nrf9160 NB-IoT insufficient timing windows for GPS after switching from LTE-M
This is the same project as described in this post with the same setup.
In the process of programming more boards to have the fast switching capability allowed by using NB-IoT, we encountered an issue where some boards that were running on LTE-M and then forced to run on NB-IoT will not be able to get a first fix for GPS for many hours due to insufficient time windows. The board will eventually get GPS, but it will take a long time again after a reset.
If we let the board run while connected to NB-IoT for about a week however, we notice that the issue goes away. Also, if the board starts off by connecting to NB-IoT, the issue doesn't occur. For boards that have this issue, if we turn disconnect cell the gps is able to get a first fix fairly quickly, and will continue to get fixes after cell is connected again.
For context, we are connecting to cell on startup, downloading AGPS data, and then using GPS on the 1HZ continuous mode while cell is connected. The LTE-M network here gives us PSM and eDRX parameters while the NB-IoT network here does not.
My guess is that there are conflicting DRX parameters that interfere with the modem radio giving time for the GPS to decode the satellite ephemerides it receives while being connected to cell, and that this is something that is set on the network side. Boards that we have been testing this specific implementation with already don't seem to have an issue switching between LTE-M and NB-IoT, just boards that we are switching from using both LTE-M and NB-IoT to only NB-IoT.
I hope that the Nordic team can help shed some light on this issue.
Stuart
  • Hi Stuart,
    I am not sure if I understand your issue correctly. Let me try to explain it with my understanding.
    1. You have three firmware only with different network settings: A is LTE-M+NB-IoT, B is only using LTE-M, and C is only using NB-IoT.
    2. Only some specific boards have this issue when you change firmware A to C.
    3. The issue is that the specific boards will get a first fix for GPS for many hours due to insufficient time windows. The board will eventually get GPS, but it will take a long time again after a reset.
    If the above descriptions are correct, could you send two modem trace recordings of two boards with and without this issue?
    Charlie
  • Hi Charlie,
    For our usual product we have not needed to have both GPS and cell on at the same time on startup. We allow the boards to use both NB-IoT and LTE-M so they can failover if there is connectivity issue on one network. With the new product in development we can use the same hardware but just reprogram the firmware. This firmware starts GPS and cell on startup and forces NB-IoT only to make use of the RAI command to enable faster switching from RRC connected to RRC idle without having to wait for the network determined timeout period.
    So far it seems to be boards that have been off for a few months and then ran on LTE-M long enough to get eDRX parameters from the network that have this issue when switching over to NB-IoT. It then takes some time running on NB-IoT for this issue to go away so switching networks doesn't cause the board to need several hours to decode satellite information.
    Since the ticket was created, we developed a solution which involves disconnecting the cell after downloading AGPS data on startup, and then reconnecting the cell after the first GPS fix. It usually only takes a couple minutes to get GPS like this. The question is now whether this is a network dependent issue, or if there is something that we missed.
    Here is the modem trace and log of a board connected to LTE-M that is able to get GPS relatively quickly:
    trace-2024-01-08T20-00-51.957Z.mtrace
    [00:00:00.868,408] <dbg> lte_lc: init_and_config: System mode (4) and preference (0) configured
    [00:00:01.024,566] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_READY
    [00:00:01.960,479] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_PERIODIC_TASKS
    [00:00:11.534,057] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"2BE8","0346840C",7
    [00:00:11.543,975] <dbg> lte_lc_helpers: parse_cereg: Network registration status: 2
    [00:00:11.552,093] <dbg> lte_lc_helpers: parse_cereg: LTE mode: 7
    [00:00:11.558,624] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=0
    [00:00:11.567,657] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:11.583,007] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:11.591,705] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:11.599,029] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=4
    [00:00:11.608,093] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:11.616,851] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:11.625,579] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:11.632,873] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=5
    [00:00:11.641,967] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:11.650,695] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:11.659,454] <inf> cloud: Active LTE mode changed: LTE-M
    [00:00:11.665,679] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:13.244,903] <dbg> lte_lc: at_handler_cscon: +CSCON notification
    [00:00:13.251,892] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=3
    [00:00:13.260,955] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:13.269,683] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:13.278,442] <inf> cloud: RRC mode: Connected
    [00:00:13.283,721] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:15.929,626] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 5,"2BE8","0346840C",7,,,"00100001","10111110"
    [00:00:15.941,741] <dbg> lte_lc_helpers: parse_cereg: Network registration status: 5
    [00:00:15.949,859] <dbg> lte_lc_helpers: parse_cereg: LTE mode: 7
    [00:00:15.956,420] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=0
    [00:00:15.965,484] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:15.974,243] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:15.982,971] <inf> cloud: Network registration status: Connected - roaming
    [00:00:15.990,783] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:15.998,840] <dbg> lte_lc_helpers: parse_psm: TAU: 1800 sec, active time: 60 sec
    [00:00:16.007,110] <dbg> lte_lc: lte_lc_psm_get: TAU: 1800 sec, active time: 60 sec
    [00:00:16.015,167] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=1
    [00:00:16.024,261] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:16.033,020] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:16.041,748] <inf> cloud: PSM parameter update: TAU: 1800, Active time: 60
    [00:00:16.049,560] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:16.056,915] <dbg> lte_lc: at_handler_cedrxp: +CEDRXP notification
    [00:00:16.064,147] <dbg> lte_lc_helpers: parse_edrx: eDRX value for LTE-M: 163.83, PTW: 2.55
    [00:00:16.072,998] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=2
    [00:00:16.082,031] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:16.090,789] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:16.099,670] <inf> cloud: eDRX parameter update: eDRX: 163.839996, PTW: 2.560000
    [00:00:16.107,940] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:16.116,851] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_READY
    [00:00:16.125,488] <inf> gnss: Init GNSS location service
    [00:00:16.131,378] <inf> multicell: Init multicell location service
    [00:00:16.138,641] <inf> gnss: Init AGNSS
    [00:00:17.116,943] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_PERIODIC_TASKS
    [00:00:21.147,430] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_START
    [00:00:21.158,447] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_AGPS_NEEDED
    [00:00:21.167,480] <inf> gnss: Assistance data needed, ephe 0xffffffff, alm 0xffffffff, flags 0x3b
    [00:00:21.443,634] <inf> gnss: Connecting to 108.177.15.192 port 7276
    [00:00:21.762,817] <inf> gnss: Starting SUPL session
    [00:00:21.770,080] <inf> gnss: ULP encoding length: 35
    [00:00:21.776,306] <inf> gnss: Bytes sent: 35
    [00:00:22.106,079] <inf> gnss: Bytes received: 30, total 30
    [00:00:22.112,518] <inf> gnss: ULP ossDecode success, choice 3
    [00:00:22.118,835] <inf> gnss: SUPL server responded using version 2.0.4
    [00:00:22.125,976] <inf> gnss: SUPL response received
    [00:00:22.131,591] <inf> gnss: ULP encoding length: 54
    [00:00:22.137,817] <inf> gnss: Bytes sent: 54
    [00:00:22.560,729] <inf> gnss: Bytes received: 708, total 708
    [00:00:22.567,352] <inf> gnss: ULP ossDecode more input 4
    [00:00:22.778,442] <inf> gnss: Bytes received: 708, total 1416
    [00:00:22.785,156] <inf> gnss: ULP ossDecode more input 4
    [00:00:23.214,294] <inf> gnss: Bytes received: 708, total 2124
    [00:00:23.221,038] <inf> gnss: ULP ossDecode more input 4
    [00:00:23.547,821] <inf> gnss: Bytes received: 708, total 2832
    [00:00:23.554,534] <inf> gnss: ULP ossDecode more input 4
    [00:00:23.740,173] <inf> gnss: Bytes received: 174, total 3006
    [00:00:23.747,253] <inf> gnss: ULP ossDecode success, choice 5
    [00:00:23.757,537] <inf> gnss: Injected A-GPS data, type: 1, size: 16
    [00:00:23.768,096] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.778,839] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.790,008] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.800,872] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.811,828] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.822,784] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.833,923] <inf> gnss:Uéb¥ééºÚ´j5Rþ[00:00:23.844,879] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.855,773] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.866,699] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.877,593] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.888,305] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.899,139] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.910,247] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.921,112] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.932,250] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.943,176] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.954,467] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.965,301] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.976,226] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.987,182] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:23.998,016] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:24.008,728] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:24.019,775] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:24.030,761] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:24.041,656] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:24.052,642] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:24.063,537] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:24.074,676] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:24.085,601] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:24.096,282] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:24.103,942] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.111,541] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.118,988] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.126,586] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.134,033] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.141,662] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.149,108] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.156,738] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.164,154] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.171,752] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.179,229] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.186,798] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.194,427] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.202,026] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.209,655] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.217,071] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.224,700] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.232,299] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.239,929] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.247,558] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.254,974] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.262,603] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.270,050] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.277,740] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.285,186] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.292,694] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.300,140] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.307,739] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.315,216] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.322,845] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.330,413] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:24.337,738] <inf> gnss: Injected A-GPS data, type: 8, size: 4
