Strange installation problem with nRF Connect SDK - git not found
I am facing yet another strange installation problem, after  nRF Connect SDK always fails with error "not found" has been solved.
The installation worked so far and I was able to use the nRF Connect SDK without any issues.
When I yesterday tried to use the setup again, I suddenly got errors like "No boards found" etc. I read up on this forum about potential issues and reinstalled the SDKs and so on. Nothing helped. I noticed that everything worked fine if I tried to build on the commandline using "west builld" in VS Code, but the UI functions did not work.
Then I tried uninstalling everything, reinstall the VS Code extensions and all of a sudden I was no longer able to install the SDK anymore given me errors like "git not found" while GIT is DEFINITELY PRESENT on the system, also in the default search path. Running git from a cmdline works fine.
So I even reinstalled GIT with the Windows installer, rebooted etc, but nothing seemed to make this problem go away.
Then I tried installing the stuff using VS Code again, but where presented the same problem
If I open a new nRF Connect terminal and issue the very same command "west init" manually there, it works:
But after the installation the extension still complains nothing is installed.
[19:08:47] nRF Command Line Tools 10.23.2 are up to date
[19:08:58] nrfutil-toolchain-manager install v2.5.0: Download toolchain
[19:09:00] nrfutil-toolchain-manager install v2.5.0: Finished, using previously downloaded file: success
[19:09:00] nrfutil-toolchain-manager install v2.5.0: Unpack toolchain
[19:09:28] nrfutil-toolchain-manager install v2.5.0: Toolchain unpacked to C:\ncs\tmp\.tmpjhd3yt: success
[19:09:28] nrfutil-toolchain-manager install v2.5.0: Install toolchain
[19:09:28] nrfutil-toolchain-manager install v2.5.0: Toolchain installed at C:\ncs\toolchains\c57af46cb7: success
[19:09:29] =========== Toolchain validation report for nRF Connect SDK Toolchain v2.5.0 ===========
No issues were detected with the toolchain.
[19:09:53] Command failed: west init -m https://github.com/nrfconnect/sdk-nrf --mr v2.5.1
FATAL ERROR: can't find git; install it or ensure it's on your PATH
IMPORTANT: The data below could contain sensitive or confidential information about your environment.
For help and support, visit the Nordic DevZone at https://devzone.nordicsemi.com/.
  "platform": {
    "os": "win32",
    "osVersion": "Windows 10 Pro",
    "osKernel": "10.0.19045",
    "vscode": "1.85.1",
    "electron": "25.9.7",
    "node": "v18.15.0"
  "system": {
    "date": "2023-12-26T18:11:31.932Z",
    "vscodeRoot": "c:\\Users\\daubsi\\AppData\\Local\\Programs\\Microsoft VS Code\\resources\\app",
    "vscodeUptime": "00:02:53",
    "osUptime": "04:51:20",
    "cpu": "Intel(R) Core(TM) i7-7500U CPU @ 2.70GHz"
  "workspace": {
    "name": "hv23last",
    "workspaceFile": null,
    "folders": [
      "c:\\Users\\daubsi\\Nextcloud\\hv23last"
  "sdks": [],
  "apps": [],
  "workspaceState": "freestanding-unconfigured",
  "toolchains": [
      "version": "2.5.0",
      "path": "c:\\ncs\\toolchains\\c57af46cb7"
  "connectedDevices": [],
  "deviceProvider": "nrfutil",
  "tools": {
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gcc.exe": "0.16.1",
    "C:\\Program Files\\SEGGER\\JLink\\JLink.exe": "7.88j",
    "C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\nrfjprog.exe": "10.23.2",
    "nrfutil": "Not found",
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\cmake.exe": "3.20.5",
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Scripts\\west.exe": "1.1.0",
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\python.exe": "3.8.2",
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\ninja.exe": "1.9.0",
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\gperf.exe": "3.1",
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\dtc.exe": "1.4.7",
