiler will report an error when I modify the "child image"
     *  Executing task: nRF Connect: Build: DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build (active)
    Building DL02_S2MB_KPD_Small
    west build --build-dir c:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build c:/nordic/DL02_S2MB_KPD_Small
    [0/1] Re-running CMake...
    Loading Zephyr default modules (Zephyr base (cached)).
    -- Application: C:/nordic/DL02_S2MB_KPD_Small
    -- CMake version: 3.20.5
    -- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found suitable version "3.8.2", minimum required is "3.8") found components: Interpreter
    -- Cache files will be written to: C:/ncs/v2.5.0/zephyr/.cache
    -- Zephyr version: 3.4.99 (C:/ncs/v2.5.0/zephyr)
    -- Found west (found suitable version "1.1.0", minimum required is "0.14.0")
    -- Board: nrf5340dk_nrf5340_cpuapp
    -- Found host-tools: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
    -- Found toolchain: zephyr 0.16.1 (C:/ncs/toolchains/c57af46cb7/opt/zephyr-sdk)
    -- Found BOARD.dts: C:/ncs/v2.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpuapp.dts
    -- Found devicetree overlay: c:/nordic/DL02_S2MB_KPD_Small/boards/nrf5340dk_nrf5340_cpuapp.overlay
    node '/soc/peripheral@50000000/i2c@9000/outside@5B' compatible 'sunion,outside' has unknown vendor prefix 'sunion'
    node '/soc/peripheral@50000000/i2c@9000/store@50' compatible 'sunion,eeprom' has unknown vendor prefix 'sunion'
    node '/soc/peripheral@50000000/i2c@9000/timer@32' compatible 'sunion,rtc' has unknown vendor prefix 'sunion'
    -- Generated zephyr.dts: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/zephyr/dts.cmake
    Parsing C:/nordic/DL02_S2MB_KPD_Small/Kconfig
    Loaded configuration 'C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/zephyr/.config'
    No change to configuration in 'C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/zephyr/.config'
    No change to Kconfig header in 'C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/zephyr/include/generated/autoconf.h'
    warning: Deprecated symbol IEEE802154_2015 is enabled.
    warning: Deprecated symbol CPLUSPLUS is enabled.
    warning: Deprecated symbol LIB_CPLUSPLUS is enabled.
    === child image multiprotocol_rpmsg - CPUNET begin ===
    loading initial cache file C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/child_image_preload.cmake
    -- Application: C:/ncs/v2.5.0/nrf/samples/nrf5340/multiprotocol_rpmsg
    -- Board: nrf5340dk_nrf5340_cpunet
    -- Found BOARD.dts: C:/ncs/v2.5.0/zephyr/boards/arm/nrf5340dk_nrf5340/nrf5340dk_nrf5340_cpunet.dts
    -- Generated zephyr.dts: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/zephyr/dts.cmake
    Parsing C:/ncs/v2.5.0/modules/lib/matter/config/nrfconnect/chip-module/Kconfig.multiprotocol_rpmsg.root
    Loaded configuration 'C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/zephyr/.config'
    No change to configuration in 'C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/zephyr/.config'
    No change to Kconfig header in 'C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/zephyr/include/generated/autoconf.h'
    === child image b0n - CPUNET (inherited) begin ===
    loading initial cache file C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/b0n/child_image_preload.cmake
    -- Application: C:/ncs/v2.5.0/nrf/samples/nrf5340/netboot
    -- Generated zephyr.dts: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/b0n/zephyr/zephyr.dts
    -- Generated devicetree_generated.h: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/b0n/zephyr/include/generated/devicetree_generated.h
    -- Including generated dts.cmake file: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/b0n/zephyr/dts.cmake
    Parsing C:/ncs/v2.5.0/nrf/samples/nrf5340/netboot/Kconfig
    Loaded configuration 'C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/b0n/zephyr/.config'
    No change to configuration in 'C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/b0n/zephyr/.config'
    No change to Kconfig header in 'C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/b0n/zephyr/include/generated/autoconf.h'
    CMake Warning at C:/ncs/v2.5.0/zephyr/CMakeLists.txt:1958 (message):
    -- Configuring done
    -- Generating done
    -- Build files have been written to: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/multiprotocol_rpmsg/b0n
    === child image b0n - CPUNET (inherited) end ===
    CMake Warning at ../../../subsys/bootloader/cmake/debug_keys.cmake:36 (message):
          --- WARNING: Using generated NSIB public/private key-pair. ---
          --- It should not be used for production.                  ---
          --- See CONFIG_SB_SIGNING_KEY_FILE                         ---
      ../../../subsys/bootloader/cmake/provision_hex.cmake:47 (include)
      ../../../subsys/CMakeLists.txt:20 (include)
    -- libmetal version: 1.4.0 (C:/ncs/v2.5.0/nrf/samples/nrf5340/multiprotocol_rpmsg)
    -- Build type:
    -- Host:    Windows/AMD64
    -- Target:  Generic/arm
    -- Machine: arm
    -- open-amp version: 1.4.0 (C:/ncs/v2.5.0/modules/lib/open-amp/open-amp)
    -- Machine: arm
    -- C_FLAGS :  -Wall -Wextra
    CMake Warning at C:/ncs/v2.5.0/zephyr/CMakeLists.txt:893 (message):
      No SOURCES given to Zephyr library: drivers__console
      Excluding target from build.
