nRF5340 QSPI flash
Hi:
SW: NCS v2.5.0
HW: nRF5340 + flash gd25q256e
To reduce the power consumption of the QSPI flash, we have two approaches.
1. cut off the QSPI flash's power when the product is in sleep mode (the power can be turned on/off by an LDO)
2. always keep the power of the QSPI flash, and put the flash into deep power down mode when the product is in sleep mode.
unfortunately, both of these two approaches have problems.
for approach 1, when turning on the power again, and initiating the QSPI and XIP again, the XIP doesn't work.
e.g
 printk("#2Address of %x value %x\n", 0x10000008, *(uint32_t *)0x10000008);
 printk("#2Address of %x value %x\n", 0x10000040, *(uint32_t *)0x10000040);
 the values are wrong.
for approach 2,
put the QSPI flash into deep power down mode by calling pm_device_action_run(flash_dev, PM_DEVICE_ACTION_SUSPEND);
this works, we can see the power consumption is reduced.
wake up the flash from deep power down mode by calling pm_device_action_run(flash_dev, PM_DEVICE_ACTION_RESUME);
but this function return -EIO, and it is caused by the nrfx_qspi_init return NRFX_ERROR_TIMEOUT.
if we don't put the flash into deep power-down mode, every thing is OK.
below is the QSPI configuration
&qspi {
	status = "okay";
	pinctrl-0 = <&qspi_default>;
	pinctrl-1 = <&qspi_sleep>;
	gd25q256: gd25q256e@0 {
		compatible = "nordic,qspi-nor";
		reg = <0>;
		/* GD25Q256 supports only pp(cmd 02H) and pp4o(cmd 32H) */
		writeoc = "pp4o";
		/* GD25Q256 supports all readoc options */
		readoc = "read4io";
		sck-frequency = <8000000>;
		jedec-id = [c8 40 19];
		sfdp-bfp = [/*read the sfdp-bfp by jesd216 sample(zephyr\samples\drivers\jesd216)*/
			e5 20 f3 ff  ff ff ff 0f  44 eb 08 6b  08 3b 42 bb
			ee ff ff ff  ff ff 00 ff  ff ff 00 ff  0c 20 0f 52
			10 d8 00 ff  d6 39 a5 fe  83 1f 15 51  ec 62 16 33
			7a 75 7a 75  04 bd d5 5c  00 06 64 00  08 50 00 01
		size = <268435456>;
		has-dpd;
		t-enter-dpd = <40000>;
		t-exit-dpd = <45000>;
		enter-4byte-addr = <0x01>;
		address-size-32;
Do you have any ideas on this issue?
Thanks!
    I recommend you have a look at this modified version of the code relocation sample you're using. In this sample XiP is disabled after use and enabled before use. The same API is called to enable and disable XIP.
    The sample loops with a 10 sec sleep. The test write/read/erase code runs from XIP. A thread runs XIP code continuously.
    xip_write_run_disable_feat_xip_thread.zip
    Andreas
    Thanks for your sample code.