    "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\gn.exe": "2122",
    "C:\\ncs\\toolchains\\c57af46cb7\\mingw64\\bin\\git.exe": "2.37.3.windows.1",
    "gdbPath": "c:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin\\arm-zephyr-eabi-gdb.exe"
  "nrfutil": {
    "nrfutil-device": {
      "version": "2.0.0",
      "binPath": "c:\\Users\\daubsi\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.11.301-win32-x64\\platform\\nrfutil\\bin\\nrfutil-device"
    "nrfutil-toolchain-manager": {
      "version": "0.14.1",
      "binPath": "c:\\Users\\daubsi\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.11.301-win32-x64\\platform\\nrfutil\\bin\\nrfutil-toolchain-manager"
  "environment": {
    "westEnv": {
      "ELECTRON_RUN_AS_NODE": "1",
      "HOME": "C:\\Users\\daubsi",
      "HOMEDRIVE": "C:",
      "HOMEPATH": "\\Users\\daubsi",
      "PATH": "C:\\ncs\\toolchains\\c57af46cb7;C:\\ncs\\toolchains\\c57af46cb7\\mingw64\\bin;C:\\ncs\\toolchains\\c57af46cb7\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Scripts;C:\\ncs\\toolchains\\c57af46cb7\\opt\\nanopb\\generator-bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\aarch64-zephyr-elf\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\x86_64-zephyr-elf\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin;c:\\Users\\daubsi\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.11.301-win32-x64\\platform\\nrfutil\\lib\\nrfutil-toolchain-manager;C:\\Program Files (x86)\\VMware\\VMware Workstation\\bin\\;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\PuTTY\\;C:\\Program Files (x86)\\Pico Technology\\PicoScope6\\;C:\\Program Files\\010 Editor;C:\\Program Files (x86)\\GitExtensions\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Git\\cmd;C:\\Users\\daubsi\\.cargo\\bin;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\Users\\daubsi\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\daubsi\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Program Files (x86)\\Nmap;C:\\Users\\daubsi\\vod_download_tools;",
      "ZEPHYR_SDK_INSTALL_DIR": "C:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk",
      "PYTHONPATH": "C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Lib;C:\\ncs\\toolchains\\c57af46cb7\\opt\\bin\\Lib\\site-packages"
    "inherited": {
      "HOMEDRIVE": "C:",
      "Path": "C:\\Program Files (x86)\\VMware\\VMware Workstation\\bin\\;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\PuTTY\\;C:\\Program Files (x86)\\Pico Technology\\PicoScope6\\;C:\\Program Files\\010 Editor;C:\\Program Files (x86)\\GitExtensions\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Git\\cmd;C:\\Users\\daubsi\\.cargo\\bin;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\Users\\daubsi\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\daubsi\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Program Files (x86)\\Nmap;C:\\Users\\daubsi\\vod_download_tools;",
      "PATH": "C:\\Program Files (x86)\\VMware\\VMware Workstation\\bin\\;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\WINDOWS\\system32;C:\\WINDOWS;C:\\WINDOWS\\System32\\Wbem;C:\\WINDOWS\\System32\\WindowsPowerShell\\v1.0\\;C:\\WINDOWS\\System32\\OpenSSH\\;C:\\Program Files\\PuTTY\\;C:\\Program Files (x86)\\Pico Technology\\PicoScope6\\;C:\\Program Files\\010 Editor;C:\\Program Files (x86)\\GitExtensions\\;C:\\Program Files\\dotnet\\;C:\\Program Files\\Nordic Semiconductor\\nrf-command-line-tools\\bin\\;C:\\Program Files\\Git\\cmd;C:\\Users\\daubsi\\.cargo\\bin;C:\\Python310\\Scripts\\;C:\\Python310\\;C:\\Users\\daubsi\\AppData\\Local\\Microsoft\\WindowsApps;C:\\Users\\daubsi\\AppData\\Local\\Programs\\Microsoft VS Code\\bin;C:\\Program Files (x86)\\Nmap;C:\\Users\\daubsi\\vod_download_tools;"
    "toolchainPath": "c:\\ncs\\toolchains\\c57af46cb7",
    "toolchainBinPath": "c:\\ncs\\toolchains\\c57af46cb7\\opt\\zephyr-sdk\\arm-zephyr-eabi\\bin",