    [00:00:24.344,940] <inf> gnss: Injected A-GPS data, type: 4, size: 8
    [00:00:24.352,661] <inf> gnss: Injected A-GPS data, type: 6, size: 144
    [00:00:24.360,076] <inf> gnss: Injected A-GPS data, type: 7, size: 16
    [00:00:24.366,943] <inf> gnss: SUPL POS received
    [00:00:24.443,023] <inf> gnss: Bytes received: 30, total 30
    [00:00:24.449,493] <inf> gnss: ULP ossDecode success, choice 6
    [00:00:24.455,718] <inf> gnss: SUPLEND:
    [00:00:24.459,960] <inf> gnss:  Mask: 0
    [00:00:24.464,233] <inf> gnss:  Status: 0
    [00:00:24.468,658] <inf> gnss: SUPL END received
    [00:00:24.473,693] <inf> gnss: SUPL session internal resources released
    [00:00:24.480,712] <inf> gnss: SUPL session finished
    [00:00:24.486,022] <inf> gnss: Done
    [00:00:25.491,210] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:25.499,328] <inf> gnss: GNSS operation blocked by LTE
    [00:00:26.505,493] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:26.513,580] <inf> gnss: GNSS operation blocked by LTE
    [00:00:27.519,836] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:27.527,923] <inf> gnss: GNSS operation blocked by LTE
    [00:00:28.534,088] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:28.542,205] <inf> gnss: GNSS operation blocked by LTE
    [00:00:29.548,431] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:29.556,549] <inf> gnss: GNSS operation blocked by LTE
    [00:00:30.562,744] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:30.570,861] <inf> gnss: GNSS operation blocked by LTE
    [00:00:30.576,995] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:00:31.586,090] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:31.594,177] <inf> gnss: GNSS operation blocked by LTE
    [00:00:32.600,433] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:32.608,551] <inf> gnss: GNSS operation blocked by LTE
    [00:00:33.614,746] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:33.622,863] <inf> gnss: GNSS operation blocked by LTE
    [00:00:34.629,058] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:34.637,176] <inf> gnss: GNSS operation blocked by LTE
    [00:00:35.643,371] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:35.651,458] <inf> gnss: GNSS operation blocked by LTE
    [00:00:36.657,745] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:36.665,863] <inf> gnss: GNSS operation blocked by LTE
    [00:00:37.672,027] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:37.680,145] <inf> gnss: GNSS operation blocked by LTE
    [00:00:38.686,340] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:38.694,458] <inf> gnss: GNSS operation blocked by LTE
    [00:00:39.700,744] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:39.708,831] <inf> gnss: GNSS operation blocked by LTE
    [00:00:40.715,026] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:40.723,144] <inf> gnss: GNSS operation blocked by LTE
    [00:00:41.729,339] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:41.737,487] <inf> gnss: GNSS operation blocked by LTE
    [00:00:42.743,652] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:42.751,770] <inf> gnss: GNSS operation blocked by LTE
    [00:00:43.758,056] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:43.766,143] <inf> gnss: GNSS operation blocked by LTE
    [00:00:44.772,369] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:44.780,456] <inf> gnss: GNSS operation blocked by LTE
    [00:00:45.786,651] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:45.794,769] <inf> gnss: GNSS operation blocked by LTE
    [00:00:46.801,055] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:46.809,173] <inf> gnss: GNSS operation blocked by LTE
    [00:00:47.815,338] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:47.823,455] <inf> gnss: GNSS operation blocked by LTE
    [00:00:48.829,650] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:48.837,799] <inf> gnss: GNSS operation blocked by LTE
    [00:00:49.843,963] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:49.852,081] <inf> gnss: GNSS operation blocked by LTE
    [00:00:50.858,337] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:50.866,455] <inf> gnss: GNSS operation blocked by LTE
    [00:00:51.872,619] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:51.880,737] <inf> gnss: GNSS operation blocked by LTE
    [00:00:52.886,901] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:52.894,989] <inf> gnss: GNSS operation blocked by LTE
    [00:00:53.901,214] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:53.909,332] <inf> gnss: GNSS operation blocked by LTE
    [00:00:54.915,496] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:54.923,645] <inf> gnss: GNSS operation blocked by LTE
    [00:00:55.929,809] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:55.937,927] <inf> gnss: GNSS operation blocked by LTE
    [00:00:56.944,122] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:56.952,239] <inf> gnss: GNSS operation blocked by LTE
    [00:00:57.615,051] <dbg> lte_lc: at_handler_cscon: +CSCON notification
    [00:00:57.622,009] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=3
    [00:00:57.631,072] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:57.639,801] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:57.648,559] <inf> cloud: RRC mode: Idle
    [00:00:57.653,900] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:00:57.662,628] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:57.958,435] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:58.966,674] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:59.974,914] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:00.574,951] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_MISSION_CYCLE
    [00:01:00.584,289] <inf> main: Mission cycle START
    [00:01:00.589,477] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_CONNECT
    [00:01:00.599,609] <inf> cloud: Network time update: 1704744163
    [00:01:00.606,597] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_CONNECTED
    [00:01:00.615,264] <inf> main: Run weekly tasks...
    [00:01:00.651,458] <inf> app_event_manager: e:main_module_event MAIN_EVT_SYSINFO
    [00:01:00.660,003] <inf> cloud: {"event":"mobile/sysinfo","data":{"origin":"350916064460440","time":"2024-01-08T20:02:43Z","fw":{"afw":"afw_assettracker_3.0.1_SRC20","mfw":"mfw_nrf9160_1.3.5"},"hw":{"hws":75}}}
    [00:01:00.983,154] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:00.991,302] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:01:01.960,479] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_PERIODIC_TASKS
    [00:01:02.000,366] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:03.008,575] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:04.016,815] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:05.025,054] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:06.033,294] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:07.041,534] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:08.049,774] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:09.058,013] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:10.048,278] <dbg> lte_lc: at_handler_cscon: +CSCON notification
    [00:01:10.055,267] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=3
    [00:01:10.064,331] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:01:10.073,120] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:01:10.081,878] <inf> cloud: RRC mode: Connected
    [00:01:10.087,188] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:01:10.095,947] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:01:10.507,202] <inf> cloud: Connecting to api.coldchase.com
    [00:01:11.103,485] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:11.111,602] <inf> gnss: GNSS operation blocked by LTE
    [00:01:12.117,797] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:12.125,915] <inf> gnss: GNSS operation blocked by LTE
    [00:01:13.102,508] <inf> cloud: Sent 309 bytes
    [00:01:13.132,232] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:13.140,319] <inf> gnss: GNSS operation blocked by LTE
    [00:01:13.744,659] <inf> cloud: Received 586 bytes
    [00:01:13.749,847] <inf> cloud: HTTP response code: 200.
    [00:01:13.756,713] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_SENT
    [00:01:13.765,533] <inf> app_event_manager: e:main_module_event MAIN_EVT_CERT_UPDATE
    [00:01:13.776,763] <inf> cloud: Connecting to api.coldchase.com
    [00:01:14.146,545] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:14.154,663] <inf> gnss: GNSS operation blocked by LTE
    [00:01:15.160,858] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:15.168,975] <inf> gnss: GNSS operation blocked by LTE
    [00:01:16.175,170] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:16.183,288] <inf> gnss: GNSS operation blocked by LTE
    [00:01:16.618,621] <inf> cloud: Sent 67 bytes
    [00:01:17.116,882] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_PERIODIC_TASKS
    [00:01:17.189,514] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:17.197,601] <inf> gnss: GNSS operation blocked by LTE
    [00:01:17.742,980] <inf> cloud: Received 2475 bytes
    [00:01:17.748,229] <inf> cloud: HTTP response code: 200.
    [00:01:17.812,530] <inf> cloud: Certificate match - 11
    [00:01:17.820,373] <inf> cloud: Connecting to api.coldchase.com
    [00:01:18.203,826] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:18.211,914] <inf> gnss: GNSS operation blocked by LTE
    [00:01:18.475,921] <inf> cloud: Sent 86 bytes
    [00:01:19.218,170] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:19.226,287] <inf> gnss: GNSS operation blocked by LTE
    [00:01:19.684,265] <inf> cloud: Received 2359 bytes
    [00:01:19.689,514] <inf> cloud: HTTP response code: 200.
    [00:01:19.750,854] <inf> cloud: Certificate match - 12
    [00:01:19.756,408] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_CERT_UPDATE_REQUEST_SUCCESSFUL
    [00:01:19.766,906] <inf> app_event_manager: e:main_module_event MAIN_EVT_CONFIG_SYNC
    [00:01:19.779,510] <inf> cloud: Connecting to api.coldchase.com
    [00:01:21.102,264] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:21.110,382] <inf> gnss: GNSS operation blocked by LTE
    [00:01:22.116,607] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:22.124,694] <inf> gnss: GNSS operation blocked by LTE
    [00:01:22.782,012] <inf> cloud: Sent 204 bytes
    [00:01:23.130,889] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:23.139,007] <inf> gnss: GNSS operation blocked by LTE
    [00:01:23.606,536] <inf> cloud: Received 1098 bytes
    [00:01:23.611,785] <inf> cloud: HTTP response code: 200.
    [00:01:23.619,079] <inf> cloud: {"request":0,"beacon":"350916064460440","last_updated":1704744177,"sampling_rate":15,"logging_decimation":15,"mode":11,"excursion":[{"temp_min":-30,"temp_max":30,"temp_change":1},{"pres_min":500,"pres_max":1500,"pres_change":0.2},{"humi_min":0,"humi_max":100,"humi_change":3},{"gas_res_min":0,"gas_res_max":500,"gas_res_change":5},{"battery_min":3.5},{"motion_thres":0.2},{"luminosity_max":1}],"mission_rate":900,"cell_to":300,"geo_dec":1,"dbg_en":true,"apm_to":0,"gps_intvl":900,"gps_to":300,"gps_offs":180}
    [00:01:23.671,813] <inf> cloud: Configuration parsed successfully.
    [00:01:23.678,405] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_CONFIG_REQUEST_SUCCESSFUL
    [00:01:23.688,476] <inf> app_event_manager: e:main_module_event MAIN_EVT_LOCATION_GET
    [00:01:23.697,418] <inf> multicell: Multicell location request.
    [00:01:23.706,817] <dbg> lte_lc: at_handler_ncellmeas: %NCELLMEAS notification: neighbor cell count: 0
    [00:01:23.716,918] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=7
    [00:01:23.725,982] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:01:23.734,710] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:01:23.743,469] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:01:23.752,227] <inf> multicell: Neighbor cell measurements received.
