After bonding, I receive write events from the central, but after reconnecting, the write events no longer come through.
Nice to meet you.
I'm looking to embark on BLE development using nrf52840.
The requirements include one-to-one communication with one central and one peripheral, and pairing using LE Secure Connection is necessary (just works).
I will be developing the peripheral side of this. The BLE requirements are based on the specifications of the central side.
Now, initially, I tried implementing it myself based on various online information and samples.
I have successfully paired, and I can receive write events from the central side.
However, when I turn off the power on the central side, then turn it back on and perform a reconnection, I no longer receive write events from the central side.
Specifically, I am manipulating the central device to perform a write operation on the peripheral.
However, I only receive BLE_GAP_EVT_CONN_PARAM_UPDATE, and no other events.
First, let me share the logs!
If there's anything suspicious, please let me know. I can also provide the code.
Thank you.
SEGGER J-Link V7.88j - Real time terminal output
SEGGER J-Link (unknown) V1.0, SN=1050228242
Process: JLinkGDBServerCLExe
<info> app_timer: RTC: initialized.
<info> app: ble_stack__init
<info> app: Service UUID:0000, UUID Type: 2
<info> app: Erase bonds.
<info> peer_manager_handler: All peers deleted.
<info> app: PM_EVT_PEERS_DELETE_SUCCEEDED
<info> app: PM_EVT_CONN_CONFIG_REQ
<info> app: BLE_GAP_EVT_CONNECTED
<info> app: PM_EVT_CONN_SEC_START
<info> app: PM_EVT_CONN_SEC_PARAMS_REQ
<info> app: BLE_GAP_EVT_SEC_PARAMS_REQUEST
<info> app: BLE_GAP_EVT_LESC_DHKEY_REQUEST
<info> nrf_ble_lesc: Calling sd_ble_gap_lesc_dhkey_reply on conn_handle: 0
<info> app: BLE_GAP_EVT_CONN_SEC_UPDATE
<info> app: Security mode: 1. Security level: 2
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
<warning> app: PM_EVT_CONN_SEC_SUCCEEDED
<info> app: BLE_GAP_EVT_AUTH_STATUS: status=0x0, bond=0x1, kdist_own:0x3 kdist_peer:0x2
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Bonding data, action: Update
<info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
<info> app: Writing or overwriting the data.
<info> app: Flash changed.
<info> app: New Bond, add the peer to the whitelist if possible
<info> app: whitelist_peer_cnt 1, MAX_PEERS_WLIST 8
<info> app: Bonded to a new peer, add it to the whitelist.
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update
<info> app: PM_PEER_DATA_ID_PEER_RANK
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
<info> app: PM_PEER_DATA_ID_GATT_LOCAL
<warning> app: ble_evt_handler:53
<info> app: BLE_GATTS_EVT_WRITE
<info> app: Notification enabled
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Central address resolution, action: Update
<info> app: PM_PEER_DATA_ID_CENTRAL_ADDR_RES
<info> app: command_char_handles
<info> app:  01 00 02 00 1E 00 1A 00|........
<info> app:  01 61 C6 00 54 53 11 00|.a..TS..
<info> app:  A5 16 FF 00            |....
<info> app:  01 01 FF FF 00 00 A7 0B|........
<info> app:  AF 16 00 01 00 00 00 52|.......R
<info> app:  7C 07                  ||.
Here, intentionally turning the power of the central device OFF/ON to trigger a reconnection.
<info> app: Disconnected, reason 8.
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
<info> app: Flash not changed.
<warning> app: PM_EVT_BONDED_PEER_CONNECTED
<info> app: PM_EVT_LOCAL_DB_CACHE_APPLIED
<info> app: BLE_GAP_EVT_SEC_INFO_REQUEST
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
<info> app: BLE_GAP_EVT_CONN_PARAM_UPDATE
<info> app: connection parameters updated. min_interval:160, max_interval:160, latency:0, timeout:810
<info> app: connection parameters updated. min_interval:80, max_interval:80, latency:0, timeout:810
  • Hi Keigo,
    keigo.imaizumi said:
    LTK, but if I do the following, will the BLE_GAP_EVT_AUTH_STATUS event get a value for s_gap_sec_key?
    It's been a long time since I tested the LTK with nRF5 SDK and the sniffer but as far as I know the ltk key when you receive BLE_GAP_EVT_AUTH_STATUS  is the one that you should input to the sniffer. I am not so sure it should be own or peer key, I think it depends on which key is agreed when the 2 device pair. The sniffer trace (before encryption) should tell which key should be used.
    This same key will be re-used when the 2 re-connect. You can check that in the peer manager in the peripheral when they reconnect.
    Regardless if you can decrypt the encrypted link, please try to capture the sniffer trace, at least we can check if they can re-pair properly or not.
    From the log I don't see any problem with your peripheral regarding re-encryption the link.
  • Hello, Hung Bui-San.
    I can now see communication between Central and Peripheral using the sniffer.
    However, I'm getting the error "Encrypted packet decrypted incorrectly (bad MIC)." Is there a solution?
    I dumped the LTK "00 04 00 20 01 0a 00" in the lower left of the image and entered it into WireShark as SC LTK with 0x00040020010a00 (or in MSB),
    but it didn't work.
  • Hi Keigo,
    You would need to input the key and then try to capture a new connection (with the 2 same device, they will re-use the LTK).
    Could you send us your sniffer trace , even though it has "Encrypted packet decrypted incorrectly (bad MIC)." Both when you first bond the 2 devices and when you re-connect.
  • I will send a packet sniffer.
    No. 2358 is the first connection and bonding. No. 2682 marks the beginning of a reconnection. If there are any suspicious points, your guidance would be greatly appreciated! I've been struggling with this issue for days and haven't been able to resolve it.
  • Hi Keigo,
    I don't see anything suspicious from the sniffer trace.
    It seems that the re-encryption worked properly and the 2 devices managed to re-connect and re-pair with no problem.
    The question, I guess, is why the central doesn't want to send the write request on reconnection. If the link can be decrypted it would be much easier to inspect.
    Please make sure you type the key and click the arrow button after you enter it.
    If your central accept legacy pairing you can try disable LESC and only do legacy pairing, this way the sniffer can automatic decrypt Just Work encryption without you providing the key.
