NRF52832 ble detection issue
I've been struggling with a board issue for a week now. I'm using the nRF52835 with an external antenna. I'm trying to run an example after installing the nRF Connect SDK. I've loaded various Bluetooth examples from both the nRF SDK (via Segger IDE) and the nRF Connect SDK, but the device is not being discovered. In my understanding, both examples should work out of the box, but unfortunately, they don't. I've uploaded the projects to the cloud. Link to the files https://drive.google.com/file/d/15gjsuDHun9xgwL13yR_y65k9e1L3tR-k/view?usp=sharing (Versions: NRF SDK 1.7.0, nrf-connect sdk 2.5.0)
When using nRF Connect, I've set the build configuration to the nRF52DK board and tried creating a custom one, but neither option worked. LED examples are working fine. I'm trying to find a BLE device with my phone.
  • Now the code is stuck in log_backend_rt.c
    while (SEGGER_RTT_HasDataUp(CONFIG_LOG_BACKEND_RTT_BUFFER) &&
                host_present) {
                on_failed_write(retry_cnt--)
  • I also soldered a low-frequency crystal and parallel capacitors
                host_present) {
    Ok, I can't make sense out of that. but you need to address the other stuff I pointed out as well,
    regards
    Jared
1 2 3