    [00:01:23.759,338] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:01:23.766,754] <inf> app_event_manager: e:multicell_module_event MULTICELL_EVT_CELLINFO_SAMPLE_COLLECTED
    [00:01:23.777,343] <inf> app_event_manager: e:main_module_event MAIN_EVT_COLLECT_DIAGNOSTICS
    [00:01:23.789,428] <inf> block_manager: Memory update - head 57947, tail 57829, count 1
    [00:01:23.797,790] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_DIAGNOSTICS_SAMPLE_COLLECTED
    [00:01:23.808,197] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:01:23.816,986] <inf> logger: Samples to upload 1
    [00:01:23.823,791] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_DATA_UPLOAD
    [00:01:23.832,885] <inf> cloud: {"event":"mobile/data","data":[{"event":"mobile/diagnostic","data":{"origin":"350916064460440","time":"2024-01-08T20:03:06Z","diag":"afw_assettracker_3.0.1_SRC20,302,220,11240,7,54952972,-92,5145,4,295050912057168,1,0,0,0,0,5,n/a,0,0,44,0"}}]}
    [00:01:23.860,015] <inf> cloud: Connecting to api.coldchase.com
    [00:01:24.145,202] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:24.153,320] <inf> gnss: GNSS operation blocked by LTE
    [00:01:24.587,432] <inf> cloud: Sent 374 bytes
    [00:01:25.200,775] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:25.208,862] <inf> gnss: GNSS operation blocked by LTE
    [00:01:25.669,647] <inf> cloud: Received 578 bytes
    [00:01:25.674,804] <inf> cloud: HTTP response code: 200.
    [00:01:25.781,799] <inf> cloud: Setting socket option to RAI_LAST to send last package!
    [00:01:25.792,083] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_SENT
    [00:01:25.801,269] <inf> block_manager: Memory update: head 57947, tail 57947, count 0
    [00:01:25.809,570] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:01:25.818,481] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:01:25.827,667] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:01:25.836,578] <inf> main: Mission/Upload cycle STOP
    [00:01:26.215,057] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:26.223,205] <inf> gnss: GNSS operation blocked by LTE
    [00:01:27.229,370] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:27.237,487] <inf> gnss: GNSS operation blocked by LTE
    [00:01:28.243,682] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:28.251,800] <inf> gnss: GNSS operation blocked by LTE
    [00:01:29.257,995] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:29.266,082] <inf> gnss: GNSS operation blocked by LTE
    [00:01:30.272,277] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:30.280,364] <inf> gnss: GNSS operation blocked by LTE
    [00:01:31.286,621] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:31.294,738] <inf> gnss: GNSS operation blocked by LTE
    [00:01:31.300,842] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:01:32.309,875] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:32.317,993] <inf> gnss: GNSS operation blocked by LTE
    [00:01:33.324,157] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:33.332,275] <inf> gnss: GNSS operation blocked by LTE
    [00:01:34.338,439] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:34.346,557] <inf> gnss: GNSS operation blocked by LTE
    [00:01:35.352,783] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:35.360,900] <inf> gnss: GNSS operation blocked by LTE
    [00:01:36.367,065] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:36.375,152] <inf> gnss: GNSS operation blocked by LTE
    [00:01:37.381,347] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:37.389,465] <inf> gnss: GNSS operation blocked by LTE
    [00:01:38.395,721] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:38.403,808] <inf> gnss: GNSS operation blocked by LTE
    [00:01:39.410,003] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:39.418,090] <inf> gnss: GNSS operation blocked by LTE
    [00:01:40.424,285] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:40.432,403] <inf> gnss: GNSS operation blocked by LTE
    [00:01:41.438,568] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:41.446,685] <inf> gnss: GNSS operation blocked by LTE
    [00:01:42.452,911] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:42.461,029] <inf> gnss: GNSS operation blocked by LTE
    [00:01:43.467,193] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:43.475,280] <inf> gnss: GNSS operation blocked by LTE
    [00:01:44.481,506] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:44.489,593] <inf> gnss: GNSS operation blocked by LTE
    [00:01:45.495,788] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:45.503,906] <inf> gnss: GNSS operation blocked by LTE
    [00:01:46.510,101] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:46.518,218] <inf> gnss: GNSS operation blocked by LTE
    [00:01:47.524,414] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:47.532,531] <inf> gnss: GNSS operation blocked by LTE
    [00:01:48.538,696] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:48.546,813] <inf> gnss: GNSS operation blocked by LTE
    [00:01:49.553,070] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:49.561,157] <inf> gnss: GNSS operation blocked by LTE
    [00:01:50.567,382] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:50.575,500] <inf> gnss: GNSS operation blocked by LTE
    [00:01:51.581,695] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:51.589,813] <inf> gnss: GNSS operation blocked by LTE
    [00:01:52.596,008] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:52.604,095] <inf> gnss: GNSS operation blocked by LTE
    [00:01:53.610,382] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:53.618,499] <inf> gnss: GNSS operation blocked by LTE
    [00:01:54.624,694] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:54.632,812] <inf> gnss: GNSS operation blocked by LTE
    [00:01:55.639,038] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:55.647,125] <inf> gnss: GNSS operation blocked by LTE
    [00:01:56.653,350] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:56.661,437] <inf> gnss: GNSS operation blocked by LTE
    [00:01:57.667,633] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:57.675,781] <inf> gnss: GNSS operation blocked by LTE
    [00:01:58.226,074] <dbg> lte_lc: at_handler_cscon: +CSCON notification
    [00:01:58.233,032] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=3
    [00:01:58.242,095] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:01:58.250,823] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:01:58.259,887] <inf> cloud: RRC mode: Idle
    [00:01:58.264,739] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:01:58.273,468] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:01:58.681,976] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:59.690,216] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:00.574,615] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:02:00.583,831] <inf> main: Upload cycle START
    [00:02:00.588,928] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:02:00.597,778] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:02:00.606,658] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:02:00.615,814] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:02:00.624,725] <inf> main: Mission/Upload cycle STOP
    [00:02:00.698,455] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:00.706,604] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:02:01.715,637] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:01.960,510] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_PERIODIC_TASKS
    [00:02:02.723,876] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:03.732,116] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:04.740,356] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:05.748,596] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:06.756,835] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:07.765,075] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:08.773,315] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:09.781,555] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:10.584,136] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 5,"2BE8","0346840A",7,,,"00100001","10111110"
    [00:02:10.596,221] <dbg> lte_lc_helpers: parse_cereg: Network registration status: 5
    [00:02:10.604,339] <dbg> lte_lc_helpers: parse_cereg: LTE mode: 7
    [00:02:10.610,870] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=4
    [00:02:10.619,903] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:02:10.628,662] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:02:10.637,390] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:02:10.646,148] <wrn> multicell: LTE cell changed: Cell ID: 54952970, Tracking area: 11240
    [00:02:10.655,303] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:02:10.669,525] <dbg> lte_lc_helpers: parse_psm: TAU: 1800 sec, active time: 60 sec
    [00:02:10.677,795] <dbg> lte_lc: lte_lc_psm_get: TAU: 1800 sec, active time: 60 sec
    [00:02:11.789,886] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:12.798,095] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:13.806,335] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:14.814,575] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:15.574,615] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:02:15.583,831] <inf> main: Upload cycle START
    [00:02:15.588,928] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:02:15.597,778] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:02:15.606,658] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:02:15.615,783] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:02:15.624,694] <inf> main: Mission/Upload cycle STOP
    [00:02:15.822,845] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:16.831,085] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:16.839,202] <inf> gnss: Insufficient GNSS time windows
    [00:02:17.116,882] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_PERIODIC_TASKS
    [00:02:17.845,458] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:17.853,546] <inf> gnss: Insufficient GNSS time windows
    [00:02:18.859,832] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:18.867,950] <inf> gnss: Insufficient GNSS time windows
    [00:02:19.874,206] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:19.882,293] <inf> gnss: Insufficient GNSS time windows
    [00:02:20.888,580] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:20.896,667] <inf> gnss: Insufficient GNSS time windows
    [00:02:21.902,954] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:21.911,041] <inf> gnss: Insufficient GNSS time windows
    [00:02:22.917,327] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:22.925,445] <inf> gnss: Insufficient GNSS time windows
    [00:02:23.931,701] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:23.939,819] <inf> gnss: Insufficient GNSS time windows
    [00:02:24.946,075] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:25.954,315] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:26.962,554] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:27.970,825] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:28.979,064] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:29.987,274] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:30.574,615] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:02:30.583,862] <inf> main: Upload cycle START
    [00:02:30.588,958] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:02:30.597,778] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:02:30.606,689] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:02:30.615,844] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:02:30.624,725] <inf> main: Mission/Upload cycle STOP
    [00:02:30.995,513] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:31.003,662] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:02:32.012,695] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:33.020,935] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:34.029,174] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:35.037,414] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:36.045,623] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:36.952,087] <wrn> logger: Motion detected at 5143006
    [00:02:36.958,312] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_SAMPLE_INTERRUPT
    [00:02:36.967,803] <inf> logger: MOTION IRQ CLEARED - MC34X9
    [00:02:37.053,863] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:38.062,103] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:39.070,343] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:40.078,582] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:41.086,822] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:41.162,475] <wrn> logger: Motion detected at 5280971
    [00:02:41.168,670] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_SAMPLE_INTERRUPT
    [00:02:41.178,161] <inf> logger: MOTION IRQ CLEARED - MC34X9
    [00:02:42.095,031] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:43.103,271] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:44.111,511] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:45.119,750] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:45.574,615] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:02:45.583,862] <inf> main: Upload cycle START
    [00:02:45.588,958] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:02:45.597,778] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:02:45.606,658] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:02:45.615,814] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:02:45.624,725] <inf> main: Mission/Upload cycle STOP
    [00:02:45.899,780] <wrn> logger: Motion detected at 5436203
    [00:02:45.906,005] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_SAMPLE_INTERRUPT
    [00:02:45.915,496] <inf> logger: MOTION IRQ CLEARED - MC34X9
