Suspending a thread also suspends another randomly
I've been working on a project using nRF52832 + NCS 2.1.1 including BLE and some sensors : MAX86150, MAX30205, MP34DT05, LIS3DH
I'm sending data of these sensors through BLE on demand i.e. requesting by sending a char code on a write characteristic for example to request PPG data (from MAX86150) I send 0x01 and for ECG (from MAX86150) I send 0x02. I have two separate threads one is the main thread (thread_main) which controls data requests, system and sensors shutdown, LED control and the other thread  (thread0):
void thread_main(void) {
	while(1) {
		// Check the input from client and manage the data send
		if (meas_value != 0xFF) {
			if (meas_value == 0x00) {
				printk("cancel any calculation\n");
				if (meas_value_current == 0x01) { 		// PPG + Force
					max86150_setPA_IR(&max86150_dev, 0);
					max86150_setPA_Red(&max86150_dev, 0);
					max86150_shutdown(&max86150_dev);
					suspend_thread0 = true;
				}else if (meas_value_current == 0x02) { // ECG
				}else if (meas_value_current == 0x03) { // PCG
					nrfx_pdm_stop();
				}else if (meas_value_current == 0x04) { // TEMP
					// max30205_shutdown(&max30205_dev);
				}else if (meas_value_current == 0x05) { // Accel
				meas_value_current = 0xFF;
			else if (meas_value == 0x01) {
				printk("cal PPG\n");
				MAX86150_config.slot[0] = MAX86150_SLOT_IR_LED1;
				MAX86150_config.slot[1] = MAX86150_SLOT_RED_LED2;
				MAX86150_config.slot[2] = 0;
				MAX86150_config.slot[3] = 0;
				MAX86150_config.IR_LED_PA = 0x1E;
				MAX86150_config.RED_LED_PA = 0x1E;
				max86150_init(&max86150_dev, &MAX86150_config, &MAX86150_data);
				// max86150_wakeup(&max86150_dev);
				k_timer_start(&thread0_timer, K_MSEC(1000), K_MSEC(0));
				meas_value_current = 0x01;
				wake_to_sleep_time = 0;
			else if (meas_value == 0x02) {
				printk("cal ECG\n");
				MAX86150_config.slot[0] = MAX86150_SLOT_ECG;
				MAX86150_config.slot[1] = 0;
				MAX86150_config.ECG_sample_rate = ECG_SAMPLE_RATE_400;
				MAX86150_config.ECG_PGA_gain = ECG_PGA_GAIN_8;
				MAX86150_config.ECG_IA_gain = ECG_IA_GAIN_9_5;
				meas_value_current = 0x02;
			else if (meas_value == 0x03) {
				printk("cal PCG\n");
				nrfx_pdm_start();
				meas_value_current = 0x03;
			else if (meas_value == 0x04) {
				printk("cal TEMP\n");
				meas_value_current = 0x04;
			else if (meas_value == 0x05) {
				printk("cal Accel\n");
				meas_value_current = 0x05;
			else {
				printk("do nothing\n");
			meas_value = 0xFF;
		// If disconnect condition is fulfilled, disconnect the BLE
		if (disconnect_ble) {
			printk("disconnecting ble\n");
			bt_conn_disconnect(my_conn, BT_HCI_ERR_REMOTE_USER_TERM_CONN);
			disconnect_ble = false;
		// Put the lis3dh device to suspend mode
		if (lis3dh_drv_off) {
			printk("turning off lis3dh\n");
			pm_device_action_run(lis3dh_dev, PM_DEVICE_ACTION_SUSPEND);
		// If system off condition is fulfilled, put it to the sleep mode
		if (system_off) {
			// turning off all leds if somehow one is on
			led_off(led_ind_pwm, 0);
			printk("turning off the system\n");
			pm_state_force(0u, &(struct pm_state_info){PM_STATE_SOFT_OFF, 0, 0});
			k_sleep(K_SECONDS(2U));
		// Stop the measurement thread (thread0) whenever needed
		if (suspend_thread0) {
			printk("suspending thread0\n");
			k_thread_suspend(thread0_id);
			suspend_thread0 = false;
		// Measure accelerometer to detect any inactivity
		struct sensor_value accel[3];
		sensor_sample_fetch(lis3dh_dev);
