API registration of certification for Azure IoT Hub / DPS
I am trying to connect a custom device to the Azure IoT Hub using DPS service. Because I am using a custom board I am trying to write certificates to the modem using api calls to the modem_key_mgmg functions. Theses functions have a tag and a credential type.
But trying to get around the different certificates in use.and what tags and credential types i should use when writing the certificates.
I have registered Baltimore and DigiCert root CA certificates using the tag CONFIG_MQTT_HELPER_SEC_TAG and CONFIG_MQTT_HELPER_SECONDARY_SEC_TAG and both of them with credential type set to MODEM_KEY_MGMT_CRED_TYPE_PUBLIC_CERT.
For the device certificate I am not really sure what the tag should be, so just set it to 12 for both types.
Then the private certificate is registered with type MODEM_KEY_MGMT_CRED_TYPE_PRIVATE_CERT.
But what about the public part? Should it be MODEM_KEY_MGMT_CRED_TYPE_PUBLIC_CERT?
Is the above at all correct? I am wondering about the tag field since I find no description except a reserrved tag for nRFCloud. Is it used somewhere in the Nordic libraries for Azure and has to have a specific value?
I am getting mqtt_helper, mqtt_connect, error: -111 when trying to connect.
  • Another huge problem. I need two root CA in the device.
    I need both Baltimore and Digicert to exist in my device......
    My hub is currently running with Baltimore so to connect now I need Baltimore and at an unknown time it will change to Digicert. If I do not have both certificates in the device I will loose connection.
    The current 3 certificates are downloaded with key 10.
    Should I just add 3 certificates with key 11 also replacing the CA for Baltimore with Digicert
  • Thomas said:
    I wanted to validate what types are used in the 3 windows of Cellular Monitor...
    Certificate Manager windows correspond to the following tree types. NCS\v2.5.0\nrf\samples\cellular\http_update samples demonstrate how to properly write certificates in fw.
    MODEM_KEY_MGMT_CRED_TYPE_CA_CHAIN
    This is not suggested since it will occupy many memory sizes and is also not secure.
    Couldn't the two sets of keys stored in different secure tags solve your problem?
    My first test showed when Baltimore in CONFIG_MQTT_HELPER_SEC_TAG did not work, it would automatically switch to Digicert in CONFIG_MQTT_HELPER_SECONDARY_SEC_TAG to build the connection.
    Charlie
  • How do I control which security tag is used. I have not found a way to do this?
  • It seems that as soon as I register two root CA.
    DigiCert in tag CONFIG_MQTT_HELPER_SEC_TAG
    Baltimore in tag CONFIG_MQTT_HELPER_SECONDARY_SEC_TAG
    I cannot connect to any IoT hub anymore.....
    I am testing agains two different IoT hubs, one running with DigiCert and one running with Baltimore. Function was as expected as long as I only registered one CA on the CONFIG_MQTT_HELPER_SEC_TAG.
    I am validating this...
  • My first test showed when Baltimore in CONFIG_MQTT_HELPER_SEC_TAG did not work, it would automatically switch to Digicert in CONFIG_MQTT_HELPER_SECONDARY_SEC_TAG to build the connection.
    I cannot validate this. It seems this is not correct.
    Hang on.... maybe wrong conclusion....
    I moved from programming certificates using Cellular Monitor to programming certificates using modem_key_mgmt_write. This might be the problem....
  • Related