    [00:02:46.127,990] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:47.136,230] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:48.144,470] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:49.152,709] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:50.160,919] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:51.169,158] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:52.177,398] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:53.185,638] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:54.193,878] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:55.202,117] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:56.210,357] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:57.218,597] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:58.226,867] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:59.235,076] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:00.243,316] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:00.574,615] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:03:00.583,862] <inf> main: Upload cycle START
    [00:03:00.588,958] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:03:00.597,778] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:03:00.606,689] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:03:00.615,844] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:03:00.624,755] <inf> main: Mission/Upload cycle STOP
    [00:03:01.251,556] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:01.259,704] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:03:01.960,479] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_PERIODIC_TASKS
    [00:03:02.268,737] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:03.276,977] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:04.285,217] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:05.293,457] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:06.301,696] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:07.309,936] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:08.318,176] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:09.326,416] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:10.334,655] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:11.342,895] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:12.351,135] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:13.359,375] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:14.367,614] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:15.375,854] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:15.574,645] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:03:15.583,892] <inf> main: Upload cycle START
    [00:03:15.588,989] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:03:15.597,808] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:03:15.606,719] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:03:15.615,905] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:03:15.624,786] <inf> main: Mission/Upload cycle STOP
    [00:03:16.384,094] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:17.116,882] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_PERIODIC_TASKS
    [00:03:17.392,333] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:18.400,573] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:19.408,813] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:20.417,053] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:21.425,292] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:22.433,532] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:23.441,772] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:24.450,012] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:25.458,251] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:26.466,491] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:27.474,731] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:28.483,062] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:29.491,302] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:30.499,542] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:30.507,720] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:03:30.574,645] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:03:30.583,892] <inf> main: Upload cycle START
    [00:03:30.588,989] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:03:30.597,839] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:03:30.606,750] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:03:30.615,905] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:03:30.624,816] <inf> main: Mission/Upload cycle STOP
    [00:03:31.516,723] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:32.524,963] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:33.533,203] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:34.541,442] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:35.549,713] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:36.557,952] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:37.566,192] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:38.574,432] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:39.582,672] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:40.590,911] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:41.599,151] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:42.607,421] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:43.615,661] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:44.623,901] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:45.574,615] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:03:45.583,862] <inf> main: Upload cycle START
    [00:03:45.588,958] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:03:45.597,808] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:03:45.606,719] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:03:45.615,966] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:03:45.624,877] <inf> main: Mission/Upload cycle STOP
    [00:03:45.632,324] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 7:24.7
    [00:03:46.641,235] <inf> gnss: Tracking  3; Using  0; Unhealthy  0; Power(dB/Hz) 7:45.8;13:29.0;30:21.5
    [00:03:47.651,641] <inf> gnss: Tracking  4; Using  0; Unhealthy  0; Power(dB/Hz) 7:45.8;13:31.3;30:11.1;5:37.1
    [00:03:48.662,658] <inf> gnss: Tracking  4; Using  0; Unhealthy  0; Power(dB/Hz) 7:43.6;13:31.9;30:11.1;5:36.9
    [00:03:49.673,645] <inf> gnss: Tracking  4; Using  0; Unhealthy  0; Power(dB/Hz) 7:42.0;13:30.0;30:42.3;5:36.0
    [00:03:50.684,661] <inf> gnss: Tracking  4; Using  0; Unhealthy  0; Power(dB/Hz) 7:41.5;13:27.7;30:42.3;5:35.4
    [00:03:51.695,831] <inf> gnss: Tracking  5; Using  0; Unhealthy  0; Power(dB/Hz) 7:41.8;13:28.1;30:37.7;5:35.1;8:26.9
    [00:03:52.707,580] <inf> gnss: Tracking  5; Using  0; Unhealthy  0; Power(dB/Hz) 7:42.0;13:30.1;30:36.7;5:35.2;8:27.7
    [00:03:53.719,329] <inf> gnss: Tracking  5; Using  5; Unhealthy  0; Power(dB/Hz) 7:42.5;13:30.1;30:36.3;5:35.8;8:27.5
    [00:03:53.730,316] <inf> gnss: GNSS position update: lat 53.312975 - lon -113.580427 - alt 739.762939 - acc 0.556040
    [00:03:53.741,333] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_LOCATION_SAMPLE_COLLECTED
    [00:03:53.751,647] <inf> block_manager: Memory update - head 57983, tail 57947, count 1
    [00:03:53.819,641] <inf> logger: Sample has been taken - battery voltage 4.000 V
    [00:03:53.828,002] <inf> block_manager: Memory update - head 58072, tail 57947, count 2
    [00:03:54.751,953] <inf> gnss: Tracking  5; Using  5; Unhealthy  0; Power(dB/Hz) 7:42.6;13:29.0;30:35.4;5:36.6;8:27.4
    [00:03:54.762,969] <inf> gnss: GNSS position update: lat 53.312897 - lon -113.580449 - alt 738.577148 - acc 0.465979
    [00:03:55.774,932] <inf> gnss: Tracking  7; Using  5; Unhealthy  0; Power(dB/Hz) 7:42.5;13:29.2;30:34.2;5:36.6;8:28.3;22:29.7;14:20.2
    And here is the modem trace and log of the board connected to NB-IoT which is unable to get GPS unless left to run for several hours:
    trace-2024-01-05T23-58-15.802Z.mtrace
    [00:00:00.886,322] <dbg> lte_lc: init_and_config: System mode (5) and preference (0) configured
    [00:00:01.030,487] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_READY
    [00:00:01.966,400] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_PERIODIC_TASKS
    [00:00:06.778,930] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 2,"BDE5","0642B281",9
    [00:00:06.788,818] <dbg> lte_lc_helpers: parse_cereg: Network registration status: 2
    [00:00:06.796,936] <dbg> lte_lc_helpers: parse_cereg: LTE mode: 9
    [00:00:06.803,466] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=0
    [00:00:06.812,500] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:06.821,655] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:06.830,322] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:06.837,585] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=4
    [00:00:06.846,679] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:06.855,407] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:06.864,135] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:06.871,398] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=5
    [00:00:06.880,462] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:06.889,190] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:06.897,918] <inf> cloud: Active LTE mode changed: NB-IoT
    [00:00:06.904,235] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:07.026,489] <dbg> lte_lc: at_handler_cscon: +CSCON notification
    [00:00:07.033,477] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=3
    [00:00:07.042,510] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:07.051,269] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:07.059,997] <inf> cloud: RRC mode: Connected
    [00:00:07.065,246] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:09.260,650] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 5,"BDE5","0642B281",9,,,"11100000","11100000"
    [00:00:09.272,705] <dbg> lte_lc_helpers: parse_cereg: Network registration status: 5
    [00:00:09.280,792] <dbg> lte_lc_helpers: parse_cereg: LTE mode: 9
    [00:00:09.287,322] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=0
    [00:00:09.296,447] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:09.305,206] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:09.313,903] <inf> cloud: Network registration status: Connected - roaming
    [00:00:09.321,685] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:09.329,803] <dbg> lte_lc_helpers: parse_psm: TAU: 3240 sec, active time: -1 sec
    [00:00:09.338,073] <dbg> lte_lc: lte_lc_psm_get: TAU: 3240 sec, active time: -1 sec
    [00:00:09.346,099] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=1
    [00:00:09.355,163] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:09.363,891] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:09.372,619] <inf> cloud: PSM parameter update: TAU: 3240, Active time: -1
    [00:00:09.380,401] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:09.389,373] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_READY
    [00:00:09.397,979] <inf> gnss: Init GNSS location service
    [00:00:09.403,839] <inf> multicell: Init multicell location service
    [00:00:09.411,071] <inf> gnss: Init AGNSS
    [00:00:10.389,404] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_PERIODIC_TASKS
    [00:00:14.409,118] <dbg> lte_lc: at_handler_cscon: +CSCON notification
    [00:00:14.416,076] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=3
    [00:00:14.425,140] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:14.433,868] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:14.442,596] <inf> cloud: RRC mode: Idle
    [00:00:14.447,448] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:00:14.456,176] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:14.463,470] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_START
    [00:00:14.474,456] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_AGPS_NEEDED
    [00:00:14.483,551] <inf> gnss: Assistance data needed, ephe 0xffffffff, alm 0xffffffff, flags 0x3b
    [00:00:14.946,899] <dbg> lte_lc: at_handler_cscon: +CSCON notification
    [00:00:14.953,887] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=3
    [00:00:14.962,921] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:14.971,679] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:14.980,407] <inf> cloud: RRC mode: Connected
    [00:00:14.985,687] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:00:14.994,415] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:15.491,088] <inf> gnss: Connecting to 74.125.71.192 port 7276
    [00:00:15.786,468] <inf> gnss: Starting SUPL session
    [00:00:15.793,670] <inf> gnss: ULP encoding length: 35
    [00:00:15.799,682] <inf> gnss: Bytes sent: 35
    [00:00:16.131,744] <inf> gnss: Bytes received: 30, total 30
    [00:00:16.138,214] <inf> gnss: ULP ossDecode success, choice 3
    [00:00:16.144,500] <inf> gnss: SUPL server responded using version 2.0.4
    [00:00:16.151,611] <inf> gnss: SUPL response received
    [00:00:16.157,226] <inf> gnss: ULP encoding length: 54
    [00:00:16.163,604] <inf> gnss: Bytes sent: 54
    [00:00:17.106,262] <inf> gnss: Bytes received: 708, total 708
    [00:00:17.112,884] <inf> gnss: ULP ossDecode more input 4
    [00:00:17.411,224] <inf> gnss: Bytes received: 708, total 1416
    [00:00:17.417,907] <inf> gnss: ULP ossDecode more input 4
    [00:00:17.716,369] <inf> gnss: Bytes received: 708, total 2124
    [00:00:17.723,083] <inf> gnss: ULP ossDecode more input 4
    [00:00:18.021,270] <inf> gnss: Bytes received: 708, total 2832
    [00:00:18.027,954] <inf> gnss: ULP ossDecode more input 4
    [00:00:18.132,049] <inf> gnss: Bytes received: 161, total 2993
    [00:00:18.139,099] <inf> gnss: ULP ossDecode success, choice 5
    [00:00:18.149,353] <inf> gnss: Injected A-GPS data, type: 1, size: 16
