External flash reading jesd216, "SFDP magic 000000 invalid"
I make a customer board and used GD25Q80C as the external Flash IC (not MX25);
Read the sfdp bfp of Flash by jesd216 sample (zephyr \ samples \ drivers \ jesd216),But it failed and prompted "SFDP magic 000000 invalid";
However, when I replaced GD25Q80C with MX25R64, it was successful;
My configuration is as follows:
I basically haven't changed the configuration of samples, only the IO port has been modified;
Can you see what the problem is?
The specifications for this IC are as follows
&spi2 {
	compatible = "nordic,nrf-spi";
	status = "okay";
	cs-gpios = <&gpio0 15 GPIO_ACTIVE_LOW>;
	pinctrl-0 = <&spi2_default>;
	pinctrl-1 = <&spi2_sleep>;
	mx25r64: mx25r6435f@0  {
		compatible = "jedec,spi-nor";
		reg = <0>;
		spi-max-frequency = <8000000>;
		jedec-id = [c8 40 14];
		size = <8388608>;//67108864
		wp-gpios = <&gpio0 22 GPIO_ACTIVE_LOW>;
		hold-gpios = <&gpio0 24 GPIO_ACTIVE_LOW>;
	spi2_default: spi2_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 17)>,//19
				<NRF_PSEL(SPIM_MOSI, 0, 20)>,//20
				<NRF_PSEL(SPIM_MISO, 0, 13)>;//21
	spi2_sleep: spi2_sleep {
		group1 {
			low-power-enable;
/////prj
CONFIG_STDOUT_CONSOLE=y
CONFIG_FLASH=y
CONFIG_FLASH_JESD216_API=y
# Assume the standard SPI NOR flash driver.  If the device uses
# another driver add an override configuration in boards/.
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_UART_CONSOLE=y
CONFIG_SOC_ENABLE_LFXO=n
