After bonding, I receive write events from the central, but after reconnecting, the write events no longer come through.
Nice to meet you.
I'm looking to embark on BLE development using nrf52840.
The requirements include one-to-one communication with one central and one peripheral, and pairing using LE Secure Connection is necessary (just works).
I will be developing the peripheral side of this. The BLE requirements are based on the specifications of the central side.
Now, initially, I tried implementing it myself based on various online information and samples.
I have successfully paired, and I can receive write events from the central side.
However, when I turn off the power on the central side, then turn it back on and perform a reconnection, I no longer receive write events from the central side.
Specifically, I am manipulating the central device to perform a write operation on the peripheral.
However, I only receive BLE_GAP_EVT_CONN_PARAM_UPDATE, and no other events.
First, let me share the logs!
If there's anything suspicious, please let me know. I can also provide the code.
Thank you.
SEGGER J-Link V7.88j - Real time terminal output
SEGGER J-Link (unknown) V1.0, SN=1050228242
Process: JLinkGDBServerCLExe
<info> app_timer: RTC: initialized.
<info> app: ble_stack__init
<info> app: Service UUID:0000, UUID Type: 2
<info> app: Erase bonds.
<info> peer_manager_handler: All peers deleted.
<info> app: PM_EVT_PEERS_DELETE_SUCCEEDED
<info> app: PM_EVT_CONN_CONFIG_REQ
<info> app: BLE_GAP_EVT_CONNECTED
<info> app: PM_EVT_CONN_SEC_START
<info> app: PM_EVT_CONN_SEC_PARAMS_REQ
<info> app: BLE_GAP_EVT_SEC_PARAMS_REQUEST
<info> app: BLE_GAP_EVT_LESC_DHKEY_REQUEST
<info> nrf_ble_lesc: Calling sd_ble_gap_lesc_dhkey_reply on conn_handle: 0
<info> app: BLE_GAP_EVT_CONN_SEC_UPDATE
<info> app: Security mode: 1. Security level: 2
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Bonding
<warning> app: PM_EVT_CONN_SEC_SUCCEEDED
<info> app: BLE_GAP_EVT_AUTH_STATUS: status=0x0, bond=0x1, kdist_own:0x3 kdist_peer:0x2
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Bonding data, action: Update
<info> app: PM_EVT_PEER_DATA_UPDATE_SUCCEEDED
<info> app: Writing or overwriting the data.
<info> app: Flash changed.
<info> app: New Bond, add the peer to the whitelist if possible
<info> app: whitelist_peer_cnt 1, MAX_PEERS_WLIST 8
<info> app: Bonded to a new peer, add it to the whitelist.
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update
<info> app: PM_PEER_DATA_ID_PEER_RANK
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Local database, action: Update
<info> app: PM_PEER_DATA_ID_GATT_LOCAL
<warning> app: ble_evt_handler:53
<info> app: BLE_GATTS_EVT_WRITE
<info> app: Notification enabled
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Central address resolution, action: Update
<info> app: PM_PEER_DATA_ID_CENTRAL_ADDR_RES
<info> app: command_char_handles
<info> app:  01 00 02 00 1E 00 1A 00|........
<info> app:  01 61 C6 00 54 53 11 00|.a..TS..
<info> app:  A5 16 FF 00            |....
<info> app:  01 01 FF FF 00 00 A7 0B|........
<info> app:  AF 16 00 01 00 00 00 52|.......R
<info> app:  7C 07                  ||.
Here, intentionally turning the power of the central device OFF/ON to trigger a reconnection.
<info> app: Disconnected, reason 8.
<info> peer_manager_handler: Peer data updated in flash: peer_id: 0, data_id: Peer rank, action: Update, no change
<info> app: Flash not changed.
<warning> app: PM_EVT_BONDED_PEER_CONNECTED
<info> app: PM_EVT_LOCAL_DB_CACHE_APPLIED
<info> app: BLE_GAP_EVT_SEC_INFO_REQUEST
<info> peer_manager_handler: Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption
<info> app: BLE_GAP_EVT_CONN_PARAM_UPDATE
<info> app: connection parameters updated. min_interval:160, max_interval:160, latency:0, timeout:810
<info> app: connection parameters updated. min_interval:80, max_interval:80, latency:0, timeout:810
  • Hello Mr. Hung Bui,
    I'm sorry, but I'm not sure how to obtain the key.
    I'm a beginner when it comes to bonding.
    Could you please provide guidance on how to obtain the key?
    By the way, is the key you mentioned the public key that appears in the sniffer? (Is it either x or y?)
    Also, what type of key should be set in WireShark? (The part where you choose SC LTK or SC Private Key, etc.)
    I apologize for the basic nature of these questions, as this is my first time delving into protocol analysis. Your guidance would be greatly appreciated!
    Thank you.
  • Hi Keigo,
    I will try to do the test here but if you take a look at the documentation you can find the instruction:
    https://infocenter.nordicsemi.com/index.jsp?topic=%2Fug_sniffer_ble%2FUG%2Fsniffer_ble%2Faction_bonded.html
    I think what you did was correct but for some reason it didn't work. I will check
  • Hi Keigo-san,
    Please add this line into line 366 in security_dispatcher.c:
       NRF_LOG_HEXDUMP_INFO(p_enc_info->ltk,p_enc_info->ltk_len);
    So it looks like this:
    You will find the LTK in the log like in the screenshot below , it's 16 bytes key. In your code it seems that it's only 8 bytes for some reason.
    Then the byte order is opposite, so you need to type it in reverse. Please see how it's typed in the sniffer. As you can see in the screenshot the sniffer managed to decrypt the connection.
    So in my case I have to input to wireshark like this:
    0x4F2CAA6E357D072F5AE9049A9CB5DA23
    When the log shows:
    <info> peer_manager_smd: 23 DA B5 9C 9A 04 E9 5A|#......Z
    <info> peer_manager_smd: 2F 07 7D 35 6E AA 2C 4F|/.}5n.,O
    Note that you only have this printout when you re-connect. Not when you first bond.
    Following your advice, I implemented dumping the LTK in the security_manager.c file. I tried entering the 16-byte key that appeared here into the sniffer, but I'm still encountering the "Encrypted packet decrypted incorrectly" issue. Does this mean that decryption was unsuccessful? Additionally, does this imply that encrypted communication between the Central and Peripheral is not working well after reconnection?
    Also, is it possible to receive the code you experimented with, Mr. Hung Bui?
  • Hi Keigo,
    I was testing with ble_app_hrs in SDK v17.1 with the only modification that I showed you.
    Could you try to test again with the example and try to connect and pair with a phone ?
    Make sure you click the arrow button after you enter the key (it turns blue when the key is entered and then turns gray after you click it).
    And after that the sniffer needs to capture a new connection, it will not be able to decrypt something it already captured.
    How long the connection last after you get "Encrypted packet decrypted incorrectly" ?
    Usually this error just shows that the sniffer couldn't decrypt the connection, there is nothing wrong between the peripheral and the central.