    [00:00:18.159,393] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.169,738] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.179,901] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.190,704] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.201,263] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.211,517] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.222,656] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.233,215] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.243,713] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.254,333] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.264,770] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.275,421] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.286,041] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.296,478] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.307,067] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.317,565] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.328,155] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.338,592] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.349,243] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.359,680] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.370,239] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.380,767] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.391,387] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.401,977] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.412,414] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.423,004] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.433,502] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.444,152] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.454,681] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.465,240] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.475,769] <inf> gnss: Injected A-GPS data, type: 2, size: 72
    [00:00:18.483,337] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.490,783] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.498,291] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.505,706] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.513,244] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.520,629] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.528,198] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.535,583] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.543,121] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.550,537] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.558,074] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.565,490] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.573,089] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.580,474] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.588,012] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.595,550] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.603,088] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.610,504] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.618,041] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.625,457] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.632,995] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.640,411] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.647,827] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.655,364] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.662,780] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.670,318] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.677,764] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.685,302] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.692,687] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.700,225] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.707,641] <inf> gnss: Injected A-GPS data, type: 3, size: 32
    [00:00:18.715,209] <inf> gnss: Injected A-GPS data, type: 8, size: 4
    [00:00:18.722,381] <inf> gnss: Injected A-GPS data, type: 4, size: 8
    [00:00:18.730,133] <inf> gnss: Injected A-GPS data, type: 6, size: 144
    [00:00:18.737,060] <inf> gnss: No location data available
    [00:00:18.743,377] <inf> gnss: Injected A-GPS data, type: 7, size: 16
    [00:00:18.750,244] <inf> gnss: MCC location info injected, MCC: 302
    [00:00:18.756,958] <inf> gnss:  Lat: 5719166 Lon: -4581578
    [00:00:18.762,908] <inf> gnss:  Unc semiminor/semimajor: 127/127
    [00:00:18.769,317] <inf> gnss:  Unc altitude: 127
    [00:00:18.774,444] <inf> gnss:  Confidence: 33
    [00:00:18.779,296] <inf> gnss:  Orientation: 0
    [00:00:18.784,118] <inf> gnss: SUPL POS received
    [00:00:18.849,822] <inf> gnss: Bytes received: 30, total 30
    [00:00:18.856,292] <inf> gnss: ULP ossDecode success, choice 6
    [00:00:18.862,518] <inf> gnss: SUPLEND:
    [00:00:18.866,760] <inf> gnss:  Mask: 0
    [00:00:18.871,002] <inf> gnss:  Status: 0
    [00:00:18.875,427] <inf> gnss: SUPL END received
    [00:00:18.880,462] <inf> gnss: SUPL session internal resources released
    [00:00:18.887,451] <inf> gnss: SUPL session finished
    [00:00:18.892,761] <inf> gnss: Done
    [00:00:19.897,888] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:19.905,975] <inf> gnss: GNSS operation blocked by LTE
    [00:00:20.912,170] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:20.920,227] <inf> gnss: GNSS operation blocked by LTE
    [00:00:21.926,452] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:21.934,509] <inf> gnss: GNSS operation blocked by LTE
    [00:00:22.940,734] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:22.948,791] <inf> gnss: GNSS operation blocked by LTE
    [00:00:23.955,017] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:23.963,073] <inf> gnss: GNSS operation blocked by LTE
    [00:00:24.741,424] <dbg> lte_lc: at_handler_cscon: +CSCON notification
    [00:00:24.748,382] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=3
    [00:00:24.757,415] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:00:24.766,174] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:00:24.774,902] <inf> cloud: RRC mode: Idle
    [00:00:24.780,181] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:00:24.788,909] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:00:24.969,268] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:25.977,508] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:26.985,687] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:27.993,896] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:29.002,105] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:30.010,314] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:31.018,524] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:31.026,672] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:00:32.035,675] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:33.043,884] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:34.052,093] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:35.060,302] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:36.068,511] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:38.076,812] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:39.085,052] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:39.093,139] <inf> gnss: Insufficient GNSS time windows
    [00:00:40.099,395] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:40.107,482] <inf> gnss: Insufficient GNSS time windows
    [00:00:41.113,769] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:41.121,856] <inf> gnss: Insufficient GNSS time windows
    [00:00:42.128,143] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:42.136,230] <inf> gnss: Insufficient GNSS time windows
    [00:00:43.142,517] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:43.150,573] <inf> gnss: Insufficient GNSS time windows
    [00:00:44.156,860] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:44.164,947] <inf> gnss: Insufficient GNSS time windows
    [00:00:45.171,203] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:45.179,290] <inf> gnss: Insufficient GNSS time windows
    [00:00:46.185,546] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:46.193,634] <inf> gnss: Insufficient GNSS time windows
    [00:00:47.199,920] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:47.208,007] <inf> gnss: Insufficient GNSS time windows
    [00:00:48.214,294] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:48.222,381] <inf> gnss: Insufficient GNSS time windows
    [00:00:49.228,668] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:49.236,755] <inf> gnss: Insufficient GNSS time windows
    [00:00:50.243,041] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:50.251,129] <inf> gnss: Insufficient GNSS time windows
    [00:00:51.257,415] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:51.265,502] <inf> gnss: Insufficient GNSS time windows
    [00:00:52.271,759] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:52.279,846] <inf> gnss: Insufficient GNSS time windows
    [00:00:53.286,132] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:53.294,219] <inf> gnss: Insufficient GNSS time windows
    [00:00:54.300,476] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:54.308,563] <inf> gnss: Insufficient GNSS time windows
    [00:00:55.314,819] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:55.322,906] <inf> gnss: Insufficient GNSS time windows
    [00:00:56.329,193] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:56.337,280] <inf> gnss: Insufficient GNSS time windows
    [00:00:57.343,566] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:57.351,654] <inf> gnss: Insufficient GNSS time windows
    [00:00:58.357,910] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:58.365,997] <inf> gnss: Insufficient GNSS time windows
    [00:00:59.372,253] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:00:59.380,340] <inf> gnss: Insufficient GNSS time windows
    [00:01:00.386,596] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:00.394,683] <inf> gnss: Insufficient GNSS time windows
    [00:01:00.400,848] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:01:00.578,155] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_MISSION_CYCLE
    [00:01:00.587,463] <inf> main: Mission cycle START
    [00:01:00.592,620] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_CONNECT
    [00:01:00.602,752] <inf> cloud: Network time update: 1704734781
    [00:01:00.609,710] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_CONNECTED
    [00:01:00.618,347] <inf> main: Run weekly tasks...
    [00:01:00.625,579] <inf> app_event_manager: e:main_module_event MAIN_EVT_SYSINFO
    [00:01:00.634,124] <inf> cloud: {"event":"mobile/sysinfo","data":{"origin":"350916064476248","time":"2024-01-08T17:26:21Z","fw":{"afw":"afw_assettracker_3.0.1_SRC20","mfw":"mfw_nrf9160_1.3.5"},"hw":{"hws":75}}}
    [00:01:01.029,144] <dbg> lte_lc: at_handler_cscon: +CSCON notification
    [00:01:01.036,132] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=3
    [00:01:01.045,166] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:01:01.053,894] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:01:01.062,622] <inf> cloud: RRC mode: Connected
    [00:01:01.067,901] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:01:01.076,660] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:01:01.409,851] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:01.417,938] <inf> gnss: Insufficient GNSS time windows
    [00:01:01.558,349] <inf> cloud: Connecting to api-staging.coldchase.com
    [00:01:01.966,400] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_PERIODIC_TASKS
    [00:01:02.424,224] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:02.432,312] <inf> gnss: GNSS operation blocked by LTE
    [00:01:03.438,476] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:03.446,563] <inf> gnss: GNSS operation blocked by LTE
    [00:01:04.452,758] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:04.460,845] <inf> gnss: GNSS operation blocked by LTE
    [00:01:05.467,010] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:05.475,097] <inf> gnss: GNSS operation blocked by LTE
    [00:01:05.585,754] <inf> cloud: Sent 317 bytes
    [00:01:06.454,742] <inf> cloud: Received 588 bytes
    [00:01:06.459,899] <inf> cloud: HTTP response code: 200.
    [00:01:06.467,163] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DATA_SENT
    [00:01:06.475,952] <inf> app_event_manager: e:main_module_event MAIN_EVT_CERT_UPDATE
    [00:01:06.486,541] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:06.494,628] <inf> gnss: GNSS operation blocked by LTE
    [00:01:06.501,159] <inf> cloud: Connecting to api-staging.coldchase.com
    [00:01:07.500,823] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:07.508,911] <inf> gnss: GNSS operation blocked by LTE
    [00:01:08.515,136] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:08.523,223] <inf> gnss: GNSS operation blocked by LTE
    [00:01:09.529,388] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:09.537,475] <inf> gnss: GNSS operation blocked by LTE
    [00:01:10.389,404] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_PERIODIC_TASKS
    [00:01:10.543,640] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:10.551,727] <inf> gnss: GNSS operation blocked by LTE
    [00:01:10.880,615] <inf> cloud: Sent 75 bytes
    [00:01:11.557,922] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:11.566,009] <inf> gnss: GNSS operation blocked by LTE
    [00:01:12.518,646] <inf> cloud: Received 2471 bytes
    [00:01:12.523,895] <inf> cloud: HTTP response code: 200.
    [00:01:12.572,204] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:12.580,291] <inf> gnss: GNSS operation blocked by LTE
    [00:01:12.593,383] <inf> cloud: Certificate match - 11
    [00:01:12.601,196] <inf> cloud: Connecting to api-staging.coldchase.com
    [00:01:13.586,517] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:13.594,604] <inf> gnss: GNSS operation blocked by LTE
    [00:01:14.600,769] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:14.608,856] <inf> gnss: GNSS operation blocked by LTE
    [00:01:15.615,020] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:15.623,107] <inf> gnss: GNSS operation blocked by LTE
    [00:01:16.629,272] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:16.637,359] <inf> gnss: GNSS operation blocked by LTE
    [00:01:17.016,143] <inf> cloud: Sent 94 bytes
    [00:01:17.643,524] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:17.651,611] <inf> gnss: GNSS operation blocked by LTE
    [00:01:18.547,912] <inf> cloud: Received 2365 bytes
    [00:01:18.553,161] <inf> cloud: HTTP response code: 200.
