Interfacing external EEPROM using I2C drivers on nrf52840 in Zephyr NCS v2.5.0
Hi. I am working on a project and I need to interface a EEPROM to store some data. I tried using I2C drivers from the ncs but it appears that the APIs support only 8 bit addresses as shown below.
Write API:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
* @brief Write multiple bytes to an internal address of an I2C device.
* This is equivalent to:
* i2c_burst_write(spec->bus, spec->addr, start_addr, buf, num_bytes);
* @param spec I2C specification from devicetree.
* @param start_addr Internal address to which the data is being written.
* @param buf Memory pool from which the data is transferred.
* @param num_bytes Number of bytes being written.
* @return a value from i2c_burst_write()
static inline int i2c_burst_write_dt(const struct i2c_dt_spec *spec,
uint8_t start_addr,
const uint8_t *buf,
uint32_t num_bytes);
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
Read API:
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
* @brief Read multiple bytes from an internal address of an I2C device.
* i2c_burst_read(spec->bus, spec->addr, start_addr, buf, num_bytes);
* @param start_addr Internal address from which the data is being read.
* @param buf Memory pool that stores the retrieved data.
* @param num_bytes Number of bytes to read.
* @return a value from i2c_burst_read()
static inline int i2c_burst_read_dt(const struct i2c_dt_spec *spec,
uint8_t start_addr,
uint8_t *buf,
So, is there any other alternative for this which I can use to access the EEPROM as 8 bits are not enough to access all the addresses. This driver is more suitable for sensors I believe.
