How to save uint32_t variable to a specific address in flash memory in nrf connect sdk?
Hello. How to save uint32_t variable to a specific address in flash memory in nrf connect sdk? in other projects this was solved by allocating a custom flash memory section in the linker script, and also using __attribute__((section("name"))). But in zephyr the linker script is generated during assembly. If it's not difficult, give an example of how to implement this, thanks in advance
    In the NRF Connect SDK, you can save a uint32_t variable to a specific address in flash memory by using the Flash Storage API provided by the Zephyr RTOS. Here's an example of how you can implement this:
    1. Define the custom flash section and symbol in your application's prj.conf file:
    CONFIG_FLASH=y
    CONFIG_FLASH_PAGE_LAYOUT=y
    CONFIG_CUSTOM_FLASH_SECTION=y
    CONFIG_CUSTOM_FLASH_SYMBOL="__custom_flash"
    2. Create a custom linker script for your application. Create a file named custom.ld in your project directory and add the following contents:
    SECTIONS {
    .custom_flash_section :
    KEEP(*(.__custom_flash))
    } > flash
    3. Update your CMakeLists.txt file to include the custom linker script. Add the following line:
    undertale yellow
    set(DTC_OVERLAY_FILE ${CMAKE_CURRENT_SOURCE_DIR}/custom.ld)
    4. In your source code, declare and define your uint32_t variable and place it in the custom flash section using the __attribute__((section("name"))) attribute:
    c
    #include <zephyr.h>
    #include <device.h>
    #include <drivers/flash.h>
    __attribute__((section(".custom_flash_section")))
    uint32_t my_variable = 42;
    5. To save the variable to flash memory, use the Flash Storage API provided by Zephyr. Here's an example of how you can do this:
    c
    #include <zephyr.h>
    #include <device.h>
    void save_variable_to_flash(void)
    const struct device *flash_dev;
    int err;
    flash_dev = device_get_binding(DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL);
    if (!flash_dev) {
    printk("Flash device not found\n");
    return;
    uint32_t flash_address = (uint32_t)&my_variable;
    err = flash_write_protection_set(flash_dev, false);
    if (err) {
    printk("Failed to disable flash write protection\n");
    return;
    err = flash_write(flash_dev, flash_address, &my_variable, sizeof(my_variable));
    if (err) {
    printk("Failed to write variable to flash\n");
    return;
    err = flash_write_protection_set(flash_dev, true);
    if (err) {
    printk("Failed to enable flash write protection\n");
    return;
    printk("Variable saved to flash\n");
    Make sure to adjust DT_CHOSEN_ZEPHYR_FLASH_CONTROLLER_LABEL to match the label of the flash controller in your device tree.
  • Hello, thanks for the answer, I'll definitely try it. I need to save a variable as a constant when compiling. Will this method work with a const specification?