    CMake Warning at C:/ncs/v2.5.0/nrf/cmake/partition_manager.cmake:79 (message):
              --- WARNING: Using a bootloader without pm_static.yml.            ---
              --- There are cases where a deployed product can consist of       ---
              --- multiple images, and only a subset of these images can be     ---
              --- upgraded through a firmware update mechanism. In such cases,  ---
              --- the upgradable images must have partitions that are static    ---
              --- and are matching the partition map used by the bootloader     ---
              --- programmed onto the device.                                   ---
      C:/ncs/v2.5.0/zephyr/cmake/modules/kernel.cmake:247 (include)
      C:/ncs/v2.5.0/zephyr/cmake/modules/zephyr_default.cmake:138 (include)
      C:/ncs/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:66 (include)
      C:/ncs/v2.5.0/zephyr/share/zephyr-package/cmake/ZephyrConfig.cmake:97 (include_boilerplate)
      CMakeLists.txt:5 (find_package)
    -- Configuring done
    -- Generating done
    === child image multiprotocol_rpmsg - CPUNET end ===
    -- Found Python3: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe (found version "3.8.2") found components: Interpreter
    === child image mcuboot -  begin ===
    loading initial cache file C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/child_image_preload.cmake
    -- Application: C:/ncs/v2.5.0/bootloader/mcuboot/boot/zephyr
    -- Found devicetree overlay: C:/ncs/v2.5.0/nrf/modules/mcuboot/flash_sim.overlay
    -- Found devicetree overlay: C:/nordic/DL02_S2MB_KPD_Small/child_image/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.overlay
    devicetree error: /chosen: undefined node label 'eeprom_m95p32'
    CMake Error at C:/ncs/v2.5.0/zephyr/cmake/modules/dts.cmake:279 (message):
    -- In: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/zephyr, command: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe;C:/ncs/v2.5.0/zephyr/scripts/dts/gen_defines.py;--dts;C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/zephyr/zephyr.dts.pre;--dtc-flags;'-Wno-unique_unit_address_if_enabled';--bindings-dirs;C:/ncs/v2.5.0/nrf/dts/bindings;C:/ncs/v2.5.0/zephyr/dts/bindings;--header-out;C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/zephyr/include/generated/devicetree_generated.h.new;--dts-out;C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/zephyr/zephyr.dts.new;--edt-pickle-out;C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/zephyr/edt.pickle;--vendor-prefixes;C:/ncs/v2.5.0/nrf/dts/bindings/vendor-prefixes.txt;--vendor-prefixes;C:/ncs/v2.5.0/zephyr/dts/bindings/vendor-prefixes.txt
      gen_defines.py failed with return code: 1
      C:/ncs/v2.5.0/zephyr/cmake/modules/zephyr_default.cmake:129 (include)
      CMakeLists.txt:31 (find_package)
    See also "C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/CMakeFiles/CMakeOutput.log".
    See also "C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/CMakeFiles/CMakeError.log".
    CMake Error at C:/ncs/v2.5.0/nrf/cmake/multi_image.cmake:449 (message):
      CMake generation for mcuboot failed, aborting.  Command: 1
      C:/ncs/v2.5.0/nrf/cmake/multi_image.cmake:178 (add_child_image_from_source)
      C:/ncs/v2.5.0/nrf/modules/mcuboot/CMakeLists.txt:268 (add_child_image)
    See also "C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/CMakeFiles/CMakeOutput.log".
    See also "C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/CMakeFiles/CMakeError.log".
    FAILED: build.ninja
    C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.exe --regenerate-during-build -SC:\nordic\DL02_S2MB_KPD_Small -BC:\nordic\DL02_S2MB_KPD_Small\DL02_S2MB_KPD_Small_build
    ninja: error: rebuilding 'build.ninja': subcommand failed
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' --build 'c:\nordic\DL02_S2MB_KPD_Small\DL02_S2MB_KPD_Small_build'
     *  The terminal process terminated with exit code: 1.
  • The error is "devicetree error: /chosen: undefined node label 'eeprom_m95p32'"
    Can you share the file where you define the dts for eeprom_m95p32?
    If you build without the "chosen" part for DTS, can you share build/zephyr/zephyr.dts for that build?
  • Hi Sigurd
    I only modified "overlay", is there any additional operation required?
    nrf5340dk_nrf5340_cpuapp.7z
