Enable mcumgr features on NRF5340 DK board while Bluetooth HCI_USB program is running
Hello community,
I am trying for multiple firmware updates for my NRF5340 DK board.
What I am doing is I have build and flashed the SMP server sample program found /zephyr/samples/subsys/mgmt/mcumgr/smp_svr
After flashing this application, I can see my board recognised as a ttyACM0 device while I perform ls /dev.
Using the mcumgr tool I am also able to flash the Bluetooth HCI_USB sample program and after confirming the image and resetting the board, the board now acts as a bluetooth controller. I can verify this using the bluetoothctl command.
Now If I want to do a firmware upgrade, I dont have any way in the HCI_USB application to go back to smp server application. How can I perform multiple firmware updates using mcumgr?
Can virtual com port concept be useful here? If yes then I would like to have a detailed tutorial for this .
  • Hello Utsav,
    In a different DevZone case, I was able to emulate two UART COM on the same USB peripheral simply by setting one more cdc_acm_uart node under the usbd node.
    Once that second virtual COM port is setup, you can select it for MCUmgr by overlaying the chosen property as such:
    Please note that it is the Christmas - New Year holiday season here. We are thus severely understaffed, and there would be delays in responses. Our apologies for the inconveniences.
    Hieu
  • Hello   thanks for your response. I understand Christmas season is here and most of  the people would be on vacations. I really appreciate your response.
    In the Bluetooth HCI_USB project I have done the following changes :
    I have tried modifying the overlay file and here are the results :
    The contents of my overlay file are as follows:
    chosen {
    zephyr,code-partition = &slot0_partition;
    zephyr,out-usb = &cdc_acm1;
    zephyr,uart-mcumgr = &cdc_acm0;
    &zephyr_udc0 {
    cdc_acm0: cdc_acm0 {
    compatible = "zephyr,cdc-acm-uart";
    cdc_acm1: cdc_acm1 {
    &uart0 {
    status = "okay";
    The contents of my prj.conf file are as follows:
    CONFIG_STDOUT_CONSOLE=y
    CONFIG_GPIO=y
    CONFIG_SERIAL=y
    CONFIG_USB_DEVICE_INITIALIZE_AT_BOOT=n
    CONFIG_BT=y
    CONFIG_BT_HCI_RAW=y
    CONFIG_USB_DEVICE_STACK=y
    CONFIG_USB_DEVICE_PID=0x000B
    CONFIG_USB_DEVICE_BLUETOOTH=y
    CONFIG_USB_DEVICE_BLUETOOTH_VS_H4=n
    # Workaround: Unable to allocate command buffer when using K_NO_WAIT since
    # Host number of completed commands does not follow normal flow control.
    CONFIG_BT_BUF_CMD_TX_COUNT=10
    #This flag is enabled to make the mcuboot features for DFU available
    CONFIG_BOOTLOADER_MCUBOOT=y
    #Commands to add composite USB feature to HCI_USB program
    #Composite USB configuration ----------------
    CONFIG_USB_COMPOSITE_DEVICE=y
    #CONFIG_USB_CDC_ACM=y
    # Enable MCUmgr and dependencies.
    CONFIG_NET_BUF=y
    CONFIG_ZCBOR=y
    CONFIG_CRC=y
    CONFIG_MCUMGR=y
    CONFIG_STREAM_FLASH=y
    CONFIG_FLASH_MAP=y
    # Some command handlers require a large stack.
    CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=2304
    CONFIG_MAIN_STACK_SIZE=2048
    # Enable flash operations.
    CONFIG_FLASH=y
    # Required by the `taskstat` command.
    CONFIG_THREAD_MONITOR=y
    # Support for taskstat command
    CONFIG_MCUMGR_GRP_OS_TASKSTAT=y
    # Enable statistics and statistic names.
    CONFIG_STATS=y
    CONFIG_STATS_NAMES=y
    # Enable most core commands.
    CONFIG_FLASH=y
    CONFIG_IMG_MANAGER=y
    CONFIG_MCUMGR_GRP_IMG=y
    CONFIG_MCUMGR_GRP_OS=y
    CONFIG_MCUMGR_GRP_STAT=y
    # Enable logging
    CONFIG_LOG=y
    CONFIG_MCUBOOT_UTIL_LOG_LEVEL_WRN=y
    # Disable debug logging
    CONFIG_LOG_MAX_LEVEL=3
    # Enable USB subsystem
    CONFIG_SERIAL=y
    CONFIG_UART_LINE_CTRL=y
    CONFIG_CONSOLE=y
    # USB backend is serial device
    CONFIG_MCUMGR_TRANSPORT_UART=y
    CONFIG_BASE64=y
    Then I have build the project using the following command :
    west build -b nrf5340dk_nrf5340_cpuapp --pristine -- -DOVERLAY_CONFIG=overlay-cdc.conf -DDTC_OVERLAY_FILE=nrf5340_cpuapp.overlay -DCONFIG_MCUBOOT_SIGNATURE_KEY_FILE=\"/home/mutsl04176/ncs/v2.4.2/bootloader/mcuboot/root-rsa-2048.pem\"
    After successful build, I flashed the program into the NRF5340 DK board and plugged in the other USB.
    You can see from the screenshot below that I get two virtual ports as ACM0 and ACM1 :
    But at the same time, the board is not visible as a Bluetooth controller under bluetoothctl . Only the default Bluetooth controller (of the laptop) is visible.
    How do I solve this?
    Any other modifications that needs to be made? If yes then please let me know in which file and what needs to be done.
    Thanks!
  • Hello Utsav,
    Thank you for your understanding.
    Could you please share your compiled zephyr.dts file? It's located in <build folder>/zephyr/zephyr.dts.
    Also, if you can, please use the insert code block feature when you share code. It makes the code a lot more readable.
1 2 3 4 5 »
