[Zigbee] ZCL: Discover Attributes Extended Command
Setup:
nrf52840dk
NCS v2.4.1
ZCL Discover Attributes Extended Command allows to get the attribute access type. Based on the Zigbee Cluster Library spec 2.5.23.1.5 section the second bit of Attribute access control field should indicate if the discovered attribute is reportable or not.
In zcl_general_commands.c: zb_zcl_disc_attr_handler() following line of code is used for putting the attribute access type to the ZCL Discover Attributes Extended Response.
It seems that only bit 0 and bit 1 of access field are being put into the packet.
zb_zcl_common.h introduces the bits for setting attribute access as follows:
ZB_ZCL_ATTR_ACCESS_REPORTING is the bit 2 in the attribute descriptor access, so it seems that it is not possible to determine if discovered attribute is reportable or not.
Could you elaborate on that topic ?
Please, correct me if I am wrong and point me to the right direction.
My goal is to be able to determine if discovered attribute is reportable or not.
1 2 3