    [00:01:18.612,701] <inf> cloud: Certificate match - 12
    [00:01:18.618,225] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_CERT_UPDATE_REQUEST_SUCCESSFUL
    [00:01:18.628,692] <inf> app_event_manager: e:main_module_event MAIN_EVT_CONFIG_SYNC
    [00:01:18.641,448] <inf> cloud: Connecting to api-staging.coldchase.com
    [00:01:18.657,806] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:18.665,863] <inf> gnss: GNSS operation blocked by LTE
    [00:01:19.672,027] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:19.680,145] <inf> gnss: GNSS operation blocked by LTE
    [00:01:20.686,309] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:20.694,396] <inf> gnss: GNSS operation blocked by LTE
    [00:01:21.700,592] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:21.708,679] <inf> gnss: GNSS operation blocked by LTE
    [00:01:22.714,843] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:22.722,930] <inf> gnss: GNSS operation blocked by LTE
    [00:01:22.881,591] <inf> cloud: Sent 212 bytes
    [00:01:23.729,217] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:23.737,304] <inf> gnss: GNSS operation blocked by LTE
    [00:01:23.935,272] <inf> cloud: Received 1001 bytes
    [00:01:23.940,490] <inf> cloud: HTTP response code: 200.
    [00:01:23.948,211] <inf> cloud: {"request":0,"beacon":"350916064476248","last_updated":1577836800,"sampling_rate":60,"logging_decimation":15,"mission_rate":900,"mode":11,"excursion":[{"temp_min":-100,"temp_max":100,"temp_change":1},{"pres_min":500,"pres_max":1500,"pres_change":1},{"humi_min":0,"humi_max":100,"humi_change":3},{"gas_res_min":0,"gas_res_max":500,"gas_res_change":5},{"battery_min":2.1},{"motion_thres":2.1},{"luminosity_max":100}]}
    [00:01:23.992,431] <inf> cloud: Configuration parsed successfully.
    [00:01:23.998,992] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_CONFIG_REQUEST_SUCCESSFUL
    [00:01:24.009,063] <inf> app_event_manager: e:main_module_event MAIN_EVT_LOCATION_GET
    [00:01:24.018,005] <inf> multicell: Multicell location request.
    [00:01:24.027,343] <dbg> lte_lc: at_handler_ncellmeas: %NCELLMEAS notification: neighbor cell count: 0
    [00:01:24.037,445] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=7
    [00:01:24.046,478] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:01:24.055,206] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:01:24.063,934] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:01:24.072,692] <inf> multicell: Neighbor cell measurements received.
    [00:01:24.079,772] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:01:24.087,188] <inf> app_event_manager: e:multicell_module_event MULTICELL_EVT_CELLINFO_SAMPLE_COLLECTED
    [00:01:24.097,747] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:01:24.106,597] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:01:24.115,478] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:01:24.124,633] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:01:24.133,514] <inf> main: Mission/Upload cycle STOP
    [00:01:24.743,499] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:24.751,586] <inf> gnss: GNSS operation blocked by LTE
    [00:01:25.757,751] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:25.765,838] <inf> gnss: GNSS operation blocked by LTE
    [00:01:26.772,003] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:26.780,090] <inf> gnss: GNSS operation blocked by LTE
    [00:01:27.786,254] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:27.794,342] <inf> gnss: GNSS operation blocked by LTE
    [00:01:28.800,506] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:28.808,593] <inf> gnss: GNSS operation blocked by LTE
    [00:01:29.381,011] <dbg> lte_lc: at_handler_cscon: +CSCON notification
    [00:01:29.388,000] <dbg> lte_lc_helpers: event_handler_list_dispatch: Dispatching event: type=3
    [00:01:29.397,033] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x000446BD
    [00:01:29.405,761] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002C8F9
    [00:01:29.414,794] <inf> cloud: RRC mode: Idle
    [00:01:29.419,647] <dbg> lte_lc_helpers: event_handler_list_dispatch:  - handler=0x0002E709
    [00:01:29.428,375] <dbg> lte_lc_helpers: event_handler_list_dispatch: Done
    [00:01:29.814,788] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:29.822,875] <inf> gnss: Insufficient GNSS time windows
    [00:01:30.829,132] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:30.837,219] <inf> gnss: Insufficient GNSS time windows
    [00:01:30.843,414] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:01:31.852,386] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:31.860,473] <inf> gnss: Insufficient GNSS time windows
    [00:01:32.866,729] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:32.874,816] <inf> gnss: Insufficient GNSS time windows
    [00:01:33.881,072] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:33.889,160] <inf> gnss: Insufficient GNSS time windows
    [00:01:34.895,416] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:34.903,503] <inf> gnss: Insufficient GNSS time windows
    [00:01:35.909,759] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:35.917,846] <inf> gnss: Insufficient GNSS time windows
    [00:01:36.924,102] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:36.932,189] <inf> gnss: Insufficient GNSS time windows
    [00:01:37.938,446] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:38.946,655] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:39.954,864] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:40.963,073] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:42.971,374] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:42.979,461] <inf> gnss: Insufficient GNSS time windows
    [00:01:43.985,717] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:43.993,804] <inf> gnss: Insufficient GNSS time windows
    [00:01:45.000,061] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:45.008,148] <inf> gnss: Insufficient GNSS time windows
    [00:01:46.014,404] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:46.022,491] <inf> gnss: Insufficient GNSS time windows
    [00:01:47.028,778] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:47.036,865] <inf> gnss: Insufficient GNSS time windows
    [00:01:48.043,121] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:48.051,208] <inf> gnss: Insufficient GNSS time windows
    [00:01:49.057,495] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:49.065,582] <inf> gnss: Insufficient GNSS time windows
    [00:01:50.071,838] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:50.079,925] <inf> gnss: Insufficient GNSS time windows
    [00:01:51.086,181] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:51.094,268] <inf> gnss: Insufficient GNSS time windows
    [00:01:52.100,524] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:52.108,612] <inf> gnss: Insufficient GNSS time windows
    [00:01:53.114,898] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:53.122,985] <inf> gnss: Insufficient GNSS time windows
    [00:01:54.129,272] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:54.137,359] <inf> gnss: Insufficient GNSS time windows
    [00:01:55.143,646] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:55.151,733] <inf> gnss: Insufficient GNSS time windows
    [00:01:56.157,989] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:56.166,076] <inf> gnss: Insufficient GNSS time windows
    [00:01:57.172,332] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:57.180,419] <inf> gnss: Insufficient GNSS time windows
    [00:01:58.186,676] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:58.194,763] <inf> gnss: Insufficient GNSS time windows
    [00:01:59.201,019] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:01:59.209,106] <inf> gnss: Insufficient GNSS time windows
    [00:02:00.215,362] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:00.223,449] <inf> gnss: Insufficient GNSS time windows
    [00:02:00.577,270] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:02:00.586,486] <inf> main: Upload cycle START
    [00:02:00.591,583] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:02:00.600,402] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:02:00.609,283] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:02:00.618,408] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:02:00.627,288] <inf> main: Mission/Upload cycle STOP
    [00:02:01.229,705] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:01.237,792] <inf> gnss: Insufficient GNSS time windows
    [00:02:01.243,988] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:02:01.966,430] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_PERIODIC_TASKS
    [00:02:02.252,990] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:02.261,077] <inf> gnss: Insufficient GNSS time windows
    [00:02:03.267,364] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:03.275,451] <inf> gnss: Insufficient GNSS time windows
    [00:02:04.281,707] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:04.289,794] <inf> gnss: Insufficient GNSS time windows
    [00:02:05.296,081] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:05.304,168] <inf> gnss: Insufficient GNSS time windows
    [00:02:06.310,424] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:06.318,511] <inf> gnss: Insufficient GNSS time windows
    [00:02:07.324,768] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:07.332,855] <inf> gnss: Insufficient GNSS time windows
    [00:02:08.339,111] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:08.347,198] <inf> gnss: Insufficient GNSS time windows
    [00:02:09.353,454] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:09.361,541] <inf> gnss: Insufficient GNSS time windows
    [00:02:10.367,828] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:10.375,915] <inf> gnss: Insufficient GNSS time windows
    [00:02:10.389,434] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_PERIODIC_TASKS
    [00:02:11.382,171] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:11.390,258] <inf> gnss: Insufficient GNSS time windows
    [00:02:12.396,514] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:12.404,602] <inf> gnss: Insufficient GNSS time windows
    [00:02:13.410,888] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:13.418,975] <inf> gnss: Insufficient GNSS time windows
    [00:02:14.425,262] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:14.433,349] <inf> gnss: Insufficient GNSS time windows
    [00:02:15.439,605] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:15.447,692] <inf> gnss: Insufficient GNSS time windows
    [00:02:16.453,948] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:16.462,036] <inf> gnss: Insufficient GNSS time windows
    [00:02:17.468,292] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:17.476,379] <inf> gnss: Insufficient GNSS time windows
    [00:02:18.482,635] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:18.490,722] <inf> gnss: Insufficient GNSS time windows
    [00:02:19.497,009] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:19.505,096] <inf> gnss: Insufficient GNSS time windows
    [00:02:20.511,383] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:20.519,500] <inf> gnss: Insufficient GNSS time windows
    [00:02:21.525,756] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:21.533,843] <inf> gnss: Insufficient GNSS time windows
    [00:02:22.540,100] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:22.548,187] <inf> gnss: Insufficient GNSS time windows
    [00:02:23.554,443] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:23.562,530] <inf> gnss: Insufficient GNSS time windows
    [00:02:24.568,786] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:24.576,873] <inf> gnss: Insufficient GNSS time windows
    [00:02:25.583,160] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:25.591,247] <inf> gnss: Insufficient GNSS time windows
    [00:02:26.597,534] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:26.605,621] <inf> gnss: Insufficient GNSS time windows
    [00:02:27.611,877] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:27.619,964] <inf> gnss: Insufficient GNSS time windows
    [00:02:28.626,251] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:28.634,338] <inf> gnss: Insufficient GNSS time windows
    [00:02:29.640,625] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:29.648,712] <inf> gnss: Insufficient GNSS time windows
    [00:02:30.654,968] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:30.663,055] <inf> gnss: Insufficient GNSS time windows
