Hi All!
I am using nrf9160dk with ncs 2.4.0 and asset tracker v2 example . I was testing with NRF cloud it was working well as it is enabled by default.
Now the issue is that I am trying to enable the AWS in asset tracker V2
But I am getting some errors while compiling.
proj.conf
# # Copyright (c) 2021 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # # General config CONFIG_NEWLIB_LIBC=y CONFIG_NEWLIB_LIBC_NANO=y CONFIG_NEWLIB_LIBC_FLOAT_PRINTF=y CONFIG_ASSERT=y CONFIG_REBOOT=y CONFIG_FPU=y # Heap and stacks CONFIG_HEAP_MEM_POOL_SIZE=47250 CONFIG_MAIN_STACK_SIZE=2048 CONFIG_SYSTEM_WORKQUEUE_STACK_SIZE=4096 CONFIG_HW_STACK_PROTECTION=y # Increase AT monitor heap size to be able to fit both neighbor cell measurement # and other AT notifications that may come in rapid succession. CONFIG_AT_MONITOR_HEAP_SIZE=1024 # Logging CONFIG_LOG=y CONFIG_LOG_MODE_DEFERRED=y # nRF modem library CONFIG_NRF_MODEM_LIB=y CONFIG_NRF_MODEM_LIB_ON_FAULT_APPLICATION_SPECIFIC=y # AT Host library - Used to send AT commands directy from an UART terminal and to allow # integration with nRF Connect for Desktop LTE Link monitor application. CONFIG_AT_HOST_LIBRARY=y # Network CONFIG_NETWORKING=y CONFIG_NET_NATIVE=n CONFIG_NET_SOCKETS=y CONFIG_NET_SOCKETS_OFFLOAD=y CONFIG_NET_IPV6=y CONFIG_NET_IPV4=y # LTE link control CONFIG_LTE_NETWORK_MODE_LTE_M_GPS=y ## Power saving timers. ### 320 hours PSM. CONFIG_LTE_PSM_REQ=y CONFIG_LTE_PSM_REQ_RPTAU="11000001" ### 20 seconds active time. CONFIG_LTE_PSM_REQ_RAT="00001010" # Settings - Used to store real-time device configuration to flash. CONFIG_SETTINGS=y CONFIG_SETTINGS_FCB=y CONFIG_FCB=y # FOTA CONFIG_FOTA_DOWNLOAD=y CONFIG_DFU_TARGET=y CONFIG_DOWNLOAD_CLIENT=y CONFIG_DOWNLOAD_CLIENT_HTTP_FRAG_SIZE_1024=y CONFIG_DOWNLOAD_CLIENT_STACK_SIZE=4096 CONFIG_DOWNLOAD_CLIENT_BUF_SIZE=2300 CONFIG_DOWNLOAD_CLIENT_MAX_HOSTNAME_SIZE=128 # Flash - Used in FOTA, settings and storage for P-GPS. CONFIG_FLASH=y CONFIG_FLASH_PAGE_LAYOUT=y CONFIG_FLASH_MAP=y CONFIG_STREAM_FLASH=y CONFIG_MPU_ALLOW_FLASH_WRITE=y # MCUBOOT CONFIG_BOOTLOADER_MCUBOOT=y CONFIG_IMG_MANAGER=y CONFIG_MCUBOOT_IMG_MANAGER=y CONFIG_IMG_ERASE_PROGRESSIVELY=y CONFIG_SECURE_BOOT=y CONFIG_BUILD_S1_VARIANT=y # Watchdog CONFIG_WATCHDOG_APPLICATION=y # Application Event Manager CONFIG_APP_EVENT_MANAGER=y CONFIG_APP_EVENT_MANAGER_LOG_EVENT_TYPE=n # cJSON - Used in cloud data encoding. CONFIG_CJSON_LIB=y # CAF - Common Application Framework CONFIG_CAF=y CONFIG_LED=y CONFIG_CAF_LEDS=y CONFIG_CAF_INIT_LOG_LED_READY_EVENTS=n CONFIG_CAF_INIT_LOG_LED_EVENTS=n CONFIG_CAF_INIT_LOG_MODULE_STATE_EVENTS=n # Location related configuration CONFIG_LOCATION=y CONFIG_LOCATION_REQUEST_DEFAULT_METHOD_FIRST_GNSS=y CONFIG_LOCATION_REQUEST_DEFAULT_METHOD_SECOND_CELLULAR=y CONFIG_LOCATION_REQUEST_DEFAULT_GNSS_TIMEOUT=90000 CONFIG_LOCATION_REQUEST_DEFAULT_CELLULAR_TIMEOUT=11000 CONFIG_LOCATION_DATA_DETAILS=y CONFIG_LOCATION_LOG_LEVEL_WRN=y # Default cloud transport service #CONFIG_NRF_CLOUD_MQTT=y CONFIG_HW_ID_LIBRARY=y CONFIG_HW_ID_LIBRARY_SOURCE_IMEI=y CONFIG_AWS_IOT=y CONFIG_AWS_IOT_BROKER_HOST_NAME="aXXXXXXX0axlqin-ats.iot.us-east-2.amazonaws.com" CONFIG_AWS_IOT_CLIENT_ID_STATIC="3515161798XXXXX" #"nrf9160" #CONFIG_MQTT_HELPER=#y #CONFIG_MQTT_HELPER_SEC_TAG=42
and overlay-aws.conf
