Toolchain Manager cannot be updated/installed via nRF Connect for Desktop v.4.3.0
With the current version of nRF Connect for Desktop I received an error when updating the Toolchain Manager.
I then uninstalled the Toolchain Manager and tried to reinstall it, but now I can no longer do that either.
The error:
Unable to install: Error invoking remote method 'apps:install-downloadable-app': Error: Failed with exit code 1. Failed to bootstrap core functionality before executing command.
HTTP request to default bootstrap resource
raw.githubusercontent.com/.../ master/bootstrap.json
failed.
Please check that your internet connection is functioning. If you use a proxy, please try the --detect-proxy flag or manually set the appropriate HTTP_PROXY- style environment variable(s).
To use a custom bootstrap config, set NRFUTIL_BOOTSTRAP_CONFIG_URL. To bootstrap directly from a nrfutil-core package tarball, set NRFUTIL_BOOTSTRAP_TARBALL_PATH.
Caused by: 0: error sending request for url (raw.githubusercontent.com/.../bootstrap.json): error trying to connect: tcp connect error: Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig. (os error 10013) 1: error trying to connect: tcp connect error: Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig. (os error 10013) 2: tcp connect error: Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig. (os error 10013) 3: Der Zugriff auf einen Socket war aufgrund der Zugriffsrechte des Sockets unzulässig. (os error 10013).
The URL raw.githubusercontent.com/.../bootstrap.json is striking in which there is a space before "master"!
When I enter the URL in the browser I get "404: Not Found".
If I remove the space, it appears in the browser:
    "nrfutil_core_tarball_urls": {
        "aarch64-apple-darwin": "">developer.nordicsemi.com/.../nrfutil-aarch64-apple-darwin-7.6.0.tar.gz",
        "x86_64-apple-darwin": "">developer.nordicsemi.com/.../nrfutil-x86_64-apple-darwin-7.6.0.tar.gz",
        "x86_64-pc-windows-msvc": "">developer.nordicsemi.com/.../nrfutil-x86_64-pc-windows-msvc-7.6.0.tar.gz",
        "x86_64-unknown-linux-gnu": "">developer.nordicsemi.com/.../nrfutil-x86_64-unknown-linux-gnu-7.6.0.tar.gz"
Uninstalling and reinstalling 4.2.1 or 4.3.0 was unsuccessful.
Can anyone confirm the problem and is there perhaps a solution for this?
    Thank you for reporting this. My colleague has already reported your issue internally, and we are tracking it. Your new update has also been noted. I hope we will find the root cause of this issue soon.
    I will update you here as soon as I have information on the issue you are experiencing. I hope that you are currently able to work with the setup.
    Kind Regards,
    Abhijith
