fatal error: app_version.h: No such file or directory when using nRF5340 DK and nRF Connect for VSC and trying to implement Zephyr versioning
I am using the nRF Connect for Visual Studio Code Add-In running with the nRF Connect 2.5.0 toolchain and was trying to implement the application versioning on a nRF5340 DK following https://docs.zephyrproject.org/latest/build/version/index.html, but I get a fatal error: app_version.h: No such file or directory. I might be missing something but was reading:
To use the version information in application code, the version file must be included, then the fields can be freely used. The include file name is app_version.h (no path is needed)
So, it seems like it should work. I've tried with "" and <>.
    Have you prepared a VERSION file for your project? If yes: is it located in the same directory as prj.conf? These requirements are described in the VERSION file section of the documentation you linked.
    Maria
  • The answer is yes to both questions. It's hard to tell what might cause the error, but given it's an include problem, would that be the issue?
    Thank you for your patience.
    I want to be sure that we are using the same methods. Please follow these instructions and report if you get the same build error:
    1. Verify that your toolchain version matches the NCS version.
    2. Add ncs/zephyr/samples/hello_world as an application in the nRF Connect for VS Code extension
    3. Create VERSION and save it to hello_world.
    4. Add
      VERSION_MAJOR = 1
      VERSION_MINOR = 2
      PATCHLEVEL = 3
      VERSION_TWEAK = 4
      EXTRAVERSION = unstable
       to VERSION
    5. Add #include <app_version.h> to hello_world/src/main.c
    6. Create a build configuration for hello_world with nrf5340dk_nrf5340_cpuapp as the build target and build the sample.
    Maria
  • I installed and set my apps toolchain to v2.5.0 and it's working now. I didn't really know what step 1 meant. I'm not even sure I know how to change the toolchains.
  • Have followed these instructions to the letter, but not working. File named VERSION
    VERSION_MAJOR = 1
    VERSION_MINOR = 0
    PATCHLEVEL = 2
    VERSION_TWEAK = 0
    EXTRAVERSION = dev
    located at app root, next to prj.conf.
    Then in main.c
    // #include <app_version.h>
    #include <zephyr/app_version.h>
        LOG_INF("Version: %s, protocol: %s", CONFIG_APP_VERSION_STRING, protocol);
    Note - also, checked `docs.zephyrproject.org/.../index.html` which suggested slightly different #include. Also, does not work.
    Error =
    C:/ncs/smpl/src/main.c: In function 'main':
    C:/ncs/smpl/src/main.c:69:37: error: 'CONFIG_APP_VERSION_STRING' undeclared (first use in this function); did you mean 'CONFIG_APP_VERSION_SHELL'?
       69 |                 CONFIG_APP_VERSION, CONFIG_APP_VERSION_STRING, protocol);