    "toolchainVersion": "2.5.0"
  "terminal": {
    "defaultProfile": null
  "config": {
      "topdir": "",
      "toolchain": {
        "path": "${nrf-connect.toolchain:2.5.0}"
      "ozonePath": "",
      "applications": [],
      "applicationOptions": {},
      "kconfig": {
        "interface": "kconfig"
      "west": {
        "env": {
          "$base": "terminal"
      "boardRoots": [],
      "taskBindings": {},
      "debugging": {
        "flash": true,
        "bindings": {},
        "justMyCode": true
      "deviceProvider": "",
      "flash": {
        "softreset": false,
        "erase": false,
        "recover": false
      "enableTelemetry": false,
      "thirdpartyIntegration": {},
      "toolchainManager": {
        "indexURL": null,
        "installDirectory": null
      "nrfutil": {
        "home": null
      "defaultOpenAction": "ask"
      "terminalMode": "character"
  "extensions": {
    "internal": {
        "version": "2023.11.301",
        "path": "c:\\Users\\daubsi\\.vscode\\extensions\\nordic-semiconductor.nrf-connect-2023.11.301-win32-x64",
        "isActive": true
        "version": "2023.10.17",
        "path": "c:\\Users\\daubsi\\.vscode\\extensions\\nordic-semiconductor.nrf-terminal-2023.10.17",
        "isActive": true
        "version": "2023.11.120",
        "path": "c:\\Users\\daubsi\\.vscode\\extensions\\nordic-semiconductor.nrf-devicetree-2023.11.120",
        "isActive": true
        "version": "2023.11.64",
        "path": "c:\\Users\\daubsi\\.vscode\\extensions\\nordic-semiconductor.nrf-kconfig-2023.11.64",
        "isActive": true
    "external": {
      "marus25.cortex-debug": null,
      "ms-vscode.cpptools": "1.18.5",
      "ms-vscode.js-debug": "1.85.0",
      "ms-vscode.js-debug-companion": "1.1.2",
      "ms-vscode.vscode-js-profile-table": "1.0.8",
      "ms-python.python": "2023.22.1",
      "ms-python.vscode-pylance": "2023.12.1",
      "ms-vscode-remote.remote-wsl": "0.81.8",
      "twxs.cmake": "0.0.17"
What could be the reason for this?
Refering to my other post mentioned at the top: I made sure that tools like "reg.exe", "git.exe" etc. fully resolve without issued.
  • ad 1) Oh! That's interesting! Let me know if someone needs more context or confirmation of certain things for analysis.
    ad 2) Its a plain vanilla Ubuntu 22.04 LTS IIRC with the latest VS Code. Isn't it the case that nrfutil is hidden deep within the ncs install directory? I am not at the system right now, but IIRC it was there: ncs/toolchains/7795df4459/usr/local/lib/python3.8/site-packages
    ad 3) What I hoped to find somewhere are the actual call to "git clone" etc. within somewhere the toolchain directories/west application, but I couldn't find it. I also had a look at the VS extension code, but it's minified/obfuscated JS as far as I see, that's why I was asking about those details at which registry keys are in scope, which pathnames, etc. Maybe this was a misunderstanding.
    Yeah I'll let you know. Though I am not sure it will be a big priority at the moment, and I guess that counts for you as well? The issue still hasn't showed up on your side again right?
    Not sure if this would necessary solve anything, but I see here that Ubuntu 20 has a Tier 1 support from nrfutil, and Ubuntu 22 only has Tier 3. I assume it isn't being tested as well for Ubuntu 22.
    daubsi said:
    Regarding nrfutil - this is a python script where I would need to setup my env first, before this would properly run, right?
    I see that I might have forgotten to reply to this one. You can download nrfutil here, and doing it that way is probably best. I thought it also came with the SDK, but it might be that I am misremembering. I just had talk with a coworker who do not think nrfutil comes with the SDK. But in either case, I'd recommend installing nrfutil on its own as well.
    Elfving
    Elfving
