API registration of certification for Azure IoT Hub / DPS
I am trying to connect a custom device to the Azure IoT Hub using DPS service. Because I am using a custom board I am trying to write certificates to the modem using api calls to the modem_key_mgmg functions. Theses functions have a tag and a credential type.
But trying to get around the different certificates in use.and what tags and credential types i should use when writing the certificates.
I have registered Baltimore and DigiCert root CA certificates using the tag CONFIG_MQTT_HELPER_SEC_TAG and CONFIG_MQTT_HELPER_SECONDARY_SEC_TAG and both of them with credential type set to MODEM_KEY_MGMT_CRED_TYPE_PUBLIC_CERT.
For the device certificate I am not really sure what the tag should be, so just set it to 12 for both types.
Then the private certificate is registered with type MODEM_KEY_MGMT_CRED_TYPE_PRIVATE_CERT.
But what about the public part? Should it be MODEM_KEY_MGMT_CRED_TYPE_PUBLIC_CERT?
Is the above at all correct? I am wondering about the tag field since I find no description except a reserrved tag for nRFCloud. Is it used somewhere in the Nordic libraries for Azure and has to have a specific value?
I am getting mqtt_helper, mqtt_connect, error: -111 when trying to connect.
  • A few questions (I think I have tried the different combinations, but....)
    When uploading a certificate to Azure IoT hub certificates list, are you using the PEM file with only the generated subordinate certificate or a manually combined file with the certificate section for both subordinate and slef-signed root CA?
    When adding your testdevice do you set authentificate to "X.509 Self-Signed" or "X.509 CA Signed"?
    If you select "X.509 Self-Signed", what secondary thump print do you use?
  • Hi Thomas,
    Thomas said:
    Could you share the test certificates and the exact way you register them?
    I can share more details about how I register them.
    1. Follow Tutorial - Create and upload certificates for testing - Azure IoT Hub | Microsoft Learn you will get the following keys.
    C:\NCS\AzureIoTCerts>dir /s
     Volume in drive C has no label.
     Volume Serial Number is 7C9B-FC43
     Directory of C:\NCS\AzureIoTCerts
    18/12/2023  15:21    <DIR>          .
    18/12/2023  15:21    <DIR>          ..
    18/12/2023  15:18    <DIR>          rootca
    18/12/2023  16:08    <DIR>          subca
                   0 File(s)              0 bytes
     Directory of C:\NCS\AzureIoTCerts\rootca
    18/12/2023  15:18    <DIR>          .
    18/12/2023  15:18    <DIR>          ..
    18/12/2023  16:04    <DIR>          certs
    18/12/2023  16:04    <DIR>          db
    18/12/2023  15:10    <DIR>          private
    18/12/2023  15:16             2,099 rootca.conf
    18/12/2023  15:18             4,135 rootca.crt
    18/12/2023  15:16             1,022 rootca.csr
                   3 File(s)          7,256 bytes
     Directory of C:\NCS\AzureIoTCerts\rootca\certs
    18/12/2023  16:04    <DIR>          .
    18/12/2023  16:04    <DIR>          ..
    18/12/2023  15:18             4,135 88A8F7A2E59F52BF8F8EA450CDBB125E.pem
    18/12/2023  16:04             4,484 88A8F7A2E59F52BF8F8EA450CDBB1260.pem
                   2 File(s)          8,619 bytes
     Directory of C:\NCS\AzureIoTCerts\rootca\db
    18/12/2023  15:03                 5 crlnumber
    18/12/2023  16:04               231 index
    18/12/2023  16:04                21 index.attr
    18/12/2023  15:25                21 index.attr.old
    18/12/2023  15:25               157 index.old
    18/12/2023  16:04                34 serial
    18/12/2023  15:25                34 serial.old
                   7 File(s)            503 bytes
     Directory of C:\NCS\AzureIoTCerts\rootca\private
    18/12/2023  15:10    <DIR>          .
    18/12/2023  15:10    <DIR>          ..
    18/12/2023  15:16             1,884 rootca.key
                   1 File(s)          1,884 bytes
     Directory of C:\NCS\AzureIoTCerts\subca
    18/12/2023  16:08    <DIR>          .
    18/12/2023  16:08    <DIR>          ..
    18/12/2023  16:08    <DIR>          certs
    18/12/2023  16:08    <DIR>          db
    18/12/2023  16:05    <DIR>          private
    18/12/2023  16:02             2,094 subca.conf
    18/12/2023  16:04             4,484 subca.crt
    18/12/2023  16:03             1,018 subca.csr
    18/12/2023  16:08             4,552 testdevice.crt
    18/12/2023  16:07             1,002 testdevice.csr
                   5 File(s)         13,150 bytes
     Directory of C:\NCS\AzureIoTCerts\subca\certs
    18/12/2023  16:08             4,552 EE3E911808A245024E9E824AC8F90B4E.pem
                   1 File(s)          4,552 bytes
     Directory of C:\NCS\AzureIoTCerts\subca\db
    18/12/2023  15:58                 5 crlnumber
    18/12/2023  16:08               120 index
    18/12/2023  16:08                21 index.attr
    18/12/2023  15:58                 0 index.old
    18/12/2023  16:08                34 serial
    18/12/2023  15:58                34 serial.old
                   6 File(s)            214 bytes
     Directory of C:\NCS\AzureIoTCerts\subca\private
    18/12/2023  16:05    <DIR>          .
    18/12/2023  16:05    <DIR>          ..
    18/12/2023  16:03             1,884 subca.key
    18/12/2023  16:05             1,732 testdevice.key
                   2 File(s)          3,616 bytes
         Total Files Listed:
                  27 File(s)         39,794 bytes
                  26 Dir(s)  101,159,108,608 bytes free
    2. Upload subordinate CA certificate C:\NCS\AzureIoTCerts\rootca\certs\88A8F7A2E59F52BF8F8EA450CDBB1260.pem to IoT Hub or DSP Certificates page.
    3. Copy and write the following keys into the device.
    Server rootCA:  DigiCertGlobalRootG2.crt.pem or  BaltimoreCyberTrustRoot.crt.pem
    Client certificate:  C:\NCS\AzureIoTCerts\subca\certs\EE3E911808A245024E9E824AC8F90B4E.pem
    Client private key: C:\NCS\AzureIoTCerts\subca\private\testdevice.key
    Program AT client or SLM sample first, then use Certificate Manager to write keys.
    If you are testing IoT Hub without DSP, remember to set the following configuration
    CONFIG_AZURE_IOT_HUB_DEVICE_ID="testdevice" # same as Subject Common Name (CN) field when you generate certificates
    CONFIG_AZURE_IOT_HUB_HOSTNAME=""
    Just let me know if there is anything else you feel confused.
    Charlie
  • If just using IoT hub, how do you add the device, especially authentification!
    I uploaded the PEM file with only the generated subordinate certificate.
    It uses X.509 Self-Signed. I input the secondary thump print same as the first.
    Charlie
  • I got it connected using Cellular Monitor and fixed on mistake by me. My thumprint was from the subordinate certificate. When creating a device directly like this, it is the thumprint of the device certificate.
    These are the 3 certificates used when writing from Cellular Monitor.
    MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN
    Moving to test on my own hub if this succeeds I will test with DPS.
    I have verified that I can connect to my own hub if I replace the Digicert root CA with the Baltimore one.
