Unit testing using CMOCK and UNITY of the BLE module gives Error: Bluetooth device missing
I am integrating unit tests on our on an NRF Connect SDK project using Unity and CMock. I followed the example on documentation here
The project uses the BLE modules and I am developing unit tests for the application files related to Bluetooth. The test compiles and produces the following error:
[141/142] cd /workdir/connectivity_project_lte/test/build && /workdir/connectivity_project_lte/test/build/zephyr/zephyr.exe
Error: Bluetooth device missing. Specify one using --bt-dev=hciN
FAILED: zephyr/CMakeFiles/run_native /workdir/connectivity_project_lte/test/build/zephyr/CMakeFiles/run_native
FATAL ERROR: command exited with status 1: /usr/local/bin/cmake --build /workdir/connectivity_project_lte/test/build --target run
After it fails, I ran `build/zephyr/zephyr.exe --bt-dev=hci0` and it built and succeeded.
Is there a way to pass '--bt-dev=hci0' as an argument option to west build -b native_posix -t run command?
