External flash reading jesd216, "SFDP magic 000000 invalid"
I make a customer board and used GD25Q80C as the external Flash IC (not MX25);
Read the sfdp bfp of Flash by jesd216 sample (zephyr \ samples \ drivers \ jesd216),But it failed and prompted "SFDP magic 000000 invalid";
However, when I replaced GD25Q80C with MX25R64, it was successful;
My configuration is as follows:
I basically haven't changed the configuration of samples, only the IO port has been modified;
Can you see what the problem is?
The specifications for this IC are as follows
&spi2 {
	compatible = "nordic,nrf-spi";
	status = "okay";
	cs-gpios = <&gpio0 15 GPIO_ACTIVE_LOW>;
	pinctrl-0 = <&spi2_default>;
	pinctrl-1 = <&spi2_sleep>;
	mx25r64: mx25r6435f@0  {
		compatible = "jedec,spi-nor";
		reg = <0>;
		spi-max-frequency = <8000000>;
		jedec-id = [c8 40 14];
		size = <8388608>;//67108864
		wp-gpios = <&gpio0 22 GPIO_ACTIVE_LOW>;
		hold-gpios = <&gpio0 24 GPIO_ACTIVE_LOW>;
	spi2_default: spi2_default {
		group1 {
			psels = <NRF_PSEL(SPIM_SCK, 0, 17)>,//19
				<NRF_PSEL(SPIM_MOSI, 0, 20)>,//20
				<NRF_PSEL(SPIM_MISO, 0, 13)>;//21
	spi2_sleep: spi2_sleep {
		group1 {
			low-power-enable;
/////prj
CONFIG_STDOUT_CONSOLE=y
CONFIG_FLASH=y
CONFIG_FLASH_JESD216_API=y
# Assume the standard SPI NOR flash driver.  If the device uses
# another driver add an override configuration in boards/.
CONFIG_SPI=y
CONFIG_SPI_NOR=y
CONFIG_UART_CONSOLE=y
CONFIG_SOC_ENABLE_LFXO=n
  • Hi, thank you for your reply.
    I am using the example "spi_flash"
    I have found that the status registers of MX25 and GD25 are different (the position of "QE BIT" is different), so GD25 cannot use QSPI to complete communication because "QE" Bit serves QSPI;
    Therefore, I modified the code to SPI and used SPI3, but the command 0x9F was unresponsive. I checked the characteristics of the GD25 manual through a logic analyzer and only found a strange place. I am not sure if this is the cause, as shown in the following figure:
    After sending command 9f, there was a delay of 12.12 microseconds before starting to read data from GD25;
    Compared to yesterday's QSPI, when in QSPI mode, its SCK is continuous; Why does SCK have a delay during SPI?
    0x9F:
    wait 12.12us ,SCK starts reading data,but MISO not response
    Other explanations:
    The frequency of SCK is 8.3MHz
    2. I enabled command 0xAB and after sending command 0xAB, CS was raised by 1ms; (See SPI3 settings)
    The following figure shows the command sent by MCU before sending command 9f:
    I have placed my settings below, please help me take a look:
    &spi3 {
    	status = "okay";
    	pinctrl-0 = <&spi3_default>;
    	pinctrl-1 = <&spi3_sleep>;
    		status = "okay";
    		reg = <0>;
    		wp-gpios = <&gpio0 22 GPIO_ACTIVE_HIGH>;
    		hold-gpios = <&gpio0 24 GPIO_ACTIVE_HIGH>;
    		spi-max-frequency = <8000000>;//8000000
    		//sck-frequency = <8000000>;
    		jedec-id = [00 00 00];
    		has-dpd;
    		t-enter-dpd = <30000>;
    		t-exit-dpd = <30000>;
    	spi3_default: spi3_default {
    		group1 {
    				<NRF_PSEL(SPIM_MISO, 0, 13)>,
    				<NRF_PSEL(SPIM_MOSI, 0, 20)>;
    	spi3_sleep: spi3_sleep {
    		group1 {
    			low-power-enable;
    ////prj
    CONFIG_FLASH=y
    CONFIG_SPI=y
    CONFIG_SPI_NOR=y
    CONFIG_NORDIC_QSPI_NOR=y
    CONFIG_NFCT_PINS_AS_GPIOS=y
    CONFIG_SPI_NOR_IDLE_IN_DPD=y
    	//DT_NODELABEL(mx25r64)
    	const struct device *flash_dev = DEVICE_DT_GET(DT_NODELABEL(mx25r64));//DT_ALIAS(spi_flash0)
    	if (!device_is_ready(flash_dev)) {
    		printk("%s: device not ready.\n", flash_dev->name);
    		//return 0;
    	printf("\n%s SPI flash testing\n", flash_dev->name);
    	printf("==========================\n");
    	single_sector_test(flash_dev);
    #if defined SPI_FLASH_MULTI_SECTOR_TEST
    	multi_sector_test(flash_dev);
    	return 0;
  • Also, can the value of the QE command be changed during QSPI mode? I found through the logic analyzer that the command 0x01 0x40 will be sent. Can this 0x40 be changed to the value I want? The following figure shows the location of QE for GD25:
    The QE Of MX25 is in the S6;
    The QE of GD25 is in the S9;
  • Hi
    Changing what bit is the QE one was addressed in this Zephyr pull request: https://github.com/zephyrproject-rtos/zephyr/pull/42334
    I also see that you're using the MX25 " mx25r64: mx25r6435f@0" in your project, so if there are more differences between the GD25 and the MX25 you haven't taken into consideration you should make a GD25 overlay setting up the flash correctly, (on what write/read OCs you want to use, what frequency to use and the JEDEC ID (and potentially the sfdp-bfp).
    Simon
