undefined SPIS macros...despite being defined?
Hello
I have recently downloaded SDK v10 for nRF51822 development using Keil uVision 5.14 IDE.
I am wishing to combine SPI slave function with custom BLE services/characteristics using S110 V8. As such, I’ve experimented with the SPI slave example and have a working version of button/led example from AN36.
I have attempted to combine them by moving the spi_slave_example.x files over to my an36 application. I’ve included relevant drivers from the “Manage Run-Time Environment” menu (nrf_drv_spis, specifically) and have my include path set to include local files.
On build I get the following errors (see attached build log.txt). Essentially it is complaining that some macros are undefined, but these are located in nrf_drv_spis.h which is included in the project. I can even link to these defines in uVision via right click > “Go To Definition Of..” so maybe something is partially working?
The only changes to main.c code was to include the spi slave example header, and initialize the example.
What could I be doing wrong?
build log.txt
  • Hello
    It seems taking a break and attacking this issue in the morning with a cup of coffee was a good idea.
    monpetit was almost correct except that the #define that needed enabling was SPISx_ENABLED (for slave mode), not SPIx_ENABLED. I somehow overlooked this several times yesterday as they looks so similar.
    Nordic SPI Slave example defines by default:
    #define SPIS1_ENABLED 1
    However Nordic template project does not, so must be set if porting..
    Thank you for your help :)
  • That's great! You solved the problem. And... God, It's slave mode! I missed it. ;)
