Can't write more than 16 bytes using i2c_transfer() on nRF5340 DK
I am developing a device that reads/writes data blocks to a proprietary sensor over i2c. There is a 2 byte hdr to the data block message so I was using i2c_transfer() to create a 2 msg transaction to write the header, then write the data block with no start/stop in between. This works great for data blocks that are les than or equal to 14 bytes. But anything larger than that I get an error -28 (ENOSPC). Is there a way to increase this limitation? Is this a kernel compile option somewhere? Or is there a format trick I don't know of.
Here is my code:
  struct i2c_msg msgs[2];
  msgs[0].flags = I2C_MSG_WRITE;
  msgs[0].buf = addr_phase;
  msgs[0].len = 2U;
  msgs[1].flags = I2C_MSG_WRITE | I2C_MSG_STOP;
  msgs[1].buf = p_out_val;
  msgs[1].len = (unsigned) len;
  int error = i2c_transfer(i2c_dev, msgs, 2, This._i2c_addr);
  if (error != 0) {
    ERR_PRINTF("Send failed error=%d\n", error);
    goto err;
I'm using version 2.4.2 of the SDK
I don't have any problem reading data blocks greater than 16 bytes, just writing them. For now, I'm using i2c_write() and copy the header and data block to a single buffer and i2c_write seems to be able to write any size I give it. But I'd love to get rid of the copy and extra buffer I have to allocate.