		sensor_channel_get(lis3dh_dev, SENSOR_CHAN_ACCEL_XYZ, accel);
		float x_accel_new = sensor_value_to_double(&accel[0]);
		float y_accel_new = sensor_value_to_double(&accel[1]);
		float z_accel_new = sensor_value_to_double(&accel[2]);
		if (abs(x_accel - x_accel_new) > 0.5 |
			abs(y_accel - y_accel_new) > 0.5 |
			abs(z_accel - z_accel_new) > 0.5)
		}else{
			wake_to_sleep_time++;
			if (wake_to_sleep_time >= WAKE_DURATION) {
				k_timer_start(&before_system_off, K_MSEC(0), K_MSEC(0));
		x_accel = x_accel_new;
		y_accel = y_accel_new;
		z_accel = z_accel_new;
		// LED Pulsing
		if (led_pulsing) {
			led_on(led_ind_pwm, 0);
			k_msleep(50);
			k_msleep(50);
			k_msleep(50);
			k_msleep(50);
		// Debug LED
		// gpio_pin_toggle_dt(&led_pin);
		printk("main loop running...\n");
		k_msleep(1000);
The other thread (thread0) manages the data acquisition and sending of sensors (except for the PDM mic which has it's own callback):
void thread0(void) {
	while(1) {
			max86150_fetch_data(&max86150_dev, &MAX86150_config, &MAX86150_data);
			uint16_t ir_data = (MAX86150_data.channel_data[0]) >> 2;
			uint16_t red_data = (MAX86150_data.channel_data[1]) >> 2;
			float filtered_force = 0, sum_force = 0;
			float new_force = read_Force();
			force_array[force_idx++] = new_force;
			force_idx %= FORCE_WINDOW_SIZE;
			for (int j=0; j<FORCE_WINDOW_SIZE; j++) {
				sum_force += force_array[j];
			filtered_force = (float)sum_force / FORCE_WINDOW_SIZE;
			// filtered_force = new_force;
			epf_buf[epf_count++] = red_data;
			epf_buf[epf_count++] = red_data >> 8;
			epf_buf[epf_count++] = ir_data;
			epf_buf[epf_count++] = ir_data >> 8;
			epf_buf[epf_count++] = 0;
			epf_buf[epf_count++] = (char) filtered_force;
			epf_buf[epf_count++] = (filtered_force - epf_buf[epf_count-1]) * 100;;
			if (epf_count >= EPF_BUF_SIZE) {
				send_notify(epf_buf, sizeof(epf_buf));
				epf_count = 0;
			k_msleep(5);
		else if (meas_value_current == 0x02) {// ECG
			int16_t ecg_data = (int16_t)(MAX86150_data.channel_data[0] >> 2);
			epf_buf[epf_count++] = ecg_data;
			epf_buf[epf_count++] = ecg_data >> 8;
				epf_count = 0;
			k_msleep(5);
		else if (meas_value_current == 0x04) {// Temperature
			float temp;
			uint8_t buf[2];
			// max30205_oneshot_read(&max30205_dev, &temp);
			temp = 32.5;
			buf[0] = (char) temp;
			buf[1] = (temp - buf[0]) * 100;
			send_notify(buf, sizeof(buf));
			k_msleep(1000);
		else if (meas_value_current == 0x05) {// Accelerometer
			uint8_t buf[6];
			float x_accel = sensor_value_to_double(&accel[0]);
			float y_accel = sensor_value_to_double(&accel[1]);
			float z_accel = sensor_value_to_double(&accel[2]);
			buf[0] = (char) x_accel;
			buf[1] = (x_accel - buf[0]) * 100;
			buf[2] = (char) y_accel;
			buf[3] = (y_accel - buf[2]) * 100;
			buf[4] = (char) z_accel;
			buf[5] = (z_accel - buf[4]) * 100;
			k_msleep(1000);
		else {
			k_msleep(1000);
The thread_main is always running but the thread0 is suspended most of the time and is resumed on demand (when data is requested). As mentioned above, resuming and suspending thread0 is done in the thread_main. The problem is suspending thread0 is also sometimes suspending the thread_main. This happens very randomly and I haven't found any pattern to it's occurrence. I don't know exactly whats going on here. If I remove the k_thread_suspend(thread0_id) from thread_main loop and leave thread0 running forever (by having a 1000ms delay in it when there is nothing to do) then it won't occur anymore.I've attached the whole project file.
