How to read multiple sensors over TWI? (nrf_drv_twi)
I had slightly modified a TWI example (using nrf_drv_twi) to work with one of my sensors; It's basically the same with a different function called to handle the received data.
However, I have multiple sensors and multiple sets of data I'd like to be able to query from each, but it seems that the TWI interrupt handler doesn't provide much scope to do this. Or at least, I can't figure out how it would.
I initiate the transfer by making a call to the TWI tx function in my main loop:
     do
	__WFE();
}while(m_twi_rx_done == false);
err_code = nrf_drv_twi_tx(&m_twi_sensors, LSM303_ADDRESS_ACCEL, &test, sizeof(test), true);
m_twi_rx_done = false;
I can see that without much difficulty I could address a different register or sensor in changing this. However, I don't see how I would RECEIVE different data within the TWI interrupt handler:
void twi_handler(nrf_drv_twi_evt_t const * p_event, void * p_context)
	ret_code_t err_code;
	static acc_sample_t m_sample; //
	switch(p_event->type)
		case NRF_DRV_TWI_RX_DONE:
			LSM303_read_acc(&m_sample);
			m_twi_rx_done = true;
		case NRF_DRV_TWI_TX_DONE:
			if(m_twi_cmd_done != true)
				m_twi_cmd_done = true; // IF just a tx command, it's done
				return;
			/* read sizeof(m_sample) bytes from the specified address */
			err_code = nrf_drv_twi_rx(&m_twi_sensors, LSM303_ADDRESS_ACCEL, (uint8_t*)&m_sample, sizeof(m_sample), false);
It doesn't seem like I can manage what happens on an "NRF_DRV_TWI_RX_DONE" event if I were to be addressing a different sensor which returned data of a different length; It would always just be set by what happens in the "NRF_DRV_TWI_TX_DONE" event, which I also can't change on the fly.
How would I go about managing this situation with multiple sensors?
