I have a nrf5340 board which I'm trying to finalize the bootloader process on.
Hi Trevor,
Thank you for contacting DevZone at NordicSemi.
As 5340 has two cores and it makes DFU bit more complicated.
The netcore will have a separate bootloader (B0N).
May I suggest you to have a look at unofficial sample from my colleague for DFU for nrf5340: 5340Bootloader Sample
And then if you have more questions, I will forward to experts.
/BR, Naeem
Thanks Naeem, I'll look over this and respond with any further questions.
Sorry for the extended delay Naeem, I got pulled into other projects. I've been working on the sample and posted a new question regarding adding TFM support without external flash.
Do you know if the ability to use NAND flash will be supported for external flash with DFU and MCUBOOT?
I think you will have to have your own custom driver for that.
See this relevant comment: Custom Driver for DFU using NAND