Thanks in advance,
Hossein
edit : The project file has been removed to convert this topic to public
  • Hi Hosssein,
    The attached code and the code snippet seems to be a bit different. In your attached code I still cannot see the logic of where you are suspending thread0 (even though you showed this in your code snippet in this thread).
    There are few clarification that I seek
    1. How do you know that suspending one thread is suspending main thread aswell? I mean how did you conclude that the main was suspended ?
    2. How are you waking up thread0? I do not see any related code to resume thread0 after it is suspended
    3. Are you sure that thread0_id value is not corrupted over time when the issue happens?
    It looks like you have stripped away most of the code in the attached zip, but it does not show any more details that can aid me to understand or reproduce this issue.
  • Hi Susheel,
    Thanks for your response. I'm sorry I send you the wrong project file I'll send the right one.
    I'm checking the log on the RTT console, the printk("main loop running...\n") line is not show up anymore also changing the request code and shutting down the device doesn't work.
    Not sure if the main thread is suspended but I know that it won't run anymore maybe it is blocked somehow?
    Waking up thread0 is done in a timer callback, now I see maybe that's the problem huh?
    Actually I turn on this timer in the main thread as you can see below and after 1 second the timer will resume the thread.
    void thread0_timer_cb(struct k_timer *timer) {
    	printk("thread0 timer cb\n");
    	k_thread_resume(thread0_id);
    as an example when ppg is requested the timer will be turned on so thread0 can be resumed:
    It might be the case but I don't know where, maybe in the timer callback?
    If you want to reproduce it's not that easy I may have to change the code cause I'm not using the nRF52 DK, we have a custom made board.
    I investigated this and figured out this is not the problem. I placed a flag in the timer callback instead of calling k_thread_suspend in it, and used this function and check the flag in the main thread and suspend the thread there but the problem still persist.
  • Hi Hosssein,
    Can you please attach your minimalistic project to reproduce this. I can try to debug how suspending one thread causes the other to suspend. Have not seen such behavior before.
    I tried to shrank down the bug and I ended up to the max86150 library. It's so weird but the i2c_burst_read_dt is causing the problem I don't know how it is related to the threads do you have any idea?
    To clarify, I myself wrote the library for max86150, I have a function called max86150_fetch_data which I'm calling whenever data is needed for example in the thread0, for ppg calculation this function is called :
    	// uint16_t ir_data = 0;
    	// uint16_t red_data = 0;
    		epf_count = 0;
    	k_msleep(5);
    Inside max86150_fetch_data I'm using i2c_burst_read_dt :
    int max86150_fetch_data(const struct i2c_dt_spec *dev_i2c, struct max86150_config *config,
                struct max86150_data *data) {
        int num_bytes = 3 * data->num_channels;
        uint8_t buffer[num_bytes];
        uint32_t fifo_data;
        int fifo_chan;
        int i;
        if (i2c_burst_read_dt(dev_i2c, MAX86150_REG_FIFO_DATA, buffer, num_bytes)) {
            LOG_ERR("Data register burst read failed");
            return -1;
        fifo_chan = 0;
        for (i = 0; i < num_bytes; i += 3) {
            fifo_data = (buffer[i] << 16) | (buffer[i+1] << 8) | (buffer[i+2]);
            // if (config->slot[i/3] != 9) fifo_data &= MAX86150_PPG_FIFO_DATA_MASK; // if data is ecg don't mask it
            data->channel_data[fifo_chan++] = fifo_data;
        return 0;
    when I comment i2c_burst_read_dt, the problem will disappear. Any idea?
    If you still want to reproduce, you have to have max86150 module if it is available to you let me know then I can provide you the proper code working for nRF52 DK.