    [00:02:30.669,250] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:02:31.678,253] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:31.686,340] <inf> gnss: Insufficient GNSS time windows
    [00:02:32.692,626] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:32.700,714] <inf> gnss: Insufficient GNSS time windows
    [00:02:33.707,000] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:33.715,087] <inf> gnss: Insufficient GNSS time windows
    [00:02:34.721,374] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:34.729,461] <inf> gnss: Insufficient GNSS time windows
    [00:02:35.735,748] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:35.743,835] <inf> gnss: Insufficient GNSS time windows
    [00:02:36.750,122] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:36.758,209] <inf> gnss: Insufficient GNSS time windows
    [00:02:37.764,495] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:37.772,613] <inf> gnss: Insufficient GNSS time windows
    [00:02:38.778,869] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:38.786,956] <inf> gnss: Insufficient GNSS time windows
    [00:02:39.793,243] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:39.801,330] <inf> gnss: Insufficient GNSS time windows
    [00:02:40.807,617] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:40.815,704] <inf> gnss: Insufficient GNSS time windows
    [00:02:41.821,990] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:41.830,078] <inf> gnss: Insufficient GNSS time windows
    [00:02:42.836,364] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:42.844,482] <inf> gnss: Insufficient GNSS time windows
    [00:02:43.850,738] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:43.858,825] <inf> gnss: Insufficient GNSS time windows
    [00:02:44.865,112] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:44.873,199] <inf> gnss: Insufficient GNSS time windows
    [00:02:45.879,455] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:45.887,573] <inf> gnss: Insufficient GNSS time windows
    [00:02:46.893,829] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:46.901,916] <inf> gnss: Insufficient GNSS time windows
    [00:02:47.908,203] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:47.916,290] <inf> gnss: Insufficient GNSS time windows
    [00:02:48.922,576] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:48.930,664] <inf> gnss: Insufficient GNSS time windows
    [00:02:49.936,950] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:49.945,068] <inf> gnss: Insufficient GNSS time windows
    [00:02:50.951,324] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:50.959,411] <inf> gnss: Insufficient GNSS time windows
    [00:02:51.965,698] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:51.973,785] <inf> gnss: Insufficient GNSS time windows
    [00:02:52.980,072] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:52.988,159] <inf> gnss: Insufficient GNSS time windows
    [00:02:53.994,445] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:54.002,532] <inf> gnss: Insufficient GNSS time windows
    [00:02:55.008,819] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:55.016,906] <inf> gnss: Insufficient GNSS time windows
    [00:02:56.023,193] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:56.031,280] <inf> gnss: Insufficient GNSS time windows
    [00:02:57.037,567] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:57.045,654] <inf> gnss: Insufficient GNSS time windows
    [00:02:58.051,940] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:58.060,028] <inf> gnss: Insufficient GNSS time windows
    [00:02:59.066,314] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:02:59.074,401] <inf> gnss: Insufficient GNSS time windows
    [00:03:00.080,688] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:00.088,775] <inf> gnss: Insufficient GNSS time windows
    [00:03:00.577,270] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:03:00.586,486] <inf> main: Upload cycle START
    [00:03:00.591,583] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:03:00.600,402] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:03:00.609,283] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:03:00.618,438] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:03:00.627,349] <inf> main: Mission/Upload cycle STOP
    [00:03:01.095,062] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:01.103,179] <inf> gnss: Insufficient GNSS time windows
    [00:03:01.109,344] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:03:01.966,430] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_PERIODIC_TASKS
    [00:03:02.118,377] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:02.126,464] <inf> gnss: Insufficient GNSS time windows
    [00:03:03.132,751] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:03.140,838] <inf> gnss: Insufficient GNSS time windows
    [00:03:04.147,125] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:04.155,212] <inf> gnss: Insufficient GNSS time windows
    [00:03:05.161,499] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:05.169,616] <inf> gnss: Insufficient GNSS time windows
    [00:03:06.175,872] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:06.183,959] <inf> gnss: Insufficient GNSS time windows
    [00:03:07.190,246] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:07.198,364] <inf> gnss: Insufficient GNSS time windows
    [00:03:08.204,620] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:08.212,738] <inf> gnss: Insufficient GNSS time windows
    [00:03:10.219,085] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:10.227,172] <inf> gnss: Insufficient GNSS time windows
    [00:03:10.389,404] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_PERIODIC_TASKS
    [00:03:11.233,459] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:11.241,577] <inf> gnss: Insufficient GNSS time windows
    [00:03:12.247,833] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:12.255,920] <inf> gnss: Insufficient GNSS time windows
    [00:03:13.262,603] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:13.270,721] <inf> gnss: Insufficient GNSS time windows
    [00:03:15.277,069] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:15.285,186] <inf> gnss: Insufficient GNSS time windows
    [00:03:16.291,442] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:16.299,560] <inf> gnss: Insufficient GNSS time windows
    [00:03:17.305,816] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:17.313,903] <inf> gnss: Insufficient GNSS time windows
    [00:03:18.320,190] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:18.328,277] <inf> gnss: Insufficient GNSS time windows
    [00:03:19.334,594] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:19.342,681] <inf> gnss: Insufficient GNSS time windows
    [00:03:20.348,937] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:20.357,055] <inf> gnss: Insufficient GNSS time windows
    [00:03:21.363,311] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:21.371,398] <inf> gnss: Insufficient GNSS time windows
    [00:03:22.377,685] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:22.385,772] <inf> gnss: Insufficient GNSS time windows
    [00:03:23.392,059] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:23.400,177] <inf> gnss: Insufficient GNSS time windows
    [00:03:24.406,433] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:24.414,520] <inf> gnss: Insufficient GNSS time windows
    [00:03:25.420,806] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:25.428,924] <inf> gnss: Insufficient GNSS time windows
    [00:03:26.435,180] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:26.443,267] <inf> gnss: Insufficient GNSS time windows
    [00:03:27.449,554] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:27.457,641] <inf> gnss: Insufficient GNSS time windows
    [00:03:28.463,928] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:28.472,015] <inf> gnss: Insufficient GNSS time windows
    [00:03:29.478,302] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:29.486,389] <inf> gnss: Insufficient GNSS time windows
    [00:03:30.492,675] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:30.500,762] <inf> gnss: Insufficient GNSS time windows
    [00:03:30.506,958] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:03:31.515,960] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:31.524,047] <inf> gnss: Insufficient GNSS time windows
    [00:03:32.530,303] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:32.538,391] <inf> gnss: Insufficient GNSS time windows
    [00:03:33.544,677] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:33.552,764] <inf> gnss: Insufficient GNSS time windows
    [00:03:34.559,051] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:34.567,138] <inf> gnss: Insufficient GNSS time windows
    [00:03:35.573,425] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:35.581,512] <inf> gnss: Insufficient GNSS time windows
    [00:03:36.587,799] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:36.595,886] <inf> gnss: Insufficient GNSS time windows
    [00:03:37.602,172] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:37.610,260] <inf> gnss: Insufficient GNSS time windows
    [00:03:38.616,546] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:38.624,633] <inf> gnss: Insufficient GNSS time windows
    [00:03:39.630,920] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:39.639,007] <inf> gnss: Insufficient GNSS time windows
    [00:03:40.645,294] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:40.653,381] <inf> gnss: Insufficient GNSS time windows
    [00:03:41.659,667] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:41.667,755] <inf> gnss: Insufficient GNSS time windows
    [00:03:42.674,041] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:42.682,128] <inf> gnss: Insufficient GNSS time windows
    [00:03:43.688,415] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:43.696,502] <inf> gnss: Insufficient GNSS time windows
    [00:03:44.702,972] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 31:25.3
    [00:03:44.711,395] <inf> gnss: Insufficient GNSS time windows
    [00:03:45.717,773] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 31:25.0
    [00:03:45.726,196] <inf> gnss: Insufficient GNSS time windows
    [00:03:46.732,635] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 31:24.4
    [00:03:46.741,058] <inf> gnss: Insufficient GNSS time windows
    [00:03:47.747,436] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 31:24.6
    [00:03:47.755,889] <inf> gnss: Insufficient GNSS time windows
    [00:03:48.762,298] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 31:24.3
    [00:03:48.770,721] <inf> gnss: Insufficient GNSS time windows
    [00:03:49.777,130] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 31:24.5
    [00:03:49.785,552] <inf> gnss: Insufficient GNSS time windows
    [00:03:50.791,961] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 31:24.9
    [00:03:50.800,384] <inf> gnss: Insufficient GNSS time windows
    [00:03:51.806,823] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 31:25.2
    [00:03:51.815,246] <inf> gnss: Insufficient GNSS time windows
    [00:03:52.821,502] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:52.829,589] <inf> gnss: Insufficient GNSS time windows
    [00:03:53.835,876] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:53.843,963] <inf> gnss: Insufficient GNSS time windows
    [00:03:54.850,250] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:03:54.858,337] <inf> gnss: Insufficient GNSS time windows
    [00:03:55.864,776] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 16:25.1
    [00:03:55.873,199] <inf> gnss: Insufficient GNSS time windows
    [00:03:56.879,638] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 16:24.2
    [00:03:56.888,061] <inf> gnss: Insufficient GNSS time windows
    [00:03:57.894,470] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 16:24.7
    [00:03:57.902,923] <inf> gnss: Insufficient GNSS time windows
    [00:03:58.909,332] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 16:24.5
    [00:03:58.917,755] <inf> gnss: Insufficient GNSS time windows
    [00:03:59.924,163] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 16:24.5
    [00:03:59.932,586] <inf> gnss: Insufficient GNSS time windows
    [00:04:00.577,270] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:04:00.586,486] <inf> main: Upload cycle START
    [00:04:00.591,583] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:04:00.600,402] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:04:00.609,283] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:04:00.618,438] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:04:00.627,319] <inf> main: Mission/Upload cycle STOP
