partial clone filter tree:0 appears to be a terrible choice for the zephyr repository
As a long time git user, I was recently very confused when I attempted to (for example)
git log zephyr/tests/kernel/common/src/atomic.c
or
gitk zephyr/tests/kernel/common/src/atomic.c
and found my machine crawling along at close to 0 kilometers per hour (I usually say miles per hour--same idea).
Some initial googling gave me the WRONG answer--suggesting I was witnessing a Windows issue--so I switched to Linux and found the same problem.
More googling and testing revealed that this was an issue with the use of tree:0 partial clone filtering. You can see that in zephyr/.git/config that has the statement
partialclonefilter = tree:0
I believe that one can also get good results by using the blob filtering
git clone --filter=blob:none ...
Please show me how you or I can fix this in the scripts or when using VS Code. I know that zephyr is not the immediate code of my project, but I do find this limitation a ridiculous annoyance. Thanks.
Burt Silverman
  • Oh, man... this appears to be a special feature limited to creating the SDK using VS Code.  Is it related to
    let a=["update"];return n&&(Ho(await eTe().catch(()=>"0.0.0"),"2.27.0")>=0&&a.push("-o=--filter=tree:0"),a.push("--narrow")),new Promise((o,u)=>{let l=this.spawn(this.topdir,a),p="",f=h=>{p+=`${h}`
    in ~/.vscode/extensions/nordic-semiconductor.nrf-connect-2023.11.301-linux-x64/dist/extension.js? Granted, I cannot read javascript/typescript.
    Burt
    Does this mean you found the answer, or is something still unclear?
    Terje
  • Thanks, Terje. I would like a bit more information: I would like to know why this>> "git clone --filter=blob:none" cannot be used rather than the tree:0 filtering. And I would like to know why toolchain manager installs an SDK one way (without filtered clone) and VS Code takes a different approach. I am guessing that none of this is documented. Anyway, I always feel better if I know the reasoning behind an approach that is not obvious. Thanks.
    Burt
  • Hi Burt
    Sorry for the slow response on this one. Terje is currently out in holiday and will get back to you first week of January.
    Best regards
    Torbjørn
    The reasoning is simply that the main use case is to install an SDK at some location, with no intentions to update it in-place, and preferably with as good as possible installation speed. For that scenario tree:0 is the best option, as blob:none would fetch unnecessary data.
    If however, as in your case, you perform git operations requiring more than one given commit, then blob:none (or even no filtering at all) may be better options. Nothing is likely to break by using blob:none, but download times and local space usage would increase.
    Terje
