NFC BLE Pairing/Bonding between Nordic Peripheral and Android Central
Hi All,
I am working on "ble_app_hids_keyboard_pairing_nfc" from nrf5 SDK v17.1.0 on a nRF52840 DK with an Android phone. Please note that I am using the Android BLE itself, not the nRF Connect App.
When I try it the first time, after a clean restart with no bonded devices in the flash, a notice is shown on the phone and I am asked whether I want to pair with this the device. I select YES and it seems to work fine. I can see the bonding events taking place on the RTT Viewer. Also, the corresponding LED indicates the established connection. Then I break the BLE connection, (again the LED behaves accordingly and goes OFF), and try to read the NFC tag again to wake it up. Unexpectedly (correct me if I am wrong), the phone asks me, again, whether I want to pair with the device.
However, I was expecting the DK to start advertising and the phone to reconnect without any pairing process. Is this not how it should be?
I tried to modify the NFC_T2T_EVENT_FIELD_ON in the nrf_callback, so that it advertises if and only if the peer_count is not 0. However it did not work.
My questions are;
1) Is this fw supposed to be restarted on each wake up (when the NFC field is detected)
2) Does it have to whitelist IRKs only (instead of both IRK and address) to work with an Android phone, whose address is regularly changed, in a stable way. If so how can I do it?
3) I want it to pair and bond with only one peer when the whitelist is empty. If there is a peer in the whitelist then it should connect to that peer when it is waken up, via NFC, and should not start a new pairing process. How can I do this?
I will be happy if you can please help me with these.
Best,
Den