# # Copyright (c) 2021 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # CONFIG_AWS_IOT=y CONFIG_AWS_IOT_TOPIC_UPDATE_DELTA_SUBSCRIBE=y CONFIG_AWS_IOT_TOPIC_GET_REJECTED_SUBSCRIBE=y CONFIG_AWS_IOT_AUTO_DEVICE_SHADOW_REQUEST=y CONFIG_AWS_IOT_MQTT_RX_TX_BUFFER_LEN=2048 CONFIG_AWS_IOT_APP_SUBSCRIPTION_LIST_COUNT=3 CONFIG_AWS_IOT_CLIENT_ID_APP=y # Options that must be configured in order to establish a connection. CONFIG_AWS_IOT_SEC_TAG=42 #CONFIG_AWS_IOT_BROKER_HOST_NAME="" CONFIG_AWS_IOT_BROKER_HOST_NAME="aXXXXXXXlqin-ats.iot.us-east-2.amazonaws.com" # MQTT Transport library # Maximum specified MQTT keepalive timeout for AWS IoT is 1200 seconds. CONFIG_MQTT_KEEPALIVE=1200
cmakelist.txt
# # Copyright (c) 2021 Nordic Semiconductor ASA # # SPDX-License-Identifier: LicenseRef-Nordic-5-Clause # cmake_minimum_required(VERSION 3.20.0) find_package(Zephyr REQUIRED HINTS $ENV{ZEPHYR_BASE}) project(asset_tracker_v2_aws) zephyr_compile_definitions(PROJECT_NAME=${PROJECT_NAME}) # NORDIC SDK APP START target_sources(app PRIVATE src/main.c) # NORDIC SDK APP END # Include source directory target_include_directories(app PRIVATE src) target_include_directories(app PRIVATE include/${BOARD}/) zephyr_include_directories_ifdef(CONFIG_MEMFAULT configuration/memfault) # Application directories add_subdirectory(src/modules) add_subdirectory(src/events) add_subdirectory_ifdef(CONFIG_CLOUD_MODULE src/cloud) add_subdirectory_ifdef(CONFIG_SENSOR_MODULE src/ext_sensors) add_subdirectory_ifdef(CONFIG_WATCHDOG_APPLICATION src/watchdog) # Include nRF modem library header file for PC builds. # These are used throughout the application in type definitions. if (CONFIG_BOARD_QEMU_X86 OR CONFIG_BOARD_NATIVE_POSIX) target_include_directories(app PRIVATE ${NRFXLIB_DIR}/nrf_modem/include/) # Make folder containing certificates global so that it can be located by the configured # cloud library. zephyr_include_directories(src/cloud-certs) target_compile_options(app PRIVATE -DCONFIG_LTE_NEIGHBOR_CELLS_MAX=10) endif()
Errors are
[0/309] Performing build step for 'mcuboot_subimage' ninja: no work to do. [1/299] Performing build step for 'b0_subimage' ninja: no work to do. [2/296] Performing build step for 's1_image_subimage' ninja: no work to do. [3/294] Performing build step for 'tfm' ninja: no work to do. [5/291] Building C object zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj FAILED: zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj C:\ncs\toolchains\31f4403e35\opt\zephyr-sdk\arm-zephyr-eabi\bin\arm-zephyr-eabi-gcc.exe -DAPP_VERSION=v2.4.0 -DEXT_API_MAGIC=0x281ee6de,0xb845acea,23298 -DFIRMWARE_INFO_MAGIC=0x281ee6de,0x8fcebb4c,23298 -DKERNEL -DMBEDTLS_CONFIG_FILE=\"nrf-config.h\" -DMBEDTLS_USER_CONFIG_FILE=\"nrf-config-user.h\" -DNRF9160_XXAA -DNRF_SKIP_FICR_NS_COPY_TO_RAM -DNRF_TRUSTZONE_NONSECURE -DPROJECT_NAME=asset_tracker_v2_aws -DUSE_PARTITION_MANAGER=1 -DVALIDATION_INFO_MAGIC=0x281ee6de,0x86518483,88834 -DVALIDATION_POINTER_MAGIC=0x281ee6de,0x6919b47e,88834 -D_ANSI_SOURCE -D_FORTIFY_SOURCE=1 -D__LINUX_ERRNO_EXTENSIONS__ -D__PROGRAM_START -D__ZEPHYR__=1 -IC:/ncs/v2.4.0/zephyr/kernel/include -IC:/ncs/v2.4.0/zephyr/arch/arm/include -Itfm/install/interface/include -IC:/ncs/v2.4.0/zephyr/include -Izephyr/include/generated -IC:/ncs/v2.4.0/zephyr/soc/arm/nordic_nrf/nrf91 -IC:/ncs/v2.4.0/zephyr/lib/libc/newlib/include -IC:/ncs/v2.4.0/zephyr/soc/arm/nordic_nrf/common/. -IC:/ncs/v2.4.0/zephyr/subsys/net/lib/sockets/. -IC:/ncs/v2.4.0/zephyr/subsys/settings/include -IC:/ncs/v2.4.0/nrf/include -IC:/ncs/v2.4.0/nrf/lib/at_cmd_parser/include -IC:/ncs/v2.4.0/nrf/subsys/net/lib/nrf_cloud/./include -IC:/ncs/v2.4.0/nrf/subsys/net/lib/fota_download/./include -IC:/ncs/v2.4.0/zephyr/../nrf/subsys/dfu/include -IC:/ncs/v2.4.0/nrf/subsys/net/lib/aws_fota/./include -IC:/ncs/v2.4.0/nrf/subsys/app_event_manager/. -IC:/ncs/v2.4.0/nrf/subsys/app_event_manager_profiler_tracer/. -IC:/ncs/v2.4.0/nrf/include/tfm -IC:/ncs/v2.4.0/nrf/tests/include -Itfm/generated/interface/include -IC:/ncs/v2.4.0/modules/lib/cjson -IC:/ncs/v2.4.0/nrf/modules/cjson/include -IC:/ncs/v2.4.0/modules/hal/cmsis/CMSIS/Core/Include -IC:/ncs/v2.4.0/modules/hal/nordic/nrfx -IC:/ncs/v2.4.0/modules/hal/nordic/nrfx/drivers/include -IC:/ncs/v2.4.0/modules/hal/nordic/nrfx/mdk -IC:/ncs/v2.4.0/zephyr/modules/hal_nordic/nrfx/. -IC:/ncs/v2.4.0/nrfxlib/nrf_modem/include -Imodules/nrfxlib/nrfxlib/nrf_security/src/include/generated -IC:/ncs/v2.4.0/nrfxlib/nrf_security/include -IC:/ncs/v2.4.0/nrfxlib/nrf_security/../crypto/nrf_oberon/core/include -IC:/ncs/v2.4.0/nrfxlib/nrf_security/../crypto/nrf_oberon/core/library -IC:/ncs/v2.4.0/modules/crypto/mbedtls/include -IC:/ncs/v2.4.0/modules/crypto/mbedtls/library -IC:/ncs/v2.4.0/nrfxlib/crypto/nrf_oberon/include/mbedtls -IC:/ncs/v2.4.0/nrfxlib/crypto/nrf_oberon/include -IC:/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/zephyr/.. -IC:/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/zephyr/../include -IC:/ncs/v2.4.0/bootloader/mcuboot/boot/bootutil/zephyr/../../zephyr/include -fno-strict-aliasing -Os -imacros C:/Nordic_apps/myapps/asset_tracker_v2_aws/build/zephyr/include/generated/autoconf.h -fno-common -g -gdwarf-4 -fdiagnostics-color=always -mcpu=cortex-m33 -mthumb -mabi=aapcs -mfpu=fpv5-sp-d16 -mfloat-abi=hard --sysroot=C:/ncs/toolchains/31f4403e35/opt/zephyr-sdk/arm-zephyr-eabi/arm-zephyr-eabi -imacros C:/ncs/v2.4.0/zephyr/include/zephyr/toolchain/zephyr_stdint.h -Wall -Wformat -Wformat-security -Wno-format-zero-length -Wno-pointer-sign -Wpointer-arith -Wexpansion-to-defined -Wno-unused-but-set-variable -Werror=implicit-int -fno-pic -fno-pie -fno-asynchronous-unwind-tables -fno-reorder-functions --param=min-pagesize=0 -fno-defer-pop -fmacro-prefix-map=C:/Nordic_apps/myapps/asset_tracker_v2_aws=CMAKE_SOURCE_DIR -fmacro-prefix-map=C:/ncs/v2.4.0/zephyr=ZEPHYR_BASE -fmacro-prefix-map=C:/ncs/v2.4.0=WEST_TOPDIR -ffunction-sections -fdata-sections -specs=nano.specs -D_POSIX_THREADS -std=c99 -MD -MT zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj -MF zephyr\CMakeFiles\zephyr.dir\misc\generated\configs.c.obj.d -o zephyr/CMakeFiles/zephyr.dir/misc/generated/configs.c.obj -c zephyr/misc/generated/configs.c C:\Users\Muhammad\AppData\Local\Temp\ccjrvjel.s: Assembler messages: C:\Users\Muhammad\AppData\Local\Temp\ccjrvjel.s:1491: Error: missing expression [14/291] Building C object zephyr/CMakeFiles/zephyr.dir/subsys/logging/log_core.c.obj ninja: build stopped: subcommand failed. FATAL ERROR: command exited with status 1: 'C:\ncs\toolchains\31f4403e35\opt\bin\cmake.EXE' --build 'c:\Nordic_apps\myapps\asset_tracker_v2_aws\build' * The terminal process terminated with exit code: 1. * Terminal will be reused by tasks, press any key to close it.
Can you please help me in this regard where is the issue?
I followed the following
Thanks & Regards,
Muhammad Usman
