DMIC pop / click sounds between each memory block
I'm trying to continuously stream data from the dmic interface, in this case over serial though only for testing.
Things seem to be largely working except for pop/click artifacts between every block.
In this case the memory slab is setup for 4 blocks with enough memory for 100ms of audio, default settings taken from the dmic sample.
The pop is usually about 0.5-1ms long and per recording looks exactly the same each time and occurs in intervals equal to the block size. Large block size means less frequent intervals.
This smells like either samples are dropped between each block or I'm getting garbage data inserted somehow, though it does feel more like audio is missing/overwritten when a pop occurs.
Giving a really large block size like 1000ms of audio make the pop occasionally not occur.
My understanding is that the dmic driver continuously reads data as soon as the start flag is given and will choose a free memory block from the slab to write to. As long as I process a returned block quickly enough and free it then the dmic should not run out of memory or drop samples (if that is even a possible behaviour)?
I can't see an off by one error or similar in the way I grab the data either. It's a bit puzzling.
The interface is not throwing me any errors with debug log enabled.
Attached a sample recording and the project code. The python script can be used to translate the ASCII HEX string to a binary.
Using NCS 2.5.0
3527.dmic.zip
5684.silence_with_clicks.zip
  • Hi Timon
    I ended up with this case also. Unfortunately we are severely understaffed during the Christmas period, and I will have to investigate further next week. I apologize for the inconvenience.
    Best regards
    Torbjørn
  • Hi   totally understand!
  • Hi Timon
    I will set aside some time tomorrow to test this on my end. I am relatively sure that the UART link is somehow part of the problem, since the DMIC code itself is very straight forward.
    Do you have a scope or logic analyzer available in order to check the UART activity?
    The UART would have to run close to 100% of the time for the bandwidth to be sufficient, any gaps between transactions or slowdowns would cause issues.
    Best regards
    Torbjørn
  • Yea I can hook up a Saleae but need to check if there are usable test points. the uart is read out via the onboard debugger.
    Ultimately I want to send the audio samples via BLE GATT (BLE audio is not well enough supported by other devices and not necessary for this application, the samples will be processed by software), while it would be really helpful for development to have some other way to send out sample data to debug I would mostly care about ensuring that you can actually stream DMIC data "easily", the current issue worries me a bit that this is going to very finicky to avoid such artifacts.
    I'm sceptical that the UART is the problem here because of the following observation and assumptions.
    The dmic peripheral is provided 4 memory blocks to use for sampling. Sampling is done via DMA so user code should not be blocking the dmic peripheral from continuing to fill up the next free block with sample data. Only when all 4 blocks are exhausted and not freed by the user should the user code become a bottleneck but the clicks appear after the very first block.
    If I would miss sample data after the 4th block it would be fair to assume that we can't keep up with freeing memory blocks fast enough to provide free blocks to the dmic peripheral.
    Which leads me to assume that there is either something that needs to be done to correctly join blocks of sample data and my naive way of just appending it all is not correct or that there is something wrong in the way I setup the dmic peripheral that it maybe resets something with each block read.
    I saw a reference in the firmware for the Thingy:53 of avoiding a click sound when starting with the sampling but not specifics as to what the reason for that artifact is. I do observe that the samples need to settle for a few ms, there is a consistent observable "curve" whenever I make a recording.
    E: See here for the mentioned comment: https://github.com/edgeimpulse/firmware-nordic-thingy53/blob/main/src/sensors/ei_microphone.cpp#L314-L331
    Also here a screenshot of the attached audio data visualized to maybe give you better context. In this case little bit of the first sample got missed in my log, usually the click occurs after the first sample, here it looks like it starts shortly within the first sample. The spikes after are from the 2-4th sample. You can see the regularity of a click after exactly 100ms, which is how much sampling data fits into one block.
  • Hi Timon
    I did some tests myself in order to evaluate the performance of the UART communication.
    Trying out the code you sent me I connected the logic analyzer to the TX line in order to see if there could be any issues with the UART communication, and the results were interesting:
    After every byte I see a gap of around 3.5us, which means the overall throughput will be reduced by a significant factor.
    Exactly why this happens I am not sure, but I wouldn't be surprised if the console driver (printk) sends data to the underlying transport layer (UART in this case) byte by byte, which means the UART driver is not able to buffer multiple bytes in one transaction.
    I did a quick rewrite of the code integrating a more efficient UART layer, utilizing the UART async driver to send larger buffers in one go, and now communication seems more efficient:
    Most bytes are sent back to back, except for a ~35us delay when switching from one buffer to the next.
    There is a larger delay every 100ms which I assume shows that the bandwidth is now more than sufficient to send the data in time.
    Can you try out my code and see if it solves the glitching issue?
    319611_dmic_issue.zip
    Please note I use a wrapper for the UART async driver called 'app_uart' in order to simplify the UART interface, but everything is included in the repo. In order to track my changes you can check the git log.
    Best regards
    Torbjørn
  • Hi Torbjørn,
    that is really interesting and yes it does fix the issue!
    I'm a bit puzzled as that means something works very differently than I thought with the dmic driver but I'm glad to know that I can ensure things stream correctly if there is definitely no bandwidth bottleneck.
    There is that "starting pop" still but that is fine and seems to be what the Thingy:53 firmware mentioned.
    Also good to know that UART is not async by default
    Thank you for looking at this so thoroughly, it's much appreciated!
  • Hi Timon
    Very good to hear that this fixed the issue Slight smile
    If you look into the exact timings of the printk calls maybe you would find when they start to lag too much behind the DMIC operation to cause issues. I understand the desire to fully understand what is happening, but it is probably not worth the investment in time in this case.
    The best of luck with your project!
    Best regards
    Torbjørn
  • Hi Timon
    Best regards
    Torbjørn