    I simplified this sample code as below
    #include <zephyr/kernel.h>
    #include <zephyr/pm/device.h>
    #include <stdint.h>
    #include <soc.h>
    #include <zephyr/device.h>
    #include <stdio.h>
    #include <string.h>
    #include <nrfx_qspi.h>
    #include <zephyr/drivers/flash/nrf_qspi_nor.h>
    #include <hal/nrf_gpio.h>
    #include <nrfx_gpiote.h>
    #define LDO_3V0_EN_PIN (32 + 12)
    #define TEST_DEEP_SLEEP_MODE 0
    	static const struct device *flash_dev;
    	printk("Hello World! %s\n", CONFIG_BOARD);
    	nrf_gpio_cfg_output(LDO_3V0_EN_PIN);
    	nrf_gpio_pin_set(LDO_3V0_EN_PIN); // turn on the flash's VDD
    	flash_dev = DEVICE_DT_GET(DT_ALIAS(spi_flash0));
    	nrf_qspi_nor_xip_enable(flash_dev, true);
    	/*read QSPI data by XIP, no problem, the value is correct*/
    	printk("#0Address of %x value %x\n", 0x10000008, *(uint32_t *)0x10000008);
    	printk("#1Address of %x value %x\n", 0x10000030, *(uint32_t *)0x10000030);
    	int cnt = 0;
    #if TEST_DEEP_SLEEP_MODE
    	while (1)
    		printk("cnt %d\n", cnt++);
    		nrf_qspi_nor_xip_enable(flash_dev, false);
    		/*put QSPI flash into deep-power-down mode, no problem*/
    		ret = pm_device_action_run(flash_dev, PM_DEVICE_ACTION_SUSPEND);
    		printf("PM_DEVICE_ACTION_SUSPEND ret = %d\n", ret);
    		k_msleep(2000);
    		/*wake up QSPI flash from deep-power-down mode, has problem,
    		pm_device_action_run return -EIO, and it is caused by the nrfx_qspi_init return NRFX_ERROR_TIMEOUT.*/
    		ret = pm_device_action_run(flash_dev, PM_DEVICE_ACTION_RESUME);
    		printf("PM_DEVICE_ACTION_RESUME ret = %d\n", ret);
    		k_msleep(2000);
    #else
    	while (1)
    		k_msleep(10);
    		nrf_gpio_pin_clear(LDO_3V0_EN_PIN); // turn off the flash's VDD
    		k_msleep(2000);
    		k_msleep(10);
    		/*read QSPI data by XIP, has problem, the value is wrong*/
    		k_msleep(2000);
    	return 0;
    this sample code works on the nrf5340-DK but still has the same problem on my custom board, please see the comments on the source code.
    the difference is that my custom board uses a different QSPI flash(gd25q256e).
    I have two questions.
    Why the XIP doesn't work correctly after turning on the flash's VDD again?
    Why the the nrfx_qspi_init return NRFX_ERROR_TIMEOUT after the flash in deep-power-down mode?
  • Why the the nrfx_qspi_init return NRFX_ERROR_TIMEOUT after the flash in deep-power-down mode?
    update a finding.
    Some PCBAs can wake up from deep-power-down mode, some can not, and some have a chance to wake up from deep-power-down mode.
    Do you think this is a HW issue or a SW issue?
    I've discussed this case with my colleagues and in general it is hard to pinpoint what could cause this
    It could be due to the flash device not properly setting itself up when you repower it. This is due to when you power of the external flash, it gets reset and you need to configure it once again to get it to the correct modus. To my understanding, through the driver at startup of the MCU
    AFAIK we don't have an LDO in our HW
    The best solution would be alternative 2. The challenge here might be that the procedure differs from flash device to flash device so the procedure might differ from how it is done in the sample I provided.
    update a finding.
    To be honest it could be either, but the best way to isolate it would be to reproduce it on other devices. Do you see the same thing if you port your sample to a 5340dk which uses the mx25 external flash?
    How long does the device sleep for when you get that error?
    Andreas
    I cut off the 'SB16' of 5340DK and connected/disconnected to the VDD manually to simulate the LDO of our customer board.
    we also prefer to approach 2 and make a decision to go for this. But we had to fix the deep-power-down mode issue.
    No, the sample code works on 5340dk with mx25, but I have only one 5240dk, I am not sure if it also works on other 5340dk, as I said, some of our customer board works and some do not work.
