IRQ_CONNECT duplication causing gen_isr_tables.py to fail
(Kubuntu, NRF5340, nRF ver 2.5.99)
I'm having an issue with the build system - I am working on a project that is based off of the audio sample - I am using a very stripped version that just has USB and I2S enabled for testing purposes.
When I try to build it, it fails on the ISR table generation, saying that I have the IRQ_CONNECT macro in multiple places in my code. (IRQ 40, in this case).
gen_isr_tables.py: (69, 0)
gen_isr_tables.py: Configured interrupt routing
gen_isr_tables.py: handler    irq flags param
gen_isr_tables.py: --------------------------
gen_isr_tables.py: 0x24d07    40  0     0x17379
gen_isr_tables.py: 0x24d07    55  0     0x1a821
gen_isr_tables.py: 0x24d07    54  0     0x1a4b9
gen_isr_tables.py: 0xf10d     14  0     0x26ac8
gen_isr_tables.py: 0x24d07    5   0     0x256bd
gen_isr_tables.py: 0x24d07    13  0     0x16c65
gen_isr_tables.py: 0x24d07    9   0     0x18b89
gen_isr_tables.py: 0x24d07    42  0     0x1752d
gen_isr_tables.py: 0x2241d    8   0     0x26aa0
gen_isr_tables.py: 0x24d07    10  0     0x17fa1
gen_isr_tables.py: 0x130a1    21  0     0x0
gen_isr_tables.py: 0x24d07    24  0     0x1aabd
gen_isr_tables.py: offset is 0
gen_isr_tables.py: num_vectors is 69
gen_isr_tables.py: error: multiple registrations at table_index 40 for irq 40 (0x28)
Existing handler 0x24d07, new handler 0x24d07
Has IRQ_CONNECT or IRQ_DIRECT_CONNECT accidentally been invoked on the same irq multiple times?
Whats odd, is I find that when I comment out the following line in audio_i2s_init(), the build passes and the ISR tied to (40) 0x28 still exists, so I don't believe it's a case of the macro appearing twice.
IRQ_CONNECT(DT_IRQN(I2S_NL), DT_IRQ(I2S_NL, priority), nrfx_isr, nrfx_i2s_0_irq_handler, 0);
Some notes:
- The regular Audio application builds just fine and spits out the following irq table:
[453/456] Generating isr_tables.c, isrList.bin
gen_isr_tables.py: 0x77b81    40  0     0x4915d
gen_isr_tables.py: 0x3e149    14  0     0x7ad00
gen_isr_tables.py: 0x77b81    5   0     0x48061
gen_isr_tables.py: 0x77b81    13  0     0x48af5
gen_isr_tables.py: 0x77b81    9   0     0x4a9a1
gen_isr_tables.py: 0x77b81    42  0     0x49311
gen_isr_tables.py: 0x75031    8   0     0x7acc4
gen_isr_tables.py: 0x77b81    10  0     0x49d41
gen_isr_tables.py: 0x44459    21  0     0x0
gen_isr_tables.py: 0x77b81    24  0     0x4abfd
- I put my own wrapper around the audio_i2s module, but it is otherwise unchanged.
- I have gone so far as to scour the both the project, into the entire SDK to see if there's somewhere else that the interrupt is generated.
- The CMakeLists I have triple checked to make ensure it is not pulling it in twice.
- It fails on both an audio DK and a regular one.
- I can't find any IRQ-related configs that the audio apphas enabled that mine does not.
- This test application was generated from a hello_world_multicore application with the relevant bits from the audio app pulled in.
Any pointers? I did notice that changing the interrupt ID in the device tree changes BOTH of the instances in the gen_isr output, so there's some sort of automatic irq connection happening under the hood where it isn't particularly clear what's happening. Commenting out the IRQ_CONNECT in code does seem to still work, my I2S spins, but the timing seems to not be right and tends to eat all of my CPU time.
