How to use M95P32 to replace the current external flash
We're going to use external SPI EEPROM, but which is working on the DK board's MX25R64
How to configure MCUboot&OTA using external SPI EEPROM memory?
I expect to get all the configuration processes and files that must be modified, such as overlay and conf modification methods,Thanks!
OS: windows 10
Hardware used: nrf5340 dk
example:C:\ncs\v2.4.1\nrf\samples\matter\lock
  • I tried to add your configurations to the hello world example, and I do not get the error. Am I missing anything?
    tmp.zip
  • Hi Sigurd
    At present, my APP code has been roughly completed.
    But our products need to use external EEPROM for OTA.
    Can you test it with the "v2.5.2\nrf\samples\matter\lock" to confirm whether there are build errors?
    Since it is 25 days since last time I looked at this ticket:
    Could you upload what I should test with the lock sample again?
    That way we are sure we avoid misunderstandings.
  • Hi Sigurd
    The information you have requested is attached below. Please accept my apologies for the delayed response.
    -- In: C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/zephyr, command: C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe;C:/ncs/v2.5.0/zephyr/scripts/dts/gen_defines.py;--dts;C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/zephyr/zephyr.dts.pre;--dtc-flags;'-Wno-unique_unit_address_if_enabled';--bindings-dirs;C:/ncs/v2.5.0/nrf/dts/bindings;C:/ncs/v2.5.0/zephyr/dts/bindings;--header-out;C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/zephyr/include/generated/devicetree_generated.h.new;--dts-out;C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/zephyr/zephyr.dts.new;--edt-pickle-out;C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/mcuboot/zephyr/edt.pickle;--vendor-prefixes;C:/ncs/v2.5.0/nrf/dts/bindings/vendor-prefixes.txt;--vendor-prefixes;C:/ncs/v2.5.0/zephyr/dts/bindings/vendor-prefixes.txt
    CMake Error at C:/ncs/v2.5.0/nrf/cmake/multi_image.cmake:449 (message):
      CMake generation for mcuboot failed, aborting.  Command: 1
      C:/ncs/v2.5.0/nrf/cmake/multi_image.cmake:178 (add_child_image_from_source)
      C:/ncs/v2.5.0/nrf/modules/mcuboot/CMakeLists.txt:268 (add_child_image)
    See also "C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/CMakeFiles/CMakeOutput.log".
    See also "C:/nordic/DL02_S2MB_KPD_Small/DL02_S2MB_KPD_Small_build/CMakeFiles/CMakeError.log".
    FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\c57af46cb7\opt\bin\cmake.EXE' -DWEST_PYTHON=C:/ncs/toolchains/c57af46cb7/opt/bin/python.exe '-Bc:\nordic\DL02_S2MB_KPD_Small\DL02_S2MB_KPD_Small_build' -GNinja -DBOARD=nrf5340dk_nrf5340_cpuapp -DNCS_TOOLCHAIN_VERSION=NONE '-DBOARD_ROOT=c:/nordic/dl02_s2mb_kpd_small;.' -DCONF_FILE=c:/nordic/DL02_S2MB_KPD_Small/prj.conf -DDTC_OVERLAY_FILE=c:/nordic/DL02_S2MB_KPD_Small/boards/nrf5340dk_nrf5340_cpuapp.overlay '-Sc:\nordic\DL02_S2MB_KPD_Small'
     *  The terminal process terminated with exit code: 1.
    config.7z
  • the error message is
    -- Found devicetree overlay: /home/sihe/ncs/nrf/samples/matter/lock/child_image/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.overlay
    You must include the configuration of eeprom_m95p32
    I guess that you are missing some configurations related to eeprom_m95p32 from child_image/mcuboot/boards/nrf5340dk_nrf5340_cpuapp.overlay.