    Two seconds in the sample code, and made no difference if increased the sleep time.
    let's go through the details of the source code. (we focus on the approach 2).
    		k_msleep(2000);
    'pm_device_action_run(flash_dev, PM_DEVICE_ACTION_RESUME)' return -EIO, and it is caused by the nrfx_qspi_init return NRFX_ERROR_TIMEOUT.
    let's have a look at the nrfx_qspi_init function.
    nrfx_err_t nrfx_qspi_init(nrfx_qspi_config_t const * p_config,
                              nrfx_qspi_handler_t        handler,
                              void *                     p_context)
        NRFX_ASSERT(p_config);
        if (m_cb.state != NRFX_QSPI_STATE_UNINITIALIZED)
            return NRFX_ERROR_INVALID_STATE;
        m_cb.handler = handler;
        m_cb.p_context = p_context;
        /* QSPI interrupt is disabled because the device should be enabled in polling mode
          (wait for activate task event ready) */
        nrf_qspi_int_disable(NRF_QSPI, NRF_QSPI_INT_READY_MASK);
        if (p_config)
            nrfx_err_t result = qspi_configure(p_config);
            if (result != NRFX_SUCCESS)
                return result;
        m_cb.p_buffer_primary = NULL;
        m_cb.p_buffer_secondary = NULL;
        m_cb.state = NRFX_QSPI_STATE_IDLE;
        nrf_qspi_enable(NRF_QSPI);
        nrf_qspi_event_clear(NRF_QSPI, NRF_QSPI_EVENT_READY);
        nrf_qspi_task_trigger(NRF_QSPI, NRF_QSPI_TASK_ACTIVATE);
        // Waiting for the peripheral to activate
        return qspi_ready_wait();
    it is caused by the qspi_ready_wait() return NRFX_ERROR_TIMEOUT.
    the qspi_ready_wait function is waiting for the  EVENTS_READY.
    According to the datasheet, this EVENTS_READY can be generated by setting TASKS_ACTIVATE.
    In nrfx_qspi_init(), this is done by nrf_qspi_task_trigger(NRF_QSPI, NRF_QSPI_TASK_ACTIVATE);
    so the root cause is that the EVENTS_READY is not generated after  TASKS_ACTIVATE was activated.
    From what I understand, the peripheral initialization has nothing to do with an external device.
    e.g. I2C, or SPI, they can be initiated without an I2C or SPI device being connected.
    one more detail.
    Line 20 of nrfx_qspi_init :  result = qspi_configure(p_config);
    static nrfx_err_t qspi_configure(nrfx_qspi_config_t const * p_config)
        if (!qspi_pins_configure(p_config))
            return NRFX_ERROR_INVALID_PARAM;
        m_cb.skip_gpio_cfg = p_config->skip_gpio_cfg;
        /* The code below accesses the IFTIMING and IFCONFIG1 registers what
         * may trigger anomaly 215 on nRF52840 or anomaly 43 on nRF5340. Use
         * the proper workaround then.
        if (NRF52_ERRATA_215_ENABLE_WORKAROUND || NRF53_ERRATA_43_ENABLE_WORKAROUND)
            if (qspi_ready_wait() == NRFX_ERROR_TIMEOUT)
                return NRFX_ERROR_TIMEOUT;
        nrf_qspi_xip_offset_set(NRF_QSPI, p_config->xip_offset);
        nrf_qspi_ifconfig0_set(NRF_QSPI, &p_config->prot_if);
    #if NRFX_CHECK(USE_WORKAROUND_FOR_ANOMALY_121)
        uint32_t regval = nrf_qspi_ifconfig0_raw_get(NRF_QSPI);
        if (p_config->phy_if.sck_freq == NRF_QSPI_FREQ_DIV1)
            regval |= ((1 << 16) | (1 << 17));
            regval &= ~(1 << 17);
            regval |=  (1 << 16);
        nrf_qspi_ifconfig0_raw_set(NRF_QSPI, regval);
        nrf_qspi_iftiming_set(NRF_QSPI, 6);
        nrf_qspi_ifconfig1_set(NRF_QSPI, &p_config->phy_if);
        if (m_cb.handler)
            NRFX_IRQ_PRIORITY_SET(QSPI_IRQn, p_config->irq_priority);
            NRFX_IRQ_ENABLE(QSPI_IRQn);
        return NRFX_SUCCESS;
    there are similar codes below, but the EVENTS_READY has no problem.
    The difference in nrfx_qspi_init is that nrf_qspi_enable(NRF_QSPI) was called before