    [00:04:00.939,025] <inf> gnss: Tracking  1; Using  0; Unhealthy  0; Power(dB/Hz) 16:24.4
    [00:04:00.947,418] <inf> gnss: Insufficient GNSS time windows
    [00:04:00.953,613] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:04:01.962,768] <inf> gnss: Trackin[00:04:01.966,400] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_PERIODIC_TASKS
    [00:04:01.980,377] <inf> gnss: Insufficient GNSS time windows
    [00:04:02.986,633] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:02.994,720] <inf> gnss: Insufficient GNSS time windows
    [00:04:04.001,007] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:04.009,094] <inf> gnss: Insufficient GNSS time windows
    [00:04:05.015,380] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:05.023,468] <inf> gnss: Insufficient GNSS time windows
    [00:04:06.029,754] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:06.037,841] <inf> gnss: Insufficient GNSS time windows
    [00:04:07.044,128] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:07.052,215] <inf> gnss: Insufficient GNSS time windows
    [00:04:08.058,502] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:08.066,589] <inf> gnss: Insufficient GNSS time windows
    [00:04:09.072,875] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:09.080,963] <inf> gnss: Insufficient GNSS time windows
    [00:04:10.087,249] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:10.095,336] <inf> gnss: Insufficient GNSS time windows
    [00:04:10.389,404] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_PERIODIC_TASKS
    [00:04:11.101,593] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:11.109,680] <inf> gnss: Insufficient GNSS time windows
    [00:04:12.115,966] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:12.124,053] <inf> gnss: Insufficient GNSS time windows
    [00:04:13.130,340] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:13.138,458] <inf> gnss: Insufficient GNSS time windows
    [00:04:14.144,714] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:14.152,801] <inf> gnss: Insufficient GNSS time windows
    [00:04:15.159,088] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:15.167,205] <inf> gnss: Insufficient GNSS time windows
    [00:04:16.173,461] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:16.181,549] <inf> gnss: Insufficient GNSS time windows
    [00:04:17.187,835] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:17.195,922] <inf> gnss: Insufficient GNSS time windows
    [00:04:18.202,239] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:18.210,327] <inf> gnss: Insufficient GNSS time windows
    [00:04:19.216,583] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:19.224,670] <inf> gnss: Insufficient GNSS time windows
    [00:04:20.230,957] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:20.239,044] <inf> gnss: Insufficient GNSS time windows
    [00:04:21.245,330] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:21.253,417] <inf> gnss: Insufficient GNSS time windows
    [00:04:22.259,704] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:22.267,791] <inf> gnss: Insufficient GNSS time windows
    [00:04:23.274,078] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:23.282,165] <inf> gnss: Insufficient GNSS time windows
    [00:04:24.288,452] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:24.296,539] <inf> gnss: Insufficient GNSS time windows
    [00:04:25.302,825] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:25.310,913] <inf> gnss: Insufficient GNSS time windows
    [00:04:26.317,199] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:26.325,317] <inf> gnss: Insufficient GNSS time windows
    [00:04:27.331,573] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:27.339,660] <inf> gnss: Insufficient GNSS time windows
    [00:04:28.345,947] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:28.354,034] <inf> gnss: Insufficient GNSS time windows
    [00:04:29.360,321] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:29.368,438] <inf> gnss: Insufficient GNSS time windows
    [00:04:30.374,694] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:30.382,781] <inf> gnss: Insufficient GNSS time windows
    [00:04:30.388,977] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:04:31.397,979] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:31.406,066] <inf> gnss: Insufficient GNSS time windows
    [00:04:32.412,353] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:32.420,471] <inf> gnss: Insufficient GNSS time windows
    [00:04:33.426,727] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:33.434,814] <inf> gnss: Insufficient GNSS time windows
    [00:04:34.441,101] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:34.449,218] <inf> gnss: Insufficient GNSS time windows
    [00:04:35.455,474] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:35.463,562] <inf> gnss: Insufficient GNSS time windows
    [00:04:36.469,848] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:36.477,966] <inf> gnss: Insufficient GNSS time windows
    [00:04:37.484,222] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:37.492,309] <inf> gnss: Insufficient GNSS time windows
    [00:04:38.498,596] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:38.506,683] <inf> gnss: Insufficient GNSS time windows
    [00:04:39.512,969] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:39.521,057] <inf> gnss: Insufficient GNSS time windows
    [00:04:40.527,343] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:40.535,430] <inf> gnss: Insufficient GNSS time windows
    [00:04:41.541,717] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:41.549,804] <inf> gnss: Insufficient GNSS time windows
    [00:04:42.556,091] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:42.564,178] <inf> gnss: Insufficient GNSS time windows
    [00:04:43.570,434] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:43.578,521] <inf> gnss: Insufficient GNSS time windows
    [00:04:44.584,808] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:44.592,895] <inf> gnss: Insufficient GNSS time windows
    [00:04:45.599,151] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:45.607,238] <inf> gnss: Insufficient GNSS time windows
    [00:04:46.613,525] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:46.621,612] <inf> gnss: Insufficient GNSS time windows
    [00:04:47.627,899] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:47.635,986] <inf> gnss: Insufficient GNSS time windows
    [00:04:48.642,272] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:48.650,390] <inf> gnss: Insufficient GNSS time windows
    [00:04:49.656,646] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:49.664,733] <inf> gnss: Insufficient GNSS time windows
    [00:04:50.671,020] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:50.679,138] <inf> gnss: Insufficient GNSS time windows
    [00:04:51.685,394] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:51.693,511] <inf> gnss: Insufficient GNSS time windows
    [00:04:52.699,768] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:52.707,885] <inf> gnss: Insufficient GNSS time windows
    [00:04:53.714,141] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:53.722,229] <inf> gnss: Insufficient GNSS time windows
    [00:04:54.728,515] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:54.736,602] <inf> gnss: Insufficient GNSS time windows
    [00:04:55.742,889] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:55.750,976] <inf> gnss: Insufficient GNSS time windows
    [00:04:56.757,263] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:56.765,350] <inf> gnss: Insufficient GNSS time windows
    [00:04:57.771,636] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:57.779,754] <inf> gnss: Insufficient GNSS time windows
    [00:04:58.786,010] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:58.794,128] <inf> gnss: Insufficient GNSS time windows
    [00:04:59.800,384] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:04:59.808,471] <inf> gnss: Insufficient GNSS time windows
    [00:05:00.577,270] <inf> app_event_manager: e:main_module_event MAIN_EVT_START_UPLOAD_CYCLE
    [00:05:00.586,486] <inf> main: Upload cycle START
    [00:05:00.591,583] <inf> app_event_manager: e:main_module_event MAIN_EVT_DATA_UPLOAD
    [00:05:00.600,402] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_UPLOAD_DONE
    [00:05:00.609,283] <inf> app_event_manager: e:main_module_event MAIN_EVT_LTE_DISCONNECT
    [00:05:00.618,438] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_DISCONNECTED
    [00:05:00.627,319] <inf> main: Mission/Upload cycle STOP
    [00:05:00.814,758] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:00.822,845] <inf> gnss: Insufficient GNSS time windows
    [00:05:00.829,040] <inf> app_event_manager: e:gnss_module_event GNSS_EVT_WORKER_HEARTBEAT
    [00:05:01.966,400] <inf> app_event_manager: e:logger_module_event LOGGER_EVT_PERIODIC_TASKS
    [00:05:02.838,134] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:02.846,252] <inf> gnss: Insufficient GNSS time windows
    [00:05:03.852,508] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:03.860,595] <inf> gnss: Insufficient GNSS time windows
    [00:05:04.866,882] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:04.875,000] <inf> gnss: Insufficient GNSS time windows
    [00:05:05.881,652] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:05.889,739] <inf> gnss: Insufficient GNSS time windows
    [00:05:07.896,118] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:07.904,235] <inf> gnss: Insufficient GNSS time windows
    [00:05:08.910,491] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:08.918,609] <inf> gnss: Insufficient GNSS time windows
    [00:05:09.924,865] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:09.932,983] <inf> gnss: Insufficient GNSS time windows
    [00:05:10.389,404] <inf> app_event_manager: e:cloud_module_event CLOUD_EVT_PERIODIC_TASKS
    [00:05:10.939,239] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:10.947,357] <inf> gnss: Insufficient GNSS time windows
    [00:05:11.953,704] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:11.961,791] <inf> gnss: Insufficient GNSS time windows
    [00:05:12.968,078] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:12.976,196] <inf> gnss: Insufficient GNSS time windows
    [00:05:13.982,452] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:13.990,539] <inf> gnss: Insufficient GNSS time windows
    [00:05:14.996,826] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:15.004,913] <inf> gnss: Insufficient GNSS time windows
    [00:05:16.011,199] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:16.019,317] <inf> gnss: Insufficient GNSS time windows
    [00:05:17.025,573] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:17.033,660] <inf> gnss: Insufficient GNSS time windows
    [00:05:18.039,947] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:18.048,034] <inf> gnss: Insufficient GNSS time windows
    [00:05:19.054,321] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:19.062,408] <inf> gnss: Insufficient GNSS time windows
    [00:05:20.068,695] <inf> gnss: Tracking  0; Using  0; Unhealthy  0; Power(dB/Hz) n/a
    [00:05:20.076,782] <inf> gnss: Insufficient GNSS time windows
    Stuart
  • Hi Stuart,
    LTE-M: [00:00:15.929,626] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 5,"2BE8","0346840C",7,,,"00100001","10111110"
    NB-IoT: [00:00:09.260,650] <dbg> lte_lc: at_handler_cereg: +CEREG notification: +CEREG: 5,"BDE5","0642B281",9,,,"11100000","11100000"
    https://infocenter.nordicsemi.com/topic/ref_at_commands/REF/at_commands/nw_service/cereg_read.html
    The log files shows your local NB-IoT may not support PSM, so your device do not have time to use GNSS revicer during PSM.
    You can refer to the following document for detials.
    Features of nRF91 Series — nRF Connect SDK 2.5.1 documentation (nordicsemi.com)
    The GNSS operation in an nRF9160-based device is time-multiplexed with the LTE modem. Therefore, the LTE modem must either be completely deactivated or in RRC idle mode or Power Saving Mode (PSM) when using the GNSS receiver. See the nRF9160 GPS receiver Specification for more information. Customers who are developing their own hardware with the nRF9160 are strongly recommended to use the nRF9160 Antenna and RF Interface Guidelines as a reference. See GPS interface and antenna for more details on GNSS interface and antenna.
    Charlie
